[OSGeo-Conf] FOSS4G Cookbook
Rappo Daniel Daniel.Rappo at heig-vd.ch
Fri Oct 14 18:26:55 EDT 2011
Guys,
My concerns are a bit far from yours right now and I don't intend to modify your plans, but I can't forget this impressive 2006 experience through a conference mgmt software developed & hosted at the "Sir Tim" proposal birthplace ;-). Today Indico stays a really great piece of open source code!
Maybe you can check this :
http://www.ohloh.net/p/compare?project_0=Indico&project_1=Open+Conference+Systems
And maybe this one: http://indico.cern.ch/ considering a future where people will organize many FOSS4G corporate events...
Regards, D.
De : conference_dev-bounces at lists.osgeo.org [mailto:conference_dev-bounces at lists.osgeo.org] De la part de Cameron Shorter
Envoyé : vendredi 14 octobre 2011 21:33
À : gavinjfleming at gmail.com
Cc : conference_dev at lists.osgeo.org
Objet : Re: [OSGeo-Conf] FOSS4G Cookbook
Gavin, Peter,
Yes, I agree that providing and standardising of tools for abstract management would be a huge value add for future foss4g conferences, and something that I wish we had available to us at foss4g 2009.
I have similar war stories to Peter about managing papers, and integrating with the proprietary PCO systems. I also think that it will take a number of conferences for us to fully streamline our process into a simple Open Source solution.
On 15/10/2011 5:07 AM, Gavin wrote:
The system we used for 2008 (http://pkp.sfu.ca/ocs/)<http://pkp.sfu.ca/ocs/%29> was suggested by Tyler on this same basis - that it would be something to use and build on in future years. It is more geared towards academic conferences but has all the machinery for abstract submission, review, publishing etc.
Whatever is chosen it then needs to be a requirement in RFPs that LOCs commit to using it and not doing their own thing.
Gavin
One other semi-related item that has been on my mind is extending the web site we put together this year, based on Drupal, for use in future years. It uses an open source conference management module but we only enabled some parts of that. It wouldn't be too much work to get Jonathan, who did the site for us, to extend the functionality so it could handle the whole abstract submission and selection process (but enough work that we would have to pay him something, as we did for his initial work).
Managing abstracts was a real pain for us this year with a lot of manual work to move them around through the process. They came in through one system, we did initial sorting in one spreadsheet, they went to Paul Ramsey's voting system then back into another spreadsheet which we couldn't easily cross-reference to the previous one, we did some duplicate checking in a separate database system, and ended up with two spreadsheets for the academic and main tracks, then at the end it was a lot of work to schedule the selected papers, notify people, and put the info on the web site. And then you have to manage the process of people dropping out and filling those slots. Having all these manual steps is very error prone too. Finally we now have the question of getting slides online, which would be much easier if people could upload their own, which they could if we were using this module fully.
This whole process would be massively streamlined if we used the conference management module the whole way through.
So anyway, I'm inclined to take a little money from the FOSS4G proceeds and get this done for the benefit of future FOSS4Gs. I think this would also be a tangible benefit that OSGeo could provide for people doing FOSS4G events (global or local) that would help justify the event contributing something back to OSGeo from the event proceeds (though that's a separate topic).
I'm not quite sure who (if anyone) I need to get permission from to do this. I would certainly welcome thoughts from this group. I can check with the board if the thought is that I need to do that. Or can just go ahead - the amount of money involved is small compared to other budget items I've been dealing with on FOSS4G. But obviously I only want to do it if others think it's a good idea.
Cheers,
    Peter.
On Fri, Oct 14, 2011 at 4:52 AM, Cameron Shorter <cameron.shorter at gmail.com<mailto:cameron.shorter at gmail.com>> wrote:
I suggest that we, the conference committee and interested people, should organically start building a FOSS4G Cookbook.
The Cookbook should cover all the aspects of putting on a FOSS4G conference, including such things as:
* Schedule coming up to the conference
* Budget
* Program
* Web Site
* Catering
* Venue selection
Initially much of the content for this cookbook can be drawn directly from Lessons Learned from previous years. As more events are run, I'd expect ideas to evolve and the Cookbook to grow with it.
I see two key advantages of such a Cookbook:
1. Access to such information will make it much easier for someone to put on a FOSS4G conference
2. The Cookbook can be used as a baseline to guide deciding whether a conference may make use of the FOSS4G brand. This will help maintain the quality associated with the FOSS4G brand.
Do others see value in building such a document?
I'm assuming we should build the Cookbook as a wiki, but am happy to hear suggestions for other collaborative tools.
If there is sufficient interest, I'll build a skeleton of the Cookbook, and invite others to contribute content.
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050<tel:%2B61%20%280%292%208570%205050>
Mob: +61 (0)419 142 254<tel:%2B61%20%280%29419%20142%20254>
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
Conference_dev mailing list
Conference_dev at lists.osgeo.org<mailto:Conference_dev at lists.osgeo.org>
http://lists.osgeo.org/<http://lists.osgeo.org/mailman/listinfo/conference_dev>mailman/listinfo/conference_<http://lists.osgeo.org/mailman/listinfo/conference_dev>dev<http://lists.osgeo.org/mailman/listinfo/conference_dev>
Gavin Fleming
t: 0218620670
c: 0845965680
f: 0866164820
Paarl
South Africa
18°59'18.8"E 33°44'40.2"S
Cameron Shorter
URL: http://lists.osgeo.org/pipermail/conference_dev/attachments/20111014/8aa61127/attachment-0001.html
More information about the Conference_dev mailing list
