[fdo-commits] r718 - branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml
svn_fdo at osgeo.org svn_fdo at osgeo.org
Fri Feb 2 12:09:25 EST 2007
Author: romicadascalescu
Date: 2007-02-02 12:09:25 -0500 (Fri, 02 Feb 2007)
New Revision: 718
   branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp
   branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.h
   branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/GeometryHandler.cpp
   branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/GeometryHandler.h
   branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.cpp
   branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.h
Fixed WFS: Loading WFS layer does not get the geometry
Modified: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp
--- branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp	2007-02-02 16:05:28 UTC (rev 717)
+++ branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.cpp	2007-02-02 17:09:25 UTC (rev 718)
@@ -234,6 +234,17 @@
 			    break;
+		//direct gml geometry association
+		case GmlBaseType_GmlDirectGeometry:
+			m_parsingStateStack.push_back(ParsingState_GmlDirectGeometry);
+			m_geometryHandler = FdoXmlGeometryHandler::Create();
+            m_geometryHandler->SetExpectedGmlGeometry((FdoXmlGeometryHandler::GmlGeometryType)m_activeGmlGeometryType);
+            nextSaxHandler = m_geometryHandler->SkipFirstParseStep();
+            if (nextSaxHandler == NULL)
+                nextSaxHandler = m_geometryHandler;
+			break;
 		//gml geometry association
 		case GmlBaseType_GmlGeometryAssociation:
 			m_parsingStateStack.push_back(ParsingState_GmlGeometryAssociation);
@@ -395,111 +406,66 @@
 	case ParsingState_BoundingShape:
 		//"Bounds" is FDO property for gml:boundedBy
-        try
-		    tempGeometry =  m_geometryHandler->GetGeometry();
-		    if (tempGeometry)
-			    tempByteArray = tempGeometry->GetFgf();
-			    isPauseParsing = curFeatureHandler->FeatureGeometricProperty(m_featureContext,
-				    L"Bounds",
-				    tempByteArray->GetData(),
-				    tempByteArray->GetCount());
-        catch(FdoException* ex)
-        {ex->Release();}
-        catch(...)
+	    tempGeometry =  m_geometryHandler->GetGeometry();
+	    if (tempGeometry)
+		    tempByteArray = tempGeometry->GetFgf();
+            if (tempByteArray != NULL)
+		        isPauseParsing = curFeatureHandler->FeatureGeometricProperty(m_featureContext,
+			                L"Bounds", tempByteArray->GetData(), tempByteArray->GetCount());
+		FDO_SAFE_RELEASE(tempByteArray);
 		FDO_SAFE_RELEASE(tempGeometry);
-		FDO_SAFE_RELEASE(tempByteArray);
 		break;
-	//gml geometry association
+	//geometry association
+	case ParsingState_GmlDirectGeometry:
 	case ParsingState_GmlGeometryAssociation:
-        try
+	case ParsingState_GeometryAssociation:
+            if (curState == ParsingState_GmlDirectGeometry) // run last step only in this case
+                m_geometryHandler->RunLastParseStep(name, (FdoXmlGeometryHandler::GmlGeometryType)m_activeGmlGeometryType);
-            if (tempGeometry)
+            FdoStringP pPropName = name;
+            bool found = false;
+            FdoXmlLpClassDefinition* classDef = m_lpClassStack.back();
+            if (NULL != classDef)
-                FdoStringP pPropName = name;
-                bool found = false;
-                if (NULL != m_lpClassStack.back())
+                FdoString* pBaseName = classDef->PropertyMappingNameFromGmlAlias(name);
+                if (pBaseName != NULL)
-                    FdoXmlLpClassDefinition* classDef = m_lpClassStack.back();
-                    FdoString* pBaseName = classDef->PropertyMappingNameFromGmlAlias(name);
-                    if (pBaseName != NULL)
-                        pPropName = pBaseName;
-                        found = true;
+                    pPropName = pBaseName;
+                    found = true;
-                if (!found)
-                    pPropName = L"gml/";
-                    pPropName += name;
-                if (tempByteArray != NULL)
-			            pPropName,
-                } else
-			            pPropName,
-			            NULL,
-			            0);
-        {ex->Release();}
-        catch(...)
-		FDO_SAFE_RELEASE(tempGeometry);
-		break;
-	//geometry association
-	case ParsingState_GeometryAssociation:
-        try
-            if (tempGeometry)
+            // only in gml geometry association add in front gml/
+            if (!found && curState == ParsingState_GmlGeometryAssociation)
+                pPropName = L"gml/";
+                pPropName += name;
+            // match the names of geometry field
+                FdoString* pMainGeomPropName = classDef->GetMainGeometryPropertyName();
+                // in case we have only one geometry and the names are different
+                if (pMainGeomPropName != NULL && pPropName != pMainGeomPropName)
+                    pPropName = pMainGeomPropName;
+            FdoByte* arrayData = NULL;
+            FdoInt32 szArrayData = 0;
+	        if (tempGeometry){
+                if (tempByteArray != NULL){
+                arrayData = tempByteArray->GetData();
+                szArrayData = tempByteArray->GetCount();
-                if (tempByteArray != NULL) {
-			            pPropName,
-                } else {
-			            pPropName,
-			            NULL,
-			            0);
+		                pPropName, arrayData, szArrayData);
-        {ex->Release();}
-        catch(...)
