[fdo-commits] r730 - branches/3.2.x/Fdo/Managed/Src/OSGeo/Spatial
svn_fdo at osgeo.org svn_fdo at osgeo.org
Wed Feb 7 16:24:58 EST 2007
Author: gregboone
Date: 2007-02-07 16:24:58 -0500 (Wed, 07 Feb 2007)
New Revision: 730
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGridTransform.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialUtility.h
893057: DOC: FDO Managed API Documentation Updates
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGridTransform.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGridTransform.h	2007-02-07 19:58:06 UTC (rev 729)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialGridTransform.h	2007-02-07 21:24:58 UTC (rev 730)
@@ -50,31 +50,25 @@
     /// Input Floating-point X ordinate.
     /// \param coordinateY
     /// Input Floating-point Y ordinate.
-    /// \param xGrid
+    /// \param gridX
     /// Output Integer X ordinate.
-    /// \param yGrid
+    /// \param gridY
     /// Output Integer Y ordinate.
-    /// \return
-    /// Returns Nothing.
 	System::Void TransformToGrid(System::Double coordinateX, System::Double coordinateY, System::Int64* gridX, System::Int64* gridY);
     /// \brief
     /// Transform integer ordinates on the grid to floating-point ordinates.
+    /// \param gridX
+    /// Input Integer X ordinate.
+    /// \param gridY
+    /// Input Integer Y ordinate.
     /// \param coordinateX
-    /// Input Floating-point X ordinate.
+    /// Output Floating-point X ordinate.
-    /// Input Floating-point Y ordinate.
-    /// \param coordinateX
-    /// Output Integer X ordinate.
-    /// \param coordinateY
-    /// Output Integer Y ordinate.
+    /// Output Floating-point Y ordinate.
-    /// \return
 	System::Void TransformFromGrid(System::Int64 gridX, System::Int64 gridY, System::Double* coordinateX, System::Double* coordinateY);
 /// \cond DOXYGEN-IGNORE
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialUtility.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialUtility.h	2007-02-07 19:58:06 UTC (rev 729)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Spatial/mgSpatialUtility.h	2007-02-07 21:24:58 UTC (rev 730)
@@ -74,12 +74,8 @@
     /// \param geometry
     /// Input Geometry to validate
-    /// \param geometryTypesCount
-    /// Input Number of elements in the array given by geometryTypes. If zero, no constraint is used.
     /// Input Array of allowed geometry types. NULL is valid if geometryTypesCount is zero.
-    /// \param geometryComponentTypesCount
-    /// Input Number of elements in the array given by geometryComponentTypes. If zero, no constraint is used.
     /// Input Array of allowed geometry component types. NULL is valid if geometryComponentTypesCount is zero.
     /// \param dimensionality
@@ -90,12 +86,67 @@
 	static NAMESPACE_OSGEO_SPATIAL::SpatialGeometryValidity ValidateGeometryByType(NAMESPACE_OSGEO_GEOMETRY::IGeometry * geometry, NAMESPACE_OSGEO_COMMON::GeometryType geometryTypes [], NAMESPACE_OSGEO_COMMON::GeometryComponentType geometryComponentTypes [], System::Int32 dimensionality);
+    /// \brief
+    /// Evaluates if two FDO geometric objects spatially interact with each other based on a user supplied spatial operator.
+    /// For example: Contains, Crosses, Disjoint, Equals, Intersects, Overlaps, Touches, Within, CoveredBy, Inside, EnvelopeIntersects.
+    /// \param g1
+    /// Input Left hand Geometry to Evaluate
+    /// \param op
+    /// Input The spatial operation to apply to the left and right hand geometries
+    /// \param g2
+    /// Input Right hand Geometry to Evaluate
+    /// \return
+    /// Returns The tesselated Geometry.
 	static System::Boolean Evaluate(NAMESPACE_OSGEO_GEOMETRY::IGeometry * g1, NAMESPACE_OSGEO_FDO_FILTER::SpatialOperations op, NAMESPACE_OSGEO_GEOMETRY::IGeometry * g2);
+    /// \brief
+    /// Tesselates a curve geometry into a set of line strings that approximate the curve geometry.
+    /// \param curve
+    /// Input Geometry to tesselate
+    /// \return
 	static NAMESPACE_OSGEO_GEOMETRY::IGeometry* TesselateCurve( NAMESPACE_OSGEO_GEOMETRY::IGeometry* curve);
+    /// \brief
+    /// Gets the extents of a geometry contained in a byte array.
