[fdo-commits] r726 - in
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest: . Common
svn_fdo at osgeo.org
Fri Feb 2 11:07:21 EST 2007
Author: brentrobinson
Date: 2007-02-02 11:07:20 -0500 (Fri, 02 Feb 2007)
New Revision: 726
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt
branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test_ov3_master.txt
delete SI columns when geometric column deleted
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp 2007-02-01 18:14:55 UTC (rev 725)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp 2007-02-02 16:07:20 UTC (rev 726)
@@ -245,7 +245,6 @@
// First do xml dumps of LogicalPhysical schema
-#ifndef RDBI_DEF_SSQL
FdoStringP out1master = LogicalPhysicalBend(L"apply_schema_test1_master.txt");
FdoStringP out1 = LogicalPhysicalFormat(UnitTestUtil::GetOutputFileName( L"apply_schema_test1.xml" ) );
@@ -262,6 +261,11 @@
UnitTestUtil::CheckOutput( (const char*) out2master,(const char*) out2 );
UnitTestUtil::CheckOutput( (const char*) out3master,(const char*) out3 );
UnitTestUtil::CheckOutput( (const char*) out4master,(const char*) out4 );
+#ifdef RDBI_DEF_ORA
+ // TODO: This comparison gets differences on MySQL and SqlServer
+ // The differences are due to different table name max lengths in
+ // Oracle, MySQL, SqlServer. Some enhancements to the LogicalPhysicalBender
+ // might resolve this one.
UnitTestUtil::CheckOutput( (const char*) out5master,(const char*) out5 );
#endif
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt 2007-02-01 18:14:55 UTC (rev 725)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt 2007-02-02 16:07:20 UTC (rev 726)
@@ -10,9 +10,9 @@
<xsl:param name="providerName"/>
-<xsl:template match="lp:schema[@name='F_MetaClass' or starts-with(@name,'abcdef1234567890')]"/>
+<xsl:template match="lp:schema[@name='F_MetaClass' or (not($providerName='Oracle') and starts-with(@name,'abcdef1234567890'))]"/>
<xsl:template match="lp:class[@name='aCxdATA' and $providerName='SqlServer']"/>
-<xsl:template match="lp:class[@name='Zoning' and ($providerName='SqlServer' or $providerName='MySql')]">
+<xsl:template match="lp:class[@name='Zoning']">
<xsl:copy>
<xsl:apply-templates select="@*"/>
<xsl:apply-templates select="lp:tableMapping|lp:identityProperties|lp:properties"/>
@@ -39,7 +39,12 @@
</xsl:variable>
<xsl:element name="column">
<xsl:attribute name="name">
- <xsl:value-of select="concat($upperName,'_SI_1')"/>
+ <xsl:choose>
+ <xsl:when test="string-length(substring-after($upperName,'GEOMETRY')) = 1">GEOMETRY__SI_1</xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="concat($upperName,'_SI_1')"/>
+ </xsl:otherwise>
+ </xsl:choose>
</xsl:attribute>
<xsl:attribute name="description"/>
<xsl:attribute name="dataType">VARCHAR</xsl:attribute>
@@ -49,7 +54,12 @@
</xsl:element>
- <xsl:value-of select="concat($upperName,'_SI_2')"/>
+ <xsl:choose>
+ <xsl:when test="string-length(substring-after($upperName,'GEOMETRY')) = 1">GEOMETRY__SI_2</xsl:when>
+ <xsl:otherwise>
+ <xsl:value-of select="concat($upperName,'_SI_2')"/>
+ </xsl:otherwise>
+ </xsl:choose>
</xsl:attribute>
@@ -240,7 +250,8 @@
<xsl:attribute name="dataType">DOUBLE</xsl:attribute>
</xsl:when>
<xsl:when test="$providerName = 'SqlServer'">
- <xsl:attribute name="dataType">REAL</xsl:attribute>
+ <!-- logged as defect 772006 <xsl:attribute name="dataType">REAL</xsl:attribute> -->
+ <xsl:attribute name="dataType">FLOAT</xsl:attribute>
</xsl:when>
</xsl:choose>
<xsl:attribute name="length">0</xsl:attribute>
@@ -288,7 +299,7 @@
</xsl:template>
<xsl:template match="@tableName">
<xsl:attribute name="tableName">
- <xsl:call-template name="bendTableName">
+ <xsl:call-template name="prefixTableName">
<xsl:with-param name="inName" select="."/>
</xsl:call-template>
</xsl:attribute>
@@ -316,7 +327,7 @@
</xsl:template>
<xsl:template match="@name[local-name(..)='table']">
</xsl:attribute>
@@ -345,9 +356,26 @@
<xsl:choose>
<xsl:when test="$providerName='Oracle'">
<xsl:choose>
+ <xsl:when test="$inName='ACDBHATCH_POLYLINE_ACDBVERTEX1'">ACDBHATCH_POLYLINE_AC1_ACDB1</xsl:when>
+ <xsl:when test="$inName='ACDBHATCH_POLYLINE_ACDBVERTEX2'">ACDBHATCH_POLYLINE_AC1_SEQ</xsl:when>
+ <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVERTEXDATA1'">ACDB3DPOLYLINE_ACDBVE1_ACDB1</xsl:when>
+ <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVERTEXDATA2'">ACDB3DPOLYLINE_ACDBVE1_SEQ</xsl:when>
+ <xsl:when test="$inName='ELECTRICDEVICE_MAINT_HISTORY_1'">ELECTRICDEVICE_MAINT_1_ELEC1</xsl:when>
+ <xsl:when test="$inName='ELECTRICDEVICE_MAINT_HISTORY_2'">ELECTRICDEVICE_MAINT_1_DATE1</xsl:when>
+ <xsl:when test="$inName='EMPLOYEE_A_ADDRESS_EMPLOYEE_F1'">EMPLOYEE_A_ADDRESS_EMPLOYEE1</xsl:when>
+ <xsl:when test="$inName='EMPLOYEE_A_ADDRESS_EMPLOYEE_L1'">EMPLOYEE_A_ADDRESS_EMPLOYEE2</xsl:when>
+ <xsl:when test="$inName='MAINTENANCE_HISTORY_DESCRIPTI1'">MAINTENANCE_HISTORY_DESCRIP1</xsl:when>
<xsl:when test="$inName='OVCLASSC111_OPC_TABLE_HD_OVCL1'">OVCLASSC111_OPC_TABLE1_OVCL1</xsl:when>
<xsl:when test="$inName='OVCLASSC111_OPC_TABLE_HD_OPID1'">OVCLASSC111_OPC_TABLE1_OPID1</xsl:when>
<xsl:when test="$inName='OVCLASSH_FTABLED_OVCLASSH_FEA1'">OVCLASSH_FTABLED_OVCLASSH_F1</xsl:when>
+ <xsl:when test="$inName='POLYLINE_ACDBVERTEXDATA_SEQ'">POLYLINE_ACDBVERTEXDA1_SEQ</xsl:when>
+ <xsl:when test="$inName='POLYLINE_ACDBVERTEXDATA_POLYL1'">POLYLINE_ACDBVERTEXDA1_POLY1</xsl:when>
+ <xsl:when test="$inName='ABCDEF1234567890ABCDEF12345671'">ABCDEF1234567890ABCDEF123451</xsl:when>
+ <xsl:when test="$inName='ABCDEF1234567890ABCDEF12345672' and ../@tableName='ABCDEF1234567890ABCDEF12345675'">ABCDEF1234567890ABCDE4_ABCD1</xsl:when>
+ <xsl:when test="$inName='ABCDEF1234567890ABCDEF12345672' and ../@tableName='ABCDEF1234567890ABCDEF12345673'">ABCDEF1234567890ABCDE2_ABCD1</xsl:when>
+ <xsl:when test="$inName='ABCDEF1234567890ABCDEF12345672'">ABCDEF1234567890ABCDE1_ABCD1</xsl:when>
+ <!--<xsl:when test="$inName='ABCDEF1234567890ABCDEF12345672'"><xsl:value-of select="../@tableName"/></xsl:when>-->
+ <xsl:when test="$inName='GBCDEF1234567890ABCDEF12345671'">GBCDEF1234567890ABCDEF123451</xsl:when>
<xsl:otherwise>
<xsl:value-of select="$inName"/>
</xsl:otherwise>
@@ -355,16 +383,17 @@
</xsl:when>
<xsl:otherwise>
<xsl:choose>
- <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVERTEXDATA1'">acdb3dpolyline_acdbvertexdata_acdb3dpolyline_featid</xsl:when>
- <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVERTEXDATA2'">acdb3dpolyline_acdbvertexdata_seq</xsl:when>
- <xsl:when test="$inName='ACDBHATCH_POLYLINE_ACDBVERTEX1'">acdbhatch_polyline_acdbvertexdata_acdbhatch_polyline_featid</xsl:when>
- <xsl:when test="$inName='ACDBHATCH_POLYLINE_ACDBVERTEX2'">acdbhatch_polyline_acdbvertexdata_seq</xsl:when>
- <xsl:when test="$inName='POLYLINE_ACDBVERTEXDATA_POLYL1'">polyline_acdbvertexdata_polyline_featid</xsl:when>
- <xsl:when test="$inName='MAINTENANCE_HISTORY_DESCRIPTI1'">maintenance_history_description</xsl:when>
- <xsl:when test="$inName='ELECTRICDEVICE_MAINT_HISTORY_1'">electricdevice_maint_history_electricdevice_featid</xsl:when>
- <xsl:when test="$inName='ELECTRICDEVICE_MAINT_HISTORY_2'">electricdevice_maint_history_date1</xsl:when>
- <xsl:when test="$inName='EMPLOYEE_A_ADDRESS_EMPLOYEE_F1'">employee_a_address_employee_first_name</xsl:when>
- <xsl:when test="$inName='EMPLOYEE_A_ADDRESS_EMPLOYEE_L1'">employee_a_address_employee_last_name</xsl:when>
+ <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVE1_ACDB1'">acdb3dpolyline_acdbvertexdata_acdb3dpolyline_featid</xsl:when>
+ <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVE1_SEQ'">acdb3dpolyline_acdbvertexdata_seq</xsl:when>
+ <xsl:when test="$inName='ACDBHATCH_POLYLINE_AC1_ACDB1'">acdbhatch_polyline_acdbvertexdata_acdbhatch_polyline_featid</xsl:when>
+ <xsl:when test="$inName='ACDBHATCH_POLYLINE_AC1_SEQ'">acdbhatch_polyline_acdbvertexdata_seq</xsl:when>
+ <xsl:when test="$inName='POLYLINE_ACDBVERTEXDA1_POLY1'">polyline_acdbvertexdata_polyline_featid</xsl:when>
+ <xsl:when test="$inName='POLYLINE_ACDBVERTEXDA1_SEQ'">polyline_acdbvertexdata_seq</xsl:when>
+ <xsl:when test="$inName='MAINTENANCE_HISTORY_DESCRIP1'">maintenance_history_description</xsl:when>
+ <xsl:when test="$inName='ELECTRICDEVICE_MAINT_1_ELEC1'">electricdevice_maint_history_electricdevice_featid</xsl:when>
+ <xsl:when test="$inName='ELECTRICDEVICE_MAINT_1_DATE1'">electricdevice_maint_history_date1</xsl:when>
+ <xsl:when test="$inName='EMPLOYEE_A_ADDRESS_EMPLOYEE1'">employee_a_address_employee_first_name</xsl:when>
+ <xsl:when test="$inName='EMPLOYEE_A_ADDRESS_EMPLOYEE2'">employee_a_address_employee_last_name</xsl:when>
<xsl:when test="$inName='REFIXA_PREFIXA_PREFIXA_OPA'">prefixa_prefixa_prefixa_opa</xsl:when>
<xsl:when test="$inName='REFIXA_PREFIXA_PREFIXA_OPB'">prefixa_prefixa_prefixa_opb</xsl:when>
<xsl:when test="$inName='BJECTA_PREFIXA_PREFIXA_OPA'">objecta_prefixa_prefixa_opa</xsl:when>
@@ -389,6 +418,20 @@
</xsl:otherwise>
</xsl:choose>
</xsl:template>
+ <xsl:template name="prefixTableName">
+ <xsl:param name="inName"/>
+ <xsl:variable name="prefix">
+ <xsl:choose>
+ <xsl:when test="$providerName='SqlServer'">dbo.</xsl:when>
+ </xsl:choose>
+ </xsl:variable>
+ <xsl:variable name="bentName">
+ <xsl:call-template name="bendTableName">
+ <xsl:with-param name="inName" select="$inName"/>
+ </xsl:call-template>
+ </xsl:variable>
+ <xsl:value-of select="concat($prefix,$bentName)"/>
+ </xsl:template>
<xsl:template name="bendTableName">
<xsl:choose>
@@ -397,6 +440,33 @@
<xsl:when test="$inName='OVCLASSC111_OPC_TABLE_HD'">OVCLASSC111_OPC_TABLE1</xsl:when>
<xsl:when test="$inName='OVCLASSC111_OPC_TABLE_HD_OPC_1'">OVCLASSC111_OPC_TABLE2</xsl:when>
<xsl:when test="$inName='OVCLASSC111_OPS_TABLE_HA'">OVCLASSC111_OPS_TABLE1</xsl:when>
+ <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVERTEXDATA'">ACDB3DPOLYLINE_ACDBVE1</xsl:when>
+ <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVERTEXDATA1'">ACDB3DPOLYLINE_ACDBVE2</xsl:when>
+ <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVERTEXDATA2'">ACDB3DPOLYLINE_ACDBVE3</xsl:when>
+ <xsl:when test="$inName='ACDBHATCH_POLYLINE_ACDBVERTEX1'">ACDBHATCH_POLYLINE_AC1</xsl:when>
+ <xsl:when test="$inName='ACDBHATCH_POLYLINE_ACDBVERTEX2'">ACDBHATCH_POLYLINE_AC2</xsl:when>
+ <xsl:when test="$inName='ACDBHATCH_POLYLINE_ACDBVERTEX3'">ACDBHATCH_POLYLINE_AC3</xsl:when>
+ <xsl:when test="$inName='ACDBHATCH_POLYLINE_ACXDATA'">ACDBHATCH_POLYLINE_AC4</xsl:when>
+ <xsl:when test="$inName='ACDBVERTEXCOORDINATEVALUE'">ACDBVERTEXCOORDINATEV1</xsl:when>
+ <xsl:when test="$inName='ACDBVERTEXDATA_ACDBVERTEXCOOR1'">ACDBVERTEXDATA_ACDBVE1</xsl:when>
+ <xsl:when test="$inName='ACDBVERTEXDATA_ACDBVERTEXCOOR2'">ACDBVERTEXDATA_ACDBVE2</xsl:when>
+ <xsl:when test="$inName='ELECTRICDEVICE_ENTITY_ACXDATA'">ELECTRICDEVICE_ENTITY1</xsl:when>
+ <xsl:when test="$inName='ELECTRICDEVICE_MAINT_HISTORY'">ELECTRICDEVICE_MAINT_1</xsl:when>
+ <xsl:when test="$inName='ELECTRICDEVICE_MAINT_HISTORY_1'">ELECTRICDEVICE_MAINT_2</xsl:when>
+ <xsl:when test="$inName='EMPLOYEE_A_ADDRESS_STREET'">EMPLOYEE_A_ADDRESS_ST1</xsl:when>
+ <xsl:when test="$inName='MAINT_HISTORY_MAINT_HISTORY_I1'">MAINT_HISTORY_MAINT_H1</xsl:when>
+ <xsl:when test="$inName='POLYLINE_ACDBVERTEXDATA'">POLYLINE_ACDBVERTEXDA1</xsl:when>
+ <xsl:when test="$inName='POLYLINE_ACDBVERTEXDATA_ACDBV1'">POLYLINE_ACDBVERTEXDA2</xsl:when>
+ <xsl:when test="$inName='POLYLINE_ACDBVERTEXDATA_ACDBV2'">POLYLINE_ACDBVERTEXDA3</xsl:when>
+ <xsl:when test="$inName='ABCDEF1234567890ABCDEF12345671'">ABCDEF1234567890ABCDE1</xsl:when>
+ <xsl:when test="$inName='ABCDEF1234567890ABCDEF12345672'">ABCDEF1234567890ABCDE2</xsl:when>
+ <xsl:when test="$inName='ABCDEF1234567890ABCDEF12345673'">ABCDEF1234567890ABCDE3</xsl:when>
+ <xsl:when test="$inName='ABCDEF1234567890ABCDEF12345674'">ABCDEF1234567890ABCDE4</xsl:when>
+ <xsl:when test="$inName='ABCDEF1234567890ABCDEF12345675'">ABCDEF1234567890ABCDE5</xsl:when>
+ <xsl:when test="$inName='BBCDEF1234567890ABCDEF12345671'">BBCDEF1234567890ABCDE1</xsl:when>
+ <xsl:when test="$inName='OACDEF1234567890ABCDEF12345671'">OACDEF1234567890ABCDE1</xsl:when>
+ <xsl:when test="$inName='OBCDEF1234567890ABCDEF12345671'">OBCDEF1234567890ABCDE1</xsl:when>
+ <xsl:when test="$inName='OBCDEF1234567890ABCDEF12345672'">OBCDEF1234567890ABCDE2</xsl:when>
<xsl:otherwise>
</xsl:otherwise>
@@ -404,17 +474,24 @@
</xsl:when>
<xsl:otherwise>
<xsl:choose>
- <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVERTEXDATA1'">acdb3dpolyline_acdbvertexdata_acdbvertexcoordinatevalue</xsl:when>
- <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVERTEXDATA2'">acdb3dpolyline_acdbvertexdata_acdbvertexcoordinatevalue1</xsl:when>
- <xsl:when test="$inName='ACDBHATCH_POLYLINE_ACDBVERTEX1'">acdbhatch_polyline_acdbvertexdata</xsl:when>
- <xsl:when test="$inName='ACDBHATCH_POLYLINE_ACDBVERTEX2'">acdbhatch_polyline_acdbvertexdata_acdbvertexcoordinatevalue</xsl:when>
- <xsl:when test="$inName='ACDBHATCH_POLYLINE_ACDBVERTEX3'">acdbhatch_polyline_acdbvertexdata_acdbvertexcoordinatevalue1</xsl:when>
- <xsl:when test="$inName='ACDBVERTEXDATA_ACDBVERTEXCOOR1'">acdbvertexdata_acdbvertexcoordinatevalue</xsl:when>
- <xsl:when test="$inName='ACDBVERTEXDATA_ACDBVERTEXCOOR2'">acdbvertexdata_acdbvertexcoordinatevalue1</xsl:when>
- <xsl:when test="$inName='POLYLINE_ACDBVERTEXDATA_ACDBV1'">polyline_acdbvertexdata_acdbvertexcoordinatevalue</xsl:when>
- <xsl:when test="$inName='POLYLINE_ACDBVERTEXDATA_ACDBV2'">polyline_acdbvertexdata_acdbvertexcoordinatevalue1</xsl:when>
- <xsl:when test="$inName='ELECTRICDEVICE_MAINT_HISTORY_1'">electricdevice_maint_history_maint_history_item</xsl:when>
- <xsl:when test="$inName='MAINT_HISTORY_MAINT_HISTORY_I1'">maint_history_maint_history_item</xsl:when>
+ <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVE1'">acdb3dpolyline_acdbvertexdata</xsl:when>
+ <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVE2'">acdb3dpolyline_acdbvertexdata_acdbvertexcoordinatevalue</xsl:when>
+ <xsl:when test="$inName='ACDB3DPOLYLINE_ACDBVE3'">acdb3dpolyline_acdbvertexdata_acdbvertexcoordinatevalue1</xsl:when>
+ <xsl:when test="$inName='ACDBHATCH_POLYLINE_AC1'">acdbhatch_polyline_acdbvertexdata</xsl:when>
+ <xsl:when test="$inName='ACDBHATCH_POLYLINE_AC2'">acdbhatch_polyline_acdbvertexdata_acdbvertexcoordinatevalue</xsl:when>
+ <xsl:when test="$inName='ACDBHATCH_POLYLINE_AC4'">acdbhatch_polyline_acdbvertexdata_acdbvertexcoordinatevalue1</xsl:when>
+ <xsl:when test="$inName='ACDBHATCH_POLYLINE_AC3'">acdbhatch_polyline_acxdata</xsl:when>
+ <xsl:when test="$inName='ACDBVERTEXCOORDINATEV1'">acdbvertexcoordinatevalue</xsl:when>
+ <xsl:when test="$inName='ACDBVERTEXDATA_ACDBVE1'">acdbvertexdata_acdbvertexcoordinatevalue</xsl:when>
+ <xsl:when test="$inName='ACDBVERTEXDATA_ACDBVE2'">acdbvertexdata_acdbvertexcoordinatevalue1</xsl:when>
+ <xsl:when test="$inName='ELECTRICDEVICE_ENTITY1'">electricdevice_entity_acxdata</xsl:when>
+ <xsl:when test="$inName='ELECTRICDEVICE_MAINT_1'">electricdevice_maint_history</xsl:when>
+ <xsl:when test="$inName='ELECTRICDEVICE_MAINT_2'">electricdevice_maint_history_maint_history_item</xsl:when>
+ <xsl:when test="$inName='EMPLOYEE_A_ADDRESS_ST1'">employee_a_address_street</xsl:when>
+ <xsl:when test="$inName='POLYLINE_ACDBVERTEXDA1'">polyline_acdbvertexdata</xsl:when>
+ <xsl:when test="$inName='POLYLINE_ACDBVERTEXDA2'">polyline_acdbvertexdata_acdbvertexcoordinatevalue</xsl:when>
+ <xsl:when test="$inName='POLYLINE_ACDBVERTEXDA3'">polyline_acdbvertexdata_acdbvertexcoordinatevalue1</xsl:when>
+ <xsl:when test="$inName='MAINT_HISTORY_MAINT_H1'">maint_history_maint_history_item</xsl:when>
<xsl:when test="$inName='OVCLASSC111_OPC_TABLE1'">ovclassc111_opc_table_hd</xsl:when>
<xsl:when test="$inName='OVCLASSC111_OPC_TABLE2'">ovclassc111_opc_table_hd_opc_table_hda</xsl:when>
<xsl:when test="$inName='OVCLASSC111_OPS_TABLE1'">ovclassc111_ops_table_ha</xsl:when>
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt 2007-02-01 18:14:55 UTC (rev 725)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt 2007-02-02 16:07:20 UTC (rev 726)
@@ -14,7 +14,7 @@
</xsl:template>
<xsl:template match="lp:column[@dataType and not(@name = 'classname' or @name = 'schemaname' or @name = 'CLASSNAME' or @name = 'SCHEMANAME')]">
<xsl:variable name="colName" select="@name"/>
- <xsl:if test="local-name(..)='property' or ../../lp:properties/lp:property[@columnName=$colName or translate(@name,'abcdefghijklmnopqrstuvwxyz','ABCDEFGHIJKLMNOPQRSTUVWXYZ')=substring-before($colName,'_SI_1') or translate(@name,'abcdefghijklmnopqrstuvwxyz','ABCDEFGHIJKLMNOPQRSTUVWXYZ')=substring-before($colName,'_SI_2')]">
+ <xsl:if test="local-name(..)='property' or ../../lp:properties/lp:property[@columnName=$colName or contains($colName,'_SI_1') or contains($colName,'_SI_2')]">
