[OSGeo-Discuss] Is there an Open Source software application that will draw a graticule on a map?
Markus Neteler
neteler.osgeo at gmail.com
Thu Sep 6 22:23:57 PDT 2007
Hi Brent,
with GRASS' ps.map you can do that rather easily:
- define the raster and vector map names
- define (optionally) legend stuff
- activate "geogrid" to overlay a geographic grid onto the output map
- define paper size
It generated a Postscript file (use ps2pdf to make PDF) which
can be printed then.
See
http://grass.itc.it/gdp/html_grass63/ps.map.html
Example screenshot (a bit low-res, sorry):
http://www.gdf-hannover.de/lit_html/grass60_v1.2/img35.png
Code for that map:
http://www.gdf-hannover.de/lit_html/grass60_v1.2_en/node78.html
Markus
On 9/6/07, Brent Fraser <bfraser at geoanalytic.com> wrote:
> Hi all,
> I've been looking for an Open Source desktop application
> that will:
> 1. Combine raster and vector spatial data, and (re)project
> them
> 2. Render a graticule (lines and labels showing latitude and
> longitude) (and no, I don't want to create a shapefile to do
> that)
> 3. Print to a large format plotter (paper 24 inches wide or
> greater)
> So far I've looked at uDig, Quantum GIS, and gvSig. As far
> as I can tell, none of them can do Step 2, and only gvSig
> does Step 3 successfully.
> Any pointers would be appreciated!
> Brent Fraser
> GeoAnalytic Inc.
> Calgary, Alberta
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
Open Source Geospatial Foundation
http://www.osgeo.org/
http://osgeo.org/grass
More information about the Discuss
