[OSGeo-Discuss] Problem with Geos-3.2.2, Python & Swig
SIEFFERT Thomas
thomas.sieffert at c-s.fr
Tue Sep 18 05:57:07 PDT 2012
Hi everyone,
I don't know if it's the right place but still, I have a little
problem while the compilation process of geos (v3.2.2). Here is the
error :
File "/freeware/python-2.5.1/lib/python2.5/runpy.py", line 87, in run_module
raise ImportError("No module named " + mod_name)
ImportError: No module named odern
make[2]: [geos_wrap.cxx] Erreur 255 (ignorée)
make[4]: [geos_wrap.cxx] Erreur 255 (ignorée)
Dans le fichier inclus à partir de geos_wrap.cxx:135:
/freeware/src/Python-2.5.1/Include/Python.h:8:22: erreur: pyconfig.h :
Aucun fichier ou répertoire de ce type
/freeware/src/Python-2.5.1/Include/Python.h:57,
/freeware/src/Python-2.5.1/Include/pyport.h:734:2: erreur: #error
"LONG_BIT definition appears wrong for platform (bad gcc/glibc
config?)."
/freeware/src/Python-2.5.1/Include/pyport.h:550: erreur: declaration
of ?double hypot(double, double)? throws different exceptions
/usr/include/bits/mathcalls.h:163: erreur: from previous declaration
?double hypot(double, double) throw ()?
geos_wrap.cxx: In function ?int SWIG_CanCastAsInteger(double*, double,
double)?:
geos_wrap.cxx:2786: erreur: ?errno? was not declared in this scope
geos_wrap.cxx:2786: erreur: ?EDOM? was not declared in this scope
geos_wrap.cxx:2786: erreur: ?ERANGE? was not declared in this scope
geos_wrap.cxx: In function ?PyObject* _wrap_geomFromWKB(PyObject*,
PyObject*)?:
geos_wrap.cxx:8247: attention : déréférencement du pointeur
type-punned brisera les strictes d'aliases
geos_wrap.cxx: In function ?PyObject* _wrap_geomFromHEX(PyObject*,
PyObject*)?:
geos_wrap.cxx:8367: attention : déréférencement du pointeur
make[4]: *** [_geos_la-geos_wrap.lo] Erreur 1
make[3]: *** [all-recursive] Erreur 1
make[2]: *** [all] Erreur 2
make[1]: *** [all-recursive] Erreur 1
make: *** [all-recursive] Erreur 1
Herewith the config.log file. If you need more information please let me know.
This message was sent using IMP, the Internet Messaging Program.
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.64. Invocation command line was
$ ./configure --prefix=/freeware/geos-3.2.2 --enable-python
## Platform. ##
hostname = webservercs
uname -m = i686
uname -r = 2.6.18-308.13.1.el5
uname -s = Linux
uname -v = #1 SMP Tue Aug 21 17:10:06 EDT 2012
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = i686
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /freeware/bin
PATH: /usr/kerberos/sbin
PATH: /usr/kerberos/bin
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /sbin
PATH: /bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /root/bin
PATH: /root/bin
## Core tests. ##
configure:2567: checking build system type
configure:2581: result: i686-pc-linux-gnu
configure:2601: checking host system type
configure:2614: result: i686-pc-linux-gnu
configure:2634: checking target system type
configure:2647: result: i686-pc-linux-gnu
configure:2709: checking for a BSD-compatible install
configure:2777: result: /usr/bin/install -c
configure:2788: checking whether build environment is sane
configure:2838: result: yes
configure:2979: checking for a thread-safe mkdir -p
configure:3018: result: /bin/mkdir -p
configure:3031: checking for gawk
configure:3047: found /bin/gawk
configure:3058: result: gawk
configure:3069: checking whether make sets $(MAKE)
configure:3091: result: yes
configure:3214: checking for gcc
configure:3230: found /usr/bin/gcc
configure:3241: result: gcc
configure:3470: checking for C compiler version
configure:3479: gcc --version >&5
gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-52)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:3490: $? = 0
configure:3479: gcc -v >&5
Using built-in specs.
