[OSGeo-Discuss] repo.osgeo.org contains empty files
Jody Garnett
jody.garnett at gmail.com
Thu Sep 7 12:04:16 PDT 2023
I have gone ahead and created a ticket there:
https://trac.osgeo.org/osgeo/ticket/2978
I did not see you report the ticket yet, and it is capturing feedback on
multiple channels.
I have found the problem with geonetwork-cache being setup to cache files
stored in a GitHub repository by geonetwork 2.x series.
GitHub must of turned off access in this manner yesterday, resulting in a
lot of time-outs and zero sized files being saved.
The geonetwork-cache has been removed from release configuration; and I
hope normal service has been restored? Please CONFIRM 🙂
Notes:
- There is a risk that other repositories have saved these zero sized
files and will need to clear their cache of OSGeo, and lazily rebuild it
again.
- Normal maven builds do not have any way to select what jar to retrieve
from different repositories. Indeed they attempt to contact each repository
in turn, checking for every jar.
So it is expect that repo.osgeo.org releases would field requests for
all manner of content as we have seen. This is one case where gradle offers
better control ...
- I will reach out to the core-geonetwork project and determine how
their build can be restored also.
Jody Garnett
Jody Garnett
On Sep 7, 2023 at 7:39:38 AM, Frank Gasdorf <fgdrf at users.sourceforge.net>
wrote:
> Hi folks,
> I recently stumble about this problem to and my investigation is as
> follows:
> * you a company uses a repository manager and has osger repo as a proxy
> repo configured AND
> * and internal artefact has been request but is not avaliable in internal
> repositories, that a http get is set to osgeo repo as well
> * this leads to enties like that with size 0 for each artefact
> IMHO it seems to be an issue in nexus configuration and I investigate how
> to configure filter for proxe repositories in Nexus.
> Once you have a trac issue id, let us know
> Frank
> Am Do., 7. Sept. 2023 um 15:22 Uhr schrieb Jody Garnett via Discuss <
> discuss at lists.osgeo.org>:
>> This should be reported to the trac issues tracker, for the system admin
>> committee.
>> I help manage the repo a bit, I wonder where the size zero files come
>> from? We may be able to check if they were uploaded or fetched from a cache
>> of an external repo.
>> On Thu, Sep 7, 2023 at 5:54 AM Brogli, Alexander via Discuss <
>> discuss at lists.osgeo.org> wrote:
>>> Hi all
>>> We're thankful consumers of osgeo's maven repository, though this
>>> morning we noticed that empty files are pulled. Inspecting certain cases,
>>> we saw that since this morning files with size 0 seem to be in the repo,
>>> e.g. the files here
>>> https://repo.osgeo.org/service/rest/repository/browse/release/org/jboss/jboss-parent/36/
>>> Do you know if there's a better place / mailing list to post this
>>> inquiry, or if the responsible persons are aware of the issue?
>>> Thanks & regards
>>> Alex
>>> Discuss mailing list
>>> Discuss at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/discuss
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20230907/8f9119ed/attachment.htm>
More information about the Discuss
