[fdo-commits] r734 - in
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands: . Feature
LongTransaction SQL Schema SpatialContext
svn_fdo at osgeo.org
Wed Feb 7 16:41:25 EST 2007
Author: gregboone
Date: 2007-02-07 16:41:24 -0500 (Wed, 07 Feb 2007)
New Revision: 734
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReaderImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgLongTransactionConflictResolution.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgLongTransactionPrivileges.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReader.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReaderImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIPhysicalElementMapping.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalElementMapping.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalSchemaMappingCollection.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContext.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContextImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReader.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReaderImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgBatchParameterValueCollection.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgCommandType.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIdentifierCollection.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValueCollection.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValueCollection.h
893057: DOC: FDO Managed API Documentation Updates
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReaderImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReaderImp.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Feature/mgIFeatureReaderImp.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -73,8 +73,6 @@
/// \param propertyName
/// Input the property name.
- /// \param count
- /// Output the number of bytes in the array.
/// \return
/// Returns a pointer to the byte array in FGF format.
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgLongTransactionConflictResolution.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgLongTransactionConflictResolution.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgLongTransactionConflictResolution.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -23,27 +23,22 @@
/// \brief
/// The LongTransactionConflictResolution enumeration defines the list of
/// available options for resolving conflict.
-/// <param name="LongTransactionConflictResolution_Unresolved">
+/// \param LongTransactionConflictResolution_Unresolved
/// Indicates that the conflict cannot be resolved.
-/// </param>
-/// <param name="LongTransactionConflictResolution_Child">
+/// \param LongTransactionConflictResolution_Child
/// Indicates the data is to be kept as defined in the long transaction to be committed,
/// overwriting the data in the long transaction's parent.
-/// </param>
-/// <param name="LongTransactionConflictResolution_Parent">
+/// \param LongTransactionConflictResolution_Parent
/// Indicates the data is to be kept as defined in the versions parent, discarding the data
/// as defined in the long transaction to be committed.
-/// </param>
public __value enum LongTransactionConflictResolution
LongTransactionConflictResolution_Unresolved = FdoLongTransactionConflictResolution_Unresolved,
- /// Keep the data as defined in the long transaction to be committed,
- /// overwriting the data in the long transaction's parent.
LongTransactionConflictResolution_Child = FdoLongTransactionConflictResolution_Child,
- /// Keep the data as defined in the versions parent, discarding the data
- /// as defined in the long transaction to be committed.
LongTransactionConflictResolution_Parent = FdoLongTransactionConflictResolution_Parent
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgLongTransactionPrivileges.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgLongTransactionPrivileges.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/LongTransaction/mgLongTransactionPrivileges.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -23,67 +23,45 @@
/// \brief
/// The LongTransactionPrivileges enumeration defines the long transaction
/// privilege flags.
-/// <param name="LongTransactionPrivileges_Access">
+/// \param LongTransactionPrivileges_Access
/// The access privilege is required for a user if the user needs to access
/// a long transaction.
-/// </param>
-/// <param name="LongTransactionPrivileges_Create">
+/// \param LongTransactionPrivileges_Create
/// A user must have access and create privileges on the active long
/// transaction if the user wants to create a new long transaction as a
/// descendent of the active long transaction.
-/// </param>
-/// <param name="LongTransactionPrivileges_Commit">
+/// \param LongTransactionPrivileges_Commit
/// A user must have access and commit privileges on a long transaction
/// in order to commit it. In addition, the user needs access privilege to
/// the long transaction's parent. The user also needs remove privilege on
/// the long transaction to be committed if the operation to be executed
/// is a commit and not a partial commit.
-/// </param>
-/// <param name="LongTransactionPrivileges_Rollback">
+/// \param LongTransactionPrivileges_Rollback
/// A user must have access and rollback privileges on a long transaction
/// in order to roll it back. In addition, the user requires access
/// privilege for each of the descendent versions involved in the operation. The user also requires the remove privilege for each of the versions involved in the operation if a rollback and not a partial rollback operation is executed.
-/// </param>
-/// <param name="LongTransactionPrivileges_Remove">
+/// \param LongTransactionPrivileges_Remove
/// The long transaction privilege is required if the user should be allowed to remove the
/// long transaction in the progress of a commit or roll back operation.
-/// </param>
-/// <param name="LongTransactionPrivileges_Freeze">
+/// \param LongTransactionPrivileges_Freeze
/// The user requires the access and freeze privileges on a long
/// transaction for which the user wants to gain exclusive access to a
/// long transaction.
-/// </param>
[System::FlagsAttribute]
public __value enum LongTransactionPrivileges
- /// The access privilege is required for a user if the user needs to access
- /// a long transaction.
LongTransactionPrivileges_Access = FdoLongTransactionPrivileges_Access,
- /// A user must have access and create privileges on the active long
- /// transaction if the user wants to create a new long transaction as a
- /// descendent of the active long transaction.