Target: i386-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-libgcj-multifile --enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk --disable-dssi --disable-plugin --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre --with-cpu=generic --host=i386-redhat-linux
Thread model: posix
gcc version 4.1.2 20080704 (Red Hat 4.1.2-52)
configure:3479: gcc -V >&5
gcc: '-V' option must have argument
configure:3490: $? = 1
configure:3479: gcc -qversion >&5
gcc: unrecognized option '-qversion'
gcc: no input files
configure:3512: checking for C compiler default output file name
configure:3534: gcc conftest.c >&5
configure:3538: $? = 0
configure:3575: result: a.out
configure:3591: checking whether the C compiler works
configure:3600: ./a.out
configure:3604: $? = 0
configure:3619: result: yes
configure:3626: checking whether we are cross compiling
configure:3628: result: no
configure:3631: checking for suffix of executables
configure:3638: gcc -o conftest conftest.c >&5
configure:3642: $? = 0
configure:3664: result:
configure:3670: checking for suffix of object files
configure:3692: gcc -c conftest.c >&5
configure:3696: $? = 0
configure:3717: result: o
configure:3721: checking whether we are using the GNU C compiler
configure:3740: gcc -c conftest.c >&5
configure:3740: $? = 0
configure:3749: result: yes
configure:3758: checking whether gcc accepts -g
configure:3778: gcc -c -g conftest.c >&5
configure:3778: $? = 0
configure:3819: result: yes
configure:3836: checking for gcc option to accept ISO C89
configure:3900: gcc -c -g -O2 conftest.c >&5
configure:3900: $? = 0
configure:3913: result: none needed
configure:3944: checking for style of include used by make
configure:3972: result: GNU
configure:3997: checking dependency style of gcc
configure:4107: result: gcc3
configure:4455: checking for a sed that does not truncate output
configure:4519: result: /bin/sed
configure:4537: checking for grep that handles long lines and -e
configure:4595: result: /bin/grep
configure:4600: checking for egrep
configure:4662: result: /bin/grep -E
configure:4667: checking for fgrep
configure:4729: result: /bin/grep -F
configure:4764: checking for ld used by gcc
configure:4831: result: /usr/bin/ld
configure:4838: checking if the linker (/usr/bin/ld) is GNU ld
configure:4853: result: yes
configure:4865: checking for BSD- or MS-compatible name lister (nm)
configure:4914: result: /usr/bin/nm -B
configure:5032: checking the name lister (/usr/bin/nm -B) interface
configure:5039: gcc -c -g -O2 conftest.c >&5
configure:5042: /usr/bin/nm -B "conftest.o"
configure:5045: output
00000000 B some_variable
configure:5052: result: BSD nm
configure:5055: checking whether ln -s works
configure:5059: result: yes
configure:5067: checking the maximum length of command line arguments
configure:5187: result: 98304
configure:5204: checking whether the shell understands some XSI constructs
configure:5214: result: yes
configure:5218: checking whether the shell understands "+="
configure:5224: result: yes
configure:5259: checking for /usr/bin/ld option to reload object files
configure:5266: result: -r
configure:5335: checking for objdump
configure:5362: result: objdump
configure:5391: checking how to recognize dependent libraries
configure:5587: result: pass_all
configure:5647: checking for ar
configure:5663: found /usr/bin/ar
configure:5674: result: ar
configure:5752: checking for strip
configure:5768: found /usr/bin/strip
configure:5779: result: strip
configure:5851: checking for ranlib
configure:5867: found /usr/bin/ranlib
configure:5878: result: ranlib
configure:5968: checking command to parse /usr/bin/nm -B output from gcc object
configure:6086: gcc -c -g -O2 conftest.c >&5
configure:6089: $? = 0
configure:6093: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p' \> conftest.nm
configure:6096: $? = 0
configure:6150: gcc -o conftest -g -O2 conftest.c conftstm.o >&5
configure:6153: $? = 0
configure:6191: result: ok
configure:7000: checking how to run the C preprocessor
configure:7031: gcc -E conftest.c
configure:7031: $? = 0
configure:7045: gcc -E conftest.c
conftest.c:9:28: error: ac_nonexistent.h: No such file or directory
configure:7045: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL ""
| /* end confdefs.h. */
| #include <ac_nonexistent.h>
configure:7070: result: gcc -E
configure:7090: gcc -E conftest.c
configure:7090: $? = 0
configure:7104: gcc -E conftest.c
configure:7104: $? = 1
| /* confdefs.h */
configure:7133: checking for ANSI C header files
configure:7153: gcc -c -g -O2 conftest.c >&5
configure:7153: $? = 0
configure:7226: gcc -o conftest -g -O2 conftest.c >&5
configure:7226: $? = 0
configure:7226: ./conftest
configure:7237: result: yes
configure:7250: checking for sys/types.h
configure:7250: gcc -c -g -O2 conftest.c >&5
configure:7250: $? = 0
configure:7250: result: yes
configure:7250: checking for sys/stat.h
configure:7250: checking for stdlib.h
configure:7250: checking for string.h
configure:7250: checking for memory.h
configure:7250: checking for strings.h
configure:7250: checking for inttypes.h
configure:7250: checking for stdint.h
configure:7250: checking for unistd.h
configure:7265: checking for dlfcn.h
configure:7265: gcc -c -g -O2 conftest.c >&5
configure:7265: $? = 0
configure:7265: result: yes
configure:7445: checking for objdir
configure:7460: result: .libs
configure:7756: checking if gcc supports -fno-rtti -fno-exceptions
configure:7774: gcc -c -g -O2 -fno-rtti -fno-exceptions conftest.c >&5
cc1: warning: command line option "-fno-rtti" is valid for C++/ObjC++ but not for C
configure:7778: $? = 0
configure:7791: result: no
configure:7811: checking for gcc option to produce PIC
configure:8083: result: -fPIC -DPIC
configure:8095: checking if gcc PIC flag -fPIC -DPIC works
configure:8113: gcc -c -g -O2 -fPIC -DPIC -DPIC conftest.c >&5
configure:8117: $? = 0
configure:8130: result: yes
configure:8154: checking if gcc static flag -static works
configure:8182: result: yes
configure:8197: checking if gcc supports -c -o file.o
configure:8218: gcc -c -g -O2 -o out/conftest2.o conftest.c >&5
configure:8222: $? = 0
configure:8244: result: yes
configure:8252: checking if gcc supports -c -o file.o
configure:8299: result: yes
configure:8332: checking whether the gcc linker (/usr/bin/ld) supports shared libraries
configure:9318: result: yes
configure:9355: checking whether -lc should be explicitly linked in
configure:9360: gcc -c -g -O2 conftest.c >&5
configure:9363: $? = 0
configure:9378: gcc -shared conftest.o -v -Wl,-soname -Wl,conftest -o conftest 2\>\&1 \| /bin/grep -lc \>/dev/null 2\>\&1
configure:9381: $? = 0
configure:9393: result: no
configure:9557: checking dynamic linker characteristics
configure:9990: gcc -o conftest -g -O2 -Wl,-rpath -Wl,/foo conftest.c >&5
configure:9990: $? = 0
configure:10208: result: GNU/Linux ld.so
configure:10310: checking how to hardcode library paths into programs
configure:10335: result: immediate
configure:10429: checking for shl_load
configure:10429: gcc -o conftest -g -O2 conftest.c >&5
/tmp/ccKsLoGc.o: In function `main':
/freeware/src/geos-3.2.2/conftest.c:55: undefined reference to `shl_load'
collect2: ld returned 1 exit status
configure:10429: $? = 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
| /* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
| For example, HP-UX 11i <limits.h> declares gettimeofday. */
| #define shl_load innocuous_shl_load
| /* System header to define __stub macros and hopefully few prototypes,
| which can conflict with char shl_load (); below.
| Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
| <limits.h> exists even on freestanding compilers. */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| #undef shl_load
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| char shl_load ();
| /* The GNU C library defines this for functions which it implements
| to always fail with ENOSYS. Some functions are actually named
| something starting with __ and the normal name is an alias. */
| #if defined __stub_shl_load || defined __stub___shl_load
| choke me
| #endif
| int
| main ()
| return shl_load ();
| return 0;
configure:10429: result: no
configure:10433: checking for shl_load in -ldld
configure:10458: gcc -o conftest -g -O2 conftest.c -ldld >&5
/usr/bin/ld: cannot find -ldld
configure:10458: $? = 1
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| char shl_load ();
| int
| main ()
| return shl_load ();
| return 0;
configure:10467: result: no
configure:10472: checking for dlopen
configure:10472: gcc -o conftest -g -O2 conftest.c >&5
/tmp/ccUD2arB.o: In function `main':
/freeware/src/geos-3.2.2/conftest.c:55: undefined reference to `dlopen'
configure:10472: $? = 1
| /* confdefs.h */
| /* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
| #define dlopen innocuous_dlopen
| which can conflict with char dlopen (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef dlopen
| #ifdef __cplusplus
| extern "C"
| #endif
| char dlopen ();
| #if defined __stub_dlopen || defined __stub___dlopen
| choke me
| #endif
| int
| main ()
| return dlopen ();
| return 0;
configure:10472: result: no
configure:10476: checking for dlopen in -ldl
configure:10501: gcc -o conftest -g -O2 conftest.c -ldl >&5
configure:10501: $? = 0
configure:10510: result: yes
configure:10629: checking whether a program can dlopen itself
configure:10699: gcc -o conftest -g -O2 -DHAVE_DLFCN_H -Wl,--export-dynamic conftest.c -ldl >&5
configure:10702: $? = 0
configure:10720: result: yes
configure:10725: checking whether a statically linked program can dlopen itself
configure:10795: gcc -o conftest -g -O2 -DHAVE_DLFCN_H -Wl,--export-dynamic -static conftest.c -ldl >&5
/tmp/ccMgsEBi.o: In function `main':
/freeware/src/geos-3.2.2/configure:10779: warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
configure:10798: $? = 0
/freeware/lib/: cannot read file data: Is a directory
configure:10816: result: no
configure:10855: checking whether stripping libraries is possible
configure:10860: result: yes
configure:10895: checking if libtool supports shared libraries
configure:10897: result: yes
configure:10900: checking whether to build shared libraries
configure:10921: result: yes
configure:10924: checking whether to build static libraries
configure:10928: result: yes
configure:11022: checking for g++
configure:11038: found /usr/bin/g++
configure:11049: result: g++
configure:11076: checking for C++ compiler version
configure:11085: g++ --version >&5
g++ (GCC) 4.1.2 20080704 (Red Hat 4.1.2-52)
configure:11096: $? = 0
configure:11085: g++ -v >&5
Thread model: posix
configure:11085: g++ -V >&5
g++: '-V' option must have argument
configure:11096: $? = 1
configure:11085: g++ -qversion >&5
g++: unrecognized option '-qversion'
g++: no input files
configure:11100: checking whether we are using the GNU C++ compiler
configure:11119: g++ -c conftest.cpp >&5
configure:11119: $? = 0
configure:11128: result: yes
configure:11137: checking whether g++ accepts -g
configure:11157: g++ -c -g conftest.cpp >&5
configure:11157: $? = 0
configure:11198: result: yes
configure:11223: checking dependency style of g++
configure:11333: result: gcc3
configure:11461: checking for C++ compiler version
configure:11470: g++ --version >&5
configure:11481: $? = 0
configure:11470: g++ -v >&5
Thread model: posix
configure:11470: g++ -V >&5
configure:11481: $? = 1
configure:11470: g++ -qversion >&5
g++: no input files
configure:11485: checking whether we are using the GNU C++ compiler
configure:11513: result: yes
configure:11522: checking whether g++ accepts -g
configure:11583: result: yes
configure:11608: checking dependency style of g++
configure:11718: result: gcc3
configure:11741: checking how to run the C++ preprocessor
configure:11768: g++ -E conftest.cpp
configure:11768: $? = 0
configure:11782: g++ -E conftest.cpp
conftest.cpp:21:28: error: ac_nonexistent.h: No such file or directory
configure:11782: $? = 1
| /* confdefs.h */
configure:11807: result: g++ -E
configure:11827: g++ -E conftest.cpp
configure:11827: $? = 0
configure:11841: g++ -E conftest.cpp
configure:11841: $? = 1
| /* confdefs.h */
configure:12009: checking for ld used by g++
configure:12076: result: /usr/bin/ld
configure:12083: checking if the linker (/usr/bin/ld) is GNU ld
configure:12098: result: yes
configure:12153: checking whether the g++ linker (/usr/bin/ld) supports shared libraries
configure:13066: result: yes
configure:13094: g++ -c -g -O2 conftest.cpp >&5
