[OSGeo-Edu] Re-starting our discussions
Sunburned Surveyor sunburned.surveyor at gmail.com
Mon Dec 15 11:40:12 EST 2008
I don't want the fire to die on this one. So I thought I would mention
it again briefly.
What is our goal here? Is the idea to allow anyone to categorize or
"tag" OSGeo educational content? Or will this web interface only be
used by authors when submitting new educational content?
Will we need a web form for search to? What format will we store the
entered metadata in? Will it be kept in a database (either the one
used by Drupal or a separate one)? Or can we store the information in
flat files?
Landon
On Wed, Dec 10, 2008 at 11:03 AM, Sunburned Surveyor
<sunburned.surveyor at gmail.com> wrote:
> Charlie wrote: "Anyone else in the group want to
> help Tyler?"
> I don't know anything about Drupal, but I can try to help if I am
> given some supervision. :]
> Landon
> On Tue, Dec 9, 2008 at 10:57 AM, Tyler Mitchell (OSGeo)
> <tmitchell at osgeo.org> wrote:
>> On 9-Dec-08, at 10:40 AM, cschweik at pubpol.umass.edu wrote:
>>> Can content be edited later if something needs to be changed?
>> Yes.  If you log into www.osgeo.org with your OSGeo user id you can create
>> an entry that is associated with your ID.  Then you can edit it again later.
>>  Certain levels of administration can also be set up to allow  group of
>> folks to edit all entries as well.
>> Tyler
>> Edu_discuss mailing list
>> Edu_discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/edu_discuss
More information about the Edu_discuss mailing list