<xsl:value-of select="@name"/>
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt 2007-02-01 18:14:55 UTC (rev 725)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt 2007-02-02 16:07:20 UTC (rev 726)
@@ -78,7 +78,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDb3dPolyline.vertices" description="Autogenerated Object Property Class"
baseClass="" abstract="False"
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA" tblCreator="True" fixedTbl="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE1" tblCreator="True" fixedTbl="False" >
<tableMapping>Concrete</tableMapping>
<identityProperties>
<property xsi:type="Data" name="AcDb3dPolyline_FeatId" />
@@ -88,7 +88,7 @@
<property xsi:type="Data" name="Seq" description="seq"
dataType="int32" length="0" precision="0" scale="0"
readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue=""
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE1" columnName="SEQ" colCreator="True" fixedCol="False" >
<column name="SEQ" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
</column>
</property>
@@ -109,7 +109,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDb3dPolyline.vertices.point" description="Autogenerated Object Property Class"
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" tblCreator="True" fixedTbl="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE2" tblCreator="True" fixedTbl="False" >
@@ -120,29 +120,29 @@
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE2" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
<property xsi:type="Data" name="Value" description=""
dataType="double" length="0" precision="0" scale="0"
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE2" columnName="VALUE1" colCreator="True" fixedCol="False" >
<column name="VALUE1" description="" dataType="NUMBER" length="0" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="AcDb3dPolyline_FeatId" description="Feature id number (uniquely identifies a feature)"
dataType="int64" length="0" precision="0" scale="0"
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" columnName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" colCreator="True" fixedCol="False" >
-<column name="ACDB3DPOLYLINE_ACDBVERTEXDATA1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE2" columnName="ACDB3DPOLYLINE_ACDBVE1_ACDB1" colCreator="True" fixedCol="False" >
+<column name="ACDB3DPOLYLINE_ACDBVE1_ACDB1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="AcDbVertexData_Seq" description="seq"
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" columnName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" colCreator="True" fixedCol="False" >
-<column name="ACDB3DPOLYLINE_ACDBVERTEXDATA2" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE2" columnName="ACDB3DPOLYLINE_ACDBVE1_SEQ" colCreator="True" fixedCol="False" >
+<column name="ACDB3DPOLYLINE_ACDBVE1_SEQ" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="ClassName" description="FDO base property: object class name"
@@ -162,9 +162,9 @@
</column>
</property>
</properties>
-<table name="ACDB3DPOLYLINE_ACDBVERTEXDATA1" description="" pkeyName="PK_ACDB3DPOLYLINE_ACDBVERTEXD1" >
+<table name="ACDB3DPOLYLINE_ACDBVE2" description="" pkeyName="PK_ACDB3DPOLYLINE_ACD1" >
<target>
-<table name="ACDB3DPOLYLINE_ACDBVERTEXDATA" description="" pkeyName="PK_ACDB3DPOLYLINE_ACDBVERTEXD2" >
+<table name="ACDB3DPOLYLINE_ACDBVE1" description="" pkeyName="PK_ACDB3DPOLYLINE_ACD2" >
<target>
<table name="ACDB3DPOLYLINE" description="" pkeyName="PK_ACDB3DPOLYLINE" >
</table>
@@ -177,8 +177,8 @@
</target>
</table>
<sourceColumns>
-<column name="ACDB3DPOLYLINE_ACDBVERTEXDATA1" />
-<column name="ACDB3DPOLYLINE_ACDBVERTEXDATA2" />
+<column name="ACDB3DPOLYLINE_ACDBVE1_ACDB1" />
+<column name="ACDB3DPOLYLINE_ACDBVE1_SEQ" />
</sourceColumns>
<targetColumns>
<column name="ACDB3DPOLYLINE_FEATID" />
@@ -193,15 +193,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -214,8 +214,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -232,7 +232,7 @@
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA" columnName="ACDB3DPOLYLINE_FEATID" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE1" columnName="ACDB3DPOLYLINE_FEATID" colCreator="True" fixedCol="False" >
<column name="ACDB3DPOLYLINE_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
@@ -253,7 +253,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -276,7 +276,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -789,7 +789,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDbHatch.edges.vertices" description="Autogenerated Object Property Class"
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX1" tblCreator="True" fixedTbl="False" >
+ tableName="ACDBHATCH_POLYLINE_AC1" tblCreator="True" fixedTbl="False" >
<property xsi:type="Data" name="Polyline_FeatId" />
@@ -799,7 +799,7 @@
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX1" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC1" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -820,7 +820,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDbHatch.edges.vertices.point" description="Autogenerated Object Property Class"
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX2" tblCreator="True" fixedTbl="False" >
+ tableName="ACDBHATCH_POLYLINE_AC2" tblCreator="True" fixedTbl="False" >
@@ -831,29 +831,29 @@
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX2" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC2" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX2" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC2" columnName="VALUE1" colCreator="True" fixedCol="False" >
</column>
</property>
<property xsi:type="Data" name="Polyline_FeatId" description="id"
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX2" columnName="ACDBHATCH_POLYLINE_ACDBVERTEX1" colCreator="True" fixedCol="False" >
-<column name="ACDBHATCH_POLYLINE_ACDBVERTEX1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+ tableName="ACDBHATCH_POLYLINE_AC2" columnName="ACDBHATCH_POLYLINE_AC1_ACDB1" colCreator="True" fixedCol="False" >
+<column name="ACDBHATCH_POLYLINE_AC1_ACDB1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX2" columnName="ACDBHATCH_POLYLINE_ACDBVERTEX2" colCreator="True" fixedCol="False" >
-<column name="ACDBHATCH_POLYLINE_ACDBVERTEX2" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
+ tableName="ACDBHATCH_POLYLINE_AC2" columnName="ACDBHATCH_POLYLINE_AC1_SEQ" colCreator="True" fixedCol="False" >
+<column name="ACDBHATCH_POLYLINE_AC1_SEQ" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
</column>
</property>
@@ -873,9 +873,9 @@
</column>
</property>
</properties>
-<table name="ACDBHATCH_POLYLINE_ACDBVERTEX2" description="" pkeyName="PK_ACDBHATCH_POLYLINE_ACDBVER1" >
+<table name="ACDBHATCH_POLYLINE_AC2" description="" pkeyName="PK_ACDBHATCH_POLYLINE2" >
<target>
-<table name="ACDBHATCH_POLYLINE_ACDBVERTEX1" description="" pkeyName="PK_ACDBHATCH_POLYLINE_ACDBVER2" >
+<table name="ACDBHATCH_POLYLINE_AC1" description="" pkeyName="PK_ACDBHATCH_POLYLINE3" >
<target>
<table name="ACDBHATCH_POLYLINE" description="" pkeyName="PK_ACDBHATCH_POLYLINE" >
<target>
@@ -898,8 +898,8 @@
</target>
</table>
<sourceColumns>
-<column name="ACDBHATCH_POLYLINE_ACDBVERTEX1" />
-<column name="ACDBHATCH_POLYLINE_ACDBVERTEX2" />
+<column name="ACDBHATCH_POLYLINE_AC1_ACDB1" />
+<column name="ACDBHATCH_POLYLINE_AC1_SEQ" />
</sourceColumns>
<targetColumns>
<column name="ACDBHATCH_POLYLINE_FEATID" />
@@ -914,15 +914,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
<target>
@@ -945,8 +945,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -963,7 +963,7 @@
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX1" columnName="ACDBHATCH_POLYLINE_FEATID" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC1" columnName="ACDBHATCH_POLYLINE_FEATID" colCreator="True" fixedCol="False" >
<column name="ACDBHATCH_POLYLINE_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
@@ -984,7 +984,7 @@
</column>
</property>
</properties>
<target>
<target>
@@ -1017,7 +1017,7 @@
</column>
</table>
<tables>
<target>
<target>
@@ -1060,7 +1060,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDbHatch.edges.xdata" description="Autogenerated Object Property Class"
- tableName="ACDBHATCH_POLYLINE_ACXDATA" tblCreator="True" fixedTbl="False" >
+ tableName="ACDBHATCH_POLYLINE_AC3" tblCreator="True" fixedTbl="False" >
@@ -1070,21 +1070,21 @@
<property xsi:type="Data" name="Datavalue" description="datavalue"
dataType="string" length="4000" precision="0" scale="0"
- tableName="ACDBHATCH_POLYLINE_ACXDATA" columnName="DATAVALUE" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC3" columnName="DATAVALUE" colCreator="True" fixedCol="False" >
<column name="DATAVALUE" description="" dataType="VARCHAR2" length="4000" scale="0" nullable="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACXDATA" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC3" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACXDATA" columnName="ACDBHATCH_POLYLINE_FEATID" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC3" columnName="ACDBHATCH_POLYLINE_FEATID" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -1105,7 +1105,7 @@
</column>
</property>
</properties>
-<table name="ACDBHATCH_POLYLINE_ACXDATA" description="" pkeyName="PK_ACDBHATCH_POLYLINE_ACXDATA" >
+<table name="ACDBHATCH_POLYLINE_AC3" description="" pkeyName="PK_ACDBHATCH_POLYLINE1" >
<target>
<target>
@@ -1137,7 +1137,7 @@
</column>
</table>
<tables>
<target>
<target>
@@ -1416,7 +1416,7 @@
</class>
<class xsi:type="Class" name="AcDbVertexCoordinateValue" description=""
- tableName="ACDBVERTEXCOORDINATEVALUE" tblCreator="False" fixedTbl="False" >
+ tableName="ACDBVERTEXCOORDINATEV1" tblCreator="False" fixedTbl="False" >
</identityProperties>
@@ -1424,12 +1424,12 @@
- tableName="ACDBVERTEXCOORDINATEVALUE" columnName="SEQ" colCreator="False" fixedCol="False" >
+ tableName="ACDBVERTEXCOORDINATEV1" columnName="SEQ" colCreator="False" fixedCol="False" >
</property>
- tableName="ACDBVERTEXCOORDINATEVALUE" columnName="VALUE1" colCreator="False" fixedCol="False" >
+ tableName="ACDBVERTEXCOORDINATEV1" columnName="VALUE1" colCreator="False" fixedCol="False" >
</property>
dataType="string" length="30" precision="0" scale="0"
@@ -1474,7 +1474,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDbVertexData.point" description="Autogenerated Object Property Class"
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR1" tblCreator="False" fixedTbl="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE1" tblCreator="False" fixedTbl="False" >
<property xsi:type="Data" name="Seq" />
@@ -1483,12 +1483,12 @@
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR1" columnName="SEQ" colCreator="False" fixedCol="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE1" columnName="SEQ" colCreator="False" fixedCol="False" >
</property>
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR1" columnName="VALUE1" colCreator="False" fixedCol="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE1" columnName="VALUE1" colCreator="False" fixedCol="False" >
</property>
@@ -1792,7 +1792,7 @@
</targetProperties>
<class xsi:type="Class" name="Polyline.vertices" description="Autogenerated Object Property Class"
- tableName="POLYLINE_ACDBVERTEXDATA" tblCreator="True" fixedTbl="False" >
+ tableName="POLYLINE_ACDBVERTEXDA1" tblCreator="True" fixedTbl="False" >
@@ -1802,7 +1802,7 @@
- tableName="POLYLINE_ACDBVERTEXDATA" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA1" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -1823,7 +1823,7 @@
</targetProperties>
<class xsi:type="Class" name="Polyline.vertices.point" description="Autogenerated Object Property Class"
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV1" tblCreator="True" fixedTbl="False" >
+ tableName="POLYLINE_ACDBVERTEXDA2" tblCreator="True" fixedTbl="False" >
@@ -1834,29 +1834,29 @@
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV1" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA2" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV1" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA2" columnName="VALUE1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV1" columnName="POLYLINE_ACDBVERTEXDATA_POLYL1" colCreator="True" fixedCol="False" >
-<column name="POLYLINE_ACDBVERTEXDATA_POLYL1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+ tableName="POLYLINE_ACDBVERTEXDA2" columnName="POLYLINE_ACDBVERTEXDA1_POLY1" colCreator="True" fixedCol="False" >
+<column name="POLYLINE_ACDBVERTEXDA1_POLY1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV1" columnName="POLYLINE_ACDBVERTEXDATA_SEQ" colCreator="True" fixedCol="False" >
-<column name="POLYLINE_ACDBVERTEXDATA_SEQ" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
+ tableName="POLYLINE_ACDBVERTEXDA2" columnName="POLYLINE_ACDBVERTEXDA1_SEQ" colCreator="True" fixedCol="False" >
+<column name="POLYLINE_ACDBVERTEXDA1_SEQ" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
</column>
</property>
@@ -1876,9 +1876,9 @@
</column>
</property>
</properties>
-<table name="POLYLINE_ACDBVERTEXDATA_ACDBV1" description="" pkeyName="PK_POLYLINE_ACDBVERTEXDATA_AC1" >
+<table name="POLYLINE_ACDBVERTEXDA2" description="" pkeyName="PK_POLYLINE_ACDBVERTE1" >
<target>
-<table name="POLYLINE_ACDBVERTEXDATA" description="" pkeyName="PK_POLYLINE_ACDBVERTEXDATA" >
+<table name="POLYLINE_ACDBVERTEXDA1" description="" pkeyName="PK_POLYLINE_ACDBVERTE2" >
<target>
<table name="POLYLINE" description="" pkeyName="PK_POLYLINE" >
</table>
@@ -1891,8 +1891,8 @@
</target>
</table>
<sourceColumns>
-<column name="POLYLINE_ACDBVERTEXDATA_POLYL1" />
-<column name="POLYLINE_ACDBVERTEXDATA_SEQ" />
+<column name="POLYLINE_ACDBVERTEXDA1_POLY1" />
+<column name="POLYLINE_ACDBVERTEXDA1_SEQ" />
</sourceColumns>
<targetColumns>
<column name="POLYLINE_FEATID" />
@@ -1907,15 +1907,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -1928,8 +1928,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -1946,7 +1946,7 @@
- tableName="POLYLINE_ACDBVERTEXDATA" columnName="POLYLINE_FEATID" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA1" columnName="POLYLINE_FEATID" colCreator="True" fixedCol="False" >
<column name="POLYLINE_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
@@ -1967,7 +1967,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -1990,7 +1990,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -2367,7 +2367,7 @@
</targetProperties>
<class xsi:type="Class" name="Conductor.graphic.xdata" description="Autogenerated Object Property Class"
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" tblCreator="False" fixedTbl="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" tblCreator="False" fixedTbl="False" >
<property xsi:type="Data" name="Entity_FeatId" />
@@ -2377,7 +2377,7 @@
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" columnName="DATAVALUE" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" columnName="DATAVALUE" colCreator="False" fixedCol="False" >
<Inherited baseClass="ElectricDevice.graphic.xdata" />
</column>
@@ -2385,7 +2385,7 @@
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" columnName="SEQ" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" columnName="SEQ" colCreator="False" fixedCol="False" >
</column>
@@ -2393,7 +2393,7 @@
<property xsi:type="Data" name="Entity_FeatId" description="id"
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" columnName="ELECTRICDEVICE_ENTITY_FEATID" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" columnName="ELECTRICDEVICE_ENTITY_FEATID" colCreator="False" fixedCol="False" >
<column name="ELECTRICDEVICE_ENTITY_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
@@ -2415,9 +2415,9 @@
</column>
</property>
</properties>
-<table name="ELECTRICDEVICE_ENTITY_ACXDATA" description="" pkeyName="PK_ELECTRICDEVICE_ENTITY_ACXD1" >
+<table name="ELECTRICDEVICE_ENTITY1" description="" pkeyName="PK_ELECTRICDEVICE_ENT1" >
<target>
-<table name="ELECTRICDEVICE_ENTITY" description="" pkeyName="PK_ELECTRICDEVICE_ENTITY" >
+<table name="ELECTRICDEVICE_ENTITY" description="" pkeyName="PK_ELECTRICDEVICE_ENT2" >
<target>
<table name="CONDUCTOR" description="" pkeyName="PK_CONDUCTOR" >
</table>
@@ -2447,9 +2447,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -2500,7 +2500,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -2529,7 +2529,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -2563,7 +2563,7 @@
</targetProperties>
<class xsi:type="Class" name="Conductor.maintenance history" description="Autogenerated Object Property Class"
- tableName="ELECTRICDEVICE_MAINT_HISTORY" tblCreator="False" fixedTbl="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" tblCreator="False" fixedTbl="False" >
<property xsi:type="Data" name="ElectricDevice_FeatId" />