configure:13097: $? = 0
configure:13279: checking for g++ option to produce PIC
configure:13596: result: -fPIC -DPIC
configure:13605: checking if g++ PIC flag -fPIC -DPIC works
configure:13623: g++ -c -g -O2 -fPIC -DPIC -DPIC conftest.cpp >&5
configure:13627: $? = 0
configure:13640: result: yes
configure:13661: checking if g++ static flag -static works
configure:13689: result: yes
configure:13701: checking if g++ supports -c -o file.o
configure:13722: g++ -c -g -O2 -o out/conftest2.o conftest.cpp >&5
configure:13726: $? = 0
configure:13748: result: yes
configure:13753: checking if g++ supports -c -o file.o
configure:13800: result: yes
configure:13830: checking whether the g++ linker (/usr/bin/ld) supports shared libraries
configure:13856: result: yes
configure:13993: checking dynamic linker characteristics
configure:14374: g++ -o conftest -g -O2 -Wl,-rpath -Wl,/foo conftest.cpp >&5
configure:14374: $? = 0
configure:14592: result: GNU/Linux ld.so
configure:14643: checking how to hardcode library paths into programs
configure:14668: result: immediate
configure:14707: checking for library containing strerror
configure:14738: gcc -o conftest -g -O2 conftest.c >&5
configure:14738: $? = 0
configure:14755: result: none required
configure:14764: checking whether make sets $(MAKE)
configure:14786: result: yes
configure:14799: checking for dirent.h that defines DIR
configure:14818: gcc -c -g -O2 conftest.c >&5
configure:14818: $? = 0
configure:14826: result: yes
configure:14840: checking for library containing opendir
configure:14871: gcc -o conftest -g -O2 conftest.c >&5
configure:14871: $? = 0
configure:14888: result: none required
configure:14955: checking whether closedir returns void
configure:14979: gcc -o conftest -g -O2 conftest.c >&5
configure:14979: $? = 0
configure:14979: ./conftest
configure:14989: result: no
configure:14997: checking for working memcmp
configure:15040: gcc -o conftest -g -O2 conftest.c >&5
configure:15040: $? = 0
configure:15040: ./conftest
configure:15050: result: yes
configure:15061: checking for strftime
configure:15061: gcc -o conftest -g -O2 conftest.c >&5
conftest.c:45: warning: conflicting types for built-in function 'strftime'
configure:15061: $? = 0
configure:15061: result: yes
configure:15116: checking for vprintf
configure:15116: gcc -o conftest -g -O2 conftest.c >&5
conftest.c:46: warning: conflicting types for built-in function 'vprintf'
configure:15116: $? = 0
configure:15116: result: yes
configure:15122: checking for _doprnt
configure:15122: gcc -o conftest -g -O2 conftest.c >&5
/tmp/cceia4SY.o: In function `main':
/freeware/src/geos-3.2.2/conftest.c:58: undefined reference to `_doprnt'
configure:15122: $? = 1
| /* confdefs.h */
| #define HAVE_DIRENT_H 1
| #define HAVE_STRFTIME 1
| #define HAVE_VPRINTF 1
| /* Define _doprnt to an innocuous variant, in case <limits.h> declares _doprnt.
| #define _doprnt innocuous__doprnt
| which can conflict with char _doprnt (); below.
| #ifdef __STDC__
| #else
| #endif
| #undef _doprnt
| #ifdef __cplusplus
| extern "C"
| #endif
| char _doprnt ();
| #if defined __stub__doprnt || defined __stub____doprnt
| choke me
| #endif
| int
| main ()
| return _doprnt ();
| return 0;
configure:15122: result: no
configure:15135: checking for working alloca.h
configure:15152: gcc -o conftest -g -O2 conftest.c >&5
configure:15152: $? = 0
configure:15160: result: yes
configure:15168: checking for alloca
configure:15205: gcc -o conftest -g -O2 conftest.c >&5
configure:15205: $? = 0
configure:15213: result: yes
configure:15326: checking for dirent.h that defines DIR
configure:15353: result: yes
configure:15367: checking for library containing opendir
configure:15415: result: none required
configure:15482: checking for ANSI C header files
configure:15586: result: yes
configure:15596: checking for memory.h
configure:15596: result: yes
configure:15608: checking for unistd.h
configure:15608: result: yes
configure:15620: checking ieeefp.h usability
configure:15620: gcc -c -g -O2 conftest.c >&5
conftest.c:63:20: error: ieeefp.h: No such file or directory
configure:15620: $? = 1
| /* confdefs.h */
| #define HAVE_ALLOCA_H 1
| #define HAVE_ALLOCA 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| #include <ieeefp.h>
configure:15620: result: no
configure:15620: checking ieeefp.h presence
configure:15620: gcc -E conftest.c
conftest.c:30:20: error: ieeefp.h: No such file or directory
| /* confdefs.h */
| #include <ieeefp.h>
configure:15620: checking for ieeefp.h
configure:15632: checking sys/file.h usability
configure:15632: gcc -c -g -O2 conftest.c >&5
configure:15632: $? = 0
configure:15632: result: yes
configure:15632: checking sys/file.h presence
configure:15632: gcc -E conftest.c
configure:15632: checking for sys/file.h
configure:15644: checking sys/time.h usability
configure:15644: gcc -c -g -O2 conftest.c >&5
configure:15644: $? = 0
configure:15644: result: yes
