[Workshops] Testing workshop material
Ian Turton ijturton at gmail.com
Fri Sep 6 03:41:01 PDT 2013
On 5 September 2013 22:04, Matt Walker <walkermatt at longwayaround.org.uk>wrote:
> Two of the computer labs will be available on Monday 16th to allow
> workshop organisers to test their workshop material. Hallward Library:
> LG101 will be available at 11:00 while Sir Clive Granger Building: B26e
> will be available at 14:00.
> Hallward Library: LG101 has an equivalent software set up to Sir Clive
> Granger Building: B29 A & B and Trent B16.
> B26e has a different set up, so if your workshop is in that room you
> should try your workshop material in that room - otherwise please test in
> Hallward LG101.
Is that available from 11am or at 11am? We'll need to set off earlier than
planned if it's only at 11?
Cheers
Ian
Ian Turton
URL: <http://lists.osgeo.org/pipermail/conference-workshops/attachments/20130906/bc6373f1/attachment.html>
More information about the Conference-workshops mailing list
