[fdo-commits] r731 - branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry
svn_fdo at osgeo.org svn_fdo at osgeo.org
Wed Feb 7 16:26:45 EST 2007
Author: gregboone
Date: 2007-02-07 16:26:44 -0500 (Wed, 07 Feb 2007)
New Revision: 731
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgDirectPositionImpl.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgEnvelopeImpl.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgFgfGeometryFactory.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgGeometryFactoryAbstract.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPosition.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelope.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelopeImp.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.h
893057: DOC: FDO Managed API Documentation Updates
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgDirectPositionImpl.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgDirectPositionImpl.h	2007-02-07 21:24:58 UTC (rev 730)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgDirectPositionImpl.h	2007-02-07 21:26:44 UTC (rev 731)
@@ -177,7 +177,7 @@
     /// Gets the X ordinate.
     /// \return
-    /// Returns the X ordinate; default is numeric_limits<double>::quiet_NaN()
+    /// Returns the X ordinate; default is numeric_limits::quiet_NaN()
 	__property System::Double get_X();
@@ -196,7 +196,7 @@
     /// Gets the Y ordinate.
     /// \return
-    /// Returns the Y ordinate; default is numeric_limits<double>::quiet_NaN()
+    /// Returns the Y ordinate; default is numeric_limits::quiet_NaN()
 	__property System::Double get_Y();
@@ -215,14 +215,14 @@
     /// Gets the Z ordinate.
     /// \return
-    /// Returns the Z ordinate; default is numeric_limits<double>::quiet_NaN()
+    /// Returns the Z ordinate; default is numeric_limits::quiet_NaN()
 	__property System::Double get_Z();
     /// \brief
     /// Sets the Z ordinate.
-    /// \param z
+    /// \param value
     /// Input Z ordinate value
     /// \return
@@ -234,7 +234,7 @@
     /// Gets the M ordinate.
     /// \return
-    /// Returns the M ordinate; default is numeric_limits<double>::quiet_NaN()
+    /// Returns the M ordinate; default is numeric_limits::quiet_NaN()
 	__property System::Double get_M();
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgEnvelopeImpl.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgEnvelopeImpl.h	2007-02-07 21:24:58 UTC (rev 730)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgEnvelopeImpl.h	2007-02-07 21:26:44 UTC (rev 731)
@@ -38,28 +38,11 @@
 public:
     /// \brief
-    /// InEquality function for EnvelopeImpl.
-    /// \param right
-    /// Input envelope for comparison (right-hand-side of equation)
-    /// \param left
-    /// Input envelope for comparison (left-hand-side of equation)
-    /// \return
-    /// Returns true if the envelope ordinates are not equal.
-	static System::Boolean op_Inequality(EnvelopeImpl *left, EnvelopeImpl* right);
-    /// \brief
     /// Constructs a default instance of a EnvelopeImpl object.
     /// \remarks
     /// Ordinate values default to System::Double::NaN.
-    /// \return
-    /// Returns nothing
     EnvelopeImpl();
     /// \brief
@@ -77,9 +60,6 @@
     /// \param maxY
     /// Input Upper-right Y ordinate
-    /// \return
 	EnvelopeImpl(System::Double minX, System::Double minY,
 		System::Double maxX, System::Double maxY);
@@ -99,9 +79,6 @@
     /// \param maxZ
     /// Input Upper-right, front Z ordinate
-    /// \return
 	EnvelopeImpl(System::Double minX, System::Double minY, System::Double minZ,
 		System::Double maxX, System::Double maxY, System::Double maxZ);
@@ -111,9 +88,6 @@
     /// \param envelopeImpl
     /// Input envelope to copy
-    /// \return
     EnvelopeImpl(EnvelopeImpl* envelopeImpl);
     /// \brief
@@ -124,9 +98,6 @@
     /// \param upperRight
     /// Input Upper-right position
-    /// \return
 	EnvelopeImpl(NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* lowerLeft, NAMESPACE_OSGEO_GEOMETRY::IDirectPosition * upperRight);
     /// \brief
@@ -137,9 +108,6 @@
     /// \param ordinates
     /// Input ordinate array representing two positions
-    /// \return
 	EnvelopeImpl(System::Int32 dimensionType, System::Double ordinates __gc[]);
     /// \brief
@@ -157,6 +125,20 @@
 	static System::Boolean op_Equality(EnvelopeImpl *left, EnvelopeImpl* right);
     /// \brief
+    /// InEquality function for EnvelopeImpl.
+    /// \param right
+    /// Input envelope for comparison (right-hand-side of equation)
+    /// \param left
+    /// Input envelope for comparison (left-hand-side of equation)
+    /// \return
+    /// Returns true if the envelope ordinates are not equal.
+	static System::Boolean op_Inequality(EnvelopeImpl *left, EnvelopeImpl* right);
+    /// \brief
     /// Equality function for EnvelopeImpl.
     /// \param obj
@@ -175,7 +157,7 @@
     /// Gets the minimum X coordinate value.