LongTransactionPrivileges_Create = FdoLongTransactionPrivileges_Create,
- /// A user must have access and commit privileges on a long transaction
- /// in order to commit it. In addition, the user needs access privilege to
- /// the long transaction's parent. The user also needs remove privilege on
- /// the long transaction to be committed if the operation to be executed
- /// is a commit and not a partial commit.
LongTransactionPrivileges_Commit = FdoLongTransactionPrivileges_Commit,
- /// A user must have access and rollback privileges on a long transaction
- /// in order to roll it back. In addition, the user requires access
- /// privilege for each of the descendent versions involved in the operation. The user also requires the remove privilege for each of the versions involved in the operation if a rollback and not a partial rollback operation is executed.
LongTransactionPrivileges_Rollback = FdoLongTransactionPrivileges_Rollback,
- /// The privilege is required if the user should be allowed to remove the
- /// long transaction in the progress of a commit or roll back operation.
LongTransactionPrivileges_Remove = FdoLongTransactionPrivileges_Remove,
- /// The user requires the access and freeze privileges on a long
- /// transaction for which the user wants to gain exclusive access to a
- /// long transaction.
LongTransactionPrivileges_Freeze = FdoLongTransactionPrivileges_Freeze
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReader.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReader.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReader.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -72,10 +72,10 @@
/// \brief
/// Gets property type of the column with the specified name. This is used
- /// to indicate if a given column is a geometric property or a data property. If the column is
- /// a PropertyType_DataProperty, then GetColumnType can be used to find the data type of the column.
+ /// to indicate if a given column is a geometric property or a data property. If the column is
+ /// a PropertyType_DataProperty, then GetColumnType can be used to find the data type of the column.
- /// \param propertyName
+ /// \param name
/// Input the column name.
/// \return
@@ -205,7 +205,7 @@
/// Because no conversion is performed, the property must be DataType_BLOB or
/// DataType_CLOB etc. (a LOB type)
+ /// \param name
/// \return
@@ -220,7 +220,7 @@
/// or DataType_CLOB etc. (a LOB type)
/// Cast the IStreamReader to the appropiate LOB Stream Reader.
+ /// \param name
/// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReaderImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReaderImp.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SQL/mgISQLDataReaderImp.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -77,10 +77,10 @@
/// \brief
+ /// \param name
/// \return
@@ -210,7 +210,7 @@
+ /// \param name
/// \return
@@ -225,7 +225,7 @@
+ /// \param name
/// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIPhysicalElementMapping.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIPhysicalElementMapping.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgIPhysicalElementMapping.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -57,7 +57,7 @@
/// been added to a parent object.
/// \return
- /// Returns PhysicalElementMapping of parent
+ /// Returns the PhysicalElementMapping of the parent
__property NAMESPACE_OSGEO_FDO_COMMANDS_SCHEMA::IPhysicalElementMapping* get_Parent();
@@ -87,19 +87,20 @@
__property System::String* get_Name();
/// \brief
- /// Sets the name of this element.
+ /// Gets the fully qualified name of this element.
- /// \param value
- /// Input the name of this element.
/// \return
- /// Returns nothing
+ /// Returns the qualified name of this element.
__property System::String* get_QualifiedName();
- // Indicates that this object allows its name
- // to change. This function is defined so that this class can
- // be a NamedCollection element.
+ /// \brief
+ /// Indicates whether the name of the Element can be changed once
+ /// it has been created.
+ /// \return
+ /// Returns true if the Element name can be changed; otherwise false.
__property System::Boolean get_CanSetName();
/// \brief
@@ -132,15 +133,67 @@
System::Void WriteXml(NAMESPACE_OSGEO_COMMON_XML::XmlWriter* xmlWriter, NAMESPACE_OSGEO_FDO_XML::XmlFlags* flags);
- /// Various error reporting functions that are not yet part of the supported FDO API.
- /// All of them return a XmlSkipElementHandler, which can be used to skip
- /// over the element in error.
+ /// \brief
+ /// Error reporting function that are not yet part of the supported FDO API.
+ /// Return a XmlSkipElementHandler, which can be used to skip over the element in error.
+ /// \param context
+ /// Input context contain information about the current deserialization operation
+ /// \param parentElement
+ /// Input the XML parent element
+ /// \param subElement
+ /// Input the XML sub element
NAMESPACE_OSGEO_COMMON_XML::IXmlSaxHandler* SubElementError(NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* context, System::String* parentElement, System::String* subElement);
+ /// \brief
NAMESPACE_OSGEO_COMMON_XML::IXmlSaxHandler* MultiSubElementError(NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* context, System::String* parentElement, System::String* subElement);
+ /// \brief
+ /// \param subElements
+ /// Input the list of the XML sub elements
NAMESPACE_OSGEO_COMMON_XML::IXmlSaxHandler* ChoiceSubElementError(NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* context, System::String* parentElement, NAMESPACE_OSGEO_COMMON::StringCollection* subElements);
+ /// \brief
+ /// \param subElementName
+ /// Input the XML sub element name
NAMESPACE_OSGEO_COMMON_XML::IXmlSaxHandler* DuplicateSubElementError(NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* context, System::String* parentElement, System::String* subElement, System::String* subElementName);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalElementMapping.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalElementMapping.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalElementMapping.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -61,7 +61,7 @@
/// \return
@@ -70,7 +70,7 @@
/// object has not been added to a feature schema.
