[fdo-commits] r735 - in branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections: . Capabilities
svn_fdo at osgeo.org svn_fdo at osgeo.org
Wed Feb 7 16:43:20 EST 2007
Author: gregboone
Date: 2007-02-07 16:43:19 -0500 (Wed, 07 Feb 2007)
New Revision: 735
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinitionCollection.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinition.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinitionCollection.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilities.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilitiesImp.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilities.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilitiesImp.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilities.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilitiesImp.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilities.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilitiesImp.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilities.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilitiesImp.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilities.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilitiesImp.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgReadOnlyArgDefColl.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSignatureDefinition.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionary.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.h
893057: DOC: FDO Managed API Documentation Updates
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinitionCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinitionCollection.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgArgumentDefinitionCollection.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -217,10 +217,11 @@
     /// \param array
     /// Output the one-dimensional Array that is the destination of the elements copied from this collection.
     /// \param startAt
     /// Input an integer that represents the index in array at which copying begins.
-	System::Void CopyTo(ArgumentDefinition* array[],System::Int32 size);
+	System::Void CopyTo(ArgumentDefinition* array[],System::Int32 startAt);
     /// \brief
     /// Gets the item in the collection at the specified index.
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinition.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinition.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinition.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -94,9 +94,6 @@
     /// \brief
     ///  Gets an array of ArgumentDefinition objects required for the function.
-    /// \param length
-    /// Output the number of argument definitions.
     /// \return
     /// Returns the list of argument definitions
@@ -123,7 +120,7 @@
     /// defined so that this class can be a NamedCollection element.
     /// \return
-    /// Returns false
+    /// Returns true if the name of the object can be changed.
 	__property System::Boolean get_CanSetName();
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinitionCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinitionCollection.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgFunctionDefinitionCollection.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -230,10 +230,11 @@
     /// \param array
     /// \param startAt
-	System::Void CopyTo(FunctionDefinition* array[],System::Int32 size);
+	System::Void CopyTo(FunctionDefinition* array[],System::Int32 startAt);
     /// \brief
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilities.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilities.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilities.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -29,9 +29,6 @@
     /// \brief
     /// Gets an array of the CommandType values supported by the feature provider.
-    /// \param size
-    /// Output the number of commands
     /// \return
     /// Returns the list of commands
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilitiesImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilitiesImp.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgICommandCapabilitiesImp.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -34,9 +34,6 @@
     /// \brief
-    /// \param size
     /// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilities.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilities.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilities.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -48,9 +48,6 @@
     /// \brief
     /// Gets the spatial context extent types supported by the feature provider.
-    /// \param length
-    /// Output the number of spatial context types.
     /// \return
     /// Returns the list of spatial context extent types.
@@ -67,9 +64,6 @@
     /// \brief
     /// Gets an array of the LockType values supported by the feature provider.
-    /// \param size
-    /// Output the number of lock types
     /// \return
     /// Returns the list of lock types
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilitiesImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilitiesImp.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIConnectionCapabilitiesImp.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -43,9 +43,6 @@
     /// \brief
-    /// \param length
     /// \return
@@ -62,9 +59,6 @@
     /// \brief
-    /// \param size
     /// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilities.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilities.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilities.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -37,9 +37,6 @@
     /// \brief
     /// Returns an array of ExpressionType objects the feature provider supports.
-    /// \param length
-    /// Input the number of expression types
     /// \return
     /// Returns the list of expression types
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilitiesImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilitiesImp.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIExpressionCapabilitiesImp.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -34,9 +34,6 @@
     /// \brief
-    /// \param length
     /// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilities.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilities.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilities.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -38,9 +38,6 @@
     /// \brief
     /// Returns an array of ConditionType objects the feature provider supports.
-    /// \param length
-    /// Output the number of condition types
     /// \return
     /// Returns the list of condition types
@@ -49,9 +46,6 @@
     /// \brief
     /// Returns an array of SpatialOperation objects the feature provider supports.