configure:15644: checking sys/time.h presence
configure:15644: gcc -E conftest.c
configure:15644: checking for sys/time.h
configure:15657: checking for strchr
configure:15657: gcc -o conftest -g -O2 conftest.c >&5
conftest.c:55: warning: conflicting types for built-in function 'strchr'
configure:15657: $? = 0
configure:15657: result: yes
configure:15657: checking for memcpy
conftest.c:56: warning: conflicting types for built-in function 'memcpy'
configure:15657: checking for gettimeofday
configure:15667: checking whether stat file-mode macros are broken
configure:15694: gcc -c -g -O2 conftest.c >&5
configure:15694: $? = 0
configure:15701: result: no
configure:15709: checking whether struct tm is in sys/time.h or time.h
configure:15729: gcc -c -g -O2 conftest.c >&5
configure:15729: $? = 0
configure:15736: result: time.h
configure:15744: checking for size_t
configure:15744: gcc -c -g -O2 conftest.c >&5
configure:15744: $? = 0
conftest.c: In function 'main':
conftest.c:71: error: expected expression before ')' token
configure:15744: $? = 1
| /* confdefs.h */
| #define HAVE_SYS_FILE_H 1
| #define HAVE_SYS_TIME_H 1
| #define HAVE_STRCHR 1
| #define HAVE_MEMCPY 1
| #define HAVE_GETTIMEOFDAY 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| if (sizeof ((size_t)))
| return 0;
| return 0;
configure:15744: result: yes
configure:15755: checking for an ANSI C-conforming const
configure:15820: gcc -c -g -O2 conftest.c >&5
configure:15820: $? = 0
configure:15827: result: yes
configure:15882: checking if g++ supports -pedantic
configure:15900: gcc -c -g -O2 -pedantic conftest.c >&5
configure:15904: $? = 0
configure:15917: result: yes
configure:15926: checking if g++ supports -Wall
configure:15944: gcc -c -g -O2 -Wall conftest.c >&5
configure:15948: $? = 0
configure:15961: result: yes
configure:15970: checking if g++ supports -ansi
configure:15988: gcc -c -g -O2 -ansi conftest.c >&5
configure:15992: $? = 0
configure:16005: result: yes
configure:16014: checking if g++ supports -Wno-long-long
configure:16032: gcc -c -g -O2 -Wno-long-long conftest.c >&5
configure:16036: $? = 0
configure:16049: result: yes
configure:16061: checking if g++ supports -ffloat-store
configure:16079: gcc -c -g -O2 -ffloat-store conftest.c >&5
configure:16083: $? = 0
configure:16096: result: yes
configure:16114: checking for finite
configure:16130: gcc -o conftest -g -O2 -pedantic -Wall -ansi -Wno-long-long -ffloat-store conftest.c -lm >&5
conftest.c:39: warning: implicit declaration of function 'finite'
conftest.c:39: warning: 'x' is used uninitialized in this function
configure:16130: $? = 0
configure:16139: result: yes
configure:16147: checking for isfinite
configure:16163: gcc -o conftest -g -O2 -pedantic -Wall -ansi -Wno-long-long -ffloat-store conftest.c -lm >&5
conftest.c:40: warning: implicit declaration of function 'isfinite'
conftest.c:40: warning: 'x' is used uninitialized in this function
/tmp/ccSOMnUD.o: In function `main':
/freeware/src/geos-3.2.2/conftest.c:40: undefined reference to `isfinite'
configure:16163: $? = 1
| /* confdefs.h */
| #define HAVE_FINITE 1
| #include <math.h>
| int
| main ()
| double x; int y; y = isfinite(x);
| return 0;
configure:16172: result: no
configure:16187: checking for isnan
configure:16203: g++ -o conftest -g -O2 -DGEOS_INLINE -pedantic -Wall -ansi -Wno-long-long -ffloat-store conftest.cpp -lm >&5
conftest.cpp: In function 'int main()':
conftest.cpp:40: warning: 'x' is used uninitialized in this function
configure:16203: $? = 0
configure:16212: result: yes
configure:16230: checking whether int64_t is 64 bits
configure:16273: gcc -o conftest -g -O2 -pedantic -Wall -ansi -Wno-long-long -ffloat-store conftest.c >&5
conftest.c:64: warning: return type defaults to 'int'
conftest.c:65: warning: implicit declaration of function 'exit'
conftest.c:65: warning: incompatible implicit declaration of built-in function 'exit'
configure:16273: $? = 0
configure:16273: ./conftest
configure:16283: result: yes
configure:16466: checking for swig
configure:16484: found /freeware/bin/swig
configure:16496: result: /freeware/bin/swig
configure:16509: checking for SWIG version
configure:16512: result: 2.0.1
configure:16550: WARNING: SWIG version >= 1.3.28 is required. You have 2.0.1. You should look at http://www.swig.org
configure:16601: checking for python
configure:16619: found /freeware/bin/python
configure:16631: result: /freeware/bin/python
configure:16652: checking for python version
configure:16659: result: 2.5
configure:16671: checking for python platform
configure:16678: result: linux2
configure:16685: checking for python script directory
configure:16693: result: ${prefix}/lib/python2.5/site-packages
configure:16702: checking for python extension module directory
configure:16710: result: ${exec_prefix}/lib/python2.5/site-packages
configure:16756: checking for Python include path
configure:16765: result: /freeware/src/Python-2.5.1/Include