/// \return
- /// Returns PhysicalSchemaMapping this object is a part of
+ /// Returns the PhysicalSchemaMapping this object is a part of
__property NAMESPACE_OSGEO_FDO_COMMANDS_SCHEMA::PhysicalSchemaMapping* get_SchemaMapping();
@@ -86,24 +86,26 @@
/// \return
- /// default implementation simply returns the element name
+ /// The Default implementation simply returns the element name
/// \brief
- /// \param value
/// \return
+ /// \brief
+ /// \return
+ /// Returns true if the name of the object can be changed.
/// \brief
@@ -136,15 +138,67 @@
+ /// \brief
+ /// \brief
+ /// \brief
+ /// \brief
/// \cond DOXYGEN-IGNORE
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalSchemaMappingCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalSchemaMappingCollection.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/Schema/mgPhysicalSchemaMappingCollection.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -158,7 +158,7 @@
/// \return
/// Returns StringCollection
PhysicalSchemaMappingCollection();
/// \brief
@@ -246,12 +246,12 @@
/// \param array
/// Output the one-dimensional Array that is the destination of the elements copied from this collection.
/// \param startAt
/// Input an integer that represents the index in array at which copying begins.
- System::Void CopyTo(NAMESPACE_OSGEO_FDO_COMMANDS_SCHEMA::PhysicalSchemaMapping* array[],System::Int32 size);
+ System::Void CopyTo(NAMESPACE_OSGEO_FDO_COMMANDS_SCHEMA::PhysicalSchemaMapping* array[],System::Int32 startAt);
/// \brief
/// Gets the item in the collection at the specified index.
@@ -310,7 +310,7 @@
/// \return
/// Returns the Schema Override set at the specified index
- NAMESPACE_OSGEO_FDO_COMMANDS_SCHEMA::PhysicalSchemaMapping* GetItem(System::Int32 item);
+ NAMESPACE_OSGEO_FDO_COMMANDS_SCHEMA::PhysicalSchemaMapping* GetItem(System::Int32 index);
/// \brief
/// Gets the Schema Override set for the specified
@@ -337,13 +337,13 @@
/// provider name.
/// \param connection
- /// Input connection.
+ /// Input the FDO connection.
/// \param schemaName
/// Input Feature Schema name.
/// \return
/// Returns the Schema Override set for the given Feature Schema and
- /// Provider for the given connection. NULL is return if the set was not
+ /// Provider for the given connection. NULL is return if the set was not
/// found.
NAMESPACE_OSGEO_FDO_COMMANDS_SCHEMA::PhysicalSchemaMapping * GetItem(NAMESPACE_OSGEO_FDO_CONNECTIONS::IConnection* connection, System::String* schemaName);
@@ -351,6 +351,7 @@
IXmlSaxHandler Implemenations
/// \brief
/// Default Sax callback that is called when the XmlReader
/// starts reading an XML document. Does nothing.
@@ -362,7 +363,7 @@
/// Returns the SAX Handler for the document's root element. If NULL then
/// this SAX handler will handle the root element
- NAMESPACE_OSGEO_COMMON_XML::IXmlSaxHandler* XmlStartDocument(NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* context);
+ NAMESPACE_OSGEO_COMMON_XML::IXmlSaxHandler* XmlStartDocument(NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* saxContext);
/// \brief
@@ -371,7 +372,7 @@
/// \param saxContext
/// Input caller specified contextual information
- System::Void XmlEndDocument(NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* context);
+ System::Void XmlEndDocument(NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* saxContext);
/// \brief
@@ -431,58 +432,85 @@
IXmlDeserializable Implemenations
/// \brief
/// Reads from an XML document in a file.
/// \param fileName
/// Input the file name. Must consist of an XML document.
+ System::Void ReadXml(System::String* fileName);
+ /// \brief
+ /// Reads from an XML document in a file.
+ /// \param fileName
+ /// Input the file name. Must consist of an XML document.
/// \param flags
/// Input controls the reading of the elements from the document.
/// If NULL then the default flags are used (see NAMESPACE_OSGEO_FDO_XML::XmlFlags::Create())
- System::Void ReadXml(System::String* fileName);
System::Void ReadXml(System::String* fileName, NAMESPACE_OSGEO_FDO_XML::XmlFlags* flags);
/// \brief
/// Reads an XML document from an XML reader.
- /// \param reader
+ /// \param xmlReader
/// Input the XML reader.
+ System::Void ReadXml(NAMESPACE_OSGEO_COMMON_XML::XmlReader* xmlReader);
+ /// \brief
+ /// Reads an XML document from an XML reader.
+ /// Input the XML reader.
