[OSGeo-Conf] Searching for Chair
Andrew Ross
andrew.ross at eclipse.org
Fri Sep 27 06:44:37 PDT 2013
Thanks for the clarification Frank, much appreciated.
Thanks again to Paul for his work chairing.
On 26/09/13 17:18, Frank Warmerdam wrote:
> Andrew,
> I believe Paul meant an ongoing chair, as opposed to the temporary
> role he has been dragged in to serve issuing RFPs and so forth. Not
> full time as in a full time job. I'd imagine the chair's job to be
> relatively light but it would include ensuring that RFPs get issued,
> that the decision process proceeds in an orderly way, that the long
> terms documents on how to run the conference are updated, and that the
> committee is renewed.
> The matter came up when I wanted someone to formally invite Stephen
> Feldman to join the committee (as we should be doing with past FOSS4G
> chairs).
> I prodded Paul to ask since I'm no longer formally on this committee.
> Best regards,
> Frank
> On Thu, Sep 26, 2013 at 1:32 PM, Andrew Ross <andrew.ross at eclipse.org
> <mailto:andrew.ross at eclipse.org>> wrote:
> Hey Paul,
> This sounds sufficiently vague that I wanted to ask if you could
> elaborate on what you mean by full-time chair?
> Andrew
> On 26/09/13 14:04, Paul Ramsey wrote:
> Hi Conference Committee,
> It would make things run smoother if we had a full-time chair,
> and I'm wondering if any of you would be so kind as to step-up
> and take on the role? Feel free to respond privately if you
> want to discuss / caveat, etc.
> P.
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20130927/d5dce5de/attachment.html>
More information about the Conference_dev