configure:16774: checking for Python library path
configure:16783: result: /freeware/lib/python2.5/config
configure:16797: checking python extra libraries
configure:16804: result:
configure:16940: checking OS-specific settings
configure:17133: creating ./config.status
## Running config.status. ##
This file was extended by config.status, which was
CONFIG_FILES =
CONFIG_HEADERS =
CONFIG_LINKS =
CONFIG_COMMANDS =
$ ./config.status
on webservercs
config.status:1305: creating Makefile
config.status:1305: creating build/Makefile
config.status:1305: creating build/msvc80/Makefile
config.status:1305: creating build/msvc80/geos_c_dll/Makefile
config.status:1305: creating build/msvc80/geos_lib/Makefile
config.status:1305: creating build/msvc80/geos_python/Makefile
config.status:1305: creating build/msvc80/geos_ruby/Makefile
config.status:1305: creating build/msvc80/geos_unit/Makefile
config.status:1305: creating build/msvc80/geos_xmltester/Makefile
config.status:1305: creating build/msvc90/Makefile
config.status:1305: creating build/msvc90/geos_c_dll/Makefile
config.status:1305: creating build/msvc90/geos_lib/Makefile
config.status:1305: creating build/msvc90/geos_python/Makefile
config.status:1305: creating build/msvc90/geos_ruby/Makefile
config.status:1305: creating build/msvc90/geos_unit/Makefile
config.status:1305: creating build/msvc90/geos_xmltester/Makefile
config.status:1305: creating build/msvc10/Makefile
config.status:1305: creating build/msvc10/geos_c_dll/Makefile
config.status:1305: creating build/msvc10/geos_lib/Makefile
config.status:1305: creating build/msvc10/geos_unit/Makefile
config.status:1305: creating build/msvc10/geos_xmltester/Makefile
config.status:1305: creating capi/Makefile
config.status:1305: creating capi/geos_c.h
config.status:1305: creating doc/Doxyfile
config.status:1305: creating doc/Makefile
config.status:1305: creating macros/Makefile
config.status:1305: creating source/Makefile
config.status:1305: creating source/algorithm/Makefile
config.status:1305: creating source/algorithm/locate/Makefile
config.status:1305: creating source/algorithm/distance/Makefile
config.status:1305: creating source/geom/Makefile
config.status:1305: creating source/geom/prep/Makefile
config.status:1305: creating source/geom/util/Makefile
config.status:1305: creating source/geomgraph/Makefile
config.status:1305: creating source/geomgraph/index/Makefile
config.status:1305: creating source/headers/Makefile
config.status:1305: creating source/headers/geos/Makefile
config.status:1305: creating source/headers/geos/algorithm/Makefile
config.status:1305: creating source/headers/geos/algorithm/locate/Makefile
config.status:1305: creating source/headers/geos/algorithm/distance/Makefile
config.status:1305: creating source/headers/geos/geom/Makefile
config.status:1305: creating source/headers/geos/geom/prep/Makefile
config.status:1305: creating source/headers/geos/geom/util/Makefile
config.status:1305: creating source/headers/geos/geomgraph/Makefile
config.status:1305: creating source/headers/geos/geomgraph/index/Makefile
config.status:1305: creating source/headers/geos/index/Makefile
config.status:1305: creating source/headers/geos/index/bintree/Makefile
config.status:1305: creating source/headers/geos/index/chain/Makefile
config.status:1305: creating source/headers/geos/index/intervalrtree/Makefile
config.status:1305: creating source/headers/geos/index/quadtree/Makefile
config.status:1305: creating source/headers/geos/index/strtree/Makefile
config.status:1305: creating source/headers/geos/index/sweepline/Makefile
config.status:1305: creating source/headers/geos/io/Makefile
config.status:1305: creating source/headers/geos/linearref/Makefile
config.status:1305: creating source/headers/geos/noding/Makefile
config.status:1305: creating source/headers/geos/noding/snapround/Makefile
config.status:1305: creating source/headers/geos/operation/Makefile
config.status:1305: creating source/headers/geos/operation/buffer/Makefile
config.status:1305: creating source/headers/geos/operation/distance/Makefile
config.status:1305: creating source/headers/geos/operation/linemerge/Makefile
config.status:1305: creating source/headers/geos/operation/overlay/Makefile
config.status:1305: creating source/headers/geos/operation/overlay/snap/Makefile
config.status:1305: creating source/headers/geos/operation/polygonize/Makefile
config.status:1305: creating source/headers/geos/operation/predicate/Makefile
config.status:1305: creating source/headers/geos/operation/relate/Makefile
config.status:1305: creating source/headers/geos/operation/union/Makefile
config.status:1305: creating source/headers/geos/operation/valid/Makefile
config.status:1305: creating source/headers/geos/planargraph/Makefile
config.status:1305: creating source/headers/geos/planargraph/algorithm/Makefile
config.status:1305: creating source/headers/geos/precision/Makefile
