[fdo-commits] r762 - branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd
svn_fdo at osgeo.org svn_fdo at osgeo.org
Mon Feb 12 13:15:24 EST 2007
Author: brentrobinson
Date: 2007-02-12 13:15:23 -0500 (Mon, 12 Feb 2007)
New Revision: 762
   branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp
Skip Foreign Key with column type mismatch
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp	2007-02-12 17:26:24 UTC (rev 761)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp	2007-02-12 18:15:23 UTC (rev 762)
@@ -302,24 +302,44 @@
 bool FdoSmPhRdPropertyReader::CheckFkey( FdoSmPhFkeyP fkey )
     FdoInt32 idx;
-    FdoSmPhColumnP column;
+    FdoSmPhColumnP fkeyColumn;
+    FdoSmPhColumnP pkeyColumn;
     FdoSmPhColumnsP fkeyColumns = fkey->GetFkeyColumns();
+    FdoSmPhColumnsP pkeyColumns = fkey->GetPkeyColumns();
+    if ( fkeyColumns->GetCount() != pkeyColumns->GetCount() )
+        // This would be a malformed foreign key so skip it.
+        return false;
     for ( idx = 0; idx < fkeyColumns->GetCount(); idx++ ) {
-        column = fkeyColumns->GetItem( idx );
+        fkeyColumn = fkeyColumns->GetItem( idx );
-        if ( !CheckColumn(column) )
+        if ( !CheckColumn(fkeyColumn) )
+            // Skipping fkey column so skip entire foreign key
             return false;
-    FdoSmPhColumnsP pkeyColumns = fkey->GetPkeyColumns();
+        pkeyColumn = pkeyColumns->GetItem( idx );
-    for ( idx = 0; idx < pkeyColumns->GetCount(); idx++ ) {
-        column = pkeyColumns->GetItem( idx );
+        if ( !CheckColumn(pkeyColumn) )
+            // Skipping pkey column so skip entire foreign key
+            return false;
+        if ( fkeyColumn->GetType() != pkeyColumn->GetType() )
+            // FDO does not support association properties whose corresponding
+            // identity property pairs aren't of the same type. This foreign key
+            // generates such an association property so skip it.
             return false;
+        if ( fkeyColumn->GetType() == FdoSmPhColType_Geom )
+            // FDO Association property does not support geometric properties as identity properties
+            return false;
+        if ( fkeyColumn->GetAutoincrement() )
+            // Association reverse identity properties cannot be autogenerated so skip
+            // foreign keys with autogenerated fkey columns.
+            return false;
     return true;
More information about the fdo-commits mailing list
