[OSGeo-Conf] OSGeo Code of Conduct, version 1.0rc1
Kristin Bott
bottk at reed.edu
Wed May 13 11:05:38 PDT 2015
Cameron,
Some minor edits to the language under "Application" --
http://wiki.osgeo.org/wiki/Code_Of_Conduct#Application
I assume that the next step in the CoC discussion, after the CoC is
approved, is how to implement the CoC. (Methods for dealing with violations
-- are those in the hands of the project admins / event organizers, is
there an OSGeo-wide involvement, etc...)
I imagine that hashing out those types of details will be a fairly involved
process -- step one, of course, is to get the CoC approved. Thanks again
for all your work on this.
-kb
On Tue, May 12, 2015 at 2:31 PM, Cameron Shorter <cameron.shorter at gmail.com>
wrote:
> Following on from the IRC meeting today,
> It was agreed by all participants that the proposed Code of Conduct should
> be adopted, with the following changes:
> * A statement explaining how the CoC should be applied, as suggested by
> Kristin Bott (below)
> * Remove negative words from the Diversity Statement, as suggested by Jeff
> McKenna
> * Move to a Code of Conduct URL (instead of Diversity URL)
> I've addressed each of these into
> Kristin,
> Your suggested has been added as:
> Can you please confirm that this addresses what you were thinking, or
> suggest alternative wording.
> Are there any further comments or suggestions before we ask the board to
> endorse it?
> Warm regards,
> Cameron
> On 13/05/2015 3:56 am, Kristin Bott wrote:
> Hi all,
> Apologies for my slow response -- Cameron, this looks good to me; thank
> you for the effort and time it took to put this together, including
> reaching out to a number of different people and incorporating their
> perspectives.
> I won't be able to make the related meeting, unfortunately. Thanks to
> all who are contributing to this effort.
> I note that there is no central / suggested / mandated way to publicize
> the CoC for a given event or group; this puts the onus on individual
> organizers / LOCs / etc to make the CoC visible and enforced. I look
> forward to seeing this (or a revision thereof) CoC featured as part of
> upcoming OSGeo events.
> cheers -
> - kristin
> On Sun, May 10, 2015 at 8:07 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
>> Hi Cameron and all,
>> On May 10, 2015 3:44 AM, "Cameron Shorter" <cameron.shorter at gmail.com>
>> wrote:
>> > Members of the conference committee,
>> Or anyone participating (but yes especially conference committee members)
>> > I haven't heard anything positive or negative about the proposed OSGeo
>> Code of Conduct [2], and only a couple of people planning to attend the IRC
>> meeting to discuss it.
>> > I'm hoping that is because interested people have read it, think it is
>> acceptable, and don't have anything else to add?
>> Yes for me but always interested in hearing from others.
>> > If you have read the Code of Conduct, and think it is suitable to be
>> applied to future OSGeo projects and FOSS4G events then please speak up
>> with your support or recommended suggestions for changes.
>> I think the we did a good job sorting through other comparable codes of
>> conduct and finding where the best aspects came together. Cameron also
>> did a lot to keep the conversation going and not getting too distracted
>> with minor details. Cameron also did a lot to try and incorporate various
>> disparate views which is not an easy task. Thanks for that.
>> Best regards, Eli
>> > Thanks in advance, Cameron
>> > On 2/05/2015 9:03 am, Cameron Shorter wrote:
>> >> All,
>> >> There has been a lot of valuable discussion around the development of
>> an OSGeo Code of Conduct / Diversity Statement earlier this year, mainly on
>> the OSGeo Conference and OSGeo Board email lists.
>> >> I've researched a number of prior Code of Conduct and Diversity
>> Statements and combined with OSGeo participant comments to build a draft
>> OSGeo Code of Conduct, along with references to prior material, comments,
>> and a list of goals we want to achieve from such a document.
>> >> I propose that we aim to finalise a 1.0 version of an OSGeo Code of
>> Conduct/Diversity Statement and provide a recommendation for the next OSGeo
>> board meeting on 21 May 2015.
>> >> I've set up a Doodle Pole for an IRC meeting aimed at finalising this
>> Code of Conduct [1]
>> >> If you would like to contribute, please:
>> >> 1. Read the draft code of conduct [2]
>> >> 2. Provide comments either in the comments section on the wiki [3] or
>> on the conference email list [4]
>> >> 3. Register for [1] and then attend the IRC meeting [5]
>> >> [1] http://doodle.com/k8bmu6e8kntht462
>> >> [2] http://wiki.osgeo.org/wiki/Diversity
>> >> [3] http://wiki.osgeo.org/wiki/Diversity#Community_Comments
>> >> [4] http://lists.osgeo.org/mailman/listinfo/conference_dev
>> >> [5] irc://freenode.net#osgeo
>> >> Warm regards,
>> > Cameron Shorter,
>> > Software and Data Solutions Manager
>> > LISAsoft
>> > Suite 112, Jones Bay Wharf,
>> > 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>> > P +61 2 9009 5000, W www.lisasoft.com, F +61 2 9009 5099
>> > _______________________________________________
>> > Conference_dev mailing list
>> > Conference_dev at lists.osgeo.org
> Cameron Shorter,
> LISAsoft
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20150513/83306c27/attachment-0001.html>
More information about the Conference_dev