@@ -2573,7 +2573,7 @@
<property xsi:type="Data" name="Date" description="Date of work done"
dataType="datetime" length="0" precision="0" scale="0"
- tableName="ELECTRICDEVICE_MAINT_HISTORY" columnName="DATE1" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" columnName="DATE1" colCreator="False" fixedCol="False" >
<Inherited baseClass="ElectricDevice.maintenance history" />
<column name="DATE1" description="" dataType="DATE" length="0" scale="0" nullable="False" >
</column>
@@ -2581,9 +2581,9 @@
<property xsi:type="Data" name="Maintenance History Description" description="datavalue"
dataType="string" length="50" precision="0" scale="0"
readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue=""
- tableName="ELECTRICDEVICE_MAINT_HISTORY" columnName="MAINTENANCE_HISTORY_DESCRIPTI1" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" columnName="MAINTENANCE_HISTORY_DESCRIP1" colCreator="False" fixedCol="False" >
-<column name="MAINTENANCE_HISTORY_DESCRIPTI1" description="" dataType="VARCHAR2" length="50" scale="0" nullable="True" >
+<column name="MAINTENANCE_HISTORY_DESCRIP1" description="" dataType="VARCHAR2" length="50" scale="0" nullable="True" >
</column>
</property>
<property xsi:type="Object" name="work items" description="tasks performed on this date"
@@ -2604,7 +2604,7 @@
</targetProperties>
<class xsi:type="Class" name="Conductor.maintenance history.work items" description="Autogenerated Object Property Class"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" tblCreator="False" fixedTbl="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" tblCreator="False" fixedTbl="False" >
@@ -2615,7 +2615,7 @@
<property xsi:type="Data" name="It'm #" description="sequence identifier"
dataType="int16" length="0" precision="0" scale="0"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="IT_M__" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="IT_M__" colCreator="False" fixedCol="False" >
<Inherited baseClass="ElectricDevice.maintenance history.work items" />
<column name="IT_M__" description="" dataType="NUMBER" length="5" scale="0" nullable="False" >
</column>
@@ -2623,7 +2623,7 @@
<property xsi:type="Data" name="Part #" description="Part used in work item"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="PART__" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="PART__" colCreator="False" fixedCol="False" >
<column name="PART__" description="" dataType="NUMBER" length="10" scale="0" nullable="True" >
</column>
@@ -2631,7 +2631,7 @@
<property xsi:type="Data" name="Work Description" description="Description of work performed"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="WORK_DESCRIPTION" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="WORK_DESCRIPTION" colCreator="False" fixedCol="False" >
<column name="WORK_DESCRIPTION" description="" dataType="VARCHAR2" length="4000" scale="0" nullable="False" >
</column>
@@ -2639,7 +2639,7 @@
<property xsi:type="Data" name="classname" description=""
dataType="string" length="255" precision="0" scale="0"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="CLASSNAME1" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="CLASSNAME1" colCreator="False" fixedCol="False" >
<column name="CLASSNAME1" description="" dataType="VARCHAR2" length="255" scale="0" nullable="True" >
</column>
@@ -2647,17 +2647,17 @@
<property xsi:type="Data" name="ElectricDevice_FeatId" description="Feature id number (uniquely identifies a feature)"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="ELECTRICDEVICE_MAINT_HISTORY_1" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="ELECTRICDEVICE_MAINT_1_ELEC1" colCreator="False" fixedCol="False" >
-<column name="ELECTRICDEVICE_MAINT_HISTORY_1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+<column name="ELECTRICDEVICE_MAINT_1_ELEC1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="Maint History_Date" description="Date of work done"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="ELECTRICDEVICE_MAINT_HISTORY_2" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="ELECTRICDEVICE_MAINT_1_DATE1" colCreator="False" fixedCol="False" >
-<column name="ELECTRICDEVICE_MAINT_HISTORY_2" description="" dataType="DATE" length="0" scale="0" nullable="False" >
+<column name="ELECTRICDEVICE_MAINT_1_DATE1" description="" dataType="DATE" length="0" scale="0" nullable="False" >
</column>
</property>
@@ -2677,9 +2677,9 @@
</column>
</property>
</properties>
-<table name="ELECTRICDEVICE_MAINT_HISTORY_1" description="" pkeyName="PK_ELECTRICDEVICE_MAINT_HISTO1" >
+<table name="ELECTRICDEVICE_MAINT_2" description="" pkeyName="PK_ELECTRICDEVICE_MAI1" >
<target>
-<table name="ELECTRICDEVICE_MAINT_HISTORY" description="" pkeyName="PK_ELECTRICDEVICE_MAINT_HISTO2" >
+<table name="ELECTRICDEVICE_MAINT_1" description="" pkeyName="PK_ELECTRICDEVICE_MAI2" >
<target>
</table>
@@ -2692,8 +2692,8 @@
</target>
</table>
<sourceColumns>
-<column name="ELECTRICDEVICE_MAINT_HISTORY_1" />
-<column name="ELECTRICDEVICE_MAINT_HISTORY_2" />
+<column name="ELECTRICDEVICE_MAINT_1_ELEC1" />
+<column name="ELECTRICDEVICE_MAINT_1_DATE1" />
</sourceColumns>
<targetColumns>
<column name="ELECTRICDEVICE_FEATID" />
@@ -2714,15 +2714,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -2735,8 +2735,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -2753,7 +2753,7 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY" columnName="ELECTRICDEVICE_FEATID" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" columnName="ELECTRICDEVICE_FEATID" colCreator="False" fixedCol="False" >
<column name="ELECTRICDEVICE_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
@@ -2775,7 +2775,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -2795,13 +2795,13 @@
</column>
</column>
</column>
</table>
<tables>
<target>
</table>
@@ -3075,7 +3075,7 @@
</column>
</property>
</properties>
-<table name="CUSTOMER___RESIDENTIAL" description="" pkeyName="PK_CUSTOMER___RESIDENTIAL" >
+<table name="CUSTOMER___RESIDENTIAL" description="" pkeyName="PK_CUSTOMER___RESIDEN1" >
<property xsi:type="Data" name="Credit Rating" />
<property xsi:type="Data" name="First Name" />
<property xsi:type="Data" name="Last Name" />
@@ -3087,7 +3087,7 @@
</column>
</table>
<tables>
</table>
<table name="F_CLASSDEFINITION" description="" pkeyName="" >
</table>
@@ -3206,7 +3206,7 @@
</targetProperties>
<class xsi:type="Class" name="ElectricDevice.graphic.xdata" description="Autogenerated Object Property Class"
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" tblCreator="True" fixedTbl="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" tblCreator="True" fixedTbl="False" >
@@ -3216,21 +3216,21 @@
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" columnName="DATAVALUE" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" columnName="DATAVALUE" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" columnName="ELECTRICDEVICE_ENTITY_FEATID" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" columnName="ELECTRICDEVICE_ENTITY_FEATID" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -3251,9 +3251,9 @@
</column>
</property>
</properties>
<target>
<target>
<table name="ELECTRICDEVICE" description="" pkeyName="PK_ELECTRICDEVICE" >
</table>
@@ -3283,9 +3283,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -3335,7 +3335,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -3364,7 +3364,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -3397,7 +3397,7 @@
</targetProperties>
<class xsi:type="Class" name="ElectricDevice.maintenance history" description="Autogenerated Object Property Class"
- tableName="ELECTRICDEVICE_MAINT_HISTORY" tblCreator="True" fixedTbl="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" tblCreator="True" fixedTbl="False" >
@@ -3407,15 +3407,15 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY" columnName="DATE1" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" columnName="DATE1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_MAINT_HISTORY" columnName="MAINTENANCE_HISTORY_DESCRIPTI1" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" columnName="MAINTENANCE_HISTORY_DESCRIP1" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -3435,7 +3435,7 @@
</targetProperties>
<class xsi:type="Class" name="ElectricDevice.maintenance history.work items" description="Autogenerated Object Property Class"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" tblCreator="True" fixedTbl="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" tblCreator="True" fixedTbl="False" >
@@ -3446,43 +3446,43 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="IT_M__" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="IT_M__" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="PART__" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="PART__" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="WORK_DESCRIPTION" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="WORK_DESCRIPTION" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="CLASSNAME1" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="CLASSNAME1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="ELECTRICDEVICE_MAINT_HISTORY_1" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="ELECTRICDEVICE_MAINT_1_ELEC1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="ELECTRICDEVICE_MAINT_HISTORY_2" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="ELECTRICDEVICE_MAINT_1_DATE1" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -3502,9 +3502,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -3517,8 +3517,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -3539,15 +3539,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -3560,8 +3560,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -3578,7 +3578,7 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY" columnName="ELECTRICDEVICE_FEATID" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" columnName="ELECTRICDEVICE_FEATID" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -3599,7 +3599,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -3619,13 +3619,13 @@
</column>
</column>
</column>
</table>
<tables>
<target>
</table>
@@ -3778,7 +3778,7 @@
</targetProperties>
<class xsi:type="Class" name="Employee.home' address.street" description="Autogenerated Object Property Class"
- tableName="EMPLOYEE_A_ADDRESS_STREET" tblCreator="True" fixedTbl="False" >
+ tableName="EMPLOYEE_A_ADDRESS_ST1" tblCreator="True" fixedTbl="False" >
<property xsi:type="Data" name="Employee_First Name" />
@@ -3788,29 +3788,29 @@
<property xsi:type="Data" name="Name" description=""
- tableName="EMPLOYEE_A_ADDRESS_STREET" columnName="NAME" colCreator="True" fixedCol="False" >
+ tableName="EMPLOYEE_A_ADDRESS_ST1" columnName="NAME" colCreator="True" fixedCol="False" >
<column name="NAME" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="Type" description=""
- tableName="EMPLOYEE_A_ADDRESS_STREET" columnName="TYPE" colCreator="True" fixedCol="False" >
+ tableName="EMPLOYEE_A_ADDRESS_ST1" columnName="TYPE" colCreator="True" fixedCol="False" >
<column name="TYPE" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="Employee_First Name" description=""
- tableName="EMPLOYEE_A_ADDRESS_STREET" columnName="EMPLOYEE_A_ADDRESS_EMPLOYEE_F1" colCreator="True" fixedCol="False" >
-<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE_F1" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
+ tableName="EMPLOYEE_A_ADDRESS_ST1" columnName="EMPLOYEE_A_ADDRESS_EMPLOYEE1" colCreator="True" fixedCol="False" >
+<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE1" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="Employee_Last Name" description=""
- tableName="EMPLOYEE_A_ADDRESS_STREET" columnName="EMPLOYEE_A_ADDRESS_EMPLOYEE_L1" colCreator="True" fixedCol="False" >
-<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE_L1" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
+ tableName="EMPLOYEE_A_ADDRESS_ST1" columnName="EMPLOYEE_A_ADDRESS_EMPLOYEE2" colCreator="True" fixedCol="False" >
+<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE2" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
</column>
</property>
@@ -3830,7 +3830,7 @@
</column>
</property>
</properties>
-<table name="EMPLOYEE_A_ADDRESS_STREET" description="" pkeyName="PK_EMPLOYEE_A_ADDRESS_STREET" >
+<table name="EMPLOYEE_A_ADDRESS_ST1" description="" pkeyName="PK_EMPLOYEE_A_ADDRESS1" >
<target>
<table name="EMPLOYEE_A_ADDRESS" description="" pkeyName="PK_EMPLOYEE_A_ADDRESS" >
<target>
@@ -3847,8 +3847,8 @@
</target>
</table>
<sourceColumns>
-<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE_F1" />
-<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE_L1" />
+<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE1" />
+<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE2" />
</sourceColumns>
<targetColumns>
<column name="EMPLOYEE_FIRST_NAME" />
@@ -3863,13 +3863,13 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
@@ -3886,8 +3886,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -4031,7 +4031,7 @@
- tableName="MAINT_HISTORY" columnName="MAINTENANCE_HISTORY_DESCRIPTI1" colCreator="False" fixedCol="False" >
+ tableName="MAINT_HISTORY" columnName="MAINTENANCE_HISTORY_DESCRIP1" colCreator="False" fixedCol="False" >
</property>
objectType="Ordered Collection" className="Electric'l:Maint History Item" idColumn="IT_M__" order="descending"
@@ -4046,7 +4046,7 @@
</targetProperties>
<class xsi:type="Class" name="Maint History.work items" description="Autogenerated Object Property Class"
- tableName="MAINT_HISTORY_MAINT_HISTORY_I1" tblCreator="False" fixedTbl="False" >
+ tableName="MAINT_HISTORY_MAINT_H1" tblCreator="False" fixedTbl="False" >
<property xsi:type="Data" name="It'm #" />
@@ -4055,22 +4055,22 @@
- tableName="MAINT_HISTORY_MAINT_HISTORY_I1" columnName="IT_M__" colCreator="False" fixedCol="False" >
+ tableName="MAINT_HISTORY_MAINT_H1" columnName="IT_M__" colCreator="False" fixedCol="False" >
</property>
- tableName="MAINT_HISTORY_MAINT_HISTORY_I1" columnName="PART__" colCreator="False" fixedCol="False" >
+ tableName="MAINT_HISTORY_MAINT_H1" columnName="PART__" colCreator="False" fixedCol="False" >
</property>
- tableName="MAINT_HISTORY_MAINT_HISTORY_I1" columnName="WORK_DESCRIPTION" colCreator="False" fixedCol="False" >
+ tableName="MAINT_HISTORY_MAINT_H1" columnName="WORK_DESCRIPTION" colCreator="False" fixedCol="False" >
</property>
- tableName="MAINT_HISTORY_MAINT_HISTORY_I1" columnName="CLASSNAME1" colCreator="False" fixedCol="False" >
+ tableName="MAINT_HISTORY_MAINT_H1" columnName="CLASSNAME1" colCreator="False" fixedCol="False" >
</property>
@@ -4453,7 +4453,7 @@
</targetProperties>
<class xsi:type="Class" name="Transformer.graphic.xdata" description="Autogenerated Object Property Class"
@@ -4463,7 +4463,7 @@
</column>
@@ -4471,7 +4471,7 @@
</column>
@@ -4479,7 +4479,7 @@
</column>
@@ -4501,9 +4501,9 @@
</column>
</property>
</properties>
<target>
<target>
<table name="TRANSFORMER" description="" pkeyName="PK_TRANSFORMER" >
</table>
@@ -4533,9 +4533,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -4586,7 +4586,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -4615,7 +4615,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -4649,7 +4649,7 @@
</targetProperties>
<class xsi:type="Class" name="Transformer.maintenance history" description="Autogenerated Object Property Class"
@@ -4659,7 +4659,7 @@
</column>
@@ -4667,9 +4667,9 @@
</column>
</property>
@@ -4690,7 +4690,7 @@
</targetProperties>
<class xsi:type="Class" name="Transformer.maintenance history.work items" description="Autogenerated Object Property Class"
@@ -4701,7 +4701,7 @@
</column>
@@ -4709,7 +4709,7 @@
</column>
@@ -4717,7 +4717,7 @@
</column>
@@ -4725,7 +4725,7 @@
</column>
@@ -4733,17 +4733,17 @@
</column>
</property>
</column>
</property>
@@ -4763,9 +4763,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -4778,8 +4778,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -4800,15 +4800,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -4821,8 +4821,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -4839,7 +4839,7 @@
</column>
@@ -4861,7 +4861,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -4881,13 +4881,13 @@
</column>
</column>
</column>
</table>
<tables>
<target>
</table>
@@ -6109,6 +6109,11 @@
</column>
</property>
</properties>
+<uniqueConstraints>
+<uniqueConstraint>
+<property xsi:type="Data" name="PolyNum" />
+</uniqueConstraint>
+</uniqueConstraints>
<table name="ZONING" description="" pkeyName="PK_ZONING" >
<property xsi:type="Data" name="Authority" />
<property xsi:type="Data" name="ByLaw" />
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt 2007-02-01 18:14:55 UTC (rev 725)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt 2007-02-02 16:07:20 UTC (rev 726)
