[OSGeo-Conf] TGP's in 2019
Till Adams
till.adams at fossgis.de
Mon Feb 11 23:39:09 PST 2019
Dear list!
Great to get so much feedback - that was my intention ...;-). OSGeo's CC
is alive!
I will try to figure out a draft based on all the comments today or
tomorrow. Maybe we decouple the call for TGP and the decision process.
We can discuss the 2nd and then setup a chapter on the WIKI.
Till
Am 11.02.19 um 23:42 schrieb Eli Adam:
> On Mon, Feb 11, 2019 at 1:31 PM adam steer <adam.d.steer at gmail.com
> <mailto:adam.d.steer at gmail.com>> wrote:
> Hi Conference dev folks
> I wrote and deleted a long post which said effectively +1 to
> Mark’s comments. The very short version is that air travel is
> pretty much the only way to get around much of Oceania, and as
> such needs to be an option (cruise ships are another, but very
> dirty also).
> +1 to a lot of what Mark said. Mark (and the Dar LOC) certainly set a
> high standard for what the TGP can be. I was certainly glad to help a
> little bit on that process (and seeing how much the TGP had grown
> since some of our efforts in PDX was humbling - nice work). But again
> these are criteria that will be set by the LOC running that individual
> TGP.
> I’m struggling a little with Eli’s idea of funding based on
> expected conference attendance. Again, in Oceania conferences
> might not be huge but TGP support costs are high. I’d preference
> assessment on a case by case basis (ie the conference LOC puts up
> a proposal, it is assessed - but proposals all have to be
> submitted in the open), with maybe some work to develop guidelines
> around ‘if you live in region X, plan around cost Y per TGP funded
> attendee’. Of course, this is prima facie unfair because it’s a
> lot cheaper to support a TGP attendee in Tanzania than it is in
> Oceania. Food for thought/further discussion.
> My suggestion was intended as a general starting guideline and not
> intended as rigid.
> Oceania (or other regions) can certainly make their case for why their
> portion should be multiplied by Z.
> Also, different regions may be able to support a different number of
> TGP recipients based on various factors. I've made cases for TGP
> recipients very near (and costing very little) as well as very distant
> with poor transportation connectivity (and costing a sizable portion
> of the total TGP but there were not going to be closer/easier FOSS4G
> events for them in the near future, but maybe they would be the seed
> that grows FOSS4G there).
> Hopefully we take a reasonable approach that is open to reason,
> revision, and flexibility and gets better over time.
> Best regards, Eli
> …and of course, a fine rebuttal would be ‘work harder on
> sponsorship/fundraising! There’s money in the region, extract it!'
> Cheers
> Adam
> Conference_dev mailing list
> Conference_dev at lists.osgeo.org <mailto:Conference_dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/conference_dev
URL: <http://lists.osgeo.org/pipermail/conference_dev/attachments/20190212/d16a25bc/attachment-0001.html>
More information about the Conference_dev
