[OSGeo-Discuss] Online shapefile Viewer
Dan Putler
dan.putler at sauder.ubc.ca
Sun Apr 3 11:26:15 PDT 2011
Hi Rashad,
I couldn't connect. I couldn't actually connect to www.iiit.ac.in
either, so there might be a problem at the university level at the moment.
Is the usage model one in which you connect and then upload a shapefile
for display?
Dan
On 04/03/2011 11:20 AM, Mohammed Rashad wrote:
> yes the our sever is facing some problems and will recover it as soon
> as possible
> Its not opensource currently but we are planning to release the
> application as Open source GPL probably in May
> we are also working on a collaborative mapping plaform VRGeo
> Did you tried with any shapefiles
> On Sun, Apr 3, 2011 at 11:47 PM, Dan Putler <dan.putler at sauder.ubc.ca
> <mailto:dan.putler at sauder.ubc.ca>> wrote:
> Hi Rashad,
> Is the viewer open source software?
> I've gone to the site, and response is fairly slow. Although,
> given the likely interest in this, you may be getting a *lot* of
> hits at the moment.
> Dan
> On 04/03/2011 11:08 AM, Mohammed Rashad wrote:
> Hi,
> I am posting here because gis users may find this application
> useful.
> here is an online shapefile viewer which reads shapefile using
> OGR and rendered on webpage.
> http://lsi.iiit.ac.in/lsi/shpviewer/
> Here the shapefile is directly rendered without mapserver,
> geoserver like packages.The only library we used is GDAL
> Please test it.
> Looking forward your comments, BUGS && suggestions
> Thanks && Regards
> Rashad
> Discuss mailing list
> Discuss at lists.osgeo.org <mailto:Discuss at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/discuss
> Thanks && Regards
> Rashad
More information about the Discuss
