[FW: [Aust-NZ] Time to move - Incorporation of OSGeo-AustNZ
[SEC=UNCLASSIFIED]]
Cameron Shorter
cameron.shorter at gmail.com
Thu Oct 16 15:50:47 EDT 2008
Bruce, thanks for pushing this forward, and Brent, thanks for suggesting
an alternative model.
I'm partial to a cheaper solution as it is much easier to sustain.
Bruce, would I be right in guessing that you would welcome someone (like
Brent) offering to take the banner getting Aust-NZ incorporated?
Bruce Bannerman wrote:
> We have had some legal advice on the structure for OSGeo-AustNZ [1]. This was along the lines of establishing
> a WA association and then registering with ASIC for an ARBN to allow trading across Australia. We didn't resolve
> trading in NZ under this model.
> Following this advice, we agreed to incorporate in WA.
> On the 27th July, I took the baton on this issue [2].
> As it did not appear that we had anyone in WA who could pursue our preferred model,
> I adopted the model of incorporating as a Pty Ltd company (as a not-for-profit). I
> have some experience with this model, having successfully run a small consultancy
> for five years and have a basic understanding of requirements. This model also appears
> to cater for cross registration in NZ (Brent, could you clarify please?).
> This is the basis of the quotes that I obtained from an accountant / auditor that I
> have used for several years.
> I am running out of time to look after this, as I'll be going on two months leave shortly.
> If we are going to debate structure again, someone else is going to have to take up the
> baton on this, as I will not have the time to follow through, given past experience on how long
> this is likely to take.
> Bruce
> [1] http://lists.osgeo.org/pipermail/aust-nz/2008-January/000285.html
> [2] http://lists.osgeo.org/pipermail/aust-nz/2008-July/000612.html
> -------- Forwarded Message --------
> From: Bruce Bannerman <B.Bannerman at bom.gov.au>
> Subject: FW: [Aust-NZ] Time to move - Incorporation of OSGeo-AustNZ [SEC=UNCLASSIFIED]
> Date: Thu, 16 Oct 2008 16:10:02 +1100
>> Subject: RE: [Aust-NZ] Time to move - Incorporation of
>> OSGeo-AustNZ[SEC=UNCLASSIFIED]
>> Brent
>> I am no legal eagle but I do (and have) belonged to a number
>> of associations.
>> One which definitely has o/s members is actually a registered company.
>> Another is registered in WA but has members from all Aust
>> states/territories, whilst another is registered in the ACT
>> but has NSW members. Yet another is registered in NSW but has
>> ACT members. These last three are associations and not companies.
>> I think it largely comes down to what is written in the
>> constitution. Eg membership, membership classes or grades,
>> board and executive make-up, powers, etc.
>> BTW, none of the groups mentioned above have gone down the
>> Registrable Australian Bodies path, so I suspect that we
>> would not need too.
>> Unfortunately, I think we might have to get accountant or
>> legal advice to work out the 'proper' way forward. Does
>> anyone have a legal acquaintance or relative?
>> But I must ask. Do we need to go down this path at all?
>> I suspect that if we want to be a legal entity and have bank
>> accounts, etc.
>> then we will need to. Otherwise, I would say that we should
>> just be a part of the greater OSGeo community.
>> Ian
>> Ian Batley
>> ian.batley at ga.gov.au
>> 02 6249 5825
>> -----Original Message-----
>> From: Brent Wood [mailto:pcreso at yahoo.com]
>> Sent: Thursday, 16 October 2008 1:58 PM
>> To: Batley Ian
>> As described below, I can see a few possible problems that we
>> really need tidied up before progressing this. I thought
>> getting this sorted out was what Tim originally had problems
>> with which made the whole process more complicated than otherwise.
>> We need a body corporate which can accept at least members,
>> and ideally committee members, from countries and states
>> other than the one of registration.
>> I'm not sure about NZ, nor about Bruce's proposal or Ian's
>> ACT suggestions.
>> I'll follow this up for NZ, but would like some clarification
>> on this aspect for the others if possible...
>> Cheers,
>> Brent
>> --- On Thu, 10/16/08, Ian.Batley at ga.gov.au
>> <Ian.Batley at ga.gov.au> wrote:
>>> From: Ian.Batley at ga.gov.au <Ian.Batley at ga.gov.au>
>>> Subject: RE: [Aust-NZ] Time to move - Incorporation of OSGeo-AustNZ
>> [SEC=UNCLASSIFIED]
>>> To: Aust-NZ at lists.osgeo.org
>>> Date: Thursday, October 16, 2008, 11:54 AM If registered in
>> the ACT it
>>> is done under the Associations Incorporations Act and all
>> the details
>>> can be found at
>> http://www.ors.act.gov.au/licensing/Assocns/assn1.html
>>> Cost is $138 for the application. It is not an onerous task and it
>>> does not require a physical address, just postal. However, it does
>>> require yearly lodgement of some things (cost $32), a
>> membership of at
>>> least 5 people, and a constitution.
>> A physical address of the first public officer is required
>> (not a big deal)
>> Is an NZ address considered "deliverable by Australian Post?"