-    /// \param length
-    /// Output the number of spatial operations
     /// \return
     /// Returns the list of spartial operations
@@ -60,9 +54,6 @@
     /// \brief
     /// Returns an array of DistanceOperation objects the feature provider supports.
-    /// \param length
-    /// Output the number of distance operations
     /// \return
     /// Returns the list of distance operations
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilitiesImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilitiesImp.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIFilterCapabilitiesImp.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -33,9 +33,6 @@
     /// \brief
-    /// \param length
     /// \return
@@ -44,9 +41,6 @@
     /// \brief
-    /// \param length
     /// \return
@@ -55,9 +49,6 @@
     /// \brief
-    /// \param length
     /// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilities.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilities.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilities.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -29,9 +29,6 @@
     /// Return the list of supported geometry types. For example, if a client wanted to know if a provider supported
     /// multi-polygons, it would call GetGeometryTypes and check if the MultiPolygon type was listed.
-    /// \param length
-    /// Output the number of geometry types.
     /// \return
     /// Returns the list of geometry types
@@ -41,9 +38,6 @@
     /// Return the list of supported component types. For example, if a client wanted to know if circular arcs were supported
     /// by a provider, it would call GetGeometryComponentTypes and check for CircularArcSegment in the returned list.
-    /// \param length
-    /// Output the number of component types.
     /// \return
     /// Returns the list of component types
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilitiesImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilitiesImp.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgIGeometryCapabilitiesImp.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -34,9 +34,6 @@
-    /// \param length
     /// \return
@@ -46,9 +43,6 @@
-    /// \param length
     /// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilities.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilities.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilities.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -41,9 +41,6 @@
     /// \brief
     /// Returns an array of the ClassType objects the feature provider supports.
-    /// \param length
-    /// Output the number of class types.
     /// \return
     /// Returns the list of class types.
@@ -52,9 +49,6 @@
     /// \brief
     /// Returns an array of the DataType objects the feature provider supports.
-    /// \param length
-    /// Output the number of data types.
     /// \return
     /// Returns the list of data types
@@ -77,9 +71,6 @@
     /// \brief
     /// Returns the maximum supported precision for a decimal data property.
-    /// \param
-    /// None.
     /// \return
@@ -88,9 +79,6 @@
     /// \brief
     /// Returns the maximum supported scale for a decimal data property.
-    /// \param
-    /// None.
     /// \return
@@ -116,9 +104,6 @@
     /// Returns a string that includes all the reserved characters that cannot be
     /// used for the various schema element names for the provider.
-    /// \param
-    /// None
     /// \return
     /// Returns a string with the reserved characters for the identified schema element.
@@ -127,9 +112,6 @@
     /// \brief
     /// Returns an array of the DataType objects the feature provider supports for auto-generation.
-    /// \param length
     /// \return
@@ -138,9 +120,6 @@
     /// \brief
     /// Returns a list of property types that can be used for identity properties.
-    /// \param length
     /// \return
@@ -190,9 +169,6 @@
     /// Returns TRUE if default values can be specified for a data property
     /// definition, FALSE otherwise.
-    /// \param
-    /// None
     /// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilitiesImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilitiesImp.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgISchemaCapabilitiesImp.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -34,9 +34,6 @@
     /// \brief
-    /// \param length
     /// \return
@@ -45,9 +42,6 @@
     /// \brief
-    /// \param length
     /// \return
@@ -70,9 +64,6 @@
     /// \brief
-    /// \param
-    /// None.
     /// \return
@@ -81,9 +72,6 @@
     /// \brief
-    /// \param
-    /// None.
     /// \return
@@ -109,9 +97,6 @@
-    /// \param
-    /// None
     /// \return
@@ -120,9 +105,6 @@
     /// \brief
-    /// \param length
     /// \return
@@ -131,9 +113,6 @@
     /// \brief
-    /// \param length
     /// \return
@@ -183,9 +162,6 @@
-    /// \param
-    /// None
     /// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgReadOnlyArgDefColl.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgReadOnlyArgDefColl.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgReadOnlyArgDefColl.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -140,10 +140,11 @@
     /// \param array
     /// \param startAt
-	System::Void CopyTo(NAMESPACE_OSGEO_FDO_CONNECTIONS_CAPABILITIES::ArgumentDefinition* array[], System::Int32 index);
+	System::Void CopyTo(NAMESPACE_OSGEO_FDO_CONNECTIONS_CAPABILITIES::ArgumentDefinition* array[], System::Int32 startAt);
     /// \brief
     /// Determines the index of a specific ArgumentDefinition object.
