[fdo-commits] r2530 - trunk/Fdo/Unmanaged/Inc/Fdo/Xml
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Feb 15 15:03:41 EST 2007
Author: gregboone
Date: 2007-02-15 15:03:41 -0500 (Thu, 15 Feb 2007)
New Revision: 2530
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ClassMapping.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ClassMappingCollection.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Context.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Deserializable.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMapping.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMappingCollection.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureContext.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureFlags.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureHandler.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeaturePropertyReader.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeaturePropertyWriter.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureReader.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureWriter.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Flags.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/NameCollectionHandler.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SchemaMapping.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextFlags.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextReader.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextWriter.h
FDO4: API - Update API documentation included in the FDO header files
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ClassMapping.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ClassMapping.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ClassMapping.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -45,6 +45,8 @@
     /// set when the type represents geometries and indicates what kind of geometries the type
     /// represents. wkBaseName must be L"" or one of the constants defined in
     /// commonGml212Gml212.h.
+	 /// \param wkSchemaName
+	 /// Well-known schema name.
     /// \return
     /// Returns FdoXmlClassMapping
@@ -90,6 +92,7 @@
 	FDO_API FdoXmlElementMappingCollection* GetElementMappings();
 /// \cond DOXYGEN-IGNORE
     /// \brief
     /// Writes this XML Class Mapping to XML. Called when
     /// the element is serialized to XML.
@@ -108,8 +111,8 @@
 /// \endcond
+/// \cond DOXYGEN-IGNORE
 protected:
-/// \cond DOXYGEN-IGNORE
     FdoXmlClassMapping() {}
     FdoXmlClassMapping(
@@ -148,6 +151,7 @@
     FdoXmlElementMappingsP mElementMappings;
+/// \ingroup (typedefs)
 /// \brief
 /// FdoXmlClassMappingP is a FdoPtr on FdoXmlClassMapping, provided for convenience.
 typedef FdoPtr<FdoXmlClassMapping> FdoXmlClassMappingP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ClassMappingCollection.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ClassMappingCollection.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ClassMappingCollection.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -55,6 +55,7 @@
 /// \endcond
 /// \brief
 /// FdoXmlClassMappingsP is a FdoPtr on FdoXmlClassMappingCollection, provided for convenience.
 typedef FdoPtr<FdoXmlClassMappingCollection> FdoXmlClassMappingsP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Context.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Context.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Context.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -30,19 +30,31 @@
     /// \brief
     /// Constructs a context for parsing FDO Deserializable items
-    /// \param schemas
-    /// Read the Feature Schemas into this collection.
+    /// \param flags
+    /// Input flags.
+	 /// \param xmlReader
+	 /// Input xmlReader.
+	 /// \return
+	 /// Returns FdoXmlContext.
 	FDO_API static FdoXmlContext* Create( FdoXmlFlags* flags, FdoXmlReader* xmlReader );
     /// \brief
     /// Decodes any element name that was encoded to be XML-compatible.
+	 /// \param name
+	 /// Input name.
+	 /// \return
+	 /// Returns FdoStringP.
     FDO_API FdoStringP DecodeName ( FdoStringP name );
     /// \brief
     /// Retrieves the current XML flags.
+	 /// \return
+	 /// Returns FdoXmlFlags.
     FDO_API FdoXmlFlags* GetFlags();
@@ -56,6 +68,9 @@
     FdoXmlFlagsP mFlags;
+/// \brief
+/// FdoXmlContextP is an FdoPtr on FdoXmlContext provided for convenience.
 typedef FdoPtr<FdoXmlContext> FdoXmlContextP;
 #endif
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Deserializable.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Deserializable.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Deserializable.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -46,7 +46,7 @@
     /// \brief
     /// Reads an XML document from an XML reader.
-    /// \param reader
     /// Input the XML reader.
     /// \param flags
     /// Input controls the reading of the elements from the document.
@@ -60,7 +60,7 @@
     /// \brief
     /// Reads an XML document from a text reader.
-    /// \param reader
+    /// \param textReader
     /// Input the text reader. Must be positioned at the
     /// start of an XML document.
     /// \param flags
@@ -75,7 +75,7 @@
     /// \brief
     /// Reads an XML document from a stream.
-    /// \param reader
+    /// \param stream
     /// Input the stream. Must be positioned at the
     /// \param flags
@@ -135,9 +135,9 @@
     FDO_API virtual ~FdoXmlDeserializable();
 private:
-    /// current XML flags
+    // current XML flags
-    /// current XML reader
+    // current XML reader
     FdoXmlReaderP mInternalReader;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMapping.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMapping.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMapping.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -107,7 +107,7 @@
     /// \brief
     /// Sets the namespace URI for this element.
-    /// \param schemaName
+    /// \param gmlUri
     /// Input a URI. Defaults to the targetNamespace
     /// for the schema containing this element.
@@ -126,7 +126,7 @@
     /// \brief
     /// Sets the local name for this element.
+    /// \param gmlLocalName
     /// Input the local name (unprefixed name) of this
     /// element. Defaults to the element name.
