[Workshops] Setting up an Apache proxy to GeoServer
    Justin Deoliveira
    jdeolive at opengeo.org
    Fri Sep 12 11:25:39 EDT 2008
Hi all,
The OpenLayers workshop will require a proxy to be setup through Apache
port 80 (under the "/geoserver" path) to GeoServer port 8910. Apologies
if this is better left for the setup instructions, I just wanted to make
sure ahead of time if this will not be a problem. Thanks.
-Justin
Justin Deoliveira
Software Engineer, OpenGeo
http://opengeo.org
More information about the Conference-workshops
