[Workshops] Testing workshop material
    Matt Walker
    walkermatt at longwayaround.org.uk
    Thu Sep  5 14:04:08 PDT 2013
Two of the computer labs will be available on Monday 16th to allow workshop
organisers to test their workshop material. Hallward Library: LG101 will be
available at 11:00 while Sir Clive Granger Building: B26e will be available
at 14:00.
Hallward Library: LG101 has an equivalent software set up to Sir Clive
Granger Building: B29 A & B and Trent B16.
B26e has a different set up, so if your workshop is in that room you should
try your workshop material in that room - otherwise please test in Hallward
LG101.
I'd strongly encourage all workshop organisers to take advantage of this
opportunity particularly if you are looking to connect to the internet
(which will require configuring the university proxy settings), to use a
local login, or to use your own Live DVD or USB package.
If you are unable to attend on the Monday then please let me know as we may
be able to arrange an alternative time.
Regards,
Matt.
Matt Walker
@_walkermatt
URL: <http://lists.osgeo.org/pipermail/conference-workshops/attachments/20130905/b7355365/attachment.html>
More information about the Conference-workshops