@@ -182,7 +183,7 @@
     /// \brief
-    /// \param index
+    /// \param name
     /// The name of the item in the collection.
     /// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSignatureDefinition.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSignatureDefinition.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/Capabilities/mgSignatureDefinition.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -29,6 +29,8 @@
 using namespace NAMESPACE_OSGEO_FDO_SCHEMA;
 BEGIN_NAMESPACE_OSGEO_FDO_CONNECTIONS_CAPABILITIES
+/// \brief
+/// The FDO SignatureDefinition class allows the signatures of FDO FunctionDefinition objects to be defined.
 public __gc class SignatureDefinition : public NAMESPACE_OSGEO_RUNTIME::Disposable
 public:
@@ -266,10 +268,11 @@
     /// \param array
     /// \param startAt
-	System::Void CopyTo(NAMESPACE_OSGEO_FDO_CONNECTIONS_CAPABILITIES::SignatureDefinition *array[], System::Int32 size);
+	System::Void CopyTo(NAMESPACE_OSGEO_FDO_CONNECTIONS_CAPABILITIES::SignatureDefinition *array[], System::Int32 startAt);
     /// \brief
@@ -411,11 +414,14 @@
 	inline FdoReadOnlySignatureDefinitionCollection *GetImpObj();
 private:
-    // System::Collections::ICollection interfaces
+    // System::Collections::ICollection methods
 	System::Void System::Collections::ICollection::CopyTo(System::Array *array, System::Int32 index);
+    // System::Collections::ICollection properties
 	__property System::Object *System::Collections::ICollection::get_SyncRoot();
 	__property System::Boolean System::Collections::ICollection::get_IsSynchronized();
+/// \endcond
 public:
 	ReadOnlySignatureDefinitionCollection();
@@ -441,11 +447,11 @@
     /// \param array
     /// \param startAt
-                        System::Int32 index);
     /// \brief
     /// Determines the index of a specific SignatureDefinition object.
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionary.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionary.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionary.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -32,16 +32,13 @@
 public:
     /// \brief
-    ///  Gets the names of all the properties that can appear in a connection string
+    /// Gets the names of all the properties that can appear in a connection string
     /// for this feature provider as an array of Strings. The order of the property
     /// names in the resulting array dictate the order in which they need to be
     /// specified. This is especially important for the success of the
     /// EnumeratePropertyValues method because properties that occur earlier in the array
     /// may be required for successful enumeration of properties that appear later.
-    /// \param count
-    /// Output the number of parameters
     /// \return
     /// Returns the list of parameter names
@@ -118,12 +115,10 @@
 	System::Boolean IsPropertyEnumerable(System::String* name);
     /// \brief
-    ///  Returns an array of possible values for the specified property.
+    /// Returns an array of possible values for the specified property.
     /// \param name
     /// Input the property name.
-    /// \param count
-    /// Output the number of values.
     /// \return
     /// Returns the list of values for this property.
@@ -131,7 +126,7 @@
 	System::String* EnumeratePropertyValues(System::String* name) [];
     /// \brief
-    ///  Gets a localized name for the property (for NLS purposes).
+    /// Gets a localized name for the property (for NLS purposes).
     /// \param name
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.h	2007-02-07 21:41:24 UTC (rev 734)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Connections/mgIConnectionPropertyDictionaryImp.h	2007-02-07 21:43:19 UTC (rev 735)
@@ -36,16 +36,13 @@
 public:
     /// \brief
-    /// \param count
     /// \return
@@ -126,8 +123,6 @@
     /// \param name
-    /// \param count
     /// \return
More information about the fdo-commits mailing list
