[fdo-commits] r763 - in branches/3.2.x/Fdo/Unmanaged/Src:
Fdo/Schema Message
svn_fdo at osgeo.org
Mon Feb 12 13:17:11 EST 2007
Author: brentrobinson
Date: 2007-02-12 13:17:11 -0500 (Mon, 12 Feb 2007)
New Revision: 763
branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/AssociationPropertyDefinition.cpp
branches/3.2.x/Fdo/Unmanaged/Src/Message/FDOMessage.mc
Added property name to FdoAssociationPropertyDefinition exception messages
Modified: branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/AssociationPropertyDefinition.cpp
--- branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/AssociationPropertyDefinition.cpp 2007-02-12 18:15:23 UTC (rev 762)
+++ branches/3.2.x/Fdo/Unmanaged/Src/Fdo/Schema/AssociationPropertyDefinition.cpp 2007-02-12 18:17:11 UTC (rev 763)
@@ -346,13 +346,13 @@
// Cannot create an association property without the associated class
if( m_associatedClass == NULL )
- throw FdoSchemaException::Create(FdoException::NLSGetMessage(FDO_NLSID(SCHEMA_55_ASSOCIATEDCLASSREQUIRED), GetName() ));
+ throw FdoSchemaException::Create(FdoException::NLSGetMessage(FDO_NLSID(SCHEMA_55_ASSOCIATEDCLASSREQUIRED), (FdoString*) GetQualifiedName() ));
if( m_identityProperties && m_identityReverseProperties )
if( m_identityProperties->GetCount() != m_identityReverseProperties->GetCount() )
- throw FdoSchemaException::Create(FdoException::NLSGetMessage(FDO_NLSID(SCHEMA_17_ASSOCIATIONMISSMATCHERROR)));
+ throw FdoSchemaException::Create(FdoException::NLSGetMessage(FDO_NLSID(SCHEMA_17_ASSOCIATIONMISSMATCHERROR), (FdoString*) GetQualifiedName() ));
// Make sure that the identity properties and reverse properties are of the same types
for( int i=0; i<m_identityProperties->GetCount(); i++ )
@@ -361,7 +361,7 @@
FdoPtr<FdoDataPropertyDefinition> revprop = m_identityReverseProperties->GetItem( i );
if( indprop->GetDataType() != revprop->GetDataType() )
@@ -373,7 +373,7 @@
if( revprop->GetIsAutoGenerated() || revprop->GetIsSystem() )
- throw FdoSchemaException::Create(FdoException::NLSGetMessage(FDO_NLSID(SCHEMA_53_BADASSOCREVERSEPROP)));
+ throw FdoSchemaException::Create(FdoException::NLSGetMessage(FDO_NLSID(SCHEMA_53_BADASSOCREVERSEPROP), (FdoString*) GetQualifiedName() ));
Modified: branches/3.2.x/Fdo/Unmanaged/Src/Message/FDOMessage.mc
--- branches/3.2.x/Fdo/Unmanaged/Src/Message/FDOMessage.mc 2007-02-12 18:15:23 UTC (rev 762)
+++ branches/3.2.x/Fdo/Unmanaged/Src/Message/FDOMessage.mc 2007-02-12 18:17:11 UTC (rev 763)
@@ -159,7 +159,7 @@
MessageId=1017
SymbolicName=SCHEMA_17_ASSOCIATIONMISSMATCHERROR
Language=English
-Type or number missmatch between the identity properties and the reverse identity properties.
+Association Property '%1$ls' has type or number missmatch between the identity properties and the reverse identity properties.
MessageId=1018
SymbolicName=SCHEMA_18_ASSOCIATIONIDENTITYERROR
@@ -339,7 +339,7 @@
MessageId=1053
SymbolicName=SCHEMA_53_BADASSOCREVERSEPROP
Language=English
-Cannot use auto-generated or system properties as reverse identity properties
+Cannot use auto-generated or system properties as reverse identity properties for association property '%1$ls'
MessageId=1054
SymbolicName=SCHEMA_54_AUTOGENREADONLY
More information about the fdo-commits