@@ -78,7 +78,7 @@
</targetProperties>
@@ -88,7 +88,7 @@
</column>
</property>
@@ -109,7 +109,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDb3dPolyline.vertices.normal" description="Autogenerated Object Property Class"
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" tblCreator="True" fixedTbl="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE3" tblCreator="True" fixedTbl="False" >
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE3" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE3" columnName="VALUE1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" columnName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE3" columnName="ACDB3DPOLYLINE_ACDBVE1_ACDB1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" columnName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE3" columnName="ACDB3DPOLYLINE_ACDBVE1_SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -162,9 +162,9 @@
</column>
</property>
</properties>
-<table name="ACDB3DPOLYLINE_ACDBVERTEXDATA2" description="" pkeyName="PK_ACDB3DPOLYLINE_ACDBVERTEXD3" >
+<table name="ACDB3DPOLYLINE_ACDBVE3" description="" pkeyName="PK_ACDB3DPOLYLINE_ACD3" >
<target>
<target>
</table>
@@ -177,8 +177,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -214,8 +214,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -246,7 +246,7 @@
</targetProperties>
@@ -257,29 +257,29 @@
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
@@ -299,9 +299,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -314,8 +314,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -330,15 +330,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -351,8 +351,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -369,7 +369,7 @@
</column>
</property>
@@ -390,7 +390,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -417,7 +417,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -930,7 +930,7 @@
</targetProperties>
@@ -940,7 +940,7 @@
</column>
</property>
@@ -961,7 +961,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDbHatch.edges.vertices.normal" description="Autogenerated Object Property Class"
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX3" tblCreator="True" fixedTbl="False" >
+ tableName="ACDBHATCH_POLYLINE_AC4" tblCreator="True" fixedTbl="False" >
@@ -972,29 +972,29 @@
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX3" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC4" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX3" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC4" columnName="VALUE1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX3" columnName="ACDBHATCH_POLYLINE_ACDBVERTEX1" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC4" columnName="ACDBHATCH_POLYLINE_AC1_ACDB1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX3" columnName="ACDBHATCH_POLYLINE_ACDBVERTEX2" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC4" columnName="ACDBHATCH_POLYLINE_AC1_SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -1014,9 +1014,9 @@
</column>
</property>
</properties>
-<table name="ACDBHATCH_POLYLINE_ACDBVERTEX3" description="" pkeyName="PK_ACDBHATCH_POLYLINE_ACDBVER3" >
+<table name="ACDBHATCH_POLYLINE_AC4" description="" pkeyName="PK_ACDBHATCH_POLYLINE4" >
<target>
<target>
<target>
@@ -1039,8 +1039,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -1055,15 +1055,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
<target>
@@ -1086,8 +1086,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -1118,7 +1118,7 @@
</targetProperties>
@@ -1129,29 +1129,29 @@
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
@@ -1171,9 +1171,9 @@
</column>
</property>
</properties>
<target>
<target>
<target>
@@ -1196,8 +1196,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -1212,15 +1212,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
<target>
@@ -1243,8 +1243,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -1261,7 +1261,7 @@
</column>
</property>
@@ -1282,7 +1282,7 @@
</column>
</property>
</properties>
<target>
<target>
@@ -1319,7 +1319,7 @@
</column>
</table>
<tables>
<target>
<target>
@@ -1362,7 +1362,7 @@
</targetProperties>
@@ -1372,21 +1372,21 @@
</column>
</property>
</column>
</property>
</column>
</property>
@@ -1407,7 +1407,7 @@
</column>
</property>
</properties>
<target>
<target>
@@ -1439,7 +1439,7 @@
</column>
</table>
<tables>
<target>
<target>
@@ -1718,7 +1718,7 @@
</class>
@@ -1726,12 +1726,12 @@
</property>
</property>
@@ -1776,7 +1776,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDbVertexData.normal" description="Autogenerated Object Property Class"
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR2" tblCreator="False" fixedTbl="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE2" tblCreator="False" fixedTbl="False" >
@@ -1785,12 +1785,12 @@
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR2" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE2" columnName="SEQ" colCreator="True" fixedCol="False" >
</property>
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR2" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE2" columnName="VALUE1" colCreator="True" fixedCol="False" >
</property>
@@ -1825,7 +1825,7 @@
</targetProperties>
@@ -1834,12 +1834,12 @@
</property>
</property>
@@ -2143,7 +2143,7 @@
</targetProperties>
@@ -2153,7 +2153,7 @@
</column>
</property>
@@ -2174,7 +2174,7 @@
</targetProperties>
<class xsi:type="Class" name="Polyline.vertices.normal" description="Autogenerated Object Property Class"
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV2" tblCreator="True" fixedTbl="False" >
+ tableName="POLYLINE_ACDBVERTEXDA3" tblCreator="True" fixedTbl="False" >
@@ -2185,29 +2185,29 @@
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV2" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA3" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV2" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA3" columnName="VALUE1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV2" columnName="POLYLINE_ACDBVERTEXDATA_POLYL1" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA3" columnName="POLYLINE_ACDBVERTEXDA1_POLY1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV2" columnName="POLYLINE_ACDBVERTEXDATA_SEQ" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA3" columnName="POLYLINE_ACDBVERTEXDA1_SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -2227,9 +2227,9 @@
</column>
</property>
</properties>
-<table name="POLYLINE_ACDBVERTEXDATA_ACDBV2" description="" pkeyName="PK_POLYLINE_ACDBVERTEXDATA_AC2" >
+<table name="POLYLINE_ACDBVERTEXDA3" description="" pkeyName="PK_POLYLINE_ACDBVERTE3" >
<target>
<target>
</table>
@@ -2242,8 +2242,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -2258,15 +2258,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -2279,8 +2279,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -2311,7 +2311,7 @@
</targetProperties>
@@ -2322,29 +2322,29 @@
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
@@ -2364,9 +2364,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -2379,8 +2379,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -2395,15 +2395,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -2416,8 +2416,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -2434,7 +2434,7 @@
</column>
</property>
@@ -2455,7 +2455,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -2482,7 +2482,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -2837,7 +2837,7 @@
</targetProperties>
@@ -2847,7 +2847,7 @@
</column>
@@ -2855,7 +2855,7 @@
</column>
@@ -2863,7 +2863,7 @@
</column>
@@ -2885,9 +2885,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -2917,9 +2917,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -2970,7 +2970,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -2999,7 +2999,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -3266,7 +3266,7 @@
</column>
</property>
</properties>
@@ -3278,7 +3278,7 @@
</column>
</table>
<tables>
</table>
</table>
@@ -3390,7 +3390,7 @@
</targetProperties>
@@ -3400,21 +3400,21 @@
</column>
</property>
</column>
</property>
</column>
</property>
@@ -3435,9 +3435,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -3467,9 +3467,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -3519,7 +3519,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -3548,7 +3548,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -3644,7 +3644,7 @@
</property>
@@ -3659,7 +3659,7 @@
</targetProperties>
@@ -3668,22 +3668,22 @@
</property>
</property>
</property>
</property>
@@ -3923,7 +3923,7 @@
</targetProperties>
@@ -3933,7 +3933,7 @@
</column>
@@ -3941,7 +3941,7 @@
</column>
@@ -3949,7 +3949,7 @@
</column>
@@ -3971,9 +3971,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -4003,9 +4003,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -4056,7 +4056,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -4085,7 +4085,7 @@
</column>
</table>
<tables>
<target>
</table>
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt 2007-02-01 18:14:55 UTC (rev 725)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt 2007-02-02 16:07:20 UTC (rev 726)
@@ -78,7 +78,7 @@
</targetProperties>
@@ -88,7 +88,7 @@
</column>
</property>
@@ -109,7 +109,7 @@
</targetProperties>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
@@ -162,9 +162,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -177,8 +177,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -214,8 +214,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -246,7 +246,7 @@
</targetProperties>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
@@ -299,9 +299,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -314,8 +314,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -351,8 +351,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -369,7 +369,7 @@
</column>
</property>
@@ -390,7 +390,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -417,7 +417,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -930,7 +930,7 @@
</targetProperties>
@@ -940,7 +940,7 @@
</column>
</property>
@@ -961,7 +961,7 @@
</targetProperties>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</properties>
<target>
<target>
<target>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
<target>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetProperties>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</properties>
<target>
<target>
<target>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
<target>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</property>
</column>
</property>
</properties>
<target>
<target>
</column>
</table>
<tables>
<target>
<target>
</targetProperties>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</properties>
<target>
<target>
</column>
</table>
<tables>
<target>
<target>
</class>
</property>
</property>
</targetProperties>
</property>
</property>
</targetProperties>
</property>
</property>
</targetProperties>
</column>
</property>
</targetProperties>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</properties>
<target>
<target>
</table>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetProperties>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</properties>
<target>
<target>
</table>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</property>
</column>
</property>
</properties>
<target>
</table>
</column>
</table>
<tables>
<target>
</table>
</targetProperties>
</column>
</column>
</column>
</column>
</property>
</properties>
<target>
<target>
</table>
</column>
</table>
<tables>
<target>
<target>
</table>
</column>
</property>
</properties>
<target>
</table>
</column>
</table>
<tables>
<target>
</table>
@@ -3033,7 +3033,7 @@
</targetProperties>
@@ -3043,7 +3043,7 @@
</column>
@@ -3051,9 +3051,9 @@
</column>
</property>
@@ -3074,7 +3074,7 @@
</targetProperties>
@@ -3085,7 +3085,7 @@
</column>
@@ -3093,7 +3093,7 @@
</column>
@@ -3101,7 +3101,7 @@
</column>
@@ -3109,7 +3109,7 @@
</column>
@@ -3117,17 +3117,17 @@
</column>
</property>
</column>
</property>
@@ -3147,9 +3147,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -3162,8 +3162,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -3184,15 +3184,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -3205,8 +3205,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -3223,7 +3223,7 @@
</column>
@@ -3245,7 +3245,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -3265,13 +3265,13 @@
</column>
</column>
</column>
</table>
<tables>
<target>
</table>
@@ -3542,7 +3542,7 @@
</column>
</property>
</properties>
@@ -3554,7 +3554,7 @@
</column>
</table>
<tables>
</table>
</table>
@@ -3666,7 +3666,7 @@
</targetProperties>
@@ -3676,21 +3676,21 @@
</column>
</property>
</column>
</property>
</column>
</property>
@@ -3711,9 +3711,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -3743,9 +3743,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -3795,7 +3795,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -3824,7 +3824,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -3857,7 +3857,7 @@
</targetProperties>
@@ -3867,15 +3867,15 @@
</column>
</property>
</column>
</property>
@@ -3895,7 +3895,7 @@
</targetProperties>
@@ -3906,43 +3906,43 @@
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
@@ -3962,9 +3962,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -3977,8 +3977,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -3999,15 +3999,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -4020,8 +4020,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -4038,7 +4038,7 @@
</column>
</property>
@@ -4059,7 +4059,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -4079,13 +4079,13 @@
</column>
</column>
</column>
</table>
<tables>
<target>
</table>
@@ -4185,7 +4185,7 @@
</property>
@@ -4200,7 +4200,7 @@
</targetProperties>
@@ -4209,22 +4209,22 @@
</property>
</property>
</property>
</property>
@@ -4603,7 +4603,7 @@
</targetProperties>
@@ -4613,7 +4613,7 @@
</column>
@@ -4621,7 +4621,7 @@
</column>
@@ -4629,7 +4629,7 @@
</column>
@@ -4651,9 +4651,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -4683,9 +4683,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -4736,7 +4736,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -4765,7 +4765,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -4799,7 +4799,7 @@
</targetProperties>
@@ -4809,7 +4809,7 @@
</column>
@@ -4817,9 +4817,9 @@
</column>
</property>
@@ -4840,7 +4840,7 @@
</targetProperties>
@@ -4851,7 +4851,7 @@
</column>
@@ -4859,7 +4859,7 @@
</column>
@@ -4867,7 +4867,7 @@
</column>
@@ -4875,7 +4875,7 @@
</column>
@@ -4883,17 +4883,17 @@
</column>
</property>
</column>
</property>
@@ -4913,9 +4913,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -4928,8 +4928,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -4950,15 +4950,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -4971,8 +4971,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -4989,7 +4989,7 @@
</column>
@@ -5011,7 +5011,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -5031,13 +5031,13 @@
</column>
</column>
</column>
</table>
<tables>
<target>
</table>
@@ -6260,6 +6260,11 @@
</column>
</property>
</properties>
+<uniqueConstraint>
@@ -6304,7 +6309,7 @@
<schema name="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" >
<class xsi:type="Feature" name="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789"
- tableName="ABCDEF1234567890ABCDEF12345671" tblCreator="True" fixedTbl="False" >
+ tableName="ABCDEF1234567890ABCDE1" tblCreator="True" fixedTbl="False" >
<geometryProperty>gbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789</geometryProperty>
@@ -6314,7 +6319,7 @@
<property xsi:type="Data" name="ClassId" description="Class id number (uniquely identifies a class)"
readOnly="True" featId="False" system="True" nullable="False" autogenerated="True" defaultValue=""
- tableName="ABCDEF1234567890ABCDEF12345671" columnName="CLASSID" colCreator="True" fixedCol="True" >
+ tableName="ABCDEF1234567890ABCDE1" columnName="CLASSID" colCreator="True" fixedCol="True" >
<Inherited baseClass="Feature" />
<column name="CLASSID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
@@ -6322,7 +6327,7 @@
<property xsi:type="Data" name="FeatId" description="Feature id number (uniquely identifies a feature)"
readOnly="True" featId="True" system="True" nullable="False" autogenerated="True" defaultValue=""
- tableName="ABCDEF1234567890ABCDEF12345671" columnName="FEATID" colCreator="True" fixedCol="True" >
+ tableName="ABCDEF1234567890ABCDE1" columnName="FEATID" colCreator="True" fixedCol="True" >
<column name="FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
@@ -6330,7 +6335,7 @@
<property xsi:type="Data" name="RevisionNumber" description="Edit count for supporting optimistic locking. This value is incremented everytime the object is updated."