/// \param flags
- System::Void ReadXml(NAMESPACE_OSGEO_COMMON_XML::XmlReader* xmlReader);
System::Void ReadXml(NAMESPACE_OSGEO_COMMON_XML::XmlReader* xmlReader, NAMESPACE_OSGEO_FDO_XML::XmlFlags* flags);
/// \brief
/// Reads an XML document from a text reader.
- /// \param reader
+ /// \param textReader
/// Input the text reader. Must be positioned at the
/// start of an XML document.
+ System::Void ReadXml(NAMESPACE_OSGEO_COMMON_IO::IoTextReader* textReader);
+ /// \brief
+ /// Reads an XML document from a text reader.
+ /// Input the text reader. Must be positioned at the
+ /// start of an XML document.
/// \param flags
- System::Void ReadXml(NAMESPACE_OSGEO_COMMON_IO::IoTextReader* textReader);
System::Void ReadXml(NAMESPACE_OSGEO_COMMON_IO::IoTextReader* textReader, NAMESPACE_OSGEO_FDO_XML::XmlFlags* flags);
/// \brief
/// Reads an XML document from a stream.
- /// \param reader
+ /// \param stream
/// Input the stream. Must be positioned at the
+ System::Void ReadXml(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream);
+ /// \brief
+ /// Reads an XML document from a stream.
+ /// \param stream
+ /// Input the stream. Must be positioned at the
/// \param flags
- System::Void ReadXml(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream);
System::Void ReadXml(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream, NAMESPACE_OSGEO_FDO_XML::XmlFlags* flags);
/// \brief
@@ -531,18 +559,26 @@
IXmlSerializable Implemenations
/// \brief
/// Writes this object to a file. A complete XML document,
/// containing this object, is written.
/// \param fileName
+ System::Void WriteXml(String* fileName);
+ /// \brief
+ /// Writes this object to a file. A complete XML document,
+ /// containing this object, is written.
/// \param flags
/// Input controls the writing of the elements to the document.
/// If NULL then the default flags are used (see XmlFlags::Create())
- System::Void WriteXml(String* fileName);
System::Void WriteXml(String* fileName, NAMESPACE_OSGEO_FDO_XML::XmlFlags* flags);
/// \brief
@@ -553,12 +589,21 @@
/// \param xmlWriter
/// Input the XML writer. When this function completes, the
/// XML writer's current position will be just after this object.
+ System::Void WriteXml(NAMESPACE_OSGEO_COMMON_XML::XmlWriter* xmlWriter);
+ /// \brief
+ /// Writes to an XML writer. This object is appended to the XML document
+ /// being written. Unlike the other WriteXml() functions it is not necessarily
+ /// the only object in its document.
+ /// \param xmlWriter
+ /// Input the XML writer. When this function completes, the
+ /// XML writer's current position will be just after this object.
/// \param flags
/// Input controls the writing of the elements to the writer.
- System::Void WriteXml(NAMESPACE_OSGEO_COMMON_XML::XmlWriter* xmlWriter);
/// \brief
@@ -568,12 +613,20 @@
/// \param textWriter
/// Input the text writer.When this function completes, the
/// text writer's current position will be just after this object.
+ System::Void WriteXml(NAMESPACE_OSGEO_COMMON_IO::IoTextWriter* textWriter);
+ /// \brief
+ /// Writes to a text writer. A complete XML document,
+ /// \param textWriter
+ /// Input the text writer.When this function completes, the
+ /// text writer's current position will be just after this object.
/// \param flags
- System::Void WriteXml(NAMESPACE_OSGEO_COMMON_IO::IoTextWriter* textWriter);
System::Void WriteXml(NAMESPACE_OSGEO_COMMON_IO::IoTextWriter* textWriter, NAMESPACE_OSGEO_FDO_XML::XmlFlags* flags);
/// \brief
@@ -583,12 +636,20 @@
/// \param stream
/// Input the stream. When this function completes, the
/// stream's current position will be just after this object.
+ System::Void WriteXml(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream);
+ /// \brief
+ /// Writes to a stream. A complete XML document,
+ /// \param stream
+ /// Input the stream. When this function completes, the
+ /// stream's current position will be just after this object.
/// \param flags
/// Input controls the writing of the elements to the stream.
- System::Void WriteXml(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream);
System::Void WriteXml(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream, NAMESPACE_OSGEO_FDO_XML::XmlFlags* flags);
/// \brief
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContext.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContext.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContext.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -151,7 +151,7 @@
/// Sets the extent of the context to create as a byte array in FGF format.
/// If the extent type is dynamic this is optional and any value specified is ignored.
- /// \param value
+ /// \param buffer
/// Input the extent of the spatial context
/// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContextImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContextImp.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgICreateSpatialContextImp.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -156,7 +156,7 @@
- /// \param value
+ /// \param buffer
/// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReader.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReader.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReader.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -79,9 +79,6 @@
/// Gets the extent of the spatial context currently being read as a byte
/// array in FGF format.
