[Workshops] Setting up an Apache proxy to GeoServer
    Jeff McKenna
    jmckenna at gatewaygeomatics.com
    Fri Sep 12 11:50:59 EDT 2008
Please put all instructions like that in a README file in your
"/software" folder in the FTP site, as we won't be following these email
threads for the install.  The README should also include steps to test
the installation (such as goto this URL and if you get a map, success)
thank you.
-jeff
Justin Deoliveira wrote:
> Hi all,
> The OpenLayers workshop will require a proxy to be setup through Apache
> port 80 (under the "/geoserver" path) to GeoServer port 8910. Apologies
> if this is better left for the setup instructions, I just wanted to make
> sure ahead of time if this will not be a problem. Thanks.
> -Justin
More information about the Conference-workshops