- tableName="ABCDEF1234567890ABCDEF12345671" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True" >
+ tableName="ABCDEF1234567890ABCDE1" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True" >
<column name="REVISIONNUMBER" description="" dataType="NUMBER" length="0" scale="0" nullable="False" >
</column>
@@ -6338,8 +6343,8 @@
<property xsi:type="Data" name="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789"
- tableName="ABCDEF1234567890ABCDEF12345671" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="True" fixedCol="False" >
-<column name="ABCDEF1234567890ABCDEF12345671" description="" dataType="VARCHAR2" length="50" scale="0" nullable="False" >
+ tableName="ABCDEF1234567890ABCDE1" columnName="ABCDEF1234567890ABCDEF123451" colCreator="True" fixedCol="False" >
+<column name="ABCDEF1234567890ABCDEF123451" description="" dataType="VARCHAR2" length="50" scale="0" nullable="False" >
</column>
<SAD>
<element name="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" value="12345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012the-end" />
@@ -6357,7 +6362,7 @@
</targetProperties>
<class xsi:type="Class" name="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456788" description="Autogenerated Object Property Class"
baseClass="" abstract="False"
- tableName="ABCDEF1234567890ABCDEF12345674" tblCreator="True" fixedTbl="False" >
+ tableName="ABCDEF1234567890ABCDE4" tblCreator="True" fixedTbl="False" >
<tableMapping>Concrete</tableMapping>
<identityProperties>
<property xsi:type="Data" name="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789_abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" />
@@ -6366,8 +6371,8 @@
readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue=""
- tableName="ABCDEF1234567890ABCDEF12345674" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="True" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE4" columnName="ABCDEF1234567890ABCDEF123451" colCreator="True" fixedCol="False" >
</column>
</property>
<property xsi:type="Object" name="cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789"
@@ -6382,7 +6387,7 @@
</targetProperties>
<class xsi:type="Class" name="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456788.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="Autogenerated Object Property Class"
- tableName="ABCDEF1234567890ABCDEF12345675" tblCreator="True" fixedTbl="False" >
+ tableName="ABCDEF1234567890ABCDE5" tblCreator="True" fixedTbl="False" >
@@ -6391,15 +6396,15 @@
- tableName="ABCDEF1234567890ABCDEF12345675" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="True" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE5" columnName="ABCDEF1234567890ABCDEF123451" colCreator="True" fixedCol="False" >
</column>
</property>
<property xsi:type="Data" name="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789_abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789"
- tableName="ABCDEF1234567890ABCDEF12345675" columnName="ABCDEF1234567890ABCDEF12345672" colCreator="True" fixedCol="False" >
-<column name="ABCDEF1234567890ABCDEF12345672" description="" dataType="VARCHAR2" length="50" scale="0" nullable="False" >
+ tableName="ABCDEF1234567890ABCDE5" columnName="ABCDEF1234567890ABCDE4_ABCD1" colCreator="True" fixedCol="False" >
+<column name="ABCDEF1234567890ABCDE4_ABCD1" description="" dataType="VARCHAR2" length="50" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="ClassName" description="FDO base property: object class name"
@@ -6419,54 +6424,54 @@
</column>
</property>
</properties>
-<table name="ABCDEF1234567890ABCDEF12345675" description="" pkeyName="PK_ABCDEF1234567890ABCDEF12341" >
+<table name="ABCDEF1234567890ABCDE5" description="" pkeyName="PK_ABCDEF1234567890AB1" >
<target>
-<table name="ABCDEF1234567890ABCDEF12345674" description="" pkeyName="PK_ABCDEF1234567890ABCDEF12342" >
+<table name="ABCDEF1234567890ABCDE4" description="" pkeyName="PK_ABCDEF1234567890AB2" >
<target>
-<table name="ABCDEF1234567890ABCDEF12345671" description="" pkeyName="PK_ABCDEF1234567890ABCDEF12345" >
+<table name="ABCDEF1234567890ABCDE1" description="" pkeyName="PK_ABCDEF1234567890AB5" >
</table>
<sourceColumns>
-<column name="ABCDEF1234567890ABCDEF12345672" />
+<column name="ABCDEF1234567890ABCDE1_ABCD1" />
</sourceColumns>
<targetColumns>
-<column name="ABCDEF1234567890ABCDEF12345671" />
+<column name="ABCDEF1234567890ABCDEF123451" />
</targetColumns>
</target>
</table>
<sourceColumns>
+<column name="ABCDEF1234567890ABCDE4_ABCD1" />
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
<property xsi:type="Data" name="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" />
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -6479,8 +6484,8 @@
- tableName="ABCDEF1234567890ABCDEF12345674" columnName="ABCDEF1234567890ABCDEF12345672" colCreator="True" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE4" columnName="ABCDEF1234567890ABCDE1_ABCD1" colCreator="True" fixedCol="False" >
+<column name="ABCDEF1234567890ABCDE1_ABCD1" description="" dataType="VARCHAR2" length="50" scale="0" nullable="False" >
</column>
</property>
@@ -6500,15 +6505,15 @@
</column>
</property>
</properties>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
@@ -6517,21 +6522,21 @@
fixedCol="False" >
</property>
</column>
</column>
</table>
<tables>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -6553,7 +6558,7 @@
</targetProperties>
<class xsi:type="Class" name="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="Autogenerated Object Property Class"
- tableName="ABCDEF1234567890ABCDEF12345672" tblCreator="True" fixedTbl="False" >
+ tableName="ABCDEF1234567890ABCDE2" tblCreator="True" fixedTbl="False" >
@@ -6562,8 +6567,8 @@
- tableName="ABCDEF1234567890ABCDEF12345672" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="True" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE2" columnName="ABCDEF1234567890ABCDEF123451" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -6578,7 +6583,7 @@
</targetProperties>
<class xsi:type="Class" name="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="Autogenerated Object Property Class"
- tableName="ABCDEF1234567890ABCDEF12345673" tblCreator="True" fixedTbl="False" >
+ tableName="ABCDEF1234567890ABCDE3" tblCreator="True" fixedTbl="False" >
@@ -6587,15 +6592,15 @@
- tableName="ABCDEF1234567890ABCDEF12345673" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="True" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE3" columnName="ABCDEF1234567890ABCDEF123451" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ABCDEF1234567890ABCDEF12345673" columnName="ABCDEF1234567890ABCDEF12345672" colCreator="True" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE3" columnName="ABCDEF1234567890ABCDE2_ABCD1" colCreator="True" fixedCol="False" >
+<column name="ABCDEF1234567890ABCDE2_ABCD1" description="" dataType="VARCHAR2" length="50" scale="0" nullable="False" >
</column>
</property>
@@ -6615,54 +6620,54 @@
</column>
</property>
</properties>
-<table name="ABCDEF1234567890ABCDEF12345673" description="" pkeyName="PK_ABCDEF1234567890ABCDEF12343" >
+<table name="ABCDEF1234567890ABCDE3" description="" pkeyName="PK_ABCDEF1234567890AB3" >
<target>
-<table name="ABCDEF1234567890ABCDEF12345672" description="" pkeyName="PK_ABCDEF1234567890ABCDEF12344" >
+<table name="ABCDEF1234567890ABCDE2" description="" pkeyName="PK_ABCDEF1234567890AB4" >
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
<sourceColumns>
+<column name="ABCDEF1234567890ABCDE2_ABCD1" />
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -6675,8 +6680,8 @@
- tableName="ABCDEF1234567890ABCDEF12345672" columnName="ABCDEF1234567890ABCDEF12345672" colCreator="True" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE2" columnName="ABCDEF1234567890ABCDE1_ABCD1" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -6696,15 +6701,15 @@
</column>
</property>
</properties>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
@@ -6713,21 +6718,21 @@
fixedCol="False" >
</property>
</column>
</column>
</table>
<tables>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -6739,20 +6744,20 @@
</property>
<property xsi:type="Geometric" name="gbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789"
geometricTypes="3" geometryTypes="42688" hasElevation="False" hasMeasure="False"
- tableName="ABCDEF1234567890ABCDEF12345671" columnName="GBCDEF1234567890ABCDEF12345671" colCreator="True" fixedCol="False" >
-<column name="GBCDEF1234567890ABCDEF12345671" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True" >
+ tableName="ABCDEF1234567890ABCDE1" columnName="GBCDEF1234567890ABCDEF123451" colCreator="True" fixedCol="False" >
+<column name="GBCDEF1234567890ABCDEF123451" description="" dataType="MDSYS.SDO_GEOMETRY" length="0" scale="0" nullable="True" >
</column>
</property>
<property xsi:type="Data" name="n/a" description=""
- tableName="ABCDEF1234567890ABCDEF12345671" columnName="N_A" colCreator="True" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE1" columnName="N_A" colCreator="True" fixedCol="False" >
<column name="N_A" description="" dataType="VARCHAR2" length="50" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Geometric" name="Bounds" description="Bounding box for the feature"
geometricTypes="4" geometryTypes="84224" hasElevation="False" hasMeasure="False"
- tableName="ABCDEF1234567890ABCDEF12345671" columnName="n/a" colCreator="False" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE1" columnName="n/a" colCreator="False" fixedCol="False" >
</property>
@@ -6772,7 +6777,7 @@
</column>
</property>
</properties>
<property xsi:type="Data" name="ClassId" />
<property xsi:type="Data" name="FeatId" />
<property xsi:type="Data" name="RevisionNumber" />
@@ -6793,19 +6798,19 @@
</column>
</column>
</column>
</column>
</column>
</table>
<tables>
</table>
<target>
</table>
<sourceColumns>
<column name="CLASSID" />
@@ -6819,7 +6824,7 @@
</class>
<class xsi:type="Feature" name="bbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789"
baseClass="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" abstract="False"
- tableName="BBCDEF1234567890ABCDEF12345671" tblCreator="True" fixedTbl="False" >
+ tableName="BBCDEF1234567890ABCDE1" tblCreator="True" fixedTbl="False" >
@@ -6828,7 +6833,7 @@
dataType="int64" length="0" precision="0" scale="0"
- tableName="BBCDEF1234567890ABCDEF12345671" columnName="CLASSID" colCreator="True" fixedCol="True" >
+ tableName="BBCDEF1234567890ABCDE1" columnName="CLASSID" colCreator="True" fixedCol="True" >
</column>
@@ -6836,7 +6841,7 @@
- tableName="BBCDEF1234567890ABCDEF12345671" columnName="FEATID" colCreator="True" fixedCol="True" >
+ tableName="BBCDEF1234567890ABCDE1" columnName="FEATID" colCreator="True" fixedCol="True" >
</column>
@@ -6844,7 +6849,7 @@
dataType="double" length="0" precision="0" scale="0"
- tableName="BBCDEF1234567890ABCDEF12345671" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True" >
+ tableName="BBCDEF1234567890ABCDE1" columnName="REVISIONNUMBER" colCreator="True" fixedCol="True" >
</column>
@@ -6852,22 +6857,22 @@
dataType="string" length="50" precision="0" scale="0"
- tableName="BBCDEF1234567890ABCDEF12345671" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="True" fixedCol="False" >
+ tableName="BBCDEF1234567890ABCDE1" columnName="ABCDEF1234567890ABCDEF123451" colCreator="True" fixedCol="False" >
<Inherited baseClass="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" />
</column>
</property>
- tableName="BBCDEF1234567890ABCDEF12345671" columnName="GBCDEF1234567890ABCDEF12345671" colCreator="True" fixedCol="False" >
+ tableName="BBCDEF1234567890ABCDE1" columnName="GBCDEF1234567890ABCDEF123451" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="BBCDEF1234567890ABCDEF12345671" columnName="N_A" colCreator="True" fixedCol="False" >
+ tableName="BBCDEF1234567890ABCDE1" columnName="N_A" colCreator="True" fixedCol="False" >
</column>
@@ -6885,7 +6890,7 @@
</targetProperties>
<class xsi:type="Class" name="bbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456788" description="Autogenerated Object Property Class"
- tableName="ABCDEF1234567890ABCDEF12345674" tblCreator="False" fixedTbl="False" >
+ tableName="ABCDEF1234567890ABCDE4" tblCreator="False" fixedTbl="False" >
@@ -6894,9 +6899,9 @@
- tableName="ABCDEF1234567890ABCDEF12345674" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="False" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE4" columnName="ABCDEF1234567890ABCDEF123451" colCreator="False" fixedCol="False" >
<Inherited baseClass="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456788" />
</column>
</property>
@@ -6912,7 +6917,7 @@
</targetProperties>
<class xsi:type="Class" name="bbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456788.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="Autogenerated Object Property Class"
- tableName="ABCDEF1234567890ABCDEF12345675" tblCreator="False" fixedTbl="False" >
+ tableName="ABCDEF1234567890ABCDE5" tblCreator="False" fixedTbl="False" >
@@ -6921,17 +6926,17 @@
- tableName="ABCDEF1234567890ABCDEF12345675" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="False" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE5" columnName="ABCDEF1234567890ABCDEF123451" colCreator="False" fixedCol="False" >
<Inherited baseClass="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456788.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" />
</column>
</property>
- tableName="ABCDEF1234567890ABCDEF12345675" columnName="ABCDEF1234567890ABCDEF12345672" colCreator="False" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE5" columnName="ABCDEF1234567890ABCDE4_ABCD1" colCreator="False" fixedCol="False" >
</column>
</property>
@@ -6951,54 +6956,54 @@
</column>
</property>
</properties>
<target>
<target>
-<table name="BBCDEF1234567890ABCDEF12345671" description="" pkeyName="PK_BBCDEF1234567890ABCDEF12341" >
+<table name="BBCDEF1234567890ABCDE1" description="" pkeyName="PK_BBCDEF1234567890AB1" >
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -7011,9 +7016,9 @@
- tableName="ABCDEF1234567890ABCDEF12345674" columnName="ABCDEF1234567890ABCDEF12345672" colCreator="False" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE4" columnName="ABCDEF1234567890ABCDE1_ABCD1" colCreator="False" fixedCol="False" >
</column>
</property>
@@ -7033,15 +7038,15 @@
</column>
</property>
</properties>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
@@ -7050,21 +7055,21 @@
fixedCol="False" >
</property>
</column>
</column>
</table>
<tables>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -7087,7 +7092,7 @@
</targetProperties>
<class xsi:type="Class" name="bbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="Autogenerated Object Property Class"
- tableName="ABCDEF1234567890ABCDEF12345672" tblCreator="False" fixedTbl="False" >
+ tableName="ABCDEF1234567890ABCDE2" tblCreator="False" fixedTbl="False" >
@@ -7096,9 +7101,9 @@
- tableName="ABCDEF1234567890ABCDEF12345672" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="False" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE2" columnName="ABCDEF1234567890ABCDEF123451" colCreator="False" fixedCol="False" >
<Inherited baseClass="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" />
</column>
</property>
@@ -7114,7 +7119,7 @@
</targetProperties>
<class xsi:type="Class" name="bbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="Autogenerated Object Property Class"
- tableName="ABCDEF1234567890ABCDEF12345673" tblCreator="False" fixedTbl="False" >
+ tableName="ABCDEF1234567890ABCDE3" tblCreator="False" fixedTbl="False" >
@@ -7123,17 +7128,17 @@
- tableName="ABCDEF1234567890ABCDEF12345673" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="False" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE3" columnName="ABCDEF1234567890ABCDEF123451" colCreator="False" fixedCol="False" >
<Inherited baseClass="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" />
</column>
</property>
- tableName="ABCDEF1234567890ABCDEF12345673" columnName="ABCDEF1234567890ABCDEF12345672" colCreator="False" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE3" columnName="ABCDEF1234567890ABCDE2_ABCD1" colCreator="False" fixedCol="False" >
</column>
</property>
@@ -7153,54 +7158,54 @@
</column>
</property>
</properties>
<target>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -7213,9 +7218,9 @@
- tableName="ABCDEF1234567890ABCDEF12345672" columnName="ABCDEF1234567890ABCDEF12345672" colCreator="False" fixedCol="False" >
+ tableName="ABCDEF1234567890ABCDE2" columnName="ABCDEF1234567890ABCDE1_ABCD1" colCreator="False" fixedCol="False" >
</column>
</property>
@@ -7235,15 +7240,15 @@
</column>
</property>
</properties>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
@@ -7252,21 +7257,21 @@
fixedCol="False" >
</property>
</column>
</column>
</table>
<tables>
<target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetColumns>
</target>
</table>
@@ -7278,7 +7283,7 @@
</property>
- tableName="BBCDEF1234567890ABCDEF12345671" columnName="n/a" colCreator="False" fixedCol="False" >
