[fdo-commits] r761 - in branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard: Scripts/1033 Templates/1033
svn_fdo at osgeo.org svn_fdo at osgeo.org
Mon Feb 12 12:26:24 EST 2007
Author: jacklee
Date: 2007-02-12 12:26:24 -0500 (Mon, 12 Feb 2007)
New Revision: 761
   branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Scripts/1033/default.js
   branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/MessageStatic.rc
   branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/Provider.h
   branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/Provider.rc
   branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/providers.xml
Change version to 3.2.2
Modified: branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Scripts/1033/default.js
--- branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Scripts/1033/default.js	2007-02-12 17:00:44 UTC (rev 760)
+++ branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Scripts/1033/default.js	2007-02-12 17:26:24 UTC (rev 761)
@@ -269,7 +269,7 @@
         var CLPostBuildEvent = config.Tools('VCPostBuildEventTool');
 		CLPostBuildEvent.Description = 'Versioning ' + upper_prefix + 'Provider.dll';
-    	CLPostBuildEvent.CommandLine = '$(FDOTHIRDPARTY)\\util\\stampver\\StampVer.exe -v\"..\\..\\SubDoc\\Providers.version\" -f\"3.2.0.0%PROVIDERS_VERSION%\" $(OutDir)\\' + upper_prefix + 'Provider.dll';
+    	CLPostBuildEvent.CommandLine = '$(FDOTHIRDPARTY)\\util\\stampver\\StampVer.exe -v\"..\\..\\SubDoc\\Providers.version\" -f\"3.2.2.0%PROVIDERS_VERSION%\" $(OutDir)\\' + upper_prefix + 'Provider.dll';
     	var CLPreLinkEvent = config.Tools('VCPreLinkEventTool');
 		CLPreLinkEvent.CommandLine = 'if not exist ..\\..\\Lib\\Win32\\Debug mkdir ..\\..\\Lib\\Win32\\Debug';
@@ -298,7 +298,7 @@
 		CLPreLinkEvent.CommandLine = 'if not exist ..\\..\\Lib\\Win32\\Release mkdir ..\\..\\Lib\\Win32\\Release';
Modified: branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/MessageStatic.rc
--- branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/MessageStatic.rc	2007-02-12 17:00:44 UTC (rev 760)
+++ branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/MessageStatic.rc	2007-02-12 17:26:24 UTC (rev 761)
@@ -83,8 +83,8 @@
 VS_VERSION_INFO VERSIONINFO
- FILEVERSION 3,0,0,0
- PRODUCTVERSION 3,0,0,0
+ FILEVERSION 3,2,2,0
+ PRODUCTVERSION 3,2,2,0
  FILEFLAGSMASK 0x17L
 #ifdef _DEBUG
  FILEFLAGS 0x1L
@@ -102,12 +102,12 @@
             VALUE "Comments", "Resource Only Dynamic Link Library"
             VALUE "CompanyName", "OSGeo"
             VALUE "FileDescription", "FDO Provider for [!output PREFIX] Message Library"
-            VALUE "FileVersion", "3.0.0.P000"
+            VALUE "FileVersion", "3.2.2.0"
             VALUE "InternalName", "[!output PREFIX]Message"
-            VALUE "LegalCopyright", "Copyright © 2006"
+            VALUE "LegalCopyright", "Copyright © 2007"
             VALUE "OriginalFilename", "[!output PREFIX]Message.dll"
             VALUE "ProductName", "Feature Data Objects"
-            VALUE "ProductVersion", "3.2.0.0"
+            VALUE "ProductVersion", "3.2.2.0"
         END
     END
     BLOCK "VarFileInfo"
Modified: branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/Provider.h
--- branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/Provider.h	2007-02-12 17:00:44 UTC (rev 760)
+++ branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/Provider.h	2007-02-12 17:26:24 UTC (rev 761)
@@ -22,8 +22,8 @@
 #define [!output PREFIX]ProviderName L"Autodesk.[!output PREFIX].3.2"
 #define [!output PREFIX]ProviderDisplayName L"OSGeo FDO Provider for [!output PREFIX]"
 #define [!output PREFIX]ProviderDescription L"OSGeo FDO Provider for [!output PREFIX]"
-#define [!output PREFIX]ProviderVersion L"3.2.0.0"
-#define FeatureDataObjectsVersion L"3.2.0.0"
+#define [!output PREFIX]ProviderVersion L"3.2.2.0"
+#define FeatureDataObjectsVersion L"3.2.2.0"
 // Connection property strings:
 const wchar_t CONNECTIONPROPERTY_DATASTORE[] = L"Datastore";
Modified: branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/Provider.rc
--- branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/Provider.rc	2007-02-12 17:00:44 UTC (rev 760)
+++ branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/Provider.rc	2007-02-12 17:26:24 UTC (rev 761)
@@ -83,8 +83,8 @@
- FILEVERSION 3,2,0,0
- PRODUCTVERSION 3,2,0,0
  FILEFLAGSMASK 0x17L
 #ifdef _DEBUG
  FILEFLAGS 0x1L
             VALUE "Comments", "FDO Provider for [!output UPPER_PREFIX]"
             VALUE "CompanyName", "Open Source Geospatial Foundation"
             VALUE "FileDescription", "FDO Provider for [!output UPPER_PREFIX] Component"
-            VALUE "FileVersion", "3.2.0.0"
             VALUE "InternalName", "[!output UPPER_PREFIX]Provider"
             VALUE "OriginalFilename", "[!output UPPER_PREFIX]Provider.dll"
         END
     END
     BLOCK "VarFileInfo"
Modified: branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/providers.xml
--- branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/providers.xml	2007-02-12 17:00:44 UTC (rev 760)
+++ branches/3.2.x/Utilities/Common/FDOProviderTemplate/Setup Files/Wizard/Templates/1033/providers.xml	2007-02-12 17:26:24 UTC (rev 761)
@@ -5,8 +5,8 @@
     <DisplayName>OSGeo FDO Provider for [!output PREFIX]</DisplayName>
     <Description>OSGeo FDO Provider for [!output PREFIX]</Description>
     <IsManaged>False</IsManaged>
-    <Version>3.2.0.0</Version>
-    <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
+    <Version>3.2.2.0</Version>
+    <FeatureDataObjectsVersion>3.2.2.0</FeatureDataObjectsVersion>
     <LibraryPath>.\[!output PREFIX]Provider.dll</LibraryPath>
   </FeatureProvider>
 </FeatureProviderRegistry>
More information about the fdo-commits mailing list