>> My impression is probably not, in which case no-one in NZ can
>> be on the inaugural committee of such an organisation, I'm
>> not sure about after the inaugural one, but again, my guess is not.
>> This issue is likely whichever country we register in. I'm
>> guessing again, but I figure the only persons able to be in a
>> recognised position of authority (committee/director) in such
>> an incorporated body will be persons who can be held
>> accountable under the registering authority.
>> I'm intrigued that the ACT form requires an Australian postal
>> address for all inaugural committee members, but does not
>> specify this for future committee members (in the
>> notification of change of committee form).
>>> Once incorporated we may need to investigate Aust wide
>> registration,
>>> but I am not sure on this, see
>> http://www.asic.gov.au/asic/asic.nsf/byheadline/Registrable+Au
>> stralian+Bodies
>> I don't fully understand this, but it seems up front that
>> while this allows the body corporate to operate throughout
>> Australia, I can't tell if it allows the governing committee
>> to have members outside of the home state?
>>> ?opendocument
>>> Cost for this registration is $330 if we have to do it.
>>> Ian Batley
>>> 02 6249 5825
>>> From: aust-nz-bounces at lists.osgeo.org
>>> [mailto:aust-nz-bounces at lists.osgeo.org] On Behalf Of Brent Wood
>>> Sent: Thursday, 16 October 2008 6:46 AM
>>> Subject: Re: [Aust-NZ] Time to move - Incorporation of OSGeo-AustNZ
>>> Eek...
>>> That seems expensive, unless I'm missing something (which given my
>>> expertise in this area, is quite possible :-)
>>> Does it matter whether the chapter is registered in
>> Australia or NZ?
>>> If is is in Australia then it problably means less work for
>> me :-) but
>>> I'm not really concerned either way.
>>> To register as a not-for-profit incorporated society in NZ
>> is NZ$100
>>> which I'm happy to fork out for, or could come out od initial
>>> membership fees?
>>> If we can find a friendly accountant, annual auditing is free or
>>> pretty cheap. The running costs will be postage (mostly
>> email anyway
>>> I'd hope) & a bank account, which I guess could well be
>> Australian if
>>> required, like if we had an Australian treasurer.
>>> & I figure accounts in both NZ & Australia might be cheaper than
>>> regularly transferring $$ internationally anyway...
>>> Is it worth following up a NZ based registration if is cheaper &
>>> simpler?
>>> As far as I can tell, NZ residency is not required, unless
>> we require
>>> it under our own rules/charter, and normally the only officers
>>> required are Chair/President, secretary & treasurer, but it does
>>> require 15 members.
>>> There are plenty of examples of charters available to model
>> ours on if
>>> required.
>>> These links give a useful how-to, one from an NZ LUG...
>> http://www.community.net.nz/How-ToGuides/LegalStructures/Publi
> cationsResource
>>> s/incorpsoc.htm
>>> http://www.wlug.org.nz/NewZealandIncorporatedSocietyHowto
>>> The official site, is at:
>> http://www.societies.govt.nz/cms/incorporated-societies/incorp
> orated-societie
>>> s-landing-page
>>> The application form is at:
>> http://www.societies.govt.nz/cms/pdf-library/incorporated-soci
> eties-forms/for
>>> m-is1-application-to-incorporate-a-society-pdf
>>> The registered address may not even have to be in NZ, nor
>> the postal
>>> address, but I (or someone else here from NZ I'm sure) can
>> provide NZ
>>> ones if required. We may need to post an application form around 15
>>> people for signing, but given signatures are on three pages, that
>>> isn't too onerous.
>>> We can state that IRC meetings, given a quorum, are acceptable for
>>> society meetings, in our rules.
>>> If people are interested in this option, I guess we could start by
>>> drafting the charter/rules on the OSGEO wiki? Once that is
>> done & we
>>> have the 15 signatures, we can apply, with a result in a few days.
>>> Cheers,
>>> Brent
>>> --- On Wed, 10/15/08, Bruce Bannerman
>>> <bruce at bannerman.id.au> wrote:
>>>> From: Bruce Bannerman <bruce at bannerman.id.au>
>>>> Subject: [Aust-NZ] Time to move - Incorporation of
>>> OSGeo-AustNZ
>>>> To: "Aust-NZ OSGeo"
>>> <Aust-NZ at lists.osgeo.org>
>>>> Date: Wednesday, October 15, 2008, 11:40 PM Getting
>> insurance quotes
>>>> is proving to be a very
>>> difficult
>>>> process in
>>>> these troubled times.
>>>> I propose that we proceed with the incorporation of
>> OSGeo-AustNZ as
>>>> a not for profit organisation and revisit the costs for insurance
>>>> when these become available.
>>>> Costs will be:
>>>> Incorporation as a Not-for-profit $1300
>>>> Annual audit fee approx $200
>>>> It will take two to four weeks to incorporate.
>>>> Now, where do we find the funds?
>>>> Bruce Bannerman
>>>> _______________________________________________
>>>> Aust-NZ mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/aust-nz
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Aust-NZ