 		break;
 	//Generic Complex Type
@@ -691,6 +657,54 @@
                         rv = GmlBaseType_GmlGeometryAssociation;
+                    else if (wcscmp(elementName, L"Point") == 0)
+                        m_activeGmlGeometryType = FdoXmlGeometryHandler::GmlGeometryType_Point;
+                        rv = GmlBaseType_GmlDirectGeometry;
+                    else if (wcscmp(elementName, L"Polygon") == 0)
+                        m_activeGmlGeometryType = FdoXmlGeometryHandler::GmlGeometryType_Polygon;
+                    else if (wcscmp(elementName, L"LineString") == 0)
+                        m_activeGmlGeometryType = FdoXmlGeometryHandler::GmlGeometryType_LineString;
+                    else if (wcscmp(elementName, L"LinearRing") == 0)
+                        m_activeGmlGeometryType = FdoXmlGeometryHandler::GmlGeometryType_LinearRing;
+                    else if (wcscmp(elementName, L"MultiPoint") == 0)
+                        m_activeGmlGeometryType = FdoXmlGeometryHandler::GmlGeometryType_MultiPoint;
+                    else if (wcscmp(elementName, L"MultiLineString") == 0)
+                        m_activeGmlGeometryType = FdoXmlGeometryHandler::GmlGeometryType_MultiLineString;
+                    else if (wcscmp(elementName, L"MultiPolygon") == 0)
+                        m_activeGmlGeometryType = FdoXmlGeometryHandler::GmlGeometryType_MultiPolygon;
+                    else if (wcscmp(elementName, L"MultiGeometry") == 0)
+                        m_activeGmlGeometryType = FdoXmlGeometryHandler::GmlGeometryType_MultiGeometry;
+                    else if (wcscmp(elementName, L"pointMember") == 0 ||
+                                wcscmp(elementName, L"lineStringMember") == 0 ||
+                                wcscmp(elementName, L"polygonMember") == 0 ||
+                                wcscmp(elementName, L"geometryMember") == 0)
+                        m_activeGmlGeometryType = FdoXmlGeometryHandler::GmlGeometryType_GeometryAssociation;
                 if (rv != GmlBaseType_Unknown)
                     break;
Modified: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.h
--- branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.h	2007-02-02 16:05:28 UTC (rev 717)
+++ branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/FeaturePropertyReaderImpl.h	2007-02-02 17:09:25 UTC (rev 718)
@@ -92,7 +92,8 @@
         GmlBaseType_Pending,
         GmlBaseType_hexBinary,
         GmlBaseType_base64Binary,
-		GmlBaseType_GmlGeometryAssociation
+		GmlBaseType_GmlGeometryAssociation,
+		GmlBaseType_GmlDirectGeometry
 	enum ParsingState{
@@ -108,7 +109,8 @@
         ParsingState_ElementPending,
         ParsingState_hexBinary,
         ParsingState_base64Binary,
-		ParsingState_GmlGeometryAssociation
+		ParsingState_GmlGeometryAssociation,
+        ParsingState_GmlDirectGeometry
Modified: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/GeometryHandler.cpp
--- branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/GeometryHandler.cpp	2007-02-02 16:05:28 UTC (rev 717)
+++ branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/GeometryHandler.cpp	2007-02-02 17:09:25 UTC (rev 718)
@@ -427,3 +427,130 @@
 	return geoType;
+FdoXmlSaxHandler* FdoXmlGeometryHandler::SkipFirstParseStep()
+	FdoXmlSaxHandler* nextHandler = NULL;
+	FdoXmlGeometry* newGeometry = NULL;
+	GmlGeometryType curType = m_typeGeomExpected;
+    m_typeGeomExpected = GmlGeometryType_Unknown;
+	switch(curType)
+	//Point
+	case GmlGeometryType_Point:
+		m_coordinates = FdoXmlCoordinateGroup::Create();
+		newGeometry = FdoXmlPoint::Create();
+		newGeometry->SetCoordinates(m_coordinates);
+		m_geometryStack.push_back(newGeometry);
+		break;
+	//LinearRing
+	case GmlGeometryType_LinearRing:
+		newGeometry = FdoXmlLinearRing::Create();
+		break;
+	//LineString
+	case GmlGeometryType_LineString:
+		newGeometry = FdoXmlLineString::Create();
+		break;
+	//Polygon
+	case GmlGeometryType_Polygon:
+		//NOTE: polygon is treated as a collection of Linear rings
+		//the first is the outer boundary
+		//the rest are the inner boundary
+		m_isMultiGeometry = true;
+		newGeometry = FdoXmlPolygon::Create();
+		break;
+	//MultiPoint
+	case GmlGeometryType_MultiPoint:
+		newGeometry = FdoXmlMultiPoint::Create();
+		break;
+	//MultiLineString
+	case GmlGeometryType_MultiLineString:
+		newGeometry = FdoXmlMultiLineString::Create();
+		break;
+	//MultiPolygon
+	case GmlGeometryType_MultiPolygon:
+		newGeometry = FdoXmlMultiPolygon::Create();
+		break;
+	//MultiGeometry
+	case GmlGeometryType_MultiGeometry:
+		newGeometry = FdoXmlMultiGeometry::Create();
+		break;
+	//Geometry Association
+	case GmlGeometryType_GeometryAssociation:
+		m_nestedHandler = new FdoXmlGeometryHandler();
+		nextHandler = m_nestedHandler;
+		break;
+	default:
+		m_parsingStateStack.push_back(ParsingState_Unknown);
+		break;
+	return nextHandler;
+void FdoXmlGeometryHandler::RunLastParseStep(FdoString* name, GmlGeometryType typeGeomExpected)
+    FdoXmlGeometry* curGeometry = NULL;
+    FdoPtr<FdoXmlGeometry> nestedGeometry;
+	if (m_nestedHandler != NULL && typeGeomExpected == GmlGeometryType_GeometryAssociation)
+	    if(!m_geometryStack.empty())
+		    curGeometry = m_geometryStack.back();
+		nestedGeometry = m_nestedHandler->GetGeometry();
+		if(m_isMultiGeometry){
+			curGeometry->AddGeometryMember(nestedGeometry);
+		else{
+			curGeometry->AddGeometricProperty(name, nestedGeometry);
Modified: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/GeometryHandler.h
--- branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/GeometryHandler.h	2007-02-02 16:05:28 UTC (rev 717)
+++ branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/GeometryHandler.h	2007-02-02 17:09:25 UTC (rev 718)
@@ -116,6 +116,8 @@
     void SetExpectedGmlGeometry(GmlGeometryType typeGeomExpected){m_typeGeomExpected = typeGeomExpected;};
     GmlGeometryType m_typeGeomExpected;
+    FdoXmlSaxHandler* SkipFirstParseStep();
+    void RunLastParseStep(FdoString* name, GmlGeometryType typeGeomExpected);
 typedef FdoPtr<FdoXmlGeometryHandler> FdoXmlGeometryHandlerP;
Modified: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.cpp
--- branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.cpp	2007-02-02 16:05:28 UTC (rev 717)
+++ branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.cpp	2007-02-02 17:09:25 UTC (rev 718)
@@ -24,6 +24,7 @@
 m_class(classDefinition), m_mapping(classMapping) {
     FDO_SAFE_ADDREF(m_class.p);
     FDO_SAFE_ADDREF(m_mapping.p);
+    m_mainGeometryPropertyName = NULL;
 FdoXmlLpClassDefinition::~FdoXmlLpClassDefinition() {
@@ -194,3 +195,29 @@
     return NULL;
+FdoString* FdoXmlLpClassDefinition::GetMainGeometryPropertyName()
+    if (m_mainGeometryPropertyName == NULL)
+        FdoPtr<FdoXmlLpPropertyCollection> props = GetProperties();
+        FdoInt32 count = props->GetCount();
+        for (int i = 0; i < count; i++)
+            FdoPtr<FdoXmlLpPropertyDefinition> prop = props->GetItem(i);
+            FdoPtr<FdoPropertyDefinition> propDef = prop->GetPropertyDefinition();
+            if (propDef != NULL && FdoPropertyType_GeometricProperty == propDef->GetPropertyType())
+                    m_mainGeometryPropertyName = propDef->GetName();
+                else
+                    // if there is more than one geometry prop return NULL
+                    break;
+    return m_mainGeometryPropertyName;
\ No newline at end of file
Modified: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.h
--- branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.h	2007-02-02 16:05:28 UTC (rev 717)
+++ branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Xml/LpClassDefinition.h	2007-02-02 17:09:25 UTC (rev 718)
@@ -73,6 +73,9 @@
     // get a mapping property name using an gml alias name if exist
     FdoString* PropertyMappingNameFromGmlAlias(FdoString* gmlName);
+    // get main geometry property name. If there are more than one geometry prop NULL will be returned
+    FdoString* GetMainGeometryPropertyName();
 protected:
     FdoXmlLpClassDefinition();
 	FdoXmlLpClassDefinition( FdoClassDefinition* classDefinition, FdoXmlClassMapping* classMapping );
@@ -85,6 +88,7 @@
     FdoPtr<FdoXmlClassMapping> m_mapping;
     FdoPtr<FdoXmlLpClassDefinition> m_baseClass;
     FdoPtr<FdoXmlLpPropertyCollection> m_properties;
+    FdoString* m_mainGeometryPropertyName;
 // helper
 private:
More information about the fdo-commits mailing list
