[OSGeo-Edu] Edu committee calendar
Puneet Kishor
punkish at eidesis.org
Mon May 8 08:24:42 EDT 2006
Arnulf Christl wrote:
>>> >> It asks me the SVN password which means that
>>> >> I need to request a role at
>>> >> https://edu.osgeo.org/servlets/ProjectMembershipRequest
>>> >> Question is, which one is able to write to SVN?
>>> >> - Observer: Read-only access to project code; can also submit issues;
>>> >> 'observer' of project
>>> >> - Project Contributor: Developer/User that contributes code via
>>> >> Project Tracker
>>> >> - User: User or application developer that makes use of the software
>>> >> in the project
>>> >> I have requested 'Project Contributor' - we'll see if that's
>>> sufficient.
>>> > OK, thanks for grating the role.
>>> > BUT: It continues to ask me the password. Apparently I am not able
>>> > as 'Project Contributor' to modify the SVN alias ical file therein.
>>> I have made you a "Project co-owner/contributor." Try now and let me
>>> know.
>> Works!
>> Please reload your calendar now :-)
>> I have modified the title to "EduCom meeting" and added
>> an pop-up alarm one hour before (hope that's ok).
>> So, only "Project co-owner/contributor" level works for modifying
>> the calendar since it is stored in SVN.
>> Thanks again,
>> Markus
> Hi,
> what I found out so far: you need to be >= "Project Developer" to write
> to SVN. "Owner" and "Co-Owner" can also write to SVN, additionally the
> "Co-Owner" can modify Mailing Lists issues and the "Owner" can delete
> the complete project with one single click (which is a very cool and
> highly useful feature that every Owner should immediately try out).
> "Users" may add tracker issues and the "Observer" does not really get
> anything but a few more links with announcements on the start page after
> login.
I would be happy to convert everyone who desires into a ">= Project
Developer." Sadly, unless I am mistaken, this is not a one-click task. I
have to actually delete an existing membership, and then re-add it with
the desired new role.
I have just moved to a new webhost for myself, and they support WebDAV.
I will be happy to move the Edu calendar there (my own calendars will be
moving there) as there would not be all this hassle of roles.
Thoughts?
> I have reported that the CN help is not good at relaying this
> information but it seems to not have been amended yet.
> I have no idea on how to start a branch and allow developers commits for
> that branch only using the CN infrastructure.
> Arnulf.
>>> If this doesn't work then we will revert to my more sub-optimal
>>> approach... I will maintain the calendar, and everyone can send me the
>>> events and I will enter them. Not satisfying, but at least everyone
>>> will know what everyone else in the edu.osgeo world is up to. If
>>> someone else has any other bright ideas, let me know (cc-ing to the
>>> entire list)
>>> Many thanks,
>>> Puneet Kishor
More information about the Edu_discuss
