[fdo-commits] r2529 - trunk/Fdo/Unmanaged/Inc/Fdo/Schema
svn_fdo at osgeo.org
Thu Feb 15 15:01:49 EST 2007
Author: gregboone
Date: 2007-02-15 15:01:49 -0500 (Thu, 15 Feb 2007)
New Revision: 2529
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AssociationPropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AutogenerationException.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/Class.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassCapabilities.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinitionCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DeleteRule.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClass.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClassCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchema.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchemaCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricPropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkClass.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkFeatureClass.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLayerClass.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLinkFeatureClass.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkNodeFeatureClass.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectPropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/OrderType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinitionCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintType.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/RasterPropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaAttributeDictionary.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaCollection.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElement.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElementState.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaException.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/TopoFeaturePropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/TopoGeometryPropertyDefinition.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/Topology.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/UniqueConstraint.h
trunk/Fdo/Unmanaged/Inc/Fdo/Schema/UniqueConstraintCollection.h
FDO4: API - Update API documentation included in the FDO header files
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AssociationPropertyDefinition.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AssociationPropertyDefinition.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AssociationPropertyDefinition.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -345,6 +345,7 @@
/// \endcond
+/// \ingroup (typedefs)
/// \brief
/// FdoAssociationPropertyP is a FdoPtr on FdoAssociationPropertyDefinition, provided for convenience.
typedef FdoPtr<FdoAssociationPropertyDefinition> FdoAssociationPropertyP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AutogenerationException.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AutogenerationException.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/AutogenerationException.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -33,8 +33,8 @@
/// or possibly because of provider-specific errors.
class FdoAutogenerationException : public FdoSchemaException
+/// \cond DOXYGEN-IGNORE
protected:
-/// \cond DOXYGEN-IGNORE
/// Constructs a default instance of an FdoAutogenerationException.
FdoAutogenerationException();
@@ -85,6 +85,7 @@
FDO_API static FdoAutogenerationException* Create(FdoString* name, FdoException* cause);
/// \brief
/// FdoSchemaExceptionP is a FdoPtr on FdoAutogenerationException, provided for convenience.
typedef FdoPtr<FdoAutogenerationException> FdoAutogenerationExceptionP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/Class.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/Class.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/Class.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -35,8 +35,8 @@
/// commands. The Class type does not pre-define any base properties.
class FdoClass : public FdoClassDefinition
protected:
/// Constructs a default instance of an FdoClass.
FdoClass();
@@ -79,6 +79,7 @@
FDO_API virtual FdoClassType GetClassType();
/// Public non-API functions for XML support
/// Initialize this class from its XML attributes
@@ -89,6 +90,7 @@
/// \endcond
/// \brief
/// FdoClassP is a FdoPtr on FdoClass, provided for convenience.
typedef FdoPtr<FdoClass> FdoClassP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassCapabilities.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassCapabilities.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassCapabilities.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -146,6 +146,7 @@
/// \brief
/// FdoClassCapabilitiesP is a FdoPtr on FdoClassCapabilities, provided for convenience.
typedef FdoPtr<FdoClassCapabilities> FdoClassCapabilitiesP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassCollection.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassCollection.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassCollection.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -66,6 +66,7 @@
FDO_API static FdoClassCollection* Create(FdoSchemaElement* parent);
/// \brief
/// FdoClassesP is a FdoPtr on FdoClassCollection, provided for convenience.
typedef FdoPtr<FdoClassCollection> FdoClassesP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassDefinition.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassDefinition.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassDefinition.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -47,8 +47,8 @@
friend class FdoRelation;
friend class FdoObjectPropertyDefinition;
protected:
/// Constructs a default instance of a ClassDefinition.
FdoClassDefinition();
@@ -227,6 +227,7 @@
FDO_API FdoUniqueConstraintCollection* GetUniqueConstraints();
// Public non-API functions for XML and Schema Merge support
// Update a class definition from the given definition.
@@ -318,6 +319,7 @@
/// \endcond
/// \brief
/// FdoClassDefinitionP is a FdoPtr on FdoClassDefinition, provided for convenience.
typedef FdoPtr<FdoClassDefinition> FdoClassDefinitionP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassType.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassType.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ClassType.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -22,27 +22,10 @@
#pragma once
#endif
+/// \ingroup (enums)
/// \brief
/// The FdoClassType enumeration lists all of the concrete class types defined in
/// the Schema package.