+ tableName="BBCDEF1234567890ABCDE1" columnName="n/a" colCreator="False" fixedCol="False" >
</property>
@@ -7298,7 +7303,7 @@
</column>
</property>
</properties>
@@ -7313,11 +7318,11 @@
objectType="Value" className="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789:obcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" idColumn="" order="ascending"
fixedCol="False" >
</property>
</column>
</column>
</column>
</column>
@@ -7327,11 +7332,11 @@
</column>
</table>
<tables>
</table>
<table name="F_CLASSDEFINITION" description="" pkeyName="" >
<target>
</table>
<sourceColumns>
@@ -7345,7 +7350,7 @@
</class>
<class xsi:type="Class" name="oacdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789"
- tableName="OACDEF1234567890ABCDEF12345671" tblCreator="False" fixedTbl="False" >
+ tableName="OACDEF1234567890ABCDE1" tblCreator="False" fixedTbl="False" >
</identityProperties>
@@ -7353,7 +7358,7 @@
- tableName="OACDEF1234567890ABCDEF12345671" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="False" fixedCol="False" >
+ tableName="OACDEF1234567890ABCDE1" columnName="ABCDEF1234567890ABCDEF123451" colCreator="False" fixedCol="False" >
</property>
dataType="string" length="30" precision="0" scale="0"
@@ -7375,7 +7380,7 @@
</class>
<class xsi:type="Class" name="obcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789"
- tableName="OBCDEF1234567890ABCDEF12345671" tblCreator="False" fixedTbl="False" >
+ tableName="OBCDEF1234567890ABCDE1" tblCreator="False" fixedTbl="False" >
@@ -7383,7 +7388,7 @@
- tableName="OBCDEF1234567890ABCDEF12345671" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="False" fixedCol="False" >
+ tableName="OBCDEF1234567890ABCDE1" columnName="ABCDEF1234567890ABCDEF123451" colCreator="False" fixedCol="False" >
</property>
objectType="Value" className="abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789:oacdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" idColumn="" order="ascending"
@@ -7395,7 +7400,7 @@
</targetProperties>
<class xsi:type="Class" name="obcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789.cbcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef1234567890abcdef123456789" description="Autogenerated Object Property Class"
- tableName="OBCDEF1234567890ABCDEF12345672" tblCreator="False" fixedTbl="False" >
+ tableName="OBCDEF1234567890ABCDE2" tblCreator="False" fixedTbl="False" >
@@ -7403,7 +7408,7 @@
- tableName="OBCDEF1234567890ABCDEF12345672" columnName="ABCDEF1234567890ABCDEF12345671" colCreator="False" fixedCol="False" >
+ tableName="OBCDEF1234567890ABCDE2" columnName="ABCDEF1234567890ABCDEF123451" colCreator="False" fixedCol="False" >
</property>
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt 2007-02-01 18:14:55 UTC (rev 725)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt 2007-02-02 16:07:20 UTC (rev 726)
@@ -86,7 +86,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDb3dPolyline.vertices" description="Autogenerated Object Property Class"
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA" tblCreator="True" fixedTbl="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE1" tblCreator="True" fixedTbl="False" >
<property xsi:type="Data" name="AcDb3dPolyline_FeatId" />
@@ -96,7 +96,7 @@
<property xsi:type="Data" name="Seq" description="seq"
dataType="int32" length="0" precision="0" scale="0"
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE1" columnName="SEQ" colCreator="True" fixedCol="False" >
<column name="SEQ" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
</column>
</property>
@@ -117,7 +117,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDb3dPolyline.vertices.normal" description="Autogenerated Object Property Class"
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" tblCreator="True" fixedTbl="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE3" tblCreator="True" fixedTbl="False" >
@@ -128,29 +128,29 @@
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE3" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
<property xsi:type="Data" name="Value" description=""
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE3" columnName="VALUE1" colCreator="True" fixedCol="False" >
<column name="VALUE1" description="" dataType="NUMBER" length="0" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="AcDb3dPolyline_FeatId" description="Feature id number (uniquely identifies a feature)"
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" columnName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" colCreator="True" fixedCol="False" >
-<column name="ACDB3DPOLYLINE_ACDBVERTEXDATA1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE3" columnName="ACDB3DPOLYLINE_ACDBVE1_ACDB1" colCreator="True" fixedCol="False" >
+<column name="ACDB3DPOLYLINE_ACDBVE1_ACDB1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="AcDbVertexData_Seq" description="seq"
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" columnName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" colCreator="True" fixedCol="False" >
-<column name="ACDB3DPOLYLINE_ACDBVERTEXDATA2" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE3" columnName="ACDB3DPOLYLINE_ACDBVE1_SEQ" colCreator="True" fixedCol="False" >
+<column name="ACDB3DPOLYLINE_ACDBVE1_SEQ" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
</column>
</property>
@@ -170,9 +170,9 @@
</column>
</property>
</properties>
-<table name="ACDB3DPOLYLINE_ACDBVERTEXDATA2" description="" pkeyName="PK_ACDB3DPOLYLINE_ACDBVERTEXD3" >
+<table name="ACDB3DPOLYLINE_ACDBVE3" description="" pkeyName="PK_ACDB3DPOLYLINE_ACD3" >
<target>
-<table name="ACDB3DPOLYLINE_ACDBVERTEXDATA" description="" pkeyName="PK_ACDB3DPOLYLINE_ACDBVERTEXD2" >
+<table name="ACDB3DPOLYLINE_ACDBVE1" description="" pkeyName="PK_ACDB3DPOLYLINE_ACD2" >
<target>
<table name="ACDB3DPOLYLINE" description="" pkeyName="PK_ACDB3DPOLYLINE" >
</table>
@@ -185,8 +185,8 @@
</target>
</table>
<sourceColumns>
-<column name="ACDB3DPOLYLINE_ACDBVERTEXDATA1" />
-<column name="ACDB3DPOLYLINE_ACDBVERTEXDATA2" />
+<column name="ACDB3DPOLYLINE_ACDBVE1_ACDB1" />
+<column name="ACDB3DPOLYLINE_ACDBVE1_SEQ" />
</sourceColumns>
<targetColumns>
<column name="ACDB3DPOLYLINE_FEATID" />
@@ -201,15 +201,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -222,8 +222,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -254,7 +254,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDb3dPolyline.vertices.point" description="Autogenerated Object Property Class"
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" tblCreator="True" fixedTbl="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE2" tblCreator="True" fixedTbl="False" >
@@ -265,29 +265,29 @@
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE2" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE2" columnName="VALUE1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" columnName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE2" columnName="ACDB3DPOLYLINE_ACDBVE1_ACDB1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA1" columnName="ACDB3DPOLYLINE_ACDBVERTEXDATA2" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE2" columnName="ACDB3DPOLYLINE_ACDBVE1_SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -307,9 +307,9 @@
</column>
</property>
</properties>
-<table name="ACDB3DPOLYLINE_ACDBVERTEXDATA1" description="" pkeyName="PK_ACDB3DPOLYLINE_ACDBVERTEXD1" >
+<table name="ACDB3DPOLYLINE_ACDBVE2" description="" pkeyName="PK_ACDB3DPOLYLINE_ACD1" >
<target>
<target>
</table>
@@ -322,8 +322,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -338,15 +338,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -359,8 +359,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -377,7 +377,7 @@
- tableName="ACDB3DPOLYLINE_ACDBVERTEXDATA" columnName="ACDB3DPOLYLINE_FEATID" colCreator="True" fixedCol="False" >
+ tableName="ACDB3DPOLYLINE_ACDBVE1" columnName="ACDB3DPOLYLINE_FEATID" colCreator="True" fixedCol="False" >
<column name="ACDB3DPOLYLINE_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
@@ -398,7 +398,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -425,7 +425,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -966,7 +966,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDbHatch.edges.vertices" description="Autogenerated Object Property Class"
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX1" tblCreator="True" fixedTbl="False" >
+ tableName="ACDBHATCH_POLYLINE_AC1" tblCreator="True" fixedTbl="False" >
<property xsi:type="Data" name="Polyline_FeatId" />
@@ -976,7 +976,7 @@
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX1" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC1" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -997,7 +997,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDbHatch.edges.vertices.normal" description="Autogenerated Object Property Class"
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX3" tblCreator="True" fixedTbl="False" >
+ tableName="ACDBHATCH_POLYLINE_AC4" tblCreator="True" fixedTbl="False" >
@@ -1008,29 +1008,29 @@
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX3" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC4" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX3" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC4" columnName="VALUE1" colCreator="True" fixedCol="False" >
</column>
</property>
<property xsi:type="Data" name="Polyline_FeatId" description="id"
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX3" columnName="ACDBHATCH_POLYLINE_ACDBVERTEX1" colCreator="True" fixedCol="False" >
-<column name="ACDBHATCH_POLYLINE_ACDBVERTEX1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+ tableName="ACDBHATCH_POLYLINE_AC4" columnName="ACDBHATCH_POLYLINE_AC1_ACDB1" colCreator="True" fixedCol="False" >
+<column name="ACDBHATCH_POLYLINE_AC1_ACDB1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX3" columnName="ACDBHATCH_POLYLINE_ACDBVERTEX2" colCreator="True" fixedCol="False" >
-<column name="ACDBHATCH_POLYLINE_ACDBVERTEX2" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
+ tableName="ACDBHATCH_POLYLINE_AC4" columnName="ACDBHATCH_POLYLINE_AC1_SEQ" colCreator="True" fixedCol="False" >
+<column name="ACDBHATCH_POLYLINE_AC1_SEQ" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
</column>
</property>
@@ -1050,9 +1050,9 @@
</column>
</property>
</properties>
-<table name="ACDBHATCH_POLYLINE_ACDBVERTEX3" description="" pkeyName="PK_ACDBHATCH_POLYLINE_ACDBVER3" >
+<table name="ACDBHATCH_POLYLINE_AC4" description="" pkeyName="PK_ACDBHATCH_POLYLINE4" >
<target>
-<table name="ACDBHATCH_POLYLINE_ACDBVERTEX1" description="" pkeyName="PK_ACDBHATCH_POLYLINE_ACDBVER2" >
+<table name="ACDBHATCH_POLYLINE_AC1" description="" pkeyName="PK_ACDBHATCH_POLYLINE3" >
<target>
<table name="ACDBHATCH_POLYLINE" description="" pkeyName="PK_ACDBHATCH_POLYLINE" >
<target>
@@ -1075,8 +1075,8 @@
</target>
</table>
<sourceColumns>
-<column name="ACDBHATCH_POLYLINE_ACDBVERTEX1" />
-<column name="ACDBHATCH_POLYLINE_ACDBVERTEX2" />
+<column name="ACDBHATCH_POLYLINE_AC1_ACDB1" />
+<column name="ACDBHATCH_POLYLINE_AC1_SEQ" />
</sourceColumns>
<targetColumns>
<column name="ACDBHATCH_POLYLINE_FEATID" />
@@ -1091,15 +1091,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
<target>
@@ -1122,8 +1122,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -1154,7 +1154,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDbHatch.edges.vertices.point" description="Autogenerated Object Property Class"
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX2" tblCreator="True" fixedTbl="False" >
+ tableName="ACDBHATCH_POLYLINE_AC2" tblCreator="True" fixedTbl="False" >
@@ -1165,29 +1165,29 @@
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX2" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC2" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX2" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC2" columnName="VALUE1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX2" columnName="ACDBHATCH_POLYLINE_ACDBVERTEX1" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC2" columnName="ACDBHATCH_POLYLINE_AC1_ACDB1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX2" columnName="ACDBHATCH_POLYLINE_ACDBVERTEX2" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC2" columnName="ACDBHATCH_POLYLINE_AC1_SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -1207,9 +1207,9 @@
</column>
</property>
</properties>
-<table name="ACDBHATCH_POLYLINE_ACDBVERTEX2" description="" pkeyName="PK_ACDBHATCH_POLYLINE_ACDBVER1" >
+<table name="ACDBHATCH_POLYLINE_AC2" description="" pkeyName="PK_ACDBHATCH_POLYLINE2" >
<target>
<target>
<target>
@@ -1232,8 +1232,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -1248,15 +1248,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
<target>
@@ -1279,8 +1279,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -1297,7 +1297,7 @@
- tableName="ACDBHATCH_POLYLINE_ACDBVERTEX1" columnName="ACDBHATCH_POLYLINE_FEATID" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC1" columnName="ACDBHATCH_POLYLINE_FEATID" colCreator="True" fixedCol="False" >
<column name="ACDBHATCH_POLYLINE_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
@@ -1318,7 +1318,7 @@
</column>
</property>
</properties>
<target>
<target>
@@ -1355,7 +1355,7 @@
</column>
</table>
<tables>
<target>
<target>
@@ -1398,7 +1398,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDbHatch.edges.xdata" description="Autogenerated Object Property Class"
- tableName="ACDBHATCH_POLYLINE_ACXDATA" tblCreator="True" fixedTbl="False" >
+ tableName="ACDBHATCH_POLYLINE_AC3" tblCreator="True" fixedTbl="False" >
@@ -1408,21 +1408,21 @@
<property xsi:type="Data" name="Datavalue" description="datavalue"
dataType="string" length="4000" precision="0" scale="0"
- tableName="ACDBHATCH_POLYLINE_ACXDATA" columnName="DATAVALUE" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC3" columnName="DATAVALUE" colCreator="True" fixedCol="False" >
<column name="DATAVALUE" description="" dataType="VARCHAR2" length="4000" scale="0" nullable="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACXDATA" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC3" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ACDBHATCH_POLYLINE_ACXDATA" columnName="ACDBHATCH_POLYLINE_FEATID" colCreator="True" fixedCol="False" >
+ tableName="ACDBHATCH_POLYLINE_AC3" columnName="ACDBHATCH_POLYLINE_FEATID" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -1443,7 +1443,7 @@
</column>
</property>
</properties>
-<table name="ACDBHATCH_POLYLINE_ACXDATA" description="" pkeyName="PK_ACDBHATCH_POLYLINE_ACXDATA" >
+<table name="ACDBHATCH_POLYLINE_AC3" description="" pkeyName="PK_ACDBHATCH_POLYLINE1" >
<target>
<target>
@@ -1475,7 +1475,7 @@
</column>
</table>
<tables>
<target>
<target>
@@ -1760,7 +1760,7 @@
</class>
<class xsi:type="Class" name="AcDbVertexCoordinateValue" description=""
- tableName="ACDBVERTEXCOORDINATEVALUE" tblCreator="False" fixedTbl="False" >
+ tableName="ACDBVERTEXCOORDINATEV1" tblCreator="False" fixedTbl="False" >
@@ -1768,12 +1768,12 @@
- tableName="ACDBVERTEXCOORDINATEVALUE" columnName="SEQ" colCreator="False" fixedCol="False" >
+ tableName="ACDBVERTEXCOORDINATEV1" columnName="SEQ" colCreator="False" fixedCol="False" >
</property>
- tableName="ACDBVERTEXCOORDINATEVALUE" columnName="VALUE1" colCreator="False" fixedCol="False" >
+ tableName="ACDBVERTEXCOORDINATEV1" columnName="VALUE1" colCreator="False" fixedCol="False" >
</property>
@@ -1818,7 +1818,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDbVertexData.normal" description="Autogenerated Object Property Class"
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR2" tblCreator="False" fixedTbl="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE2" tblCreator="False" fixedTbl="False" >
<property xsi:type="Data" name="Seq" />
@@ -1827,12 +1827,12 @@
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR2" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE2" columnName="SEQ" colCreator="True" fixedCol="False" >
</property>
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR2" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE2" columnName="VALUE1" colCreator="True" fixedCol="False" >
</property>
@@ -1867,7 +1867,7 @@
</targetProperties>
<class xsi:type="Class" name="AcDbVertexData.point" description="Autogenerated Object Property Class"
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR1" tblCreator="False" fixedTbl="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE1" tblCreator="False" fixedTbl="False" >
@@ -1876,12 +1876,12 @@
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR1" columnName="SEQ" colCreator="False" fixedCol="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE1" columnName="SEQ" colCreator="False" fixedCol="False" >
</property>
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR1" columnName="VALUE1" colCreator="False" fixedCol="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE1" columnName="VALUE1" colCreator="False" fixedCol="False" >
</property>
@@ -2203,7 +2203,7 @@
</targetProperties>
