[OSGeo-Edu] Re: [gdal-dev] Using the CORINE2000 land cover/land
use data base with GRASS-GIS under Ubuntu-linux 8.04
cschweik at pubpol.umass.edu
Mon Jun 16 18:03:03 EDT 2008
Wonderful Nikos!
Quoting Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
> The new corrected/re-styled document replaced the first "bad-looking"
> version and is to be found in the same web-link as before:
http://www.isprs-studentconsortium.org/assets/files/Material_reports/Volume_2_No2/CORINE_withGRASS.pdf
I see you indeed have an entry for this on the OSGeo Educational Content page as
well. Terrific!
Please consider adding a section with an open content license if you haven't
already at the top of your tutorial. For our tutorials, we are using this
passage:
"This tutorial is licensed under a Creative Commons Attribution-No Derivative
Works 3.0 License (http://creativecommons.org/licenses/by-nd/3.0/). This means
that users are free to copy and share this material with others. Requests for
creating new derivatives should be sent to the primary author."
This allows us to control the source that will be in the OSGeo subversion
system. But you may have a difference license you'd prefer to use.
Cheers and thanks!
Charlie Schweik
OSgeo edu co-chair
> Thank you,
> Nikos
> Edu_discuss mailing list
> Edu_discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/edu_discuss
More information about the Edu_discuss
