[OSGeo-Conf] Start 2019 RFP / Board discussion about RFP for FOSS4G-2019
Steven Feldman
shfeldman at gmail.com
Fri Sep 1 10:03:38 PDT 2017
The 2018 RfP had a lot of changes made, including extracting all the dates, contacts etc into a section at the front which makes it much easier to update
Cheers
Steven
07958 924 101
> On 1 Sep 2017, at 17:38, Eli Adam <eadam at co.lincoln.or.us> wrote:
>> On Fri, Sep 1, 2017 at 4:46 AM, Till Adams <till.adams at fossgis.de> wrote:
>> Dear Eli,
>> many thanks for your input, always appreciated.
>> I've seen that the RFP document here
>> https://svn.osgeo.org/osgeo/foss4g/rfp/2019/osgeo-conference-2017-request-for-proposal.pdf
> The original is I believe in SVN right next to the pdf,
> https://svn.osgeo.org/osgeo/foss4g/rfp/2017/
> But I really think that you should build off the most recent 2018 RFP
> by Steven, and also as with all such documents, in SVN,
> https://svn.osgeo.org/osgeo/foss4g/rfp/2018/
>> was originally created by you. Do you mind so send me the real document or
>> share it via google, so that I could insert the changes and prepare the
>> document ready for the 2019 call?
> Check into SVN once you're ready. If you need help with that let me
> or someone else know and we'll do it.
> Best regards, Eli
>> Thanks, Till
> Conference_dev mailing list
> Conference_dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/conference_dev
More information about the Conference_dev
