[OSGeo-Conf] Proposed text for an OSGeo Code of Conduct
Cameron Shorter
cameron.shorter at gmail.com
Sun Jan 25 13:10:31 PST 2015
Thanks Eli,
I like your list of characteristics. I'd add:
* Have a CoC in the first place, which breaks down to:
** Ensure conferences remember / realise that a CoC should be in place.
(Add it to our cookbook [1] and bid process)
** Make it easy to apply a CoC by referencing an existing document.
(Complete this discussion and provide a best practice document that can
be referenced).
I acknowledge your point re over-doing sexualized images discussion.
I like the qgis CoC, and suggest that if we can make adding a CoC easy
(by providing generic text), then we should add having a CoC a
requirement for OSGeo graduation. I've added a placemarker into the
proposed text for the next OSGeo Project Graduation Checklist. [2]
[1] http://wiki.osgeo.org/wiki/FOSS4G_Handbook
[2] http://wiki.osgeo.org/wiki/Project_Graduation_Checklist#processes.4
On 26/01/2015 5:53 am, Eli Adam wrote:
> Code of Conduct specific wording is less important than these characteristics:
> * Being present (i.e. not implied but clearly stated)
> * Appearing sincere
> * Being sincere
> * Having reasonable people implementing it
> In that regard, the similar texts you listed were all fine.
> Generally, I think that we are spending too much time and emphasis on
> sexualized images. We are in the open source geospatial software,
> geospatial standards, open data, education, and related fields; 95%+
> of all presentations and other content can be done entirely
> successfully without images of people at all. For the 5% of cases
> that images of people substantively contribute to the presentation,
> err on the side of caution, "If in doubt, leave it out".
> I like the idea of the conference committee starting with a CoC for
> conferences and the Board possibly modifying and expanding it to other
> areas of OSGeo or projects establishing their own (see QGIS,
> http://qgis.org/en/site/getinvolved/governance/codeofconduct/codeofconduct.html)
> I don't think that 2015 FOSS4G needs any input, they already seem to
> have it under control, http://2015.foss4g.org/about/codeofconduct/,
> and there was nothing about a CoC in the bid. We should be focusing
> 2016 and beyond.
> Thanks for working on guiding this process Cameron.
> Best regards, Eli
> On Sat, Jan 24, 2015 at 3:12 AM, Cameron Shorter
> <cameron.shorter at gmail.com> wrote:
>> Hi David,
>> Thanks for starting this discussion. When you opened the discussion, you
>> very kindly offered to help set a Code of Conduct in place. How do you
>> suggest we move toward concluding the discussion and getting a Code of
>> Conduct in place?
>> Do you have a timeframe in mind for this? I assume we should try to make a
>> CoC available for FOSS4G 2015 if they wish to make use of one?
>> Peter, thanks for you comments on proposed text.
>> Is there anyone else with an interest in influencing the final text? If so,
>> please speak up.
>> Which is the better version of a CoC?
>> 1. Prior foss4g: https://2015.foss4g-na.org/code-conduct
>> 2. OReilly: http://www.oreilly.com/conferences/code-of-conduct.html (copied
>> below)
>> 3. My revised version (copied below)
>> 4. Something else
>> On 19/01/2015 9:16 am, Cameron Shorter wrote:
>> Hi David,
>> I'm happy to move proposed CoC text across to a wiki. If requested, I'll
>> copy across now (within 48 hours), or can wait till there has been further
>> discussion.
>> Also happy to expand the discussion to other lists, although I expect the
>> conference committee is probably the logical primary point for discussion,
>> as a CoC is most applicable to conferences. The board would need to sign off
>> on a CoC and should be invited to comment.
>> Re identifying what should be in a code of conduct. I've attempted to start
>> on that in the list of items I've attempted to address, listed below.
>> I have presented the draft CoC (below), as I find it is often easier to
>> start with a "straw man" which can be picked apart, rather than talking
>> vaguely in conceptual levels. However, I'm not wedded to the text, and hope
>> to see constructive criticism of the ideas, text and structure.
>> On 19/01/2015 3:46 am, David William Bitner wrote:
>> I really want to thank everyone here for engaging in this issue. I do
>> appreciate all the different voices that have contributed to this
>> conversation -- they all certainly speak to the diversity of thoughts and
>> experiences that we already have in this community.
>> Cameron -- thank you very much for putting forward a first draft of a
>> potential CoC for us to use. Before drafting and wordsmithing a CoC I want
>> to step back and make sure we answer a few questions that would certainly
>> impact how a CoC gets written. When we get to the point of drafting, we
>> should certainly do so on the wiki (or other trackable collaborative medium)
>> rather than in an email thread.
>> With some of the wording in this draft as well as seeing the discussion from
>> the last Board Meeting, is the conference committee the correct venue for
>> this discussion or should this be at the Board level so that this applies to
>> all OSGeo activities (mailing lists, events, etc)? I am certain that many of
>> the same people would remain engaged in helping draft a Code of Conduct
>> either for the foundation as a whole or just for our events, but this
>> certainly impacts the scope and wording required in a draft.