- /// \param length
- /// Output the length of the returned byte array.
/// \return
/// Returns the extent as a byte array in FGF format.
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReaderImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReaderImp.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/SpatialContext/mgISpatialContextReaderImp.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -85,9 +85,6 @@
- /// \param length
/// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgBatchParameterValueCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgBatchParameterValueCollection.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgBatchParameterValueCollection.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -229,10 +229,11 @@
/// \param array
- /// \param startAt
+ /// \param index
- System::Void CopyTo(NAMESPACE_OSGEO_FDO_COMMANDS::ParameterValueCollection* array[],System::Int32 size);
+ System::Void CopyTo(NAMESPACE_OSGEO_FDO_COMMANDS::ParameterValueCollection* array[],System::Int32 index);
/// \brief
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgCommandType.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgCommandType.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgCommandType.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -21,322 +21,219 @@
BEGIN_NAMESPACE_OSGEO_FDO_COMMANDS
/// \brief
-/// The CommandType enumeration defines the list of abstract commands a feature
-/// provider can support.
-/// <param name="CommandType_Select">
+/// The CommandType enumeration defines the list of abstract commands a feature provider can support.
+/// \param CommandType_Select
/// Represents the Select command
-/// </param>
-/// <param name="CommandType_Insert">
+/// \param CommandType_Insert
/// Represents the Insert command
-/// </param>
-/// <param name="CommandType_Delete">
+/// \param CommandType_Delete
/// Represents the Delete command
-/// </param>
-/// <param name="CommandType_Update">
+/// \param CommandType_Update
/// Represents the Update command
-/// </param>
-/// <param name="CommandType_DescribeSchema">
+/// \param CommandType_DescribeSchema
/// Represents the DescribeSchema command
-/// </param>
-/// <param name="CommandType_DescribeSchemaMapping">
+/// \param CommandType_DescribeSchemaMapping
/// Represents the DescribeSchemaMapping command
-/// </param>
-/// <param name="CommandType_ApplySchema">
+/// \param CommandType_ApplySchema
/// Represents the ApplySchema command.
-/// </param>
-/// <param name="CommandType_DestroySchema">
+/// \param CommandType_DestroySchema
/// Represents the DestroySchema command.
-/// </param>
-/// <param name="CommandType_ActivateSpatialContext">
+/// \param CommandType_ActivateSpatialContext
/// Represents the ActivateSpatialContext command.
-/// </param>
-/// <param name="CommandType_CreateSpatialContext">
+/// \param CommandType_CreateSpatialContext
/// Represents the CreateSpatialContext command.
-/// </param>
-/// <param name="CommandType_DestroySpatialContext">
+/// \param CommandType_DestroySpatialContext
/// Represents the DestroySpatialContext command.
-/// </param>
-/// <param name="CommandType_GetSpatialContexts">
+/// \param CommandType_GetSpatialContexts
/// Represents the GetSpatialContexts command.
-/// </param>
-/// <param name="CommandType_CreateMeasureUnit">
+/// \param CommandType_CreateMeasureUnit
/// Represents the CreateMeasureUnit command.
-/// </param>
-/// <param name="CommandType_DestroyMeasureUnit">
+/// \param CommandType_DestroyMeasureUnit
/// Represents the DestroyMeasureUnit command.
-/// </param>
-/// <param name="CommandType_GetMeasureUnits">
+/// \param CommandType_GetMeasureUnits
/// Represents the GetMeasureUnits command.
-/// </param>
-/// <param name="CommandType_SQLCommand">
+/// \param CommandType_SQLCommand
/// Represents the SQLCommand command.
-/// </param>
-/// <param name="CommandType_AcquireLock">
+/// \param CommandType_AcquireLock
/// Represents the AcquireLock command.
-/// </param>
-/// <param name="CommandType_GetLockInfo">
+/// \param CommandType_GetLockInfo
/// Represents the GetLockInfo command.
-/// </param>
-/// <param name="CommandType_GetLockedObjects">
+/// \param CommandType_GetLockedObjects
/// Represents the GetLockedObjects command.
-/// </param>
-/// <param name="CommandType_GetLockOwners">
+/// \param CommandType_GetLockOwners
/// Represents the GetLockOwners command.
-/// </param>
-/// <param name="CommandType_ReleaseLock">
+/// \param CommandType_ReleaseLock
/// Represents the ReleaseLock command.
-/// </param>
-/// <param name="CommandType_ActivateLongTransaction">
+/// \param CommandType_ActivateLongTransaction
/// Represents the ActivateLongTransaction command.
-/// </param>
-/// <param name="CommandType_CommitLongTransaction">
+/// \param CommandType_CommitLongTransaction
/// Represents the CommitLongTransaction command.
-/// </param>
-/// <param name="CommandType_CreateLongTransaction">
+/// \param CommandType_CreateLongTransaction
/// Represents the CreateLongTransaction command.
