[Aust-NZ] Geoscience Australia WMS - Fix
Duncan Jackson duncangjacks at yahoo.com
Sat Feb 26 06:11:37 EST 2011
Hi
I've been able to make it work - I added it as a WMS layer in MapInfo and
copied the CONNECTION. I also had to change the STATUS to DEFAULT (neither
ON or OFF worked). This is the revised LAYER:
LAYER
                NAME "GDA94_MapConnect_SDE_250kmap_WMS"
                TYPE RASTER
                STATUS DEFAULT
#             CONNECTION
"http://mapconnect.ga.gov.au/wmsconnector/com.esri.wms.Esrimap?"
                CONNECTION
"http://mapconnect.ga.gov.au:80/wmsconnector/com.esri.wms.Esrimap/GDA94_MapC
onnect_SDE_250kmap_WMS?"
                CONNECTIONTYPE WMS
                METADATA
                                "wms_srs" "EPSG:4283"
                                "wms_name" "LandsatMosaic"
                                "wms_server_version" "1.1.1"
                                "wms_format" "image/png"
                END
END #End Layer
One day I'll find the time to work out why, especially the difference
between this CONNECTION and the string pasted into browser.
Cheers, Duncan
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20110226/c39a0ee0/attachment.html
More information about the Aust-NZ mailing list