+    /// \param bytes
+    /// Input Geometry whose extents will be returned
+    /// \param minX
+    /// Output The minimim x position of the geometry
+    /// \param minY
+    /// Output The minimim y position of the geometry
+    /// \param maxX
+    /// Output The maximum x position of the geometry
+    /// \param maxY
+    /// Output The maximum y position of the geometry
 	static System::Void GetExtents(System::Byte bytes [],  System::Double* minX, System::Double* minY, System::Double* maxX,  System::Double* maxY);
+    /// \brief
+    /// \param bytes
+    /// \param minX
+    /// \param minY
+    /// \param minZ
+    /// Output The minimim z position of the geometry
+    /// \param maxX
+    /// \param maxY
+    /// \param maxZ
+    /// Output The maximum z position of the geometry
 	static System::Void GetExtents(System::Byte bytes [],  System::Double* minX, System::Double* minY, System::Double* minZ, System::Double* maxX,  System::Double* maxY, System::Double* maxZ);
     /// \brief
@@ -107,14 +158,30 @@
     /// Input X ordinate.
     /// Input Y ordinate.
+    /// \param isOnBoundary
+    /// Output Specifies if the specified point is on the boundary of the ring.
     /// \return
     /// Returns TRUE if the point is within ring or on its boundary, FALSE otherwise.
 	static System::Boolean PointInRing( NAMESPACE_OSGEO_GEOMETRY::ILinearRing* ring, System::Double coordinateX, System::Double coordinateY, System::Boolean* isOnBoundary);
-	static System::Boolean PointInRing( NAMESPACE_OSGEO_GEOMETRY::ILinearRing* ring, System::Double coordinateX, System::Double coordinateY);
     /// \brief
+    /// Tests whether a point is within a ring or not.
+    /// \param ring
+    /// Input Ring to test
+    /// \param coordinateX
+    /// Input X ordinate.
+    /// \param coordinateY
+    /// Input Y ordinate.
+    /// \return
+    /// Returns TRUE if the point is within ring or on its boundary, FALSE otherwise.
+    static System::Boolean PointInRing( NAMESPACE_OSGEO_GEOMETRY::ILinearRing* ring, System::Double coordinateX, System::Double coordinateY);
+    /// \brief
     /// Tests whether a point is within a polygon (including its islands) or not.
     /// \param polygon
@@ -123,18 +190,52 @@
+    /// \param isOnExtBoundary
+    /// Output Specifies if the specified point is on the exterior boundary of the polygon.
+    /// \param isOnInBoundary
+    /// Output Specifies if the specified point is on the interior boundary of the polygon.
     /// \return
     /// Returns TRUE if the point is within polygon or on its boundary, FALSE otherwise.
 	static System::Boolean PointInPolygon(NAMESPACE_OSGEO_GEOMETRY::IPolygon* polygon, System::Double coordinateX, System::Double coordinateY, System::Boolean * isOnExtBoundary, System::Boolean * isOnInBoundary);
-	static System::Boolean PointInPolygon(NAMESPACE_OSGEO_GEOMETRY::IPolygon* polygon, System::Double coordinateX, System::Double coordinateY, System::Boolean * isOnExtBoundary);
-	static System::Boolean PointInPolygon(NAMESPACE_OSGEO_GEOMETRY::IPolygon* polygon, System::Double coordinateX, System::Double coordinateY);
     /// \brief
+    /// Tests whether a point is within a polygon (including its islands) or not.
+    /// \param polygon
+    /// Input Polygon to test
+    /// \return
+    /// Returns TRUE if the point is within polygon or on its boundary, FALSE otherwise.
+    static System::Boolean PointInPolygon(NAMESPACE_OSGEO_GEOMETRY::IPolygon* polygon, System::Double coordinateX, System::Double coordinateY, System::Boolean * isOnExtBoundary);
+    /// \brief
+    /// \return
+    static System::Boolean PointInPolygon(NAMESPACE_OSGEO_GEOMETRY::IPolygon* polygon, System::Double coordinateX, System::Double coordinateY);
+    /// \brief
     /// Computes the area of a ring.
-    /// \param poly
+    /// \param ring
     /// \return
@@ -146,7 +247,7 @@
     /// \brief
     /// Computes the length (perimeter) of a ring.
-    /// \param poly
+    /// \param ring
     /// \return
More information about the fdo-commits mailing list
