[fdo-commits] r2468 - trunk/Providers/ArcSDE
svn_fdo at osgeo.org svn_fdo at osgeo.org
Fri Feb 9 18:28:40 EST 2007
Author: gregboone
Date: 2007-02-09 18:28:39 -0500 (Fri, 09 Feb 2007)
New Revision: 2468
   trunk/Providers/ArcSDE/configure
   trunk/Providers/ArcSDE/configure.in
Update FDO 3.3 build scripts
Modified: trunk/Providers/ArcSDE/configure
--- trunk/Providers/ArcSDE/configure	2007-02-09 23:28:11 UTC (rev 2467)
+++ trunk/Providers/ArcSDE/configure	2007-02-09 23:28:39 UTC (rev 2468)
@@ -1,8 +1,8 @@
 #! /bin/sh
 # Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.59 for FDOArcSDE 3.3.0.
+# Generated by GNU Autoconf 2.59 for FDOARCSDE 3.3.0.
-# Report bugs to <http://www.fdo.osgeo.org>.
+# Report bugs to <http://fdo.osgeo.org>.
 # Copyright (C) 2003 Free Software Foundation, Inc.
 # This configure script is free software; the Free Software Foundation
@@ -421,11 +421,11 @@
 : ${ac_max_here_lines=38}
 # Identity of this package.
-PACKAGE_NAME='FDOArcSDE'
+PACKAGE_NAME='FDOARCSDE'
 PACKAGE_TARNAME='fdoarcsde'
 PACKAGE_VERSION='3.3.0'
-PACKAGE_STRING='FDOArcSDE 3.3.0'
-PACKAGE_BUGREPORT='http://www.fdo.osgeo.org'
+PACKAGE_STRING='FDOARCSDE 3.3.0'
+PACKAGE_BUGREPORT='http://fdo.osgeo.org'
 ac_unique_file="configure.in"
 ac_default_prefix=/usr/local/fdo-3.2.0
@@ -955,7 +955,7 @@
   # Omit some internal or obsolete options to make the list less imposing.
   # This message is too long to be a string in the A/UX 3.1 sh.
   cat <<_ACEOF
-\`configure' configures FDOArcSDE 3.3.0 to adapt to many kinds of systems.
+\`configure' configures FDOARCSDE 3.3.0 to adapt to many kinds of systems.
 Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1021,7 +1021,7 @@
 if test -n "$ac_init_help"; then
   case $ac_init_help in
-     short | recursive ) echo "Configuration of FDOArcSDE 3.3.0:";;
+     short | recursive ) echo "Configuration of FDOARCSDE 3.3.0:";;
    esac
   cat <<\_ACEOF
@@ -1073,7 +1073,7 @@
 Use these variables to override the choices made by `configure' or to help
 it to find libraries and programs with nonstandard names/locations.
-Report bugs to <http://www.fdo.osgeo.org>.
+Report bugs to <http://fdo.osgeo.org>.
 _ACEOF
 fi
@@ -1169,7 +1169,7 @@
 test -n "$ac_init_help" && exit 0
 if $ac_init_version; then
   cat <<\_ACEOF
-FDOArcSDE configure 3.3.0
+FDOARCSDE configure 3.3.0
 generated by GNU Autoconf 2.59
@@ -1183,7 +1183,7 @@
 This file contains any messages produced by compilers while
 running configure, to aid debugging if configure makes a mistake.
-It was created by FDOArcSDE $as_me 3.3.0, which was
+It was created by FDOARCSDE $as_me 3.3.0, which was
 generated by GNU Autoconf 2.59.  Invocation command line was
   $ $0 $@
@@ -4979,9 +4979,9 @@
 echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
       cat <<\_ASBOX
-## Report this to http://www.fdo.osgeo.org ##
+## Report this to http://fdo.osgeo.org ##
 _ASBOX
       sed "s/^/$as_me: WARNING:     /" >&2
@@ -19245,7 +19245,7 @@
 } >&5
 cat >&5 <<_CSEOF
-This file was extended by FDOArcSDE $as_me 3.3.0, which was
+This file was extended by FDOARCSDE $as_me 3.3.0, which was
   CONFIG_FILES    = $CONFIG_FILES
@@ -19303,7 +19303,7 @@
 cat >>$CONFIG_STATUS <<_ACEOF
 ac_cs_version="\\
-FDOArcSDE config.status 3.3.0
+FDOARCSDE config.status 3.3.0
 configured by $0, generated by GNU Autoconf 2.59,
   with options \\"`echo "$ac_configure_args" | sed 's/[\\""\`\$]/\\\\&/g'`\\"
Modified: trunk/Providers/ArcSDE/configure.in
--- trunk/Providers/ArcSDE/configure.in	2007-02-09 23:28:11 UTC (rev 2467)
+++ trunk/Providers/ArcSDE/configure.in	2007-02-09 23:28:39 UTC (rev 2468)
@@ -21,7 +21,7 @@
 # Variables
 # Following are the makefile directories
-AC_INIT(FDOArcSDE,3.3.0,http://www.fdo.osgeo.org)
+AC_INIT(FDOARCSDE,3.3.0,http://fdo.osgeo.org)
 AC_CONFIG_SRCDIR(configure.in)
 AM_INIT_AUTOMAKE
More information about the fdo-commits mailing list
