[OSGeo-Conf] Proposed text for an OSGeo Code of Conduct
    Eli Adam
    eadam at co.lincoln.or.us
    Sun Jan 25 10:53:04 PST 2015
Code of Conduct specific wording is less important than these characteristics:
* Being present (i.e. not implied but clearly stated)
* Appearing sincere
* Being sincere
* Having reasonable people implementing it
In that regard, the similar texts you listed were all fine.
Generally, I think that we are spending too much time and emphasis on
sexualized images.  We are in the open source geospatial software,
geospatial standards, open data, education, and related fields; 95%+
of all presentations and other content can be done entirely
successfully without images of people at all.  For the 5% of cases
that images of people substantively contribute to the presentation,
err on the side of caution, "If in doubt, leave it out".
I like the idea of the conference committee starting with a CoC for
conferences and the Board possibly modifying and expanding it to other
areas of OSGeo or projects establishing their own (see QGIS,
http://qgis.org/en/site/getinvolved/governance/codeofconduct/codeofconduct.html)
I don't think that 2015 FOSS4G needs any input, they already seem to
have it under control, http://2015.foss4g.org/about/codeofconduct/,
and there was nothing about a CoC in the bid.  We should be focusing
2016 and beyond.
Thanks for working on guiding this process Cameron.
Best regards, Eli
On Sat, Jan 24, 2015 at 3:12 AM, Cameron Shorter
<cameron.shorter at gmail.com> wrote:
> Hi David,
> Thanks for starting this discussion. When you opened the discussion, you
> very kindly offered to help set a Code of Conduct in place. How do you
> suggest we move toward concluding the discussion and getting a Code of
> Conduct in place?
> Do you have a timeframe in mind for this? I assume we should try to make a
> CoC available for FOSS4G 2015 if they wish to make use of one?
> Peter, thanks for you comments on proposed text.
> Is there anyone else with an interest in influencing the final text? If so,
> please speak up.
> Which is the better version of a CoC?
> 1. Prior foss4g: https://2015.foss4g-na.org/code-conduct
> 2. OReilly: http://www.oreilly.com/conferences/code-of-conduct.html (copied
> below)
> 3. My revised version (copied below)
> 4. Something else
> On 19/01/2015 9:16 am, Cameron Shorter wrote:
> Hi David,
> I'm happy to move proposed CoC text across to a wiki. If requested, I'll
> copy across now (within 48 hours), or can wait till there has been further
> discussion.
> Also happy to expand the discussion to other lists, although I expect the
> conference committee is probably the logical primary point for discussion,
> as a CoC is most applicable to conferences. The board would need to sign off
> on a CoC and should be invited to comment.
> Re identifying what should be in a code of conduct. I've attempted to start
> on that in the list of items I've attempted to address, listed below.
> I have presented the draft CoC (below), as I find it is often easier to
> start with a "straw man" which can be picked apart, rather than talking
> vaguely in conceptual levels. However, I'm not wedded to the text, and hope
> to see constructive criticism of the ideas, text and structure.
> On 19/01/2015 3:46 am, David William Bitner wrote:
> I really want to thank everyone here for engaging in this issue. I do
> appreciate all the different voices that have contributed to this
> conversation -- they all certainly speak to the diversity of thoughts and
> experiences that we already have in this community.
> Cameron -- thank you very much for putting forward a first draft of a
> potential CoC for us to use. Before drafting and wordsmithing a CoC I want
> to step back and make sure we answer a few questions that would certainly
> impact how a CoC gets written. When we get to the point of drafting, we
> should certainly do so on the wiki (or other trackable collaborative medium)
> rather than in an email thread.
> With some of the wording in this draft as well as seeing the discussion from
> the last Board Meeting, is the conference committee the correct venue for
> this discussion or should this be at the Board level so that this applies to
> all OSGeo activities (mailing lists, events, etc)? I am certain that many of
> the same people would remain engaged in helping draft a Code of Conduct
> either for the foundation as a whole or just for our events, but this
> certainly impacts the scope and wording required in a draft.
> Many of the comments that I read as against having a CoC seem to stem from
> people wondering what does a CoC solve. Sadly, having a CoC does not "solve"
> anything. There will still be issues. A CoC simply provides one tool for us
> to help resolve those issues when they come up as well as providing a
> proactive statement that we aim to be a welcoming and diverse community to
> hopefully prevent some of those issues in the first place. A CoC is not the
> end point of diversity initiatives, but it is a very low hanging fruit to
> start with. Other initiatives that I know have been tried that we should
> continue to look at their effectiveness include author blind public program
> review, scholarship initiatives, proactively seeking out diversity in key
> notes, and many more things that we haven't tried.