-/// </param>
-/// <param name="CommandType_GetLongTransactions">
+/// \param CommandType_GetLongTransactions
/// Represents the GetLongTransactions command.
-/// </param>
-/// <param name="CommandType_FreezeLongTransaction">
+/// \param CommandType_FreezeLongTransaction
/// Represents the FreezeLongTransaction command.
-/// </param>
-/// <param name="CommandType_RollbackLongTransaction">
+/// \param CommandType_RollbackLongTransaction
/// Represents the RollbackLongTransaction command.
-/// </param>
-/// <param name="CommandType_ActivateLongTransactionCheckpoint">
+/// \param CommandType_ActivateLongTransactionCheckpoint
/// Represents the ActivateLongTransactionCheckpoint command.
-/// </param>
-/// <param name="CommandType_CreateLongTransactionCheckpoint">
+/// \param CommandType_CreateLongTransactionCheckpoint
/// Represents the CreateLongTransactionCheckpoint command.
-/// </param>
-/// <param name="CommandType_GetLongTransactionCheckpoints">
+/// \param CommandType_GetLongTransactionCheckpoints
/// Represents the GetLongTransactionCheckpoints command.
-/// </param>
-/// <param name="CommandType_RollbackLongTransactionCheckpoint">
+/// \param CommandType_RollbackLongTransactionCheckpoint
/// Represents the RollbackLongTransactionCheckpoint command.
-/// </param>
-/// <param name="CommandType_ChangeLongTransactionPrivileges">
+/// \param CommandType_ChangeLongTransactionPrivileges
/// Represents the ChangeLongTransactionPrivileges command.
-/// </param>
-/// <param name="CommandType_GetLongTransactionPrivileges">
+/// \param CommandType_GetLongTransactionPrivileges
/// Represents the GetLongTransactionPrivileges command.
-/// </param>
-/// <param name="CommandType_ChangeLongTransactionSet">
+/// \param CommandType_ChangeLongTransactionSet
/// Represents the ChangeLongTransactionSet command.
-/// </param>
-/// <param name="CommandType_GetLongTransactionsInSet">
+/// \param CommandType_GetLongTransactionsInSet
/// Represents the GetLongTransactionsInSet command.
-/// </param>
-/// <param name="CommandType_FirstProviderCommand">
+/// \param CommandType_FirstProviderCommand
/// Represents the index of the first provider specific command.
-/// </param>
-/// <param name="CommandType_SelectAggregates">
+/// \param CommandType_SelectAggregates
/// Represents the SelectAggregate command.
-/// </param>
-/// <param name="(See Description note)">
-/// \note
-/// The following parameters are not supported in this release.
-/// They are provided here for informational use only. OSGeo
-/// reserves the right to change the software related to the content herein.
-/// </param>
-/// <param name="CommandType_NetworkShortestPath">
-/// Represents the NetworkShortestPath command (see <b>Note</b>).
-/// </param>
-/// <param name="CommandType_NetworkAllPaths">
-/// Represents the NetworkAllPaths command (see <b>Note</b>).
-/// </param>
-/// <param name="CommandType_NetworkReachableNodes">
-/// Represents the NetworkReachableNodes command (see <b>Note</b>).
-/// </param>
-/// <param name="CommandType_NetworkReachingNodes">
-/// Represents the NetworkReachingNodes command (see <b>Note</b>).
-/// </param>
-/// <param name="CommandType_NetworkNearestNeighbors">
-/// Represents the NetworkNearestNeighbors command (see <b>Note</b>).
-/// </param>
-/// <param name="CommandType_NetworkWithinCost">
-/// Represents the NetworkWithinCost command (see <b>Note</b>).
-/// </param>
-/// <param name="CommandType_NetworkTSP">
-/// Represents the NetworkTSP command (see <b>Note</b>).
-/// </param>
-/// <param name="CommandType_ActivateTopologyArea">
-/// Represents the ActivateTopologyArea command (see <b>Note</b>).
-/// </param>
-/// <param name="CommandType_DeactivateTopologyArea">
-/// Represents the DeactivateTopologyArea command (see <b>Note</b>).
-/// </param>
-/// <param name="CommandType_ActivateTopologyInCommandResult">
-/// Represents the ActivateTopologyInCommandResult command (see <b>Note</b>).
-/// </param>
-/// <param name="CommandType_DeactivateTopologyInCommandResults">
-/// Represents the DeactivateTopologyInCommandResults command (see <b>Note</b>).
-/// </param>
-/// <param name="CommandType_CreateDataStore">
+/// \param CommandType_NetworkShortestPath
+/// Represents the NetworkShortestPath command (see <b>remarks</b>).
+/// \param CommandType_NetworkAllPaths
+/// Represents the NetworkAllPaths command (see <b>remarks</b>).
+/// \param CommandType_NetworkReachableNodes
+/// Represents the NetworkReachableNodes command (see <b>remarks</b>).
+/// \param CommandType_NetworkReachingNodes
+/// Represents the NetworkReachingNodes command (see <b>remarks</b>).