<class xsi:type="Class" name="Polyline.vertices" description="Autogenerated Object Property Class"
- tableName="POLYLINE_ACDBVERTEXDATA" tblCreator="True" fixedTbl="False" >
+ tableName="POLYLINE_ACDBVERTEXDA1" tblCreator="True" fixedTbl="False" >
@@ -2213,7 +2213,7 @@
- tableName="POLYLINE_ACDBVERTEXDATA" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA1" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -2234,7 +2234,7 @@
</targetProperties>
<class xsi:type="Class" name="Polyline.vertices.normal" description="Autogenerated Object Property Class"
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV2" tblCreator="True" fixedTbl="False" >
+ tableName="POLYLINE_ACDBVERTEXDA3" tblCreator="True" fixedTbl="False" >
@@ -2245,29 +2245,29 @@
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV2" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA3" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV2" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA3" columnName="VALUE1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV2" columnName="POLYLINE_ACDBVERTEXDATA_POLYL1" colCreator="True" fixedCol="False" >
-<column name="POLYLINE_ACDBVERTEXDATA_POLYL1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+ tableName="POLYLINE_ACDBVERTEXDA3" columnName="POLYLINE_ACDBVERTEXDA1_POLY1" colCreator="True" fixedCol="False" >
+<column name="POLYLINE_ACDBVERTEXDA1_POLY1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV2" columnName="POLYLINE_ACDBVERTEXDATA_SEQ" colCreator="True" fixedCol="False" >
-<column name="POLYLINE_ACDBVERTEXDATA_SEQ" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
+ tableName="POLYLINE_ACDBVERTEXDA3" columnName="POLYLINE_ACDBVERTEXDA1_SEQ" colCreator="True" fixedCol="False" >
+<column name="POLYLINE_ACDBVERTEXDA1_SEQ" description="" dataType="NUMBER" length="10" scale="0" nullable="False" >
</column>
</property>
@@ -2287,9 +2287,9 @@
</column>
</property>
</properties>
-<table name="POLYLINE_ACDBVERTEXDATA_ACDBV2" description="" pkeyName="PK_POLYLINE_ACDBVERTEXDATA_AC2" >
+<table name="POLYLINE_ACDBVERTEXDA3" description="" pkeyName="PK_POLYLINE_ACDBVERTE3" >
<target>
-<table name="POLYLINE_ACDBVERTEXDATA" description="" pkeyName="PK_POLYLINE_ACDBVERTEXDATA" >
+<table name="POLYLINE_ACDBVERTEXDA1" description="" pkeyName="PK_POLYLINE_ACDBVERTE2" >
<target>
<table name="POLYLINE" description="" pkeyName="PK_POLYLINE" >
</table>
@@ -2302,8 +2302,8 @@
</target>
</table>
<sourceColumns>
-<column name="POLYLINE_ACDBVERTEXDATA_POLYL1" />
-<column name="POLYLINE_ACDBVERTEXDATA_SEQ" />
+<column name="POLYLINE_ACDBVERTEXDA1_POLY1" />
+<column name="POLYLINE_ACDBVERTEXDA1_SEQ" />
</sourceColumns>
<targetColumns>
<column name="POLYLINE_FEATID" />
@@ -2318,15 +2318,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -2339,8 +2339,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -2371,7 +2371,7 @@
</targetProperties>
<class xsi:type="Class" name="Polyline.vertices.point" description="Autogenerated Object Property Class"
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV1" tblCreator="True" fixedTbl="False" >
+ tableName="POLYLINE_ACDBVERTEXDA2" tblCreator="True" fixedTbl="False" >
@@ -2382,29 +2382,29 @@
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV1" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA2" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV1" columnName="VALUE1" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA2" columnName="VALUE1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV1" columnName="POLYLINE_ACDBVERTEXDATA_POLYL1" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA2" columnName="POLYLINE_ACDBVERTEXDA1_POLY1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="POLYLINE_ACDBVERTEXDATA_ACDBV1" columnName="POLYLINE_ACDBVERTEXDATA_SEQ" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA2" columnName="POLYLINE_ACDBVERTEXDA1_SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -2424,9 +2424,9 @@
</column>
</property>
</properties>
-<table name="POLYLINE_ACDBVERTEXDATA_ACDBV1" description="" pkeyName="PK_POLYLINE_ACDBVERTEXDATA_AC1" >
+<table name="POLYLINE_ACDBVERTEXDA2" description="" pkeyName="PK_POLYLINE_ACDBVERTE1" >
<target>
<target>
</table>
@@ -2439,8 +2439,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -2455,15 +2455,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -2476,8 +2476,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -2494,7 +2494,7 @@
- tableName="POLYLINE_ACDBVERTEXDATA" columnName="POLYLINE_FEATID" colCreator="True" fixedCol="False" >
+ tableName="POLYLINE_ACDBVERTEXDA1" columnName="POLYLINE_FEATID" colCreator="True" fixedCol="False" >
<column name="POLYLINE_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
@@ -2515,7 +2515,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -2542,7 +2542,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -2915,7 +2915,7 @@
</targetProperties>
<class xsi:type="Class" name="Conductor.graphic.xdata" description="Autogenerated Object Property Class"
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" tblCreator="False" fixedTbl="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" tblCreator="False" fixedTbl="False" >
<property xsi:type="Data" name="Entity_FeatId" />
@@ -2925,7 +2925,7 @@
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" columnName="DATAVALUE" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" columnName="DATAVALUE" colCreator="False" fixedCol="False" >
<Inherited baseClass="ElectricDevice.graphic.xdata" />
</column>
@@ -2933,7 +2933,7 @@
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" columnName="SEQ" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" columnName="SEQ" colCreator="False" fixedCol="False" >
</column>
@@ -2941,7 +2941,7 @@
<property xsi:type="Data" name="Entity_FeatId" description="id"
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" columnName="ELECTRICDEVICE_ENTITY_FEATID" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" columnName="ELECTRICDEVICE_ENTITY_FEATID" colCreator="False" fixedCol="False" >
<column name="ELECTRICDEVICE_ENTITY_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
@@ -2963,9 +2963,9 @@
</column>
</property>
</properties>
-<table name="ELECTRICDEVICE_ENTITY_ACXDATA" description="" pkeyName="PK_ELECTRICDEVICE_ENTITY_ACXD1" >
+<table name="ELECTRICDEVICE_ENTITY1" description="" pkeyName="PK_ELECTRICDEVICE_ENT1" >
<target>
-<table name="ELECTRICDEVICE_ENTITY" description="" pkeyName="PK_ELECTRICDEVICE_ENTITY" >
+<table name="ELECTRICDEVICE_ENTITY" description="" pkeyName="PK_ELECTRICDEVICE_ENT2" >
<target>
<table name="CONDUCTOR" description="" pkeyName="PK_CONDUCTOR" >
</table>
@@ -2995,9 +2995,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -3048,7 +3048,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -3080,7 +3080,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -3350,7 +3350,7 @@
</column>
</property>
</properties>
-<table name="CUSTOMER___RESIDENTIAL" description="" pkeyName="PK_CUSTOMER___RESIDENTIAL" >
+<table name="CUSTOMER___RESIDENTIAL" description="" pkeyName="PK_CUSTOMER___RESIDEN1" >
<property xsi:type="Data" name="Credit Rating" />
<property xsi:type="Data" name="First Name" />
<property xsi:type="Data" name="Last Name" />
@@ -3362,7 +3362,7 @@
</column>
</table>
<tables>
</table>
</table>
@@ -3487,7 +3487,7 @@
</targetProperties>
<class xsi:type="Class" name="ElectricDevice.graphic.xdata" description="Autogenerated Object Property Class"
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" tblCreator="True" fixedTbl="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" tblCreator="True" fixedTbl="False" >
@@ -3497,21 +3497,21 @@
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" columnName="DATAVALUE" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" columnName="DATAVALUE" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" columnName="SEQ" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" columnName="SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_ENTITY_ACXDATA" columnName="ELECTRICDEVICE_ENTITY_FEATID" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_ENTITY1" columnName="ELECTRICDEVICE_ENTITY_FEATID" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -3532,9 +3532,9 @@
</column>
</property>
</properties>
<target>
<target>
<table name="ELECTRICDEVICE" description="" pkeyName="PK_ELECTRICDEVICE" >
</table>
@@ -3564,9 +3564,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -3616,7 +3616,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -3648,7 +3648,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -3747,7 +3747,7 @@
<property xsi:type="Data" name="Maintenance History Description" description="datavalue"
readOnly="False" featId="False" system="False" nullable="True" autogenerated="False" defaultValue=""
- tableName="MAINT_HISTORY" columnName="MAINTENANCE_HISTORY_DESCRIPTI1" colCreator="False" fixedCol="False" >
+ tableName="MAINT_HISTORY" columnName="MAINTENANCE_HISTORY_DESCRIP1" colCreator="False" fixedCol="False" >
</property>
<property xsi:type="Object" name="work items" description="tasks performed on this date"
objectType="Ordered Collection" className="Electric'l:Maint History Item" idColumn="IT_M__" order="descending"
@@ -3762,7 +3762,7 @@
</targetProperties>
<class xsi:type="Class" name="Maint History.work items" description="Autogenerated Object Property Class"
- tableName="MAINT_HISTORY_MAINT_HISTORY_I1" tblCreator="False" fixedTbl="False" >
+ tableName="MAINT_HISTORY_MAINT_H1" tblCreator="False" fixedTbl="False" >
<property xsi:type="Data" name="It'm #" />
@@ -3771,22 +3771,22 @@
<property xsi:type="Data" name="It'm #" description="sequence identifier"
dataType="int16" length="0" precision="0" scale="0"
- tableName="MAINT_HISTORY_MAINT_HISTORY_I1" columnName="IT_M__" colCreator="False" fixedCol="False" >
+ tableName="MAINT_HISTORY_MAINT_H1" columnName="IT_M__" colCreator="False" fixedCol="False" >
</property>
<property xsi:type="Data" name="Part #" description="Part used in work item"
- tableName="MAINT_HISTORY_MAINT_HISTORY_I1" columnName="PART__" colCreator="False" fixedCol="False" >
+ tableName="MAINT_HISTORY_MAINT_H1" columnName="PART__" colCreator="False" fixedCol="False" >
</property>
<property xsi:type="Data" name="Work Description" description="Description of work performed"
- tableName="MAINT_HISTORY_MAINT_HISTORY_I1" columnName="WORK_DESCRIPTION" colCreator="False" fixedCol="False" >
+ tableName="MAINT_HISTORY_MAINT_H1" columnName="WORK_DESCRIPTION" colCreator="False" fixedCol="False" >
</property>
<property xsi:type="Data" name="classname" description=""
dataType="string" length="255" precision="0" scale="0"
- tableName="MAINT_HISTORY_MAINT_HISTORY_I1" columnName="CLASSNAME1" colCreator="False" fixedCol="False" >
+ tableName="MAINT_HISTORY_MAINT_H1" columnName="CLASSNAME1" colCreator="False" fixedCol="False" >
</property>
@@ -4048,7 +4048,7 @@
</targetProperties>
<class xsi:type="Class" name="Transformer.graphic.xdata" description="Autogenerated Object Property Class"
baseClass="" abstract="False"
@@ -4058,7 +4058,7 @@
</column>
@@ -4066,7 +4066,7 @@
</column>
@@ -4074,7 +4074,7 @@
</column>
@@ -4096,9 +4096,9 @@
</column>
</property>
</properties>
<target>
<target>
<table name="TRANSFORMER" description="" pkeyName="PK_TRANSFORMER" >
</table>
@@ -4128,9 +4128,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -4181,7 +4181,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -4213,7 +4213,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -5445,6 +5445,11 @@
</column>
</property>
</properties>
+<uniqueConstraints>
+<uniqueConstraint>
+<property xsi:type="Data" name="PolyNum" />
+</uniqueConstraint>
+</uniqueConstraints>
<table name="ZONING" description="" pkeyName="PK_ZONING" >
<property xsi:type="Data" name="Authority" />
<property xsi:type="Data" name="ByLaw" />
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt 2007-02-01 18:14:55 UTC (rev 725)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt 2007-02-02 16:07:20 UTC (rev 726)
@@ -86,7 +86,7 @@
</targetProperties>
<tableMapping>Concrete</tableMapping>
<identityProperties>
@@ -96,7 +96,7 @@
readOnly="False" featId="False" system="False" nullable="False" autogenerated="False" defaultValue=""
</column>
</property>
@@ -117,7 +117,7 @@
</targetProperties>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
@@ -170,9 +170,9 @@
</column>
</property>
</properties>
-<table name="ACDB3DPOLYLINE_ACDBVERTEXDATA2" description="" pkeyName="PK_ACDB3DPOLYLINE_ACDBVERTEXD1" >
+<table name="ACDB3DPOLYLINE_ACDBVE3" description="" pkeyName="PK_ACDB3DPOLYLINE_ACD1" >
<target>
-<table name="ACDB3DPOLYLINE_ACDBVERTEXDATA" description="" pkeyName="PK_ACDB3DPOLYLINE_ACDBVERTEXD3" >
+<table name="ACDB3DPOLYLINE_ACDBVE1" description="" pkeyName="PK_ACDB3DPOLYLINE_ACD3" >
<target>
</table>
@@ -185,8 +185,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -222,8 +222,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -254,7 +254,7 @@
</targetProperties>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
@@ -307,9 +307,9 @@
</column>
</property>
</properties>
-<table name="ACDB3DPOLYLINE_ACDBVERTEXDATA1" description="" pkeyName="PK_ACDB3DPOLYLINE_ACDBVERTEXD2" >
+<table name="ACDB3DPOLYLINE_ACDBVE2" description="" pkeyName="PK_ACDB3DPOLYLINE_ACD2" >
<target>
<target>
</table>
@@ -322,8 +322,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -359,8 +359,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -377,7 +377,7 @@
</column>
</property>
@@ -398,7 +398,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -425,7 +425,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -966,7 +966,7 @@
</targetProperties>
@@ -976,7 +976,7 @@
</column>
</property>
@@ -997,7 +997,7 @@
</targetProperties>
</column>
</property>
+ tableName="ACDBHATCH_POLYLINE_AC3" columnName="VALUE1" colCreator="True" fixedCol="False" >
</column>
</property>
+ tableName="ACDBHATCH_POLYLINE_AC3" columnName="ACDBHATCH_POLYLINE_AC1_ACDB1" colCreator="True" fixedCol="False" >
</column>
</property>
+ tableName="ACDBHATCH_POLYLINE_AC3" columnName="ACDBHATCH_POLYLINE_AC1_SEQ" colCreator="True" fixedCol="False" >
</column>
</property>
</column>
</property>
</properties>
-<table name="ACDBHATCH_POLYLINE_ACDBVERTEX3" description="" pkeyName="PK_ACDBHATCH_POLYLINE_ACDBVER1" >
+<table name="ACDBHATCH_POLYLINE_AC3" description="" pkeyName="PK_ACDBHATCH_POLYLINE2" >
<target>
-<table name="ACDBHATCH_POLYLINE_ACDBVERTEX1" description="" pkeyName="PK_ACDBHATCH_POLYLINE_ACDBVER3" >
+<table name="ACDBHATCH_POLYLINE_AC1" description="" pkeyName="PK_ACDBHATCH_POLYLINE4" >
<target>
<target>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
<target>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetProperties>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
<property xsi:type="Data" name="ClassName" description="FDO base property: object class name"
</column>
</property>
</properties>
-<table name="ACDBHATCH_POLYLINE_ACDBVERTEX2" description="" pkeyName="PK_ACDBHATCH_POLYLINE_ACDBVER2" >
+<table name="ACDBHATCH_POLYLINE_AC2" description="" pkeyName="PK_ACDBHATCH_POLYLINE3" >
<target>
<target>
<target>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
<target>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</property>
</column>
</property>
</properties>
<target>
<target>
</column>
</table>
<tables>
<target>
<target>
</targetProperties>
+ tableName="ACDBHATCH_POLYLINE_AC4" columnName="DATAVALUE" colCreator="True" fixedCol="False" >
</column>
</property>
</column>
</property>
+ tableName="ACDBHATCH_POLYLINE_AC4" columnName="ACDBHATCH_POLYLINE_FEATID" colCreator="True" fixedCol="False" >
</column>
</property>
</column>
</property>
</properties>
+<table name="ACDBHATCH_POLYLINE_AC4" description="" pkeyName="PK_ACDBHATCH_POLYLINE1" >
<target>
<target>
</column>
</table>
<tables>
<target>
<target>
</class>
</property>
</property>
</targetProperties>
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR2" columnName="SEQ" colCreator="False" fixedCol="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE2" columnName="SEQ" colCreator="False" fixedCol="False" >
</property>
- tableName="ACDBVERTEXDATA_ACDBVERTEXCOOR2" columnName="VALUE1" colCreator="False" fixedCol="False" >
+ tableName="ACDBVERTEXDATA_ACDBVE2" columnName="VALUE1" colCreator="False" fixedCol="False" >
</property>
</targetProperties>
</property>
</property>
</targetProperties>
</column>
</property>
</targetProperties>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</properties>
-<table name="POLYLINE_ACDBVERTEXDATA_ACDBV2" description="" pkeyName="PK_POLYLINE_ACDBVERTEXDATA_AC1" >
+<table name="POLYLINE_ACDBVERTEXDA3" description="" pkeyName="PK_POLYLINE_ACDBVERTE1" >
<target>
+<table name="POLYLINE_ACDBVERTEXDA1" description="" pkeyName="PK_POLYLINE_ACDBVERTE3" >
<target>
</table>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</targetProperties>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</column>
</property>
</properties>
-<table name="POLYLINE_ACDBVERTEXDATA_ACDBV1" description="" pkeyName="PK_POLYLINE_ACDBVERTEXDATA_AC2" >