-/// <param name="FdoClassType_Class">
-/// Represents the concrete class type Class
-/// </param>
-/// <param name="FdoClassType_FeatureClass">
-/// Represents the concrete class type FeatureClass
-/// </param>
-/// <param name="FdoClassType_NetworkClass">
-/// Represents the concrete class type NetworkClass
-/// </param>
-/// <param name="FdoClassType_NetworkLayerClass">
-/// Represents the concrete class type NetworkLayerClass
-/// </param>
-/// <param name="FdoClassType_NetworkNodeClass">
-/// Represents the concrete class type NetworkNodeClass
-/// </param>
-/// <param name="FdoClassType_NetworkLinkClass">
-/// Represents the concrete class type NetworkLinkClass
-/// </param>
enum FdoClassType
/// Represents the concrete class type Class.
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinition.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinition.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinition.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -38,8 +38,8 @@
template <class OBJ> friend class FdoSchemaCollection;
protected:
/// Constructs a default instance of an FdoDataPropertyDefinition.
FdoDataPropertyDefinition();
@@ -333,6 +333,7 @@
/// \endcond
/// \brief
/// FdoDataPropertyP is a FdoPtr on FdoDataPropertyDefinition, provided for convenience.
typedef FdoPtr<FdoDataPropertyDefinition> FdoDataPropertyP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinitionCollection.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinitionCollection.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataPropertyDefinitionCollection.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -116,6 +116,7 @@
FDO_API virtual void Insert(FdoInt32 index, FdoDataPropertyDefinition* value);
/// \brief
/// FdoDataPropertiesP is a FdoPtr on FdoDataPropertyDefinitionCollection, provided for convenience.
typedef FdoPtr<FdoDataPropertyDefinitionCollection> FdoDataPropertiesP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataType.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataType.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DataType.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -22,48 +22,9 @@
#pragma once
#endif
/// \brief
/// The FdoDataType enumeration lists all of the base data types supported by FDO.
-/// <param name="FdoDataType_Boolean">
-/// Represents a Boolean value of true or false
-/// </param>
-/// <param name="FdoDataType_Byte">
-/// Represents unsigned 8-bit integers with values between 0 and 255
-/// </param>
-/// <param name="FdoDataType_DateTime">
-/// Represents a date and time value
-/// </param>
-/// <param name="FdoDataType_Decimal">
-/// Represents values ranging from 1.0 x 10^-28 to approximately 7.9 x 10^28,
-/// with 28-29 significant digits
-/// </param>
-/// <param name="FdoDataType_Double">
-/// Represents a floating point value ranging from approximately 5.0
-/// x 10^-324 to 1.7 x 10^308 with a precision of 15-16 digits
-/// </param>
-/// <param name="FdoDataType_Int16">
-/// Represents signed 16-bit integers with values between -32768 and 32767
-/// </param>
-/// <param name="FdoDataType_Int32">
-/// Represents signed 32-bit integers with values between -2147483648 and 2147483647
-/// </param>
-/// <param name="FdoDataType_Int64">
-/// Represents signed 64-bit integers with values between -9223372036854775808 and 9223372036854775807
-/// </param>
-/// <param name="FdoDataType_Single">
-/// Represents floating point values ranging from approximately 1.5 x 10^-45
-/// to 3.4 x 10^38, with a precision of 7 digits
-/// </param>
-/// <param name="FdoDataType_String">
-/// Represents a Unicode character string
-/// </param>
-/// <param name="FdoDataType_BLOB">
-/// Represents a binary large object stored as a collection of bytes
-/// </param>
-/// <param name="FdoDataType_CLOB">
-/// Represents a character large object stored as a collection of
-/// characters
-/// </param>
enum FdoDataType
/// Represents a Boolean value of true or false.
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DeleteRule.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DeleteRule.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/DeleteRule.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -22,19 +22,11 @@
#pragma once
#endif
/// \brief
/// The FdoDeleteRule enumeration specifies the action to take when a delete
/// operation is executed on the class instance at the other end of the
/// relation.
-/// <param name="FdoDeleteRule_Cascade">
-/// Cascade the delete operation to class instances at this end of the relation
-/// </param>
-/// <param name="FdoDeleteRule_Prevent">
-/// Prevent the delete operation if there are class instances at this end of the relation
-/// </param>
-/// <param name="FdoDeleteRule_Break">
-/// Break the relationship by setting the identifying properties at this end to null values
-/// </param>
enum FdoDeleteRule
/// Cascade the delete operation to class instances at this end of the relation.