+/// \param CommandType_NetworkNearestNeighbors
+/// Represents the NetworkNearestNeighbors command (see <b>remarks</b>).
+/// \param CommandType_NetworkWithinCost
+/// Represents the NetworkWithinCost command (see <b>remarks</b>).
+/// \param CommandType_NetworkTSP
+/// Represents the NetworkTSP command (see <b>remarks</b>).
+/// \param CommandType_ActivateTopologyArea
+/// Represents the ActivateTopologyArea command (see <b>remarks</b>).
+/// \param CommandType_DeactivateTopologyArea
+/// Represents the DeactivateTopologyArea command (see <b>remarks</b>).
+/// \param CommandType_ActivateTopologyInCommandResult
+/// Represents the ActivateTopologyInCommandResult command (see <b>remarks</b>).
+/// \param CommandType_DeactivateTopologyInCommandResults
+/// Represents the DeactivateTopologyInCommandResults command (see <b>remarks</b>).
+/// \param CommandType_CreateDataStore
/// Represents the CreateDataStore command.
-/// </param>
-/// <param name="CommandType_DestroyDataStore">
+/// \param CommandType_DestroyDataStore
/// Represents the DestroyDataStore command.
-/// </param>
-/// <param name="CommandType_ListDataStores">
+/// \param CommandType_ListDataStores
/// Represents the ListDataStores command.
-/// </param>
+/// \remarks
+/// These parameters are not supported in this release.
+/// They are provided here for informational use only. OSGeo
+/// reserves the right to change the software related to the content herein.
public __value enum CommandType {
- /// Represents the Select Command.
CommandType_Select = FdoCommandType_Select,
- /// Represents the Insert Command.
CommandType_Insert = FdoCommandType_Insert,
- /// Represents the Delete Command.
CommandType_Delete = FdoCommandType_Delete,
- /// Represents the Update Command.
CommandType_Update = FdoCommandType_Update,
- /// Represents the DescribeSchema Command.
CommandType_DescribeSchema = FdoCommandType_DescribeSchema,
- /// Represents the DescribeSchemaMapping Command.
CommandType_DescribeSchemaMapping = FdoCommandType_DescribeSchemaMapping,
- /// Represents the ApplySchema command.
CommandType_ApplySchema = FdoCommandType_ApplySchema,
- /// Represents the DestroySchema command.
CommandType_DestroySchema = FdoCommandType_DestroySchema,
- /// Represents the ActivateSpatialContext command.
CommandType_ActivateSpatialContext = FdoCommandType_ActivateSpatialContext,
- /// Represents the CreateSpatialContext command.
CommandType_CreateSpatialContext = FdoCommandType_CreateSpatialContext,
- /// Represents the DestroySpatialContext command.
CommandType_DestroySpatialContext = FdoCommandType_DestroySpatialContext,
- /// Represents the GetSpatialContexts command.
CommandType_GetSpatialContexts = FdoCommandType_GetSpatialContexts,
- /// Represents the CreateMeasureUnit command.
CommandType_CreateMeasureUnit = FdoCommandType_CreateMeasureUnit,
- /// Represents the DestroyMeasureUnit command.
CommandType_DestroyMeasureUnit = FdoCommandType_DestroyMeasureUnit,
- /// Represents the GetMeasureUnits command.
CommandType_GetMeasureUnits = FdoCommandType_GetMeasureUnits,
- /// Represents the SQLCommand command.
CommandType_SQLCommand = FdoCommandType_SQLCommand,
- /// Represents the AcquireLock command.
CommandType_AcquireLock = FdoCommandType_AcquireLock,
- /// Represents the GetLockInfo command.
CommandType_GetLockInfo = FdoCommandType_GetLockInfo,
- /// Represents the GetLockedObjects command.
CommandType_GetLockedObjects = FdoCommandType_GetLockedObjects,
- /// Represents the GetLockOwners command.
CommandType_GetLockOwners = FdoCommandType_GetLockOwners,
- /// Represents the ReleaseLock command.
CommandType_ReleaseLock = FdoCommandType_ReleaseLock,
- /// Represents the ActivateLongTransaction command.
CommandType_ActivateLongTransaction = FdoCommandType_ActivateLongTransaction,
- /// Represents the DeactivateLongTransaction command.
CommandType_DeactivateLongTransaction = FdoCommandType_DeactivateLongTransaction,
- /// Represents the CommitLongTransaction command.
CommandType_CommitLongTransaction = FdoCommandType_CommitLongTransaction,
- /// Represents the CreateLongTransaction command.
CommandType_CreateLongTransaction = FdoCommandType_CreateLongTransaction,
- /// Represents the GetLongTransactions command.
CommandType_GetLongTransactions = FdoCommandType_GetLongTransactions,
- /// Represents the FreezeLongTransaction command.
CommandType_FreezeLongTransaction = FdoCommandType_FreezeLongTransaction,
- /// Represents the RollbackLongTransaction command.
CommandType_RollbackLongTransaction = FdoCommandType_RollbackLongTransaction,
- /// Represents the ActivateLongTransactionCheckpoint command.