config.status:1305: creating source/headers/geos/simplify/Makefile
config.status:1305: creating source/headers/geos/util/Makefile
config.status:1305: creating source/headers/geos/version.h
config.status:1305: creating source/index/Makefile
config.status:1305: creating source/index/bintree/Makefile
config.status:1305: creating source/index/chain/Makefile
config.status:1305: creating source/index/intervalrtree/Makefile
config.status:1305: creating source/index/quadtree/Makefile
config.status:1305: creating source/index/strtree/Makefile
config.status:1305: creating source/index/sweepline/Makefile
config.status:1305: creating source/io/Makefile
config.status:1305: creating source/linearref/Makefile
config.status:1305: creating source/noding/Makefile
config.status:1305: creating source/noding/snapround/Makefile
config.status:1305: creating source/operation/Makefile
config.status:1305: creating source/operation/buffer/Makefile
config.status:1305: creating source/operation/distance/Makefile
config.status:1305: creating source/operation/linemerge/Makefile
config.status:1305: creating source/operation/overlay/Makefile
config.status:1305: creating source/operation/polygonize/Makefile
config.status:1305: creating source/operation/predicate/Makefile
config.status:1305: creating source/operation/relate/Makefile
config.status:1305: creating source/operation/union/Makefile
config.status:1305: creating source/operation/valid/Makefile
config.status:1305: creating source/planargraph/Makefile
config.status:1305: creating source/precision/Makefile
config.status:1305: creating source/simplify/Makefile
config.status:1305: creating source/util/Makefile
config.status:1305: creating swig/geos.i
config.status:1305: creating swig/Makefile
config.status:1305: creating swig/python/Makefile
config.status:1305: creating swig/python/tests/Makefile
config.status:1305: creating swig/ruby/Makefile
config.status:1305: creating swig/ruby/test/Makefile
config.status:1305: creating tests/Makefile
config.status:1305: creating tests/bigtest/Makefile
config.status:1305: creating tests/unit/Makefile
config.status:1305: creating tests/perf/Makefile
config.status:1305: creating tests/perf/operation/Makefile
config.status:1305: creating tests/perf/operation/buffer/Makefile
config.status:1305: creating tests/xmltester/Makefile
config.status:1305: creating tests/geostest/Makefile
config.status:1305: creating tests/thread/Makefile
config.status:1305: creating tools/Makefile
config.status:1305: creating tools/geos-config
config.status:1305: creating source/headers/config.h
config.status:1477: source/headers/config.h is unchanged
config.status:1305: creating source/headers/geos/platform.h
config.status:1477: source/headers/geos/platform.h is unchanged
config.status:1525: executing depfiles commands
config.status:1525: executing libtool commands
## Cache variables. ##
ac_cv_build=i686-pc-linux-gnu
ac_cv_c_compiler_gnu=yes
ac_cv_c_const=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_finite=yes
ac_cv_func__doprnt=no
ac_cv_func_alloca_works=yes
ac_cv_func_closedir_void=no
ac_cv_func_dlopen=no
ac_cv_func_gettimeofday=yes
ac_cv_func_memcmp_working=yes
ac_cv_func_memcpy=yes
ac_cv_func_shl_load=no
ac_cv_func_strchr=yes
ac_cv_func_strftime=yes
ac_cv_func_vprintf=yes
ac_cv_header_dirent_dirent_h=yes
ac_cv_header_dlfcn_h=yes
ac_cv_header_ieeefp_h=no
ac_cv_header_inttypes_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_stat_broken=no
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_file_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_time_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_host=i686-pc-linux-gnu
ac_cv_isfinite=no
ac_cv_isnan=yes
ac_cv_lib_dl_dlopen=yes
ac_cv_lib_dld_shl_load=no
ac_cv_objext=o
ac_cv_path_EGREP='/bin/grep -E'
ac_cv_path_FGREP='/bin/grep -F'
ac_cv_path_GREP=/bin/grep
ac_cv_path_PYTHON=/freeware/bin/python
ac_cv_path_SED=/bin/sed
ac_cv_path_SWIG=/freeware/bin/swig
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/bin/mkdir
ac_cv_prog_AWK=gawk
ac_cv_prog_CPP='gcc -E'
ac_cv_prog_CXXCPP='g++ -E'
ac_cv_prog_ac_ct_AR=ar
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_ac_ct_OBJDUMP=objdump
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_ac_ct_STRIP=strip
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_make_make_set=yes
ac_cv_search_opendir='none required'
ac_cv_search_strerror='none required'
ac_cv_struct_tm=time.h
ac_cv_target=i686-pc-linux-gnu
ac_cv_type_size_t=yes
ac_cv_working_alloca_h=yes
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=gcc3
am_cv_python_platform=linux2
am_cv_python_pyexecdir='${exec_prefix}/lib/python2.5/site-packages'
am_cv_python_pythondir='${prefix}/lib/python2.5/site-packages'
am_cv_python_version=2.5
dummy_cv_ansi=yes
dummy_cv_ffloat_store=yes
dummy_cv_no_long_long=yes
dummy_cv_pedantic=yes
dummy_cv_wall=yes
lt_cv_deplibs_check_method=pass_all