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClass.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClass.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClass.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -38,8 +38,8 @@
protected:
/// Constructs a default instance of an FdoFeatureClass.
FdoFeatureClass();
@@ -136,6 +136,7 @@
/// \endcond
/// \brief
/// FdoFeatureClassP is a FdoPtr on FdoFeatureClass, provided for convenience.
typedef FdoPtr<FdoFeatureClass> FdoFeatureClassP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClassCollection.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClassCollection.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureClassCollection.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -29,8 +29,8 @@
/// The FdoFeatureClassCollection class represents a collection of FdoFeatureClasse objects.
class FdoFeatureClassCollection: public FdoSchemaCollection<FdoFeatureClass>
protected:
/// Constructs an instance of a FeatureClassCollection using the specified argument.
FdoFeatureClassCollection(FdoSchemaElement* parent) : FdoSchemaCollection<FdoFeatureClass>(parent)
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchema.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchema.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchema.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -45,8 +45,8 @@
public FdoSchemaElement,
public FdoXmlSerializable
protected:
/// Constructs a default empty instance of an FdoFeatureSchema.
FdoFeatureSchema();
@@ -135,6 +135,7 @@
FDO_API virtual FdoXmlReader* GetFromInternalStylesheet();
/// Public non-API functions for XML serialization and Schema Merge
/// Merge the given schema into this schema. An additive merge
@@ -169,6 +170,7 @@
FdoClassCollection* m_classes;
/// \brief
/// FdoFeatureSchemaP is a FdoPtr on FdoFeatureSchema, provided for convenience.
typedef FdoPtr<FdoFeatureSchema> FdoFeatureSchemaP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchemaCollection.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchemaCollection.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/FeatureSchemaCollection.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -38,8 +38,8 @@
public FdoXmlDeserializable,
protected:
FdoFeatureSchemaCollection()
@@ -119,7 +119,8 @@
FDO_API FdoPhysicalSchemaMappingCollection* GetXmlSchemaMappings();
- /// \cond DOXYGEN-IGNORE
/// FdoXmlDeserializable override for getting the SAX Context for reading
/// Feature Schemas. Not exposed via the FDO API.
virtual FdoXmlSaxContext* GetSaxContext();
@@ -145,6 +146,7 @@
/// \brief
/// FdoFeatureSchemasP is a FdoPtr on FdoFeatureSchemaCollection, provided for convenience.
typedef FdoPtr<FdoFeatureSchemaCollection> FdoFeatureSchemasP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricPropertyDefinition.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricPropertyDefinition.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricPropertyDefinition.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -47,8 +47,8 @@
friend class FdoFeatureClass;
protected:
/// Constructs a default instance of an FdoGeometricPropertyDefinition.
FdoGeometricPropertyDefinition();
@@ -325,6 +325,7 @@
/// \endcond
/// \brief
/// FdoGeometricPropertyP is a FdoPtr on FdoGeometricPropertyDefinition, provided for convenience.
typedef FdoPtr<FdoGeometricPropertyDefinition> FdoGeometricPropertyP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricType.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricType.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/GeometricType.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -22,21 +22,11 @@
#pragma once
#endif
/// \brief
/// The FdoGeometricType enumeration categorizes all of the geometry types
/// supported by FDO based on their geometric dimensionality.
-/// <param name="FdoGeometricType_Point">
-/// Represents 0-dimensional geometric primitives, such as Points
-/// </param>
-/// <param name="FdoGeometricType_Curve">
-/// Represents 1 dimensional geometric primitives, such as Curves and Lines
-/// </param>
-/// <param name="FdoGeometricType_Surface">
-/// Represents 2 dimensional geometric primitives, such as Polygons
-/// </param>
-/// <param name="FdoGeometricType_Solid">
-/// Represents 3 dimensional geometric primitives, such as Cubes
-/// </param>
enum FdoGeometricType
/// Represents 0-dimensional geometric primitives, such as Points.
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/MergeContext.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -31,6 +31,7 @@
#include <Fdo/Xml/Flags.h>
/// \brief
/// FdoSchemaMergeContext provides support for updating a set of feature schemas
/// base on a second set of schemas. It's main purpose is to support the reading
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkClass.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkClass.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkClass.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -42,8 +42,8 @@
class FdoNetworkClass : public FdoClassDefinition
protected:
/// Constructs a default instance of an FdoNetworkClass.
