[fdo-commits] r2469 - trunk/Providers/GDAL
svn_fdo at osgeo.org
Fri Feb 9 18:29:16 EST 2007
Author: gregboone
Date: 2007-02-09 18:29:15 -0500 (Fri, 09 Feb 2007)
New Revision: 2469
trunk/Providers/GDAL/configure
trunk/Providers/GDAL/configure.in
Update FDO 3.3 build scripts
Modified: trunk/Providers/GDAL/configure
--- trunk/Providers/GDAL/configure 2007-02-09 23:28:39 UTC (rev 2468)
+++ trunk/Providers/GDAL/configure 2007-02-09 23:29:15 UTC (rev 2469)
@@ -1,8 +1,8 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.59 for FDORASTER 3.3.0.
+# Generated by GNU Autoconf 2.59 for FDOGDAL 3.3.0.
-# Report bugs to <https://www.fdoraster.osgeo.org>.
+# Report bugs to <http://fdo.osgeo.org>.
# Copyright (C) 2003 Free Software Foundation, Inc.
# This configure script is free software; the Free Software Foundation
@@ -421,11 +421,11 @@
: ${ac_max_here_lines=38}
# Identity of this package.
-PACKAGE_NAME='FDORASTER'
-PACKAGE_TARNAME='fdoraster'
+PACKAGE_NAME='FDOGDAL'
+PACKAGE_TARNAME='fdogdal'
PACKAGE_VERSION='3.3.0'
-PACKAGE_STRING='FDORASTER 3.3.0'
-PACKAGE_BUGREPORT='https://www.fdoraster.osgeo.org'
+PACKAGE_STRING='FDOGDAL 3.3.0'
+PACKAGE_BUGREPORT='http://fdo.osgeo.org'
ac_unique_file="configure.in"
ac_default_prefix=/usr/local/fdo-3.2.0
@@ -955,7 +955,7 @@
# Omit some internal or obsolete options to make the list less imposing.
# This message is too long to be a string in the A/UX 3.1 sh.
cat <<_ACEOF
-\`configure' configures FDORASTER 3.3.0 to adapt to many kinds of systems.
+\`configure' configures FDOGDAL 3.3.0 to adapt to many kinds of systems.
Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1021,7 +1021,7 @@
if test -n "$ac_init_help"; then
case $ac_init_help in
- short | recursive ) echo "Configuration of FDORASTER 3.3.0:";;
+ short | recursive ) echo "Configuration of FDOGDAL 3.3.0:";;
esac
cat <<\_ACEOF
@@ -1071,7 +1071,7 @@
Use these variables to override the choices made by `configure' or to help
it to find libraries and programs with nonstandard names/locations.
-Report bugs to <https://www.fdoraster.osgeo.org>.
+Report bugs to <http://fdo.osgeo.org>.
_ACEOF
fi
@@ -1167,7 +1167,7 @@
test -n "$ac_init_help" && exit 0
if $ac_init_version; then
cat <<\_ACEOF
-FDORASTER configure 3.3.0
+FDOGDAL configure 3.3.0
generated by GNU Autoconf 2.59
@@ -1181,7 +1181,7 @@
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
-It was created by FDORASTER $as_me 3.3.0, which was
+It was created by FDOGDAL $as_me 3.3.0, which was
generated by GNU Autoconf 2.59. Invocation command line was
$ $0 $@
@@ -1824,7 +1824,7 @@
# Define the identity of the package.
- PACKAGE='fdoraster'
+ PACKAGE='fdogdal'
VERSION='3.3.0'
@@ -4977,9 +4977,9 @@
echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
cat <<\_ASBOX
-## Report this to https://www.fdoraster.osgeo.org ##
+## Report this to http://fdo.osgeo.org ##
_ASBOX
sed "s/^/$as_me: WARNING: /" >&2
@@ -19206,7 +19206,7 @@
} >&5
cat >&5 <<_CSEOF
-This file was extended by FDORASTER $as_me 3.3.0, which was
+This file was extended by FDOGDAL $as_me 3.3.0, which was
CONFIG_FILES = $CONFIG_FILES
@@ -19264,7 +19264,7 @@
cat >>$CONFIG_STATUS <<_ACEOF
ac_cs_version="\\
-FDORASTER config.status 3.3.0
+FDOGDAL config.status 3.3.0
configured by $0, generated by GNU Autoconf 2.59,
with options \\"`echo "$ac_configure_args" | sed 's/[\\""\`\$]/\\\\&/g'`\\"
Modified: trunk/Providers/GDAL/configure.in
--- trunk/Providers/GDAL/configure.in 2007-02-09 23:28:39 UTC (rev 2468)
+++ trunk/Providers/GDAL/configure.in 2007-02-09 23:29:15 UTC (rev 2469)
@@ -21,7 +21,7 @@
# Variables
# Following are the makefile directories
-AC_INIT(FDORASTER,3.3.0,https://www.fdoraster.osgeo.org)
+AC_INIT(FDOGDAL,3.3.0,http://fdo.osgeo.org)
AC_CONFIG_SRCDIR(configure.in)
AM_INIT_AUTOMAKE
More information about the fdo-commits