lt_cv_dlopen=dlopen
lt_cv_dlopen_libs=-ldl
lt_cv_dlopen_self=yes
lt_cv_dlopen_self_static=no
lt_cv_file_magic_cmd='$MAGIC_CMD'
lt_cv_file_magic_test_file=
lt_cv_ld_reload_flag=-r
lt_cv_nm_interface='BSD nm'
lt_cv_objdir=.libs
lt_cv_path_LD=/usr/bin/ld
lt_cv_path_LDCXX=/usr/bin/ld
lt_cv_path_NM='/usr/bin/nm -B'
lt_cv_prog_compiler_c_o=yes
lt_cv_prog_compiler_c_o_CXX=yes
lt_cv_prog_compiler_pic_works=yes
lt_cv_prog_compiler_pic_works_CXX=yes
lt_cv_prog_compiler_rtti_exceptions=no
lt_cv_prog_compiler_static_works=yes
lt_cv_prog_compiler_static_works_CXX=yes
lt_cv_prog_gnu_ld=yes
lt_cv_prog_gnu_ldcxx=yes
lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'''
lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\) $/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/ {"\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='sed -n -e '\''s/^: \([^ ]*\) $/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \(lib[^ ]*\)$/ {"\2", (void *) \&\2},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/ {"lib\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^T .* \(.*\)$/extern int \1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\'''
lt_cv_sys_max_cmd_len=98304
pgac_cv_type_int64_t_64=yes
## Output variables. ##
ACLOCAL='${SHELL} /freeware/src/geos-3.2.2/missing --run aclocal-1.11'
ALLOCA=''
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='${SHELL} /freeware/src/geos-3.2.2/missing --run tar'
AR='ar'
AS='as'
AUTOCONF='${SHELL} /freeware/src/geos-3.2.2/missing --run autoconf'
AUTOHEADER='${SHELL} /freeware/src/geos-3.2.2/missing --run autoheader'
AUTOMAKE='${SHELL} /freeware/src/geos-3.2.2/missing --run automake-1.11'
AWK='gawk'
CAPI_INTERFACE_AGE='6'
CAPI_INTERFACE_CURRENT='7'
CAPI_INTERFACE_REVISION='2'
CAPI_VERSION='1.6.2'
CAPI_VERSION_MAJOR='1'
CAPI_VERSION_MINOR='6'
CAPI_VERSION_PATCH='2'
CC='gcc'
CCDEPMODE='depmode=gcc3'
CFLAGS='-g -O2 -pedantic -Wall -ansi -Wno-long-long -ffloat-store'
CPP='gcc -E'
CPPFLAGS=''
CXX='g++'
CXXCPP='g++ -E'
CXXDEPMODE='depmode=gcc3'
CXXFLAGS='-g -O2 -DGEOS_INLINE -pedantic -Wall -ansi -Wno-long-long -ffloat-store'
CYGPATH_W='echo'
DEFS='-DHAVE_CONFIG_H'
DEPDIR='.deps'
DLLTOOL='dlltool'
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
ENABLE_PYTHON_FALSE='#'
ENABLE_PYTHON_TRUE=''
ENABLE_RUBY_FALSE=''
ENABLE_RUBY_TRUE='#'
ENABLE_SWIG_FALSE='#'
ENABLE_SWIG_TRUE=''
EXEEXT=''
GREP='/bin/grep'
INLINE_FLAGS='-DGEOS_INLINE'
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
INTERFACE_AGE=''
INTERFACE_CURRENT=''
INTERFACE_REVISION=''
JTS_PORT='1.10.0'
LD='/usr/bin/ld'
LDFLAGS=''
LIBOBJS=''
LIBS=''
LIBTOOL='$(SHELL) $(top_builddir)/libtool'
LIPO=''
LN_S='ln -s'
LTLIBOBJS=''
MAKEINFO='${SHELL} /freeware/src/geos-3.2.2/missing --run makeinfo'
MKDIR_P='/bin/mkdir -p'
NM='/usr/bin/nm -B'
NMEDIT=''
OBJDUMP='objdump'
OBJEXT='o'
OTOOL64=''
OTOOL=''
PACKAGE='geos'
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_URL=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PYTHON='/freeware/bin/python'
PYTHON_CPPFLAGS='-I/freeware/src/Python-2.5.1/Include'
PYTHON_EXEC_PREFIX='${exec_prefix}'
PYTHON_EXTRA_LIBS=' -lpthread -ldl -lutil'
PYTHON_LDFLAGS='-L/freeware/lib/python2.5/config -lpython2.5'
PYTHON_PLATFORM='linux2'
PYTHON_PREFIX='${prefix}'
PYTHON_SITE_PKG='/freeware'
PYTHON_VERSION='2.5'
RANLIB='ranlib'
RUBY=''
RUBY_BIN_DIR=''
RUBY_EXTENSION_DIR=''
RUBY_INCLUDE_DIR=''
RUBY_LIB_DIR=''
RUBY_SHARED_LIB=''
RUBY_SO_NAME=''
RUBY_VERSION=''
SED='/bin/sed'
SET_MAKE=''
SHELL='/bin/sh'
STRIP='strip'
SWIG=''
SWIG_LIB=''
SWIG_PYTHON_CPPFLAGS='-I/freeware/src/Python-2.5.1/Include'
SWIG_PYTHON_OPT='-python -modern'
VERSION='3.2.2'
VERSION_MAJOR='3'
VERSION_MINOR='2'
VERSION_PATCH='2'
ac_ct_CC='gcc'
ac_ct_CXX='g++'
ac_ct_DUMPBIN=''
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE='#'
am__fastdepCC_FALSE='#'
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE='#'
am__fastdepCXX_TRUE=''
am__include='include'
am__isrc=''
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build='i686-pc-linux-gnu'
build_alias=''
build_cpu='i686'
build_os='linux-gnu'
build_vendor='pc'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE}'
dvidir='${docdir}'
exec_prefix='${prefix}'
host='i686-pc-linux-gnu'
host_alias=''
host_cpu='i686'
host_os='linux-gnu'
host_vendor='pc'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='${SHELL} /freeware/src/geos-3.2.2/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
lt_ECHO='echo'
mandir='${datarootdir}/man'
mkdir_p='/bin/mkdir -p'
oldincludedir='/usr/include'
pdfdir='${docdir}'
pkgpyexecdir='${pyexecdir}/geos'
pkgpythondir='${pythondir}/geos'
prefix='/freeware/geos-3.2.2'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target='i686-pc-linux-gnu'
target_alias=''
target_cpu='i686'
target_os='linux-gnu'
target_vendor='pc'
## confdefs.h. ##
/* confdefs.h */
#define HAVE_ISNAN 1
#define HAVE_INT64_T_64 /**/
configure: exit 0
More information about the Discuss