FdoNetworkClass();
@@ -106,6 +106,7 @@
FDO_API void SetLayerClass(FdoNetworkLayerClass* value);
/// Public non-API functions for XML and Schema Merge support
/// Update this property from the given property.
@@ -135,6 +136,7 @@
/// \endcond
/// \brief
/// FdoNetworkClassP is a FdoPtr on FdoNetworkClass, provided for convenience.
typedef FdoPtr<FdoNetworkClass> FdoNetworkClassP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkFeatureClass.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkFeatureClass.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkFeatureClass.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -37,8 +37,8 @@
class FdoNetworkFeatureClass : public FdoFeatureClass
protected:
/// Constructs a default instance of an FdoNetworkFeatureClass.
/// To make a class of this type, you need to either create a FdoNetworkNodeFeatureClass
/// or FdoNetworkLinkFeatureClass.
@@ -192,6 +192,7 @@
/// \endcond
/// \brief
/// FdoNetworkFeatureClassP is a FdoPtr on FdoNetworkFeatureClass, provided for convenience.
typedef FdoPtr<FdoNetworkFeatureClass> FdoNetworkFeatureClassP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLayerClass.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLayerClass.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLayerClass.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -36,8 +36,8 @@
class FdoNetworkLayerClass : public FdoClassDefinition
protected:
/// Constructs a default instance of an FdoNetworkLayerClass.
FdoNetworkLayerClass();
@@ -80,6 +80,7 @@
@@ -101,6 +102,7 @@
/// \endcond
/// \brief
/// FdoNetworkLayerClassP is a FdoPtr on FdoNetworkLayerClass, provided for convenience.
typedef FdoPtr<FdoNetworkLayerClass> FdoNetworkLayerClassP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLinkFeatureClass.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLinkFeatureClass.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkLinkFeatureClass.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -37,8 +37,8 @@
class FdoNetworkLinkFeatureClass : public FdoNetworkFeatureClass
protected:
/// Constructs a default instance of an FdoNetworkLinkFeatureClass.
FdoNetworkLinkFeatureClass();
@@ -174,6 +174,7 @@
/// \endcond
/// \brief
/// FdoNetworkLinkFeatureClassP is a FdoPtr on FdoNetworkLinkFeatureClass, provided for convenience.
typedef FdoPtr<FdoNetworkLinkFeatureClass> FdoNetworkLinkFeatureClassP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkNodeFeatureClass.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkNodeFeatureClass.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/NetworkNodeFeatureClass.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -36,8 +36,8 @@
class FdoNetworkNodeFeatureClass : public FdoNetworkFeatureClass
protected:
/// Constructs a default instance of an FdoNetworkNodeFeatureClass.
FdoNetworkNodeFeatureClass();
@@ -150,6 +150,7 @@
/// \endcond
/// \brief
/// FdoNetworkNodeFeatureClassP is a FdoPtr on FdoNetworkNodeFeatureClass, provided for convenience.
typedef FdoPtr<FdoNetworkNodeFeatureClass> FdoNetworkNodeFeatureClassP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectPropertyDefinition.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectPropertyDefinition.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectPropertyDefinition.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -215,6 +215,7 @@
/// \endcond
/// \brief
/// FdoObjectPropertyP is a FdoPtr on FdoObjectPropertyDefinition, provided for convenience.
typedef FdoPtr<FdoObjectPropertyDefinition> FdoObjectPropertyP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectType.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectType.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/ObjectType.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -22,18 +22,10 @@
#pragma once
#endif
/// \brief
/// The FdoObjectType enumeration defines whether an object property is a single
/// value, a collection, or an ordered collection.
-/// <param name="FdoObjectType_Value">
-/// Represents a simple value property
-/// </param>
-/// <param name="FdoObjectType_Collection">
-/// Represents a property that is a collection of values
-/// </param>
-/// <param name="FdoObjectType_OrderedCollection">
-/// Represents a property that is an ordered collection of values
-/// </param>
enum FdoObjectType
/// Represents a simple value property.
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/OrderType.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/OrderType.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/OrderType.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -22,15 +22,10 @@
#pragma once
#endif
/// \brief
/// The FdoOrderType enumeration list contains two values to indicate if the
/// object collection is to be ordered in ascending or descending fashion.