+<table name="POLYLINE_ACDBVERTEXDA2" description="" pkeyName="PK_POLYLINE_ACDBVERTE2" >
<target>
<target>
</table>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
</column>
</property>
</column>
</property>
</properties>
<target>
</table>
</column>
</table>
<tables>
<target>
</table>
@@ -2960,7 +2960,7 @@
</targetProperties>
@@ -2970,7 +2970,7 @@
</column>
@@ -2978,7 +2978,7 @@
</column>
@@ -2986,7 +2986,7 @@
</column>
@@ -3008,9 +3008,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -3040,9 +3040,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -3093,7 +3093,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -3125,7 +3125,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -3159,7 +3159,7 @@
</targetProperties>
<class xsi:type="Class" name="Conductor.maintenance history" description="Autogenerated Object Property Class"
- tableName="ELECTRICDEVICE_MAINT_HISTORY" tblCreator="False" fixedTbl="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" tblCreator="False" fixedTbl="False" >
<property xsi:type="Data" name="ElectricDevice_FeatId" />
@@ -3169,7 +3169,7 @@
<property xsi:type="Data" name="Date" description="Date of work done"
dataType="datetime" length="0" precision="0" scale="0"
- tableName="ELECTRICDEVICE_MAINT_HISTORY" columnName="DATE1" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" columnName="DATE1" colCreator="False" fixedCol="False" >
<Inherited baseClass="ElectricDevice.maintenance history" />
<column name="DATE1" description="" dataType="DATE" length="0" scale="0" nullable="False" >
</column>
@@ -3177,9 +3177,9 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY" columnName="MAINTENANCE_HISTORY_DESCRIPTI1" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" columnName="MAINTENANCE_HISTORY_DESCRIP1" colCreator="False" fixedCol="False" >
-<column name="MAINTENANCE_HISTORY_DESCRIPTI1" description="" dataType="VARCHAR2" length="50" scale="0" nullable="True" >
+<column name="MAINTENANCE_HISTORY_DESCRIP1" description="" dataType="VARCHAR2" length="50" scale="0" nullable="True" >
</column>
</property>
@@ -3200,7 +3200,7 @@
</targetProperties>
<class xsi:type="Class" name="Conductor.maintenance history.work items" description="Autogenerated Object Property Class"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" tblCreator="False" fixedTbl="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" tblCreator="False" fixedTbl="False" >
@@ -3211,7 +3211,7 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="IT_M__" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="IT_M__" colCreator="False" fixedCol="False" >
<Inherited baseClass="ElectricDevice.maintenance history.work items" />
<column name="IT_M__" description="" dataType="NUMBER" length="5" scale="0" nullable="False" >
</column>
@@ -3219,7 +3219,7 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="PART__" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="PART__" colCreator="False" fixedCol="False" >
<column name="PART__" description="" dataType="NUMBER" length="10" scale="0" nullable="True" >
</column>
@@ -3227,7 +3227,7 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="WORK_DESCRIPTION" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="WORK_DESCRIPTION" colCreator="False" fixedCol="False" >
<column name="WORK_DESCRIPTION" description="" dataType="VARCHAR2" length="4000" scale="0" nullable="False" >
</column>
@@ -3235,7 +3235,7 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="CLASSNAME1" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="CLASSNAME1" colCreator="False" fixedCol="False" >
<column name="CLASSNAME1" description="" dataType="VARCHAR2" length="255" scale="0" nullable="True" >
</column>
@@ -3243,17 +3243,17 @@
<property xsi:type="Data" name="ElectricDevice_FeatId" description="Feature id number (uniquely identifies a feature)"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="ELECTRICDEVICE_MAINT_HISTORY_1" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="ELECTRICDEVICE_MAINT_1_ELEC1" colCreator="False" fixedCol="False" >
-<column name="ELECTRICDEVICE_MAINT_HISTORY_1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
+<column name="ELECTRICDEVICE_MAINT_1_ELEC1" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="Maint History_Date" description="Date of work done"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="ELECTRICDEVICE_MAINT_HISTORY_2" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="ELECTRICDEVICE_MAINT_1_DATE1" colCreator="False" fixedCol="False" >
-<column name="ELECTRICDEVICE_MAINT_HISTORY_2" description="" dataType="DATE" length="0" scale="0" nullable="False" >
+<column name="ELECTRICDEVICE_MAINT_1_DATE1" description="" dataType="DATE" length="0" scale="0" nullable="False" >
</column>
</property>
@@ -3273,9 +3273,9 @@
</column>
</property>
</properties>
-<table name="ELECTRICDEVICE_MAINT_HISTORY_1" description="" pkeyName="PK_ELECTRICDEVICE_MAINT_HISTO1" >
+<table name="ELECTRICDEVICE_MAINT_2" description="" pkeyName="PK_ELECTRICDEVICE_MAI1" >
<target>
-<table name="ELECTRICDEVICE_MAINT_HISTORY" description="" pkeyName="PK_ELECTRICDEVICE_MAINT_HISTO2" >
+<table name="ELECTRICDEVICE_MAINT_1" description="" pkeyName="PK_ELECTRICDEVICE_MAI2" >
<target>
</table>
@@ -3288,8 +3288,8 @@
</target>
</table>
<sourceColumns>
-<column name="ELECTRICDEVICE_MAINT_HISTORY_1" />
-<column name="ELECTRICDEVICE_MAINT_HISTORY_2" />
+<column name="ELECTRICDEVICE_MAINT_1_ELEC1" />
+<column name="ELECTRICDEVICE_MAINT_1_DATE1" />
</sourceColumns>
<targetColumns>
<column name="ELECTRICDEVICE_FEATID" />
@@ -3310,15 +3310,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -3331,8 +3331,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -3349,7 +3349,7 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY" columnName="ELECTRICDEVICE_FEATID" colCreator="False" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" columnName="ELECTRICDEVICE_FEATID" colCreator="False" fixedCol="False" >
<column name="ELECTRICDEVICE_FEATID" description="" dataType="NUMBER" length="20" scale="0" nullable="False" >
</column>
@@ -3371,7 +3371,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -3391,13 +3391,13 @@
</column>
</column>
</column>
</table>
<tables>
<target>
</table>
@@ -3671,7 +3671,7 @@
</column>
</property>
</properties>
@@ -3683,7 +3683,7 @@
</column>
</table>
<tables>
</table>
</table>
@@ -3808,7 +3808,7 @@
</targetProperties>
@@ -3818,21 +3818,21 @@
</column>
</property>
</column>
</property>
</column>
</property>
@@ -3853,9 +3853,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -3885,9 +3885,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -3937,7 +3937,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -3969,7 +3969,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -4002,7 +4002,7 @@
</targetProperties>
<class xsi:type="Class" name="ElectricDevice.maintenance history" description="Autogenerated Object Property Class"
- tableName="ELECTRICDEVICE_MAINT_HISTORY" tblCreator="True" fixedTbl="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" tblCreator="True" fixedTbl="False" >
@@ -4012,15 +4012,15 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY" columnName="DATE1" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" columnName="DATE1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_MAINT_HISTORY" columnName="MAINTENANCE_HISTORY_DESCRIPTI1" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" columnName="MAINTENANCE_HISTORY_DESCRIP1" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -4040,7 +4040,7 @@
</targetProperties>
<class xsi:type="Class" name="ElectricDevice.maintenance history.work items" description="Autogenerated Object Property Class"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" tblCreator="True" fixedTbl="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" tblCreator="True" fixedTbl="False" >
@@ -4051,43 +4051,43 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="IT_M__" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="IT_M__" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="PART__" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="PART__" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="WORK_DESCRIPTION" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="WORK_DESCRIPTION" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="CLASSNAME1" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="CLASSNAME1" colCreator="True" fixedCol="False" >
</column>
</property>
dataType="int64" length="0" precision="0" scale="0"
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="ELECTRICDEVICE_MAINT_HISTORY_1" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="ELECTRICDEVICE_MAINT_1_ELEC1" colCreator="True" fixedCol="False" >
</column>
</property>
- tableName="ELECTRICDEVICE_MAINT_HISTORY_1" columnName="ELECTRICDEVICE_MAINT_HISTORY_2" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_2" columnName="ELECTRICDEVICE_MAINT_1_DATE1" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -4107,9 +4107,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -4122,8 +4122,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -4144,15 +4144,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -4165,8 +4165,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -4183,7 +4183,7 @@
- tableName="ELECTRICDEVICE_MAINT_HISTORY" columnName="ELECTRICDEVICE_FEATID" colCreator="True" fixedCol="False" >
+ tableName="ELECTRICDEVICE_MAINT_1" columnName="ELECTRICDEVICE_FEATID" colCreator="True" fixedCol="False" >
</column>
</property>
@@ -4204,7 +4204,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -4224,13 +4224,13 @@
</column>
</column>
</column>
</table>
<tables>
<target>
</table>
@@ -4383,7 +4383,7 @@
</targetProperties>
<class xsi:type="Class" name="Employee.home' address.street" description="Autogenerated Object Property Class"
- tableName="EMPLOYEE_A_ADDRESS_STREET" tblCreator="True" fixedTbl="False" >
+ tableName="EMPLOYEE_A_ADDRESS_ST1" tblCreator="True" fixedTbl="False" >
<property xsi:type="Data" name="Employee_First Name" />
@@ -4393,29 +4393,29 @@
<property xsi:type="Data" name="Name" description=""
- tableName="EMPLOYEE_A_ADDRESS_STREET" columnName="NAME" colCreator="True" fixedCol="False" >
+ tableName="EMPLOYEE_A_ADDRESS_ST1" columnName="NAME" colCreator="True" fixedCol="False" >
<column name="NAME" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="Type" description=""
- tableName="EMPLOYEE_A_ADDRESS_STREET" columnName="TYPE" colCreator="True" fixedCol="False" >
+ tableName="EMPLOYEE_A_ADDRESS_ST1" columnName="TYPE" colCreator="True" fixedCol="False" >
<column name="TYPE" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="Employee_First Name" description=""
- tableName="EMPLOYEE_A_ADDRESS_STREET" columnName="EMPLOYEE_A_ADDRESS_EMPLOYEE_F1" colCreator="True" fixedCol="False" >
-<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE_F1" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
+ tableName="EMPLOYEE_A_ADDRESS_ST1" columnName="EMPLOYEE_A_ADDRESS_EMPLOYEE1" colCreator="True" fixedCol="False" >
+<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE1" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
</column>
</property>
<property xsi:type="Data" name="Employee_Last Name" description=""
- tableName="EMPLOYEE_A_ADDRESS_STREET" columnName="EMPLOYEE_A_ADDRESS_EMPLOYEE_L1" colCreator="True" fixedCol="False" >
-<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE_L1" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
+ tableName="EMPLOYEE_A_ADDRESS_ST1" columnName="EMPLOYEE_A_ADDRESS_EMPLOYEE2" colCreator="True" fixedCol="False" >
+<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE2" description="" dataType="VARCHAR2" length="30" scale="0" nullable="False" >
</column>
</property>
@@ -4435,7 +4435,7 @@
</column>
</property>
</properties>
-<table name="EMPLOYEE_A_ADDRESS_STREET" description="" pkeyName="PK_EMPLOYEE_A_ADDRESS_STREET" >
+<table name="EMPLOYEE_A_ADDRESS_ST1" description="" pkeyName="PK_EMPLOYEE_A_ADDRESS1" >
<target>
<table name="EMPLOYEE_A_ADDRESS" description="" pkeyName="PK_EMPLOYEE_A_ADDRESS" >
<target>
@@ -4452,8 +4452,8 @@
</target>
</table>
<sourceColumns>
-<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE_F1" />
-<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE_L1" />
+<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE1" />
+<column name="EMPLOYEE_A_ADDRESS_EMPLOYEE2" />
</sourceColumns>
<targetColumns>
<column name="EMPLOYEE_FIRST_NAME" />
@@ -4468,13 +4468,13 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
@@ -4491,8 +4491,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -4636,7 +4636,7 @@
dataType="string" length="50" precision="0" scale="0"
</property>
@@ -4651,7 +4651,7 @@
</targetProperties>
@@ -4660,22 +4660,22 @@
</property>
</property>
</property>
</property>
@@ -5073,7 +5073,7 @@
</targetProperties>
@@ -5083,7 +5083,7 @@
</column>
@@ -5091,7 +5091,7 @@
</column>
@@ -5099,7 +5099,7 @@
</column>
@@ -5121,9 +5121,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -5153,9 +5153,9 @@
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -5206,7 +5206,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -5238,7 +5238,7 @@
</column>
</table>
<tables>
<target>
</table>
@@ -5272,7 +5272,7 @@
</targetProperties>
<class xsi:type="Class" name="Transformer.maintenance history" description="Autogenerated Object Property Class"
@@ -5282,7 +5282,7 @@
</column>
@@ -5290,9 +5290,9 @@
</column>
</property>
@@ -5313,7 +5313,7 @@
</targetProperties>
<class xsi:type="Class" name="Transformer.maintenance history.work items" description="Autogenerated Object Property Class"
@@ -5324,7 +5324,7 @@
</column>
@@ -5332,7 +5332,7 @@
</column>
@@ -5340,7 +5340,7 @@
</column>
@@ -5348,7 +5348,7 @@
</column>
@@ -5356,17 +5356,17 @@
</column>
</property>
</column>
</property>
@@ -5386,9 +5386,9 @@
</column>
</property>
</properties>
<target>
<target>
</table>
@@ -5401,8 +5401,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -5423,15 +5423,15 @@
</column>
</column>
</column>
</column>
</table>
<tables>
<target>
<target>
</table>
@@ -5444,8 +5444,8 @@
</target>
</table>
<sourceColumns>
</sourceColumns>
<targetColumns>
@@ -5462,7 +5462,7 @@
</column>
@@ -5484,7 +5484,7 @@
</column>
</property>
</properties>
<target>
</table>
@@ -5504,13 +5504,13 @@
</column>
</column>
</column>
</table>
<tables>
<target>
</table>
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test_ov3_master.txt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test_ov3_master.txt 2007-02-01 18:14:55 UTC (rev 725)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_test_ov3_master.txt 2007-02-02 16:07:20 UTC (rev 726)
@@ -29,7 +29,7 @@
<Table pkeyName="PK_CUSTOMER___BUSINESS" name="CUSTOMER___BUSINESS"/>
</complexType>
<complexType name="Customer-x20---x20-ResidentialType" tableMapping="Concrete">
-<Table pkeyName="PK_CUSTOMER___RESIDENTIAL" name="CUSTOMER___RESIDENTIAL"/>
+<Table pkeyName="PK_CUSTOMER___RESIDEN1" name="CUSTOMER___RESIDENTIAL"/>
</complexType>
<complexType name="ElectricDeviceType" tableMapping="Concrete">
<Table pkeyName="PK_ELECTRICDEVICE" name="ELECTRICDEVICE"/>
@@ -47,7 +47,7 @@
</element>
<element name="graphic">
<PropertyMappingConcrete>
-<Table pkeyName="PK_ELECTRICDEVICE_ENTITY" name="ELECTRICDEVICE_ENTITY"/>
+<Table pkeyName="PK_ELECTRICDEVICE_ENT2" name="ELECTRICDEVICE_ENTITY"/>
<element name="FeatId">
<Column name="FEATID"/>
</element>
@@ -59,7 +59,7 @@
</element>
<element name="xdata">
-<Table pkeyName="PK_ELECTRICDEVICE_ENTITY_ACXD1" name="ELECTRICDEVICE_ENTITY_ACXDATA"/>
+<Table pkeyName="PK_ELECTRICDEVICE_ENT1" name="ELECTRICDEVICE_ENTITY1"/>
<element name="Datavalue">
<Column name="DATAVALUE"/>
</element>
@@ -78,16 +78,16 @@
</element>
<element name="maintenance-x20-history">
-<Table pkeyName="PK_ELECTRICDEVICE_MAINT_HISTO2" name="ELECTRICDEVICE_MAINT_HISTORY"/>
+<Table pkeyName="PK_ELECTRICDEVICE_MAI2" name="ELECTRICDEVICE_MAINT_1"/>
<element name="Date">
<Column name="DATE1"/>
</element>
<element name="Maintenance-x20-History-x20-Description">
-<Column name="MAINTENANCE_HISTORY_DESCRIPTI1"/>
+<Column name="MAINTENANCE_HISTORY_DESCRIP1"/>
</element>
<element name="work-x20-items">
-<Table pkeyName="PK_ELECTRICDEVICE_MAINT_HISTO1" name="ELECTRICDEVICE_MAINT_HISTORY_1"/>
+<Table pkeyName="PK_ELECTRICDEVICE_MAI1" name="ELECTRICDEVICE_MAINT_2"/>
<element name="It-x27-m-x20--x23-">
<Column name="IT_M__"/>
</element>
@@ -101,10 +101,10 @@
<Column name="CLASSNAME1"/>
</element>
<element name="ElectricDevice_FeatId">
-<Column name="ELECTRICDEVICE_MAINT_HISTORY_1"/>
+<Column name="ELECTRICDEVICE_MAINT_1_ELEC1"/>
</element>
<element name="Maint-x20-History_Date">
-<Column name="ELECTRICDEVICE_MAINT_HISTORY_2"/>
+<Column name="ELECTRICDEVICE_MAINT_1_DATE1"/>
</element>
</PropertyMappingConcrete>
</element>
@@ -120,11 +120,11 @@
</element>
</element>
-<Table name="MAINT_HISTORY_MAINT_HISTORY_I1"/>
+<Table name="MAINT_HISTORY_MAINT_H1"/>
</element>
More information about the fdo-commits
