[OSGeo-Edu] Edu virtual meeting to start in 20 minutes
Ari Jolma
ari.jolma at gmail.com
Fri Dec 9 18:44:54 EST 2011
On 12/09/2011 10:52 PM, Phillip Davis wrote:
> It requires any browser, that's it
Does it require also an Adobe Connect add-in? I installed such for linux
32 bit (I use Ubuntu 10.04 on tihs machine) and it seemed to go ok. My
mic works as I just used it for Skype. Yesterday the browser froze when
I tried running the audio setup wizard, now it allows me to run it and
it seems to suggest all is well but I couldn't record anything (did not
hear anything back although I can see that mic works and flash player is
asking a permission to my mic). Yesterday I had the green mic icon which
responded and I thought my mic was working in the beginning but now
checking the recording I find that it did not.
I think the chairperson should control the mics, i.e., open and close
them for people - I don't know if that's possible in this software -
without that it's often a confusion. Also the mic levels were wildly
different. The chat box was very slow to type in and small.
Best regards,
Ari
> ________________________________________
> From: edu_discuss-bounces at lists.osgeo.org [edu_discuss-bounces at lists.osgeo.org] On Behalf Of Ari Jolma [ari.jolma at gmail.com]
> Sent: Friday, December 09, 2011 8:50 AM
> To: edu_discuss at lists.osgeo.org
> Subject: Re: [OSGeo-Edu] Edu virtual meeting to start in 20 minutes
> did anybody get the adobe connect to work on Ubuntu?
> On 12/09/2011 10:43 PM, Charles Schweik wrote:
>> Hi virtual meeting participants:
>> 1. Go to http://delmarcollege.adobeconnect.com/dmcgis/.
>> 2. Choose "Meeting" from the menu.
>> 3. Audio setup wizard. You may need to install the add-in. Follow the
>> wizard to set up your sound and microphone.
>> After the wizard ends you need to then enable your microphone.
>> Talk to some of you soon! I am already in the room.
>> Charlie
>> Edu_discuss mailing list
>> Edu_discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/edu_discuss
> Confidentiality Notice: The information contained in this email, including attachments, may be
> privileged, proprietary, and/or confidential as provided by law. The information in this email is intended
> only for the use of the individual or entity to whom it is addressed. If you have received this
> communication in error, please notify the sender by replying to the email message and immediately
> return the email, attachments, and any and all copies to the sender. If you are not the intended recipient
> of this email and received it in error, please be advised that you may be subject to civil liability for any
> use of privileged, proprietary, and/or confidential information contained herein.
More information about the Edu_discuss