-/// <param name="FdoOrderType_Ascending">
-/// Specifies the collection is to be ordered from the smallest value to the largest value
-/// </param>
-/// <param name="FdoOrderType_Descending">
-/// Specifies the collection is to be ordered from the largest value to the smallest value
-/// </param>
enum FdoOrderType
/// Specifies the collection is to be ordered from the smallest value to the largest value.
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinition.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinition.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinition.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -32,8 +32,8 @@
/// FdoGeometricPropertyDefinition, and FdoObjectPropertyDefinition.
class FdoPropertyDefinition : public FdoSchemaElement
protected:
/// Constructs a default instance of a PropertyDefinition.
FdoPropertyDefinition();
@@ -81,6 +81,7 @@
FDO_API virtual void SetIsSystem( bool value );
@@ -98,6 +99,7 @@
/// \endcond
/// \brief
/// FdoPropertyP is a FdoPtr on FdoPropertyDefinition, provided for convenience.
typedef FdoPtr<FdoPropertyDefinition> FdoPropertyP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinitionCollection.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinitionCollection.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyDefinitionCollection.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -88,6 +88,7 @@
FDO_API virtual void RemoveAt(FdoInt32 index);
/// \brief
/// FdoPropertiesP is a FdoPtr on FdoPropertyDefinitionCollection, provided for convenience.
typedef FdoPtr<FdoPropertyDefinitionCollection> FdoPropertiesP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyType.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyType.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyType.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -22,23 +22,9 @@
#pragma once
#endif
/// \brief
/// The FdoPropertyType enumeration lists the possible types that a Property can be.
-/// <param name="FdoPropertyType_DataProperty">
-/// Represents a Data Property type
-/// </param>
-/// <param name="FdoPropertyType_ObjectProperty">
-/// Represents an Object Property type
-/// </param>
-/// <param name="FdoPropertyType_GeometricProperty">
-/// Represents a Geometric Property type
-/// </param>
-/// <param name="FdoPropertyType_AssociationProperty">
-/// Represents an Association Property type
-/// </param>
-/// <param name="FdoPropertyType_RasterProperty">
-/// Represents a Raster (image) Property type
-/// </param>
enum FdoPropertyType
/// Represents a Data Property type.
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintType.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintType.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/PropertyValueConstraintType.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -22,21 +22,18 @@
#pragma once
#endif
/// \brief
/// The FdoPropertyValueConstraintType enumeration categorizes the
/// supported constraint.
-/// <param name="FdoPropertyValueConstraintType_Range">
-/// This constraint specifies minimum and / or maximum allowed values for a particular property. It can be used for all data property types except for Boolean, BLOB, or CLOB
-/// </param>
-/// <param name="FdoPropertyValueConstraintType_List">
-/// This constraint specifies a list of allowed values for a particular property. It can be used for all data property types except for Boolean, BLOB, or CLOB
-/// </param>
enum FdoPropertyValueConstraintType
- /// Represents a range constaint.
+ /// Specifies minimum and / or maximum allowed values for a particular property.
+ /// It can be used for all data property types except for Boolean, BLOB, or CLOB.
FdoPropertyValueConstraintType_Range = 0x01,
- /// Represents a list constraint.
+ /// Specifies a list of allowed values for a particular property.
FdoPropertyValueConstraintType_List = 0x02
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/RasterPropertyDefinition.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/RasterPropertyDefinition.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/RasterPropertyDefinition.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -39,8 +39,8 @@
protected:
/// Constructs a default instance of an FdoRasterPropertyDefinition.
FdoRasterPropertyDefinition ();
@@ -214,7 +214,7 @@
/// \brief
/// Sets a Spatial Context association for this raster property.
- /// \param value
+ /// \param spatialContextName
/// Input the Spatial Context name to be set.
/// Defaults to the active Spatial Context.