     /// \return
-    /// Returns the minimum X ordinate; numeric_limits<double>::quiet_NaN() by default
+    /// Returns the minimum X ordinate; numeric_limits::quiet_NaN() by default
 	__property System::Double get_MinX();
@@ -194,7 +176,7 @@
     /// Gets the minimum Y coordinate value.
     /// \return
-    /// Returns the minimum Y ordinate; numeric_limits<double>::quiet_NaN() by default
+    /// Returns the minimum Y ordinate; numeric_limits::quiet_NaN() by default
     __property System::Double get_MinY();
@@ -213,7 +195,7 @@
     /// Gets the minimum Z coordinate value.
     /// \return
-    /// Returns the minimum Z ordinate; numeric_limits<double>::quiet_NaN() by default
+    /// Returns the minimum Z ordinate; numeric_limits::quiet_NaN() by default
 	__property System::Double get_MinZ();
@@ -232,7 +214,7 @@
     /// Gets the maximum X coordinate value.
     /// \return
-    /// Returns the maximum X ordinate; numeric_limits<double>::quiet_NaN() by default
+    /// Returns the maximum X ordinate; numeric_limits::quiet_NaN() by default
 	__property System::Double get_MaxX();
@@ -251,7 +233,7 @@
     /// Gets the maximum Y coordinate value.
     /// \return
-    /// Returns the maximum Y ordinate; numeric_limits<double>::quiet_NaN() by default
+    /// Returns the maximum Y ordinate; numeric_limits::quiet_NaN() by default
 	__property System::Double get_MaxY();
@@ -270,7 +252,7 @@
     /// Gets the maximum Z coordinate value.
     /// \return
-    /// Returns the maximum Z ordinate; numeric_limits<double>::quiet_NaN() by default
+    /// Returns the maximum Z ordinate; numeric_limits::quiet_NaN() by default
 	__property System::Double get_MaxZ();
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgFgfGeometryFactory.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgFgfGeometryFactory.h	2007-02-07 21:24:58 UTC (rev 730)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgFgfGeometryFactory.h	2007-02-07 21:26:44 UTC (rev 731)
@@ -125,7 +125,7 @@
     /// \brief
     /// Creates an FGF-based Geometry from OpenGIS WKB data.
-    /// \param byteArray
+    /// \param bytes
     /// Input WKB data that defines the Geometry.
     /// \return
@@ -306,7 +306,7 @@
     /// \brief
     /// Creates a LineStringSegment object by copying from an array of ordinates.
-    /// \param dimtype
+    /// \param dimType
     /// Input dimensionality of the ordinates (see Dimensionality)
     /// \param ordinateNumber
     /// Input total number of ordinates in the array
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgGeometryFactoryAbstract.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgGeometryFactoryAbstract.h	2007-02-07 21:24:58 UTC (rev 730)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgGeometryFactoryAbstract.h	2007-02-07 21:26:44 UTC (rev 731)
@@ -409,7 +409,7 @@
     /// \brief
@@ -505,7 +505,7 @@
     /// \param startPosition
     /// Input starting position of the arc
-    /// \param coordinateMidPosition
+    /// \param midPosition
     /// Input a position on the arc, and not equal to the starting or ending positions
     /// \param endPosition
     /// Input ending position of the arc
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPosition.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPosition.h	2007-02-07 21:24:58 UTC (rev 730)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPosition.h	2007-02-07 21:26:44 UTC (rev 731)
@@ -37,7 +37,7 @@
     /// \return
@@ -45,7 +45,7 @@
     /// \return
@@ -53,7 +53,7 @@
     /// \return
@@ -61,7 +61,7 @@
     /// \return
@@ -87,6 +87,14 @@
 public:
     /// \brief
+    /// Creates an instance of DirectPositionCollection with no contained elements.
+    /// \return
+    /// Returns an empty collection
+	DirectPositionCollection();
+    /// \brief
     /// Constructs a DirectPositionCollection managed object based on an unmanaged instance of the object
     /// \param unmanaged
@@ -98,10 +106,10 @@
 	DirectPositionCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
+/// \cond DOXYGEN-IGNORE
 public private:
 	FdoDirectPositionCollection *GetImpObj();
-/// \cond DOXYGEN-IGNORE
 protected:
 	__sealed System::Void ReleaseUnmanagedObject();
@@ -175,14 +183,6 @@
         System::Void Reset();
-public:
-    /// \brief
-    /// Creates an instance of DirectPositionCollection with no contained elements.
-    /// \return
-    /// Returns an empty collection
-	DirectPositionCollection();
 private:
     // System::Collections::ICollection interface properties
@@ -205,6 +205,8 @@
     System::Void System::Collections::IList::Insert(System::Int32 index, Object* value);
     System::Void System::Collections::IList::Remove(Object* value);
+/// \endcond
 public:
     /// \brief
     /// Gets the count of items in collection.