> On 18/01/2015 2:33 pm, Cameron Shorter wrote:
> Following on from this email thread, I've drafted a proposed Code of
> Conduct, where I've aimed to address:
> * Be concise (concise words get read more)
> * Cover key messages
> * Include an escalation process for dealing with both minor and major issues
> * Ensure key terms are understood (in particular reference to definition of
> sexualised images)
> * Couch in positive language
>  Tickbox version:
> * I agree to act respectfully toward others in line with the OSGeo Code of
> Conduct.
> OSGeo Code of Conduct:
> This Code of Conduct collates the collective values adopted by our OSGeo
> community which baselines the behaviour we do and don’t support to ensure
> OSGeo is a safe and productive environment for all.
> We invite everyone to be respectful to all, regardless of race, gender, age,
> sexual orientation, disability, physical appearance, national origin,
> ethnicity, religion, or ideas. We do not tolerate harassment of others in
> any form. Examples of harassment include offensive comments, verbal threats
> or demands, sexualized images in public spaces, intimidation, stalking,
> harassing photography or recording, sustained disruption of events, and
> unwelcome physical contact or sexual attention. [1]
> We expect all participants to follow the Code of Conduct when involved in
> OSGeo activities. This includes conferences, related social events, and
> online forums. Participants violating this Code of Conduct will be asked to
> desist and/or make amends. For gross or continual violations, offenders may
> be expelled from the event or forum without a refund, and/or banned from
> future events or other forums.
> Participants are encouraged to bring any concerns to the attention of event
> staff, the forum, forum leader, or OSGeo Board. We thank all for helping
> keep OSGeo welcoming, respectful, and friendly for all.
> [1] Examples of inappropriate sexualised environments are described here:
> https://www.humanrights.gov.au/publications/sexual-harassment-code-practice-what-sexual-harassment
> On 10/01/2015 9:59 pm, Cameron Shorter wrote:
> Looking around at various Conference "Codes of Conduct", I found the
> O'Reilly definition to be eloquently worded, and less threatening to
> potential attendees. (Although I still can't find a clear definition of
> "sexual images".)
> Code of Conduct
> At O'Reilly, we assume that most people are intelligent and well-intended,
> and we're not inclined to tell people what to do. However, we want every
> O'Reilly conference to be a safe and productive environment for everyone. To
> that end, this code of conduct spells out the behavior we support and don't
> support at conferences. The core of our approach is this:
> We don't condone harassment or offensive behavior, at our conference venues
> or anywhere. It's counter to our company values. More importantly, it's
> counter to our values as human beings.
> We're voicing our strong, unequivocal support of appropriate behavior by all
> participants at technical events, including all O'Reilly conferences. We
> invite you to help us make each O'Reilly conference a place that is
> welcoming and respectful to all participants, regardless of race, gender,
> age, sexual orientation, disability, physical appearance, national origin,
> ethnicity, or religion. So that everyone can focus on the conference itself,
> and the great networking and community richness that happens when we get
> together in person, we will not tolerate harassment of conference
> participants in any form—in person or online.
> Examples of harassment include offensive comments, verbal threats or
> harassing photography or recording, sustained disruption of sessions or
> events, and unwelcome physical contact or sexual attention.
> We expect all participants—attendees, speakers, sponsors, and volunteers—to
> follow the Code of Conduct during the conference. This includes
> conference-related social events at off-site locations, and in related
> online communities and social media. Participants asked to stop any
> harassing behavior are expected to comply immediately. Conference
> participants violating this Code of Conduct may be expelled from the
> conference without a refund, and/or banned from future O'Reilly events, at
> the discretion of O'Reilly Media.
> Please bring any concerns to the immediate attention of the event staff, or
> contact our VP of Conferences, Gina Blaber at gina at oreilly.com. We thank our
> participants for your help in keeping the event welcoming, respectful, and
> friendly to all participants.
> Read the blog post by Tim O'Reilly that is the basis of our functional code
> of conduct for all O'Reilly conferences.
> Thanks to the Lean Startup folks and the jsconf.us folks, whose Codes of
> Conduct inspired some changes to our own.
> Cameron Shorter,
> Software and Data Solutions Manager
> LISAsoft
> Suite 112, Jones Bay Wharf,
> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
> P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
> Cameron Shorter,
> LISAsoft
> Cameron Shorter,
> LISAsoft
> Conference_dev mailing list
> Conference_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/conference_dev
More information about the Conference_dev
