[fdo-commits] r736 - branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression
svn_fdo at osgeo.org svn_fdo at osgeo.org
Wed Feb 7 16:44:29 EST 2007
Author: gregboone
Date: 2007-02-07 16:44:29 -0500 (Wed, 07 Feb 2007)
New Revision: 736
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgBLOBValue.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValue.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValueCollection.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionCollection.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgFunction.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIdentifier.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgLOBValue.h
893057: DOC: FDO Managed API Documentation Updates
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgBLOBValue.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgBLOBValue.h	2007-02-07 21:43:19 UTC (rev 735)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgBLOBValue.h	2007-02-07 21:44:29 UTC (rev 736)
@@ -55,16 +55,50 @@
 	BLOBValue(System::Byte value []);
+    /// \brief
+    /// Gets the FDO DataType of the BLOB
+    /// \return
+    /// Returns the FDO DataType
 	__property NAMESPACE_OSGEO_FDO_SCHEMA::DataType get_DataType();
+    /// \brief
+    /// Gets the data associated to the blob as an Byte Array
+    /// \return
+    /// Returns the Byte Array containing the BLOB data
 	__property System::Byte get_Data() [];
+    /// \brief
+    /// Sets the data associated to the BLOB using an FDO ByteArray
+    /// \param value
+    /// Input the FDO Byte Array
 	__property System::Void set_Data(System::Byte value []);
+    /// \brief
+    /// Sets the value of the BLOB to NULL.
 	System::Void SetNull();
+    /// \brief
+    /// Overrides FdoIExpression::Process to pass the DataValue to the appropriate
+    /// expression processor operation.
+    /// \param processor
+    /// Input the pointer to the FDO expression processor
 	System::Void Process(NAMESPACE_OSGEO_FDO_EXPRESSION::IExpressionProcessor* processor);
+    /// \brief
+    /// Gets the value of the BLOB as a string.
+    /// \return
+    /// Returns the well defined text representation of the BLOB
 	System::String* ToString();
     /// \brief
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValue.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValue.h	2007-02-07 21:43:19 UTC (rev 735)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValue.h	2007-02-07 21:44:29 UTC (rev 736)
@@ -149,8 +149,7 @@
     /// \param value
     /// Input a byte array
-    /// \param length
-    /// Input the length of the byte array
     /// \param dataType
     /// Input the type of value to create
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValueCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValueCollection.h	2007-02-07 21:43:19 UTC (rev 735)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgDataValueCollection.h	2007-02-07 21:44:29 UTC (rev 736)
@@ -230,10 +230,11 @@
     /// \param array
     /// Output the one-dimensional Array that is the destination of the elements copied from this collection.
     /// \param startAt
     /// Input an integer that represents the index in array at which copying begins.
-	System::Void CopyTo(NAMESPACE_OSGEO_FDO_EXPRESSION::DataValue* array[],System::Int32 size);
+	System::Void CopyTo(NAMESPACE_OSGEO_FDO_EXPRESSION::DataValue* array[],System::Int32 startAt);
     /// \brief
     /// Gets the item in the collection at the specified index.
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionCollection.h	2007-02-07 21:43:19 UTC (rev 735)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgExpressionCollection.h	2007-02-07 21:44:29 UTC (rev 736)
     /// \param array
     /// \param startAt
-	System::Void CopyTo(NAMESPACE_OSGEO_FDO_EXPRESSION::Expression* array[],System::Int32 size);
+	System::Void CopyTo(NAMESPACE_OSGEO_FDO_EXPRESSION::Expression* array[],System::Int32 startAt);
     /// \brief
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgFunction.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgFunction.h	2007-02-07 21:43:19 UTC (rev 735)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgFunction.h	2007-02-07 21:44:29 UTC (rev 736)
@@ -49,8 +49,6 @@
     /// Input name of the function
     /// \param arguments
     /// Input pointer to arguments
-    /// \param numArgs
-    /// Input number of arguments
     /// \return
     /// Returns Function
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIdentifier.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIdentifier.h	2007-02-07 21:43:19 UTC (rev 735)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgIdentifier.h	2007-02-07 21:44:29 UTC (rev 736)
@@ -87,9 +87,6 @@
     /// \brief
     /// Gets the scope of the identifier as an array of strings.
-    /// \param length
-    /// Output number of strings
     /// \return
     /// Returns scope as array of strings
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgLOBValue.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgLOBValue.h	2007-02-07 21:43:19 UTC (rev 735)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Expression/mgLOBValue.h	2007-02-07 21:44:29 UTC (rev 736)
@@ -37,8 +37,11 @@
 public:
     /// \brief
-    /// A cast operator to get the BLOB value.
+    /// Transforms the FDO LOB value into a byte array.
+    /// \param value
+    /// Input an FDO LOBValue object
     /// \return
     /// Returns a byte array
@@ -53,7 +56,7 @@
     /// \brief
-    /// Gets the LOB value.
+    /// Gets the LOB data.
     /// \return
@@ -61,7 +64,7 @@
     /// \brief
-    /// Sets the LOB value.
+    /// Sets the LOB data.
     /// \param value
     /// Input an array of bytes
More information about the fdo-commits mailing list