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.h	2007-02-07 21:24:58 UTC (rev 730)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.h	2007-02-07 21:26:44 UTC (rev 731)
@@ -58,7 +58,7 @@
     /// \return
@@ -66,7 +66,7 @@
     /// \return
@@ -74,7 +74,7 @@
     /// \return
@@ -82,7 +82,7 @@
     /// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelope.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelope.h	2007-02-07 21:24:58 UTC (rev 730)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelope.h	2007-02-07 21:26:44 UTC (rev 731)
@@ -28,7 +28,7 @@
 /// known in 2 dimensions as an MBR ("Minimum Bounding Rectangle").
 /// The box may be initially empty, meaning that no dimensions have an assigned value.
 /// Each individual extent may be unassigned, in which case using its
-/// accessor will return numeric_limits<double>::quiet_NaN().
+/// accessor will return numeric_limits::quiet_NaN().
 public __gc __interface IEnvelope : public System::IDisposable
 public:
@@ -42,7 +42,7 @@
     /// corner of the envelope.
     /// \return
-    /// Returns the miniumum X ordinate; numeric_limits<double>::quiet_NaN() by default
+    /// Returns the miniumum X ordinate; numeric_limits::quiet_NaN() by default
@@ -56,7 +56,7 @@
     /// \return
-    /// Returns the miniumum Y ordinate; numeric_limits<double>::quiet_NaN() by default
+    /// Returns the miniumum Y ordinate; numeric_limits::quiet_NaN() by default
@@ -70,7 +70,7 @@
     /// \return
-    /// Returns the miniumum Z ordinate; numeric_limits<double>::quiet_NaN() by default
+    /// Returns the miniumum Z ordinate; numeric_limits::quiet_NaN() by default
@@ -84,7 +84,7 @@
     /// \return
-    /// Returns the maxiumum X ordinate; numeric_limits<double>::quiet_NaN() by default
+    /// Returns the maxiumum X ordinate; numeric_limits::quiet_NaN() by default
@@ -98,7 +98,7 @@
     /// \return
-    /// Returns the maxiumum Y ordinate; numeric_limits<double>::quiet_NaN() by default
+    /// Returns the maxiumum Y ordinate; numeric_limits::quiet_NaN() by default
@@ -112,7 +112,7 @@
     /// \return
-    /// Returns the maxiumum Z ordinate; numeric_limits<double>::quiet_NaN() by default
+    /// Returns the maxiumum Z ordinate; numeric_limits::quiet_NaN() by default
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelopeImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelopeImp.h	2007-02-07 21:24:58 UTC (rev 730)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIEnvelopeImp.h	2007-02-07 21:26:44 UTC (rev 731)
@@ -28,12 +28,12 @@
 /// The IEnvelopeImp class is a three-dimensional, axis-aligned box.  This is a
 /// helper type for Geometries, and does not itself inherit from
 /// IGeometry.
+/// \remarks
 /// This type is typically used to record the "extents" of a shape, also
-/// assigned value.
-/// each individual extent may be unassigned, in which case using its
+/// assigned value. Each individual extent may be unassigned, in which case using its
 public __gc class IEnvelopeImp : public NAMESPACE_OSGEO_RUNTIME::Disposable, public NAMESPACE_OSGEO_GEOMETRY::IEnvelope
 public:
@@ -65,7 +65,7 @@
     /// \return
@@ -79,7 +79,7 @@
     /// \return
@@ -93,7 +93,7 @@
     /// \return
@@ -107,7 +107,7 @@
     /// \return
@@ -121,7 +121,7 @@
     /// \return
@@ -135,7 +135,7 @@
     /// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.h	2007-02-07 21:24:58 UTC (rev 730)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.h	2007-02-07 21:26:44 UTC (rev 731)
@@ -81,13 +81,13 @@
     /// \param index
     /// Input Zero-based index in the object's list of positions.
-    /// \param x
+    /// \param coordinateX
     /// Output X ordinate value.
-    /// \param y
+    /// \param coordinateY
     /// Output Y ordinate value.
-    /// \param z
+    /// \param coordinateZ
     /// Output Z ordinate value.
-    /// \param m
+    /// \param coordinateM
     /// Output M ordinate value.
     /// \param dimensionality
     /// Output Dimensionality of ordinates in this position.
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.h	2007-02-07 21:24:58 UTC (rev 730)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.h	2007-02-07 21:26:44 UTC (rev 731)
@@ -81,13 +81,13 @@
     /// \param index
-    /// \param x
-    /// \param y
-    /// \param z
-    /// \param m
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.h	2007-02-07 21:24:58 UTC (rev 730)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.h	2007-02-07 21:26:44 UTC (rev 731)
@@ -65,13 +65,13 @@
     /// does not internally use FdoIDirectPosition objects for storage, or for
     /// an application seeking to avoid overhead of accessor methods.
-    /// \param x
-    /// \param y
-    /// \param z
-    /// \param m
More information about the fdo-commits mailing list
