[Aust-NZ] Geoscience Australia WMS
Duncan Jackson duncangjacks at yahoo.com
Sat Feb 26 05:18:07 EST 2011
Hi
I've been trying to add the Geoscience Australia
GDA94_MapConnect_SDE_250kmap_WMS service to a MAP file with no luck. This is
my LAYER text:
LAYER
                NAME "GDA94_MapConnect_SDE_250kmap_WMS"
                TYPE RASTER
                STATUS ON
                CONNECTION
"http://mapconnect.ga.gov.au/wmsconnector/com.esri.wms.Esrimap?"
                CONNECTIONTYPE WMS
                METADATA
                                "wms_srs" "EPSG:4326"
                                "wms_name" "LandsatMosaic"
                                "wms_server_version" "1.1.1"
                                "wms_format" "image/png"
                END
END
This request works:
http://mapconnect.ga.gov.au/wmsconnector/com.esri.wms.Esrimap?ServiceName=GD
<http://mapconnect.ga.gov.au/wmsconnector/com.esri.wms.Esrimap?ServiceName=G
DA94_MapConnect_SDE_250kmap_WMS&BBOX=115.716011,-32.206971,116.073987,-31.71
2102&WIDTH=450&HEIGHT=750&SRS=EPSG:4326&Layers=LandsatMosaic,CartographicLin
es,FrameworkBoundaries,Cities&version=1.1.1&service=WMS&FORMAT=JPEG&TRANSPAR
ENT=TRUE&request=getmap>
&BBOX=115.716011,-32.206971,116.073987,-31.712102&WIDTH=450&HEIGHT=750&SRS=E
PSG:4326&Layers=LandsatMosaic,CartographicLines,FrameworkBoundaries,Cities&v
ersion=1.1.1&service=WMS&FORMAT=JPEG&TRANSPARENT=TRUE&request=getmap
But I haven't been able to translate it to a working MAP file. Using
'shp2img -m example.map -o test.png -map_debug 3' I get the service
exception 'Access to the specified service 8080 is not available'
TIA, Duncan
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20110226/5f9f48e7/attachment.html
More information about the Aust-NZ mailing list