>> Many of the comments that I read as against having a CoC seem to stem from
>> people wondering what does a CoC solve. Sadly, having a CoC does not "solve"
>> anything. There will still be issues. A CoC simply provides one tool for us
>> to help resolve those issues when they come up as well as providing a
>> proactive statement that we aim to be a welcoming and diverse community to
>> hopefully prevent some of those issues in the first place. A CoC is not the
>> end point of diversity initiatives, but it is a very low hanging fruit to
>> start with. Other initiatives that I know have been tried that we should
>> continue to look at their effectiveness include author blind public program
>> review, scholarship initiatives, proactively seeking out diversity in key
>> notes, and many more things that we haven't tried.
>> On 18/01/2015 2:33 pm, Cameron Shorter wrote:
>> Following on from this email thread, I've drafted a proposed Code of
>> Conduct, where I've aimed to address:
>> * Be concise (concise words get read more)
>> * Cover key messages
>> * Include an escalation process for dealing with both minor and major issues
>> * Ensure key terms are understood (in particular reference to definition of
>> sexualised images)
>> * Couch in positive language
>> Tickbox version:
>> * I agree to act respectfully toward others in line with the OSGeo Code of
>> Conduct.
>> OSGeo Code of Conduct:
>> This Code of Conduct collates the collective values adopted by our OSGeo
>> community which baselines the behaviour we do and don’t support to ensure
>> OSGeo is a safe and productive environment for all.
>> We invite everyone to be respectful to all, regardless of race, gender, age,
>> sexual orientation, disability, physical appearance, national origin,
>> ethnicity, religion, or ideas. We do not tolerate harassment of others in
>> any form. Examples of harassment include offensive comments, verbal threats
>> or demands, sexualized images in public spaces, intimidation, stalking,
>> harassing photography or recording, sustained disruption of events, and
>> unwelcome physical contact or sexual attention. [1]
>> We expect all participants to follow the Code of Conduct when involved in
>> OSGeo activities. This includes conferences, related social events, and
>> online forums. Participants violating this Code of Conduct will be asked to
>> desist and/or make amends. For gross or continual violations, offenders may
>> be expelled from the event or forum without a refund, and/or banned from
>> future events or other forums.
>> Participants are encouraged to bring any concerns to the attention of event
>> staff, the forum, forum leader, or OSGeo Board. We thank all for helping
>> keep OSGeo welcoming, respectful, and friendly for all.
>> [1] Examples of inappropriate sexualised environments are described here:
>> https://www.humanrights.gov.au/publications/sexual-harassment-code-practice-what-sexual-harassment
>> On 10/01/2015 9:59 pm, Cameron Shorter wrote:
>> Looking around at various Conference "Codes of Conduct", I found the
>> O'Reilly definition to be eloquently worded, and less threatening to
>> potential attendees. (Although I still can't find a clear definition of
>> "sexual images".)
>> Code of Conduct
>> At O'Reilly, we assume that most people are intelligent and well-intended,
>> and we're not inclined to tell people what to do. However, we want every
>> O'Reilly conference to be a safe and productive environment for everyone. To
>> that end, this code of conduct spells out the behavior we support and don't
>> support at conferences. The core of our approach is this:
>> We don't condone harassment or offensive behavior, at our conference venues
>> or anywhere. It's counter to our company values. More importantly, it's
>> counter to our values as human beings.
>> We're voicing our strong, unequivocal support of appropriate behavior by all
>> participants at technical events, including all O'Reilly conferences. We
>> invite you to help us make each O'Reilly conference a place that is
>> welcoming and respectful to all participants, regardless of race, gender,
>> age, sexual orientation, disability, physical appearance, national origin,
>> ethnicity, or religion. So that everyone can focus on the conference itself,
>> and the great networking and community richness that happens when we get
>> together in person, we will not tolerate harassment of conference
>> participants in any form—in person or online.
>> Examples of harassment include offensive comments, verbal threats or
>> harassing photography or recording, sustained disruption of sessions or
>> events, and unwelcome physical contact or sexual attention.
>> We expect all participants—attendees, speakers, sponsors, and volunteers—to
>> follow the Code of Conduct during the conference. This includes
>> conference-related social events at off-site locations, and in related
>> online communities and social media. Participants asked to stop any
>> harassing behavior are expected to comply immediately. Conference
>> participants violating this Code of Conduct may be expelled from the
>> conference without a refund, and/or banned from future O'Reilly events, at
>> the discretion of O'Reilly Media.
>> Please bring any concerns to the immediate attention of the event staff, or
>> contact our VP of Conferences, Gina Blaber at gina at oreilly.com. We thank our
>> participants for your help in keeping the event welcoming, respectful, and
>> friendly to all participants.
>> Read the blog post by Tim O'Reilly that is the basis of our functional code
>> of conduct for all O'Reilly conferences.
>> Thanks to the Lean Startup folks and the jsconf.us folks, whose Codes of
>> Conduct inspired some changes to our own.
>> Cameron Shorter,
>> Software and Data Solutions Manager
>> LISAsoft
>> Suite 112, Jones Bay Wharf,
>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>> P +61 2 9009 5000, W www.lisasoft.com, F +61 2 9009 5099
>> Cameron Shorter,
>> LISAsoft
>> Cameron Shorter,
>> LISAsoft
>> Conference_dev mailing list
>> Conference_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/conference_dev
Cameron Shorter,
LISAsoft
More information about the Conference_dev
