[OSGeo-Discuss] Error compiling FDO 3.3.0
Jack Lee
jack.lee at autodesk.com
Tue May 27 07:12:20 EDT 2008
The script runs under the bash shell.
Are you running a version of Linux that is not using the bash shell (like Ubuntu)?
From: discuss-bounces at lists.osgeo.org [mailto:discuss-bounces at lists.osgeo.org] On Behalf Of Gianfranco Imbrogno
Sent: Tuesday, May 27, 2008 7:07 AM
To: OSGeo Discussions
Subject: Re: [OSGeo-Discuss] Error compiling FDO 3.3.0
Thanks...
I tried to run the command and I have this resoult:
test: 197: ==: unexpected operator
test: 200: ==: unexpected operator
test: 203: ==: unexpected operator
test: 259: ==: unexpected operator
test: 276: ==: unexpected operator
test: 296: ==: unexpected operator
test: 334: ==: unexpected operator
test: 354: ==: unexpected operator
test: 363: ==: unexpected operator
test: 372: ==: unexpected operator
test: 381: ==: unexpected operator
test: 390: ==: unexpected operator
test: 399: ==: unexpected operator
test: 408: ==: unexpected operator
test: 417: ==: unexpected operator
test: 426: ==: unexpected operator
test: 435: ==: unexpected operator
test: 444: ==: unexpected operator
Is it normal?
2008/5/27 Jack Lee <jack.lee at autodesk.com<mailto:jack.lee at autodesk.com>>:
You should run the build_linux.sh script instead of the configure script directly.
From: discuss-bounces at lists.osgeo.org<mailto:discuss-bounces at lists.osgeo.org> [mailto:discuss-bounces at lists.osgeo.org<mailto:discuss-bounces at lists.osgeo.org>] On Behalf Of Gianfranco Imbrogno
Sent: Tuesday, May 27, 2008 6:36 AM
To: discuss at lists.osgeo.org<mailto:discuss at lists.osgeo.org>
Subject: [OSGeo-Discuss] Error compiling FDO 3.3.0
hello, I'm a new user of MapGuide and I've some problems building the FDO 3.3.0.<http://3.3.0.>
After executing the ./configure there is an error "error: cannot find input file: Makefile.in"
Where is the problem?
Discuss mailing list
Discuss at lists.osgeo.org<mailto:Discuss at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/discuss
Gianfranco Imbrogno
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20080527/a84916d4/attachment.html
More information about the Discuss