@@ -233,6 +233,7 @@
@@ -280,6 +281,7 @@
/// \endcond
/// \brief
/// FdoRasterPropertyP is a FdoPtr on FdoRasterPropertyDefinition, provided for convenience.
typedef FdoPtr<FdoRasterPropertyDefinition> FdoRasterPropertyP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaAttributeDictionary.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaAttributeDictionary.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaAttributeDictionary.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -38,8 +38,8 @@
friend class FdoSchemaElement;
protected:
FdoSchemaAttributeDictionary()
@@ -141,6 +141,7 @@
FDO_API void Clear();
/// Handle the start of a dictionary element
@@ -195,6 +196,7 @@
/// \endcond
/// \brief
/// FdoSADP is a FdoPtr on FdoSchemaAttributeDictionary, provided for convenience.
typedef FdoPtr<FdoSchemaAttributeDictionary> FdoSADP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaCollection.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaCollection.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaCollection.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -35,8 +35,8 @@
template <class OBJ> class FdoSchemaCollection : public FdoNamedCollection<OBJ, FdoSchemaException>
protected:
FdoSchemaCollection()
@@ -356,8 +356,8 @@
FdoNamedCollection<OBJ, FdoSchemaException>::RemoveAt(index);
protected:
/// States stored in the m_changeInfoState bitfield flag
static const unsigned int CHANGEINFO_PRESENT = 0x00000001;
static const unsigned int CHANGEINFO_PROCESSING = 0x00000002;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElement.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElement.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElement.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -50,8 +50,8 @@
friend class FdoNetworkFeatureClass;
friend class FdoNetworkLinkFeatureClass;
protected:
/// Constructs a default instance of an FdoSchemaElement.
FdoSchemaElement();
@@ -268,7 +268,7 @@
/// \endcond
/// \brief
/// FdoSchemaElementP is a FdoPtr on FdoSchemaElement, provided for convenience.
typedef FdoPtr<FdoSchemaElement> FdoSchemaElementP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElementState.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElementState.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaElementState.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -23,23 +23,9 @@
#pragma once
#endif
/// \brief
/// The FdoSchemaElementState enumeration defines the current state of the schema element
-/// <param name="FdoSchemaElementState_Added">
-/// Indicates the schema element has been added
-/// </param>
-/// <param name="FdoSchemaElementState_Deleted">
-/// Indicates the schema element is marked for deletion
-/// </param>
-/// <param name="FdoSchemaElementState_Detached">
-/// Indicates the schema element is not associated with an FdoFeatureSchema
-/// </param>
-/// <param name="FdoSchemaElementState_Modified">
-/// Indicates the schema element has been modified in some way
-/// </param>
-/// <param name="FdoSchemaElementState_Unchanged">
-/// Indicates the schema element has not been changed
-/// </param>
enum FdoSchemaElementState
/// Indicates the schema element has been added.
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaException.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaException.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/SchemaException.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -30,8 +30,8 @@
/// environment-specific.
class FdoSchemaException : public FdoException
protected:
/// Constructs a default instance of an FdoSchemaException.
FdoSchemaException();
@@ -82,6 +82,7 @@
FDO_API static FdoSchemaException* Create(FdoString* name, FdoException* cause);
/// \brief
/// FdoSchemaExceptionP is a FdoPtr on FdoSchemaException, provided for convenience.
typedef FdoPtr<FdoSchemaException> FdoSchemaExceptionP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/TopoFeaturePropertyDefinition.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/TopoFeaturePropertyDefinition.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/TopoFeaturePropertyDefinition.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -60,6 +60,7 @@
/// Initialize the class from its XML attributes
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/TopoGeometryPropertyDefinition.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/TopoGeometryPropertyDefinition.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/TopoGeometryPropertyDefinition.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -76,6 +76,7 @@
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/Topology.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/Topology.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/Topology.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -117,7 +117,8 @@
virtual void Dispose ();
/// Hide default constructor to ensure that it cannot be used.
FdoTopology() {};
virtual ~FdoTopology();
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/UniqueConstraint.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/UniqueConstraint.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/UniqueConstraint.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -68,6 +68,7 @@
FdoDataPropertyDefinitionCollection* m_properties;
/// \brief
/// FdoUniqueConstraintP is a FdoPtr on FdoUniqueConstraint, provided for convenience.
typedef FdoPtr<FdoUniqueConstraint> FdoUniqueConstraintP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Schema/UniqueConstraintCollection.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Schema/UniqueConstraintCollection.h 2007-02-15 19:58:44 UTC (rev 2528)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Schema/UniqueConstraintCollection.h 2007-02-15 20:01:49 UTC (rev 2529)
@@ -55,6 +55,9 @@
FDO_API static FdoUniqueConstraintCollection* Create();
+/// \brief
+/// FdoUniqueConstraintCollectionP is a FdoPtr on FdoUniqueConstraintCollection, provided for convenience.
typedef FdoPtr<FdoUniqueConstraintCollection> FdoUniqueConstraintCollectionP;
#endif
More information about the fdo-commits