CommandType_ActivateLongTransactionCheckpoint = FdoCommandType_ActivateLongTransactionCheckpoint,
- /// Represents the CreateLongTransactionCheckpoint command.
CommandType_CreateLongTransactionCheckpoint = FdoCommandType_CreateLongTransactionCheckpoint,
- /// Represents the GetLongTransactionCheckpoints command.
CommandType_GetLongTransactionCheckpoints = FdoCommandType_GetLongTransactionCheckpoints,
- /// Represents the RollbackLongTransactionCheckpoint command.
CommandType_RollbackLongTransactionCheckpoint = FdoCommandType_RollbackLongTransactionCheckpoint,
- /// Represents the ChangeLongTransactionPrivileges command.
CommandType_ChangeLongTransactionPrivileges = FdoCommandType_ChangeLongTransactionPrivileges,
- /// Represents the GetLongTransactionPrivileges command.
CommandType_GetLongTransactionPrivileges = FdoCommandType_GetLongTransactionPrivileges,
- /// Represents the ChangeLongTransactionSet command.
CommandType_ChangeLongTransactionSet = FdoCommandType_ChangeLongTransactionSet,
- /// Represents the GetLongTransactionsInSet command.
CommandType_GetLongTransactionsInSet = FdoCommandType_GetLongTransactionsInSet,
- /// Represents the NetworkShortestPath command.
CommandType_NetworkShortestPath = FdoCommandType_NetworkShortestPath,
- /// Represents the NetworkAllPaths command.
CommandType_NetworkAllPaths = FdoCommandType_NetworkAllPaths,
- /// Represents the NetworkReachableNodes command.
CommandType_NetworkReachableNodes = FdoCommandType_NetworkReachableNodes,
- /// Represents the NetworkReachingNodes command.
CommandType_NetworkReachingNodes = FdoCommandType_NetworkReachingNodes,
- /// Represents the NetworkNearestNeighbors command.
CommandType_NetworkNearestNeighbors = FdoCommandType_NetworkNearestNeighbors,
- /// Represents the NetworkWithinCost command.
CommandType_NetworkWithinCost = FdoCommandType_NetworkWithinCost,
- /// Represents the NetworkTSP command.
CommandType_NetworkTSP = FdoCommandType_NetworkTSP,
- /// Represents the ActivateTopologyArea command.
CommandType_ActivateTopologyArea = FdoCommandType_ActivateTopologyArea,
- /// Represents the DeactivateTopologyArea command.
CommandType_DeactivateTopologyArea = FdoCommandType_DeactivateTopologyArea,
- /// Represents the ActivateTopologyInCommandResult command.
CommandType_ActivateTopologyInCommandResult = FdoCommandType_ActivateTopologyInCommandResult,
- /// Represents the DeactivateTopologyInCommandResults command.
CommandType_DeactivateTopologyInCommandResults = FdoCommandType_DeactivateTopologyInCommandResults,
- /// Represents the SelectAggregates command.
CommandType_SelectAggregates = FdoCommandType_SelectAggregates,
- /// Represents the index of the first provider specific command.
CommandType_FirstProviderCommand = FdoCommandType_FirstProviderCommand,
- /// Represents the CreateDataStore command.
CommandType_CreateDataStore = FdoCommandType_CreateDataStore,
- /// Represents the DestroyDataStore command.
CommandType_DestroyDataStore = FdoCommandType_DestroyDataStore,
- /// Represents the ListDatastores command
CommandType_ListDataStores = FdoCommandType_ListDataStores,
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIdentifierCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIdentifierCollection.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgIdentifierCollection.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -226,10 +226,11 @@
/// \param array
+ /// \param index
- System::Void CopyTo(NAMESPACE_OSGEO_FDO_EXPRESSION::Identifier* array[],System::Int32 size);
+ System::Void CopyTo(NAMESPACE_OSGEO_FDO_EXPRESSION::Identifier* array[],System::Int32 index);
/// \brief
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValueCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValueCollection.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgParameterValueCollection.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -231,9 +231,8 @@
/// \param startAt
- System::Void CopyTo(NAMESPACE_OSGEO_FDO_COMMANDS::ParameterValue* array[],System::Int32 size);
+ System::Void CopyTo(NAMESPACE_OSGEO_FDO_COMMANDS::ParameterValue* array[],System::Int32 startAt);
/// \brief
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValueCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValueCollection.h 2007-02-07 21:37:53 UTC (rev 733)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Commands/mgPropertyValueCollection.h 2007-02-07 21:41:24 UTC (rev 734)
@@ -227,7 +227,7 @@
/// \param startAt
- System::Void CopyTo(NAMESPACE_OSGEO_FDO_COMMANDS::PropertyValue* array[],System::Int32 size);
+ System::Void CopyTo(NAMESPACE_OSGEO_FDO_COMMANDS::PropertyValue* array[],System::Int32 startAt);
/// \brief
More information about the fdo-commits
