[OSGeo-Discuss] repo.osgeo.org contains empty files
Frank Gasdorf
fgdrf at users.sourceforge.net
Thu Sep 7 07:39:38 PDT 2023
Hi folks,
I recently stumble about this problem to and my investigation is as follows:
* you a company uses a repository manager and has osger repo as a proxy
repo configured AND
* and internal artefact has been request but is not avaliable in internal
repositories, that a http get is set to osgeo repo as well
* this leads to enties like that with size 0 for each artefact
IMHO it seems to be an issue in nexus configuration and I investigate how
to configure filter for proxe repositories in Nexus.
Once you have a trac issue id, let us know
Frank
Am Do., 7. Sept. 2023 um 15:22 Uhr schrieb Jody Garnett via Discuss <
discuss at lists.osgeo.org>:
> This should be reported to the trac issues tracker, for the system admin
> committee.
> I help manage the repo a bit, I wonder where the size zero files come
> from? We may be able to check if they were uploaded or fetched from a cache
> of an external repo.
> On Thu, Sep 7, 2023 at 5:54 AM Brogli, Alexander via Discuss <
> discuss at lists.osgeo.org> wrote:
>> Hi all
>> We're thankful consumers of osgeo's maven repository, though this morning
>> we noticed that empty files are pulled. Inspecting certain cases, we saw
>> that since this morning files with size 0 seem to be in the repo, e.g. the
>> files here
>> https://repo.osgeo.org/service/rest/repository/browse/release/org/jboss/jboss-parent/36/
>> Do you know if there's a better place / mailing list to post this
>> inquiry, or if the responsible persons are aware of the issue?
>> Thanks & regards
>> Alex
>> Discuss mailing list
>> Discuss at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/discuss
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20230907/5c9e4c36/attachment.htm>
More information about the Discuss
