[OSGeo-Discuss] Questions about CS-Map, ArcSDE 9.3, buffer operations
surrounded Rob.Sosnowski at itd.idaho.gov
Wed Oct 15 13:03:47 PDT 2008
RESOLVED 2 and 3:
#2) I saw a post that indicated FDO 3.4 to be released (I believe) in Nov or
Dec 2008 will support ArcSDE 9.3.
#3) I used FWTools for the buffering functionality and then just converted
the geometry back to OSGeo.FDO geometry type.
REGARDING MY QUESTION ABOUT PROJECTIONS:
I can use FWTools to do this also, but as of yet have not fully explored
this.
surrounded wrote:
> Excuse my ignorance - here goes,
> I am building a GIS web application using FDO 3.3.1, C#.net, MS Virtual
> Earth, and Silverlight.  As I am not sure of the relationship between
> OSGeo and FDO, I will post these questions here:
> 1) I need to project coordinate systems (ex. WGS 1984 to state plane) and
> cannot find a way to do this using FDO.  WHAT TOOLS ARE AVAILABLE UNDER
> THE OSGeo UMBRELLA TO MAKE PROJECTIONS.  IF CS-MAP (recent donation from
> AutoDesk) IS THE TOOL TO USE FOR PROJECTING COODINATE SYSTEMS, WHERE DO I
> DOWNLOAD IT FROM?
> 2) FDO 3.3.1 currently supports ArcSDE 9.2.  DOES FDO 3.3.1 ALSO SUPPORT
> ArcSDE 9.3?  IF NOT WHEN WILL THAT HAPPEN?
> 2) I need the ability to buffer features and cannot find a way to do this
> using FDO.  WHAT OSGeo TOOLS ARE AVAILABLE FOR BUFFERING FEATURES WHOSE
> OBJECTS ARE COMPATABLE WITH FDO?
> Thanks for the help.....
View this message in context: http://n2.nabble.com/Questions-about-CS-Map%2C-ArcSDE-9.3%2C-buffer-operations-tp1142120p1338272.html
Sent from the OSGeo Discuss mailing list archive at Nabble.com.
More information about the Discuss mailing list
