[OSGeo-Discuss] repo.osgeo.org contains empty files
Jody Garnett
jody.garnett at gmail.com
Mon Sep 11 23:39:28 PDT 2023
I would recommend invalidating your cache and let it repopulate.
Jody
On Mon, Sep 11, 2023 at 10:50 PM Frank Gasdorf <fgdrf at users.sourceforge.net>
wrote:
> Interesting, we use it in Nexus as a proxy repo and you were right, these
> zero-size jars were present in our cache as well.
> How did you cleaned-up the cache? Search on filesystem and remove files
> with this attributes and updated index within nexus afterwards?
> Your help is much appreciated
> Frank
> Am Mo., 11. Sept. 2023 um 16:48 Uhr schrieb Jody Garnett <
> jody.garnett at gmail.com>:
>> I was only asking as if you have a mirror it would of been filled up with
>> junk and need to have its cache of jars cleaned up.
>> When building directlt it is best to have the fewest number of maven
>> repositories listed (as each one is checked in turn).
>> I am not sure why maven pom.xml does not allow an include/exclude filter
>> on repositories…
>> Jody
>> On Mon, Sep 11, 2023 at 2:08 AM Brogli, Alexander <
>> Alexander.Brogli at ebp.ch> wrote:
>>> Answer:
>>> We do build it directly and dont mirror it (so far, maybe we should, at
>>> least to reduce some traffic for osgeo). So for us the fix indeed worked.
>>> Thanks & Regards
>>> Alex
>>> *Von:* Jody Garnett <jody.garnett at gmail.com>
>>> *Gesendet:* Freitag, 8. September 2023 00:59
>>> *An:* Brogli, Alexander <Alexander.Brogli at ebp.ch>
>>> *Cc:* discuss at lists.osgeo.org <discuss at lists.osgeo.org>;
>>> fgdrf at users.sourceforge.net <fgdrf at users.sourceforge.net>
>>> *Betreff:* Re: [OSGeo-Discuss] repo.osgeo.org contains empty files
>>> *[EXTERNE E-MAIL]* Klicke nicht auf Links und öffne keine angehängten
>>> Dateien, wenn du die Absenderin oder den Absender nicht kennst.
>>> Question:
>>> Are you building against repo osgeo "release" directly in your maven
>>> build?
>>> If so you should indeed be fixed 🙂
>>> Or have you setup a mirror or nexus repository of your own that caches
>>> repo osgeo "releases"?
>>> In this case you may need to clear your cache (to get rid of any zero
>>> sized jars).
>>> I am curious how many folks are running downstream caches or mirrors and
>>> may be affected ...
>>> Jody Garnett
>>> On Sep 7, 2023 at 12:42:09 PM, "Brogli, Alexander" <
>>> Hello
>>> Thanks for creating the ticket. I haven't created one, since I don't
>>> have a osgeo ID and am still waiting for a reply to my mantra request. I've
>>> checked, it seems we can regularly pull from repo.osgeo.org again, so I
>>> can confirm the problem seems to be resolved for us, thanks a lot!
>>> Regards, Alex
>>> *Gesendet:* Donnerstag, 7. September 2023 21:04
>>> *An:* fgdrf at users.sourceforge.net <fgdrf at users.sourceforge.net>
>>> *Cc:* Brogli, Alexander <Alexander.Brogli at ebp.ch>;
>>> I have gone ahead and created a ticket there:
>>> https://trac.osgeo.org/osgeo/ticket/2978
>>> I did not see you report the ticket yet, and it is capturing feedback on
>>> multiple channels.
>>> I have found the problem with geonetwork-cache being setup to cache
>>> files stored in a GitHub repository by geonetwork 2.x series.
>>> GitHub must of turned off access in this manner yesterday, resulting in
>>> a lot of time-outs and zero sized files being saved.
>>> The geonetwork-cache has been removed from release configuration; and I
>>> hope normal service has been restored? Please CONFIRM 🙂
>>> Notes:
>>> - There is a risk that other repositories have saved these zero
>>> sized files and will need to clear their cache of OSGeo, and lazily rebuild
>>> it again.
>>> - Normal maven builds do not have any way to select what jar to
>>> retrieve from different repositories. Indeed they attempt to contact each
>>> repository in turn, checking for every jar.
>>> So it is expect that repo.osgeo.org releases would field requests
>>> for all manner of content as we have seen. This is one case where gradle
>>> offers better control ...
>>> - I will reach out to the core-geonetwork project and determine how
>>> their build can be restored also.
>>> Jody Garnett
>>> Jody Garnett
>>> On Sep 7, 2023 at 7:39:38 AM, Frank Gasdorf <fgdrf at users.sourceforge.net>
>>> wrote:
>>> Hi folks,
>>> I recently stumble about this problem to and my investigation is as
>>> follows:
>>> * you a company uses a repository manager and has osger repo as a proxy
>>> repo configured AND
>>> * and internal artefact has been request but is not avaliable in
>>> internal repositories, that a http get is set to osgeo repo as well
>>> * this leads to enties like that with size 0 for each artefact
>>> IMHO it seems to be an issue in nexus configuration and I investigate
>>> how to configure filter for proxe repositories in Nexus.
>>> Once you have a trac issue id, let us know
>>> Frank
>>> Am Do., 7. Sept. 2023 um 15:22 Uhr schrieb Jody Garnett via Discuss <
>>> discuss at lists.osgeo.org>:
>>> This should be reported to the trac issues tracker, for the system admin
>>> committee.
>>> I help manage the repo a bit, I wonder where the size zero files come
>>> from? We may be able to check if they were uploaded or fetched from a cache
>>> of an external repo.
>>> On Thu, Sep 7, 2023 at 5:54 AM Brogli, Alexander via Discuss <
>>> discuss at lists.osgeo.org> wrote:
>>> Hi all
>>> We're thankful consumers of osgeo's maven repository, though this
>>> morning we noticed that empty files are pulled. Inspecting certain cases,
>>> we saw that since this morning files with size 0 seem to be in the repo,
>>> e.g. the files here
>>> https://repo.osgeo.org/service/rest/repository/browse/release/org/jboss/jboss-parent/36/
>>> Do you know if there's a better place / mailing list to post this
>>> inquiry, or if the responsible persons are aware of the issue?
>>> Thanks & regards
>>> Alex
>>> Discuss mailing list
>>> Discuss at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/discuss
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20230911/233fe957/attachment.htm>
More information about the Discuss
