[OSGeo-Discuss] Attn: PROJ: Transverse and oblique Mercator
Kristian Evers kreve at sdfe.dk
Fri Jan 10 04:49:10 PST 2020
Hi Pierre
This sounds like a question for the PROJ mailing list [0]. The transverse Mercator already
exists in a very accurate version in PROJ but if yours is both faster and better it is worth
considering.
/Kristian
[0] https://lists.osgeo.org/mailman/listinfo/proj
-----Original Message-----
From: Discuss <discuss-bounces at lists.osgeo.org> On Behalf Of Pierre Abbat
Sent: 10. januar 2020 12:25
To: discuss at lists.osgeo.org
Subject: [OSGeo-Discuss] Attn: PROJ: Transverse and oblique Mercator
Jody Garnett posted on the incubator list some CONTRIBUTING files, one of which
is at PROJ, so I've been looking around. I've written code that computes the
transverse Mercator projection accurate to within 1 mm over 80% of the earth
and 100 µm over 71%, that is, within 100 µm up to 45° from the central
meridian. Are you interested?
I'd also like to understand the oblique Mercator well enough to write code for
it and what the differences are (besides the obvious) between Alaska and
Switzerland.
Pierre
loi mintu se ckaji danlu cu jmaji
Discuss mailing list
Discuss at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/discuss
More information about the Discuss mailing list