@@ -146,6 +146,7 @@
     /// Functions for XML support
     /// \brief
     /// Initializes this Xml Element Mapping from its XML attributes. Called when
     /// the element is deserialized from XML.
@@ -184,8 +185,8 @@
     virtual void SetChoiceName(FdoString* pChoiceName){m_choiceName = pChoiceName;}
     virtual FdoString* GetChoiceName(){return m_choiceName;}
 protected:
     FdoXmlElementMapping() {}
@@ -207,6 +208,7 @@
     FdoStringP                  m_choiceName;
 /// \brief
 /// FdoXmlElementMappingP is a FdoPtr on FdoXmlElementMapping, provided for convenience.
 typedef FdoPtr<FdoXmlElementMapping> FdoXmlElementMappingP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMappingCollection.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMappingCollection.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/ElementMappingCollection.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -44,8 +44,8 @@
     FDO_API static FdoXmlElementMappingCollection* Create(FdoPhysicalElementMapping* parent);
 protected:
     FdoXmlElementMappingCollection() : FdoPhysicalElementMappingCollection<FdoXmlElementMapping>()
@@ -61,6 +61,7 @@
 /// \endcond
 /// \brief
 /// FdoXmlElementMappingsP is a FdoPtr on FdoXmlElementMappingCollection, provided for convenience.
 typedef FdoPtr<FdoXmlElementMappingCollection> FdoXmlElementMappingsP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureContext.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureContext.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureContext.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -60,6 +60,7 @@
 	virtual ~FdoXmlFeatureContext();
 /// \brief
 /// FdoXmlFeatureContextP is a FdoPtr on FdoXmlFeatureContext, provided for convenience.
 typedef FdoPtr<FdoXmlFeatureContext> FdoXmlFeatureContextP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureFlags.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureFlags.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureFlags.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -58,23 +58,18 @@
 class FdoXmlFeatureFlags : public FdoXmlFlags
 public:
-    /// \brief
-    /// The FdoXmlFeatureFlags::ConflictOption specifies how to handle features that
-    /// are already in the DataStore, when Deserializing:
-    /// \param ConflictOption_Add
-    /// just add new features to the FDO DataStore. If a feature already exists, an
-    /// exception is thrown.
-    /// \param ConflictOption_Update
-    /// Update the feature if it already exists, add it if it doesn't exist. This is
-    /// the slowest option, since the feature must be queried from the DataStore before
-    /// it is inserted or updated.
-    /// \param ConflictOption_Skip
-    /// just add new features. Silently skip features already in the DataStore.
+    	/// \brief
+    	/// The FdoXmlFeatureFlags::ConflictOption specifies how to handle features that
+    	/// are already in the DataStore, when Deserializing:
 	enum ConflictOption {
+    		/// Add new features to the FDO DataStore and if a feature already exists,
+    		/// throw an exception.
 		ConflictOption_Add,
+    		/// Update the feature if it already exists, add it if it doesn't exist.
+		/// This is the slowest option, since the feature must be queried from the DataStore
+    		/// before it is inserted or updated.
 		ConflictOption_Update,
+    		/// Add new features and silently skip features already in the DataStore.
 		ConflictOption_Skip
@@ -121,7 +116,7 @@
     /// \brief
     /// Sets the write feature collection flag. This flag is initially set to true.
-    /// \param writeMember
+    /// \param writeCollection
     /// Input
     /// true: The serialized features are wrapped in a GML FeatureCollection element.
     /// false: features are serialize without a wrapping collection element.
@@ -322,6 +317,7 @@
 /// \brief
 /// FdoXmlFeatureFlagsP is a FdoPtr on FdoXmlFeatureFlags, provided for convenience.
 typedef FdoPtr<FdoXmlFeatureFlags> FdoXmlFeatureFlagsP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureHandler.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureHandler.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureHandler.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -51,7 +51,7 @@
     /// Returns the feature Handler for all sub-elements of the element that was current
     /// when the read started. If NULL, this feature handler remains in effect.
-    FDO_API virtual FdoXmlFeatureHandler* FeatureDocumentStart(FdoXmlFeatureContext*);
+    FDO_API virtual FdoXmlFeatureHandler* FeatureDocumentStart(FdoXmlFeatureContext* featureContext);
     /// \brief
     /// Default feature handler callback that is called when the
@@ -61,7 +61,7 @@
     /// \param featureContext
     /// Input caller specified contextual information
-    FDO_API virtual void FeatureDocumentEnd(FdoXmlFeatureContext*);
+    FDO_API virtual void FeatureDocumentEnd(FdoXmlFeatureContext* featureContext);
     /// \brief
@@ -71,11 +71,14 @@
+    /// \param classDefinition
+    /// Input class definition.
     /// \return
     /// Returns the feature Handler for the features in this collection.
     /// If NULL, this feature handler remains in effect.
