[Conference-resources] Request to create CfP of academic track and workshop for FOSS4G 2026 Hiroshima
Luca Delucchi lucadeluge at gmail.com
Tue Sep 16 14:00:15 PDT 2025
On Tue, 16 Sept 2025 at 19:10, Vicky Vergara <vicky at erosion.dev> wrote:
> Hello Igarashi San
Hi Vicky, Igarashi San
> I added you as a team member of FOSS4G Japan admin.
> I think something is wrong.
> Luca: please correct me if I am wrong:
> The FOSS4G international organizer is supposed to be FOSS4G not OSGeo.JP
> I created the workshop and academic trac instinctively using the FOSS4G
> organizer.
> So right now there are:
> The general trac with  OSGeo.JP as organizer   <- I think this should be
> FOSS4G as organizer
> The academic trac with  FOSS4G as organizer
> The workshop trac with  FOSS4G as organizer
> The registered reviewers for the international event are registered under
> FOSS4G organizer
> That is the main reason I think it is not OSGEO.JP the organizer.
Yeah, we created different teams under the FOSS4G organizer, probably we
should continue like that but for me it could be also good to use the
OSGeo.JP organizer, I don't see big differences. I probably made a mistake
when I created the general track but I'm not able to change the organizer.
> This is the history of the event of the general trac:
> [image: image.png]
> I can see that it has not been worked out yet.
> And of course the recently created ones have not been modified yet either.
> It's a good time to fix whatever needs to be fixed.
> I Just need Luca's confirmation about which to fix.
> About the fix:
> I could not find that pretalx can change organizer, so I think the way to
> standardize the organizer is:
> Create the event(s) with the correct organizer  and remove the one(s)
> with the wrong organizer
> If the organizer is FOSS4G then create a new team under that organizer
> that has all the OSGEO.JP team members
> I need Luca to confirm.
> Yeah in the previous years were like that.
> Regards
> Vicky
ciao
Luca
www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/conference-resources/attachments/20250916/68d76d48/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/conference-resources/attachments/20250916/68d76d48/attachment-0001.png>
More information about the Conference-resources mailing list
