[OSGeo-Discuss] repo.osgeo.org contains empty files
Brogli, Alexander
Alexander.Brogli at ebp.ch
Mon Sep 11 23:16:36 PDT 2023
Yeah, thanks for the hint. We only have central and osgeo (for the dependencies that aren't on central), and we poll osgeo second 🙂.
Regards
Alex
Von: Jody Garnett <jody.garnett at gmail.com>
Gesendet: Montag, 11. September 2023 16:47
An: Brogli, Alexander <Alexander.Brogli at ebp.ch>
Cc: discuss at lists.osgeo.org <discuss at lists.osgeo.org>; fgdrf at users.sourceforge.net <fgdrf at users.sourceforge.net>
Betreff: Re: [OSGeo-Discuss] repo.osgeo.org contains empty files
[EXTERNE E-MAIL] Klicke nicht auf Links und öffne keine angehängten Dateien, wenn du die Absenderin oder den Absender nicht kennst.
I was only asking as if you have a mirror it would of been filled up with junk and need to have its cache of jars cleaned up.
When building directlt it is best to have the fewest number of maven repositories listed (as each one is checked in turn).
I am not sure why maven pom.xml does not allow an include/exclude filter on repositories…
Jody
On Mon, Sep 11, 2023 at 2:08 AM Brogli, Alexander <Alexander.Brogli at ebp.ch<mailto:Alexander.Brogli at ebp.ch>> wrote:
Answer:
We do build it directly and dont mirror it (so far, maybe we should, at least to reduce some traffic for osgeo). So for us the fix indeed worked.
Thanks & Regards
Alex
Von: Jody Garnett <jody.garnett at gmail.com<mailto:jody.garnett at gmail.com>>
Gesendet: Freitag, 8. September 2023 00:59
An: Brogli, Alexander <Alexander.Brogli at ebp.ch<mailto:Alexander.Brogli at ebp.ch>>
Cc: discuss at lists.osgeo.org<mailto:discuss at lists.osgeo.org> <discuss at lists.osgeo.org<mailto:discuss at lists.osgeo.org>>; fgdrf at users.sourceforge.net<mailto:fgdrf at users.sourceforge.net> <fgdrf at users.sourceforge.net<mailto:fgdrf at users.sourceforge.net>>
Betreff: Re: [OSGeo-Discuss] repo.osgeo.org<http://repo.osgeo.org> contains empty files
Question:
Are you building against repo osgeo "release" directly in your maven build?
If so you should indeed be fixed 🙂
Or have you setup a mirror or nexus repository of your own that caches repo osgeo "releases"?
In this case you may need to clear your cache (to get rid of any zero sized jars).
I am curious how many folks are running downstream caches or mirrors and may be affected ...
Jody Garnett
On Sep 7, 2023 at 12:42:09 PM, "Brogli, Alexander" <Alexander.Brogli at ebp.ch<mailto:Alexander.Brogli at ebp.ch>> wrote:
Hello
Thanks for creating the ticket. I haven't created one, since I don't have a osgeo ID and am still waiting for a reply to my mantra request. I've checked, it seems we can regularly pull from repo.osgeo.org<http://repo.osgeo.org> again, so I can confirm the problem seems to be resolved for us, thanks a lot!
Regards, Alex
Gesendet: Donnerstag, 7. September 2023 21:04
An: fgdrf at users.sourceforge.net<mailto:fgdrf at users.sourceforge.net> <fgdrf at users.sourceforge.net<mailto:fgdrf at users.sourceforge.net>>
Cc: Brogli, Alexander <Alexander.Brogli at ebp.ch<mailto:Alexander.Brogli at ebp.ch>>; discuss at lists.osgeo.org<mailto:discuss at lists.osgeo.org> <discuss at lists.osgeo.org<mailto:discuss at lists.osgeo.org>>
I have gone ahead and created a ticket there: https://trac.osgeo.org/osgeo/ticket/2978
I did not see you report the ticket yet, and it is capturing feedback on multiple channels.
I have found the problem with geonetwork-cache being setup to cache files stored in a GitHub repository by geonetwork 2.x series.
GitHub must of turned off access in this manner yesterday, resulting in a lot of time-outs and zero sized files being saved.
The geonetwork-cache has been removed from release configuration; and I hope normal service has been restored? Please CONFIRM 🙂
Notes:
* There is a risk that other repositories have saved these zero sized files and will need to clear their cache of OSGeo, and lazily rebuild it again.
* Normal maven builds do not have any way to select what jar to retrieve from different repositories. Indeed they attempt to contact each repository in turn, checking for every jar.
So it is expect that repo.osgeo.org<http://repo.osgeo.org/> releases would field requests for all manner of content as we have seen. This is one case where gradle offers better control ...
* I will reach out to the core-geonetwork project and determine how their build can be restored also.
Jody Garnett
Jody Garnett
On Sep 7, 2023 at 7:39:38 AM, Frank Gasdorf <fgdrf at users.sourceforge.net<mailto:fgdrf at users.sourceforge.net>> wrote:
Hi folks,
I recently stumble about this problem to and my investigation is as follows:
* you a company uses a repository manager and has osger repo as a proxy repo configured AND
* and internal artefact has been request but is not avaliable in internal repositories, that a http get is set to osgeo repo as well
* this leads to enties like that with size 0 for each artefact
IMHO it seems to be an issue in nexus configuration and I investigate how to configure filter for proxe repositories in Nexus.
Once you have a trac issue id, let us know
Frank
Am Do., 7. Sept. 2023 um 15:22 Uhr schrieb Jody Garnett via Discuss <discuss at lists.osgeo.org<mailto:discuss at lists.osgeo.org>>:
This should be reported to the trac issues tracker, for the system admin committee.
I help manage the repo a bit, I wonder where the size zero files come from? We may be able to check if they were uploaded or fetched from a cache of an external repo.
On Thu, Sep 7, 2023 at 5:54 AM Brogli, Alexander via Discuss <discuss at lists.osgeo.org<mailto:discuss at lists.osgeo.org>> wrote:
Hi all
We're thankful consumers of osgeo's maven repository, though this morning we noticed that empty files are pulled. Inspecting certain cases, we saw that since this morning files with size 0 seem to be in the repo, e.g. the files here https://repo.osgeo.org/service/rest/repository/browse/release/org/jboss/jboss-parent/36/.
Do you know if there's a better place / mailing list to post this inquiry, or if the responsible persons are aware of the issue?
Thanks & regards
Alex
Discuss mailing list
Discuss at lists.osgeo.org<mailto:Discuss at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/discuss
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20230912/4ae0c95f/attachment.htm>
More information about the Discuss
