[OSGeo-Discuss] Error compiling FDO 3.3.0
Gianfranco Imbrogno
gimbrogno at smartlab.it
Tue May 27 08:05:30 EDT 2008
Yes I am running kubuntu...
Are there known problems around this distro and fdo?
2008/5/27 Jack Lee <jack.lee at autodesk.com>:
> Hi,
> The script runs under the bash shell.
> Are you running a version of Linux that is not using the bash shell (like
> Ubuntu)?
> *From:* discuss-bounces at lists.osgeo.org [mailto:
> discuss-bounces at lists.osgeo.org] *On Behalf Of *Gianfranco Imbrogno
> *Sent:* Tuesday, May 27, 2008 7:07 AM
> *To:* OSGeo Discussions
> *Subject:* Re: [OSGeo-Discuss] Error compiling FDO 3.3.0
> Thanks...
> I tried to run the command and I have this resoult:
> test: 197: ==: unexpected operator
> test: 200: ==: unexpected operator
> test: 203: ==: unexpected operator
> test: 259: ==: unexpected operator
> test: 276: ==: unexpected operator
> test: 296: ==: unexpected operator
> test: 334: ==: unexpected operator
> test: 354: ==: unexpected operator
> test: 363: ==: unexpected operator
> test: 372: ==: unexpected operator
> test: 381: ==: unexpected operator
> test: 390: ==: unexpected operator
> test: 399: ==: unexpected operator
> test: 408: ==: unexpected operator
> test: 417: ==: unexpected operator
> test: 426: ==: unexpected operator
> test: 435: ==: unexpected operator
> test: 444: ==: unexpected operator
> Is it normal?
> Hi,
> You should run the build_linux.sh script instead of the configure script
> directly.
> *Sent:* Tuesday, May 27, 2008 6:36 AM
> *To:* discuss at lists.osgeo.org
> *Subject:* [OSGeo-Discuss] Error compiling FDO 3.3.0
> hello, I'm a new user of MapGuide and I've some problems building the FDO
> 3.3.0.
> After executing the ./configure there is an error "error: cannot find
> input file: Makefile.in"
> Where is the problem?
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
> Gianfranco Imbrogno
Gianfranco Imbrogno
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20080527/1ed8436e/attachment.html
More information about the Discuss