-    FDO_API virtual FdoXmlFeatureHandler* FeatureCollectionStart(FdoXmlFeatureContext*,FdoClassDefinition*);
+    FDO_API virtual FdoXmlFeatureHandler* FeatureCollectionStart(FdoXmlFeatureContext* featureContext, FdoClassDefinition* classDefinition);
     /// \brief
@@ -90,7 +93,7 @@
     /// to continue. Return value is ignored if the current parse is not an incremental
     /// parse ( see FdoXmlFeaturePropertyReader::Parse())
-    FDO_API virtual FdoBoolean FeatureCollectionEnd(FdoXmlFeatureContext*);
+    FDO_API virtual FdoBoolean FeatureCollectionEnd(FdoXmlFeatureContext* featureContext);
     /// \brief
@@ -106,7 +109,7 @@
     /// Returns the feature Handler for the feature's properties. If NULL, this feature
     /// handler remains in effect.
-    FDO_API virtual FdoXmlFeatureHandler* FeatureStart(FdoXmlFeatureContext*,FdoClassDefinition*);
+    FDO_API virtual FdoXmlFeatureHandler* FeatureStart(FdoXmlFeatureContext* featureContext, FdoClassDefinition* classDefinition);
     /// \brief
@@ -120,7 +123,7 @@
     /// parse to continue. Return value is ignored if the current parse is not an
     /// incremental parse ( see FdoXmlFeaturePropertyReader::Parse())
-    FDO_API virtual FdoBoolean FeatureEnd(FdoXmlFeatureContext*);
+    FDO_API virtual FdoBoolean FeatureEnd(FdoXmlFeatureContext* featureContext);
     /// \brief
@@ -132,15 +135,15 @@
     /// \param name
     /// Input property name
-    /// \param name
-    /// Input property value
+    /// \param  boolPropertyValue
+    /// Input value of boolean property.
     /// \return
     /// Returning true causes the current parse to stop. Returning false causes
     /// the parse to continue. Return value is ignored if the current parse is not an
-    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext*, FdoString*, FdoBoolean);
+    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext* featureContext, FdoString* name, FdoBoolean boolPropertyValue);
     /// \brief
@@ -152,15 +155,15 @@
     /// \param name
-    /// \param name
+    /// \param bytePropertyValue
+    /// Input byte property value
     /// \return
-    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext*, FdoString*, FdoByte);
+    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext* featureContext, FdoString* name, FdoByte bytePropertyValue);
     /// \brief
@@ -172,15 +175,15 @@
     /// \param name
-    /// \param name
+    /// \param dateTimePropertyValue
+    /// Input FdoDateTime property value
     /// \return
-    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext*, FdoString*, FdoDateTime);
+    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext* featureContext, FdoString* name, FdoDateTime dateTimePropertyValue);
     /// \brief
@@ -192,15 +195,15 @@
     /// \param name
-    /// \param name
+    /// \param doublePropertyValue
+    /// Input double property value
     /// \return
-    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext*, FdoString*, FdoDouble);
+    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext* featureContext, FdoString* name, FdoDouble doublePropertyValue);
     /// \brief
@@ -212,15 +215,15 @@
     /// \param name
-    /// \param name
+    /// \param int16PropertyValue
+    /// Input Int16 property value
     /// \return
-    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext*, FdoString*, FdoInt16);
+    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext* featureContext, FdoString* name, FdoInt16 int16PropertyValue);
     /// \brief
@@ -232,15 +235,15 @@
     /// \param name
-    /// \param name
+    /// \param int32PropertyValue
+    /// Input Int32 property value
     /// \return
-    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext*, FdoString*, FdoInt32);
+    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext* featureContext, FdoString* name, FdoInt32 int32PropertyValue);
     /// \brief
@@ -252,15 +255,15 @@
     /// \param name
-    /// \param name
+    /// \param int64PropertyValue
+    /// Input Int64 property value
     /// \return
-    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext*, FdoString*, FdoInt64);
+    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext* featureContext, FdoString* name, FdoInt64 int64PropertyValue);
     /// \brief
@@ -272,15 +275,15 @@
     /// \param name
-    /// \param name
+    /// \param floatPropertyValue
+    /// Input float property value
     /// \return
-    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext*, FdoString*, FdoFloat);
+    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext* featureContext, FdoString* name, FdoFloat floatPropertyValue);
     /// \brief
@@ -292,15 +295,15 @@
     /// \param name
-    /// \param name
+    /// \param stringPropertyValue
+    /// Input string property value
     /// \return
-    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext*, FdoString*, FdoString*);
+    FDO_API virtual FdoBoolean FeatureProperty(FdoXmlFeatureContext* featureContext, FdoString* name, FdoString* stringPropertyValue);
     /// \brief
@@ -313,7 +316,7 @@
     /// \param name
-    /// \param raster
+    /// \param rasterPropertyValue
     /// Input raster image properties. This object always has a NULL stream reader. The image is
     /// handled by the FeatureBinaryData() callback.
@@ -322,7 +325,7 @@
-    FDO_API virtual FdoBoolean FeatureStartRasterProperty(FdoXmlFeatureContext*, FdoString*, FdoIRaster*);
+    FDO_API virtual FdoBoolean FeatureStartRasterProperty(FdoXmlFeatureContext* featureContext, FdoString* name, FdoIRaster* rasterPropertyValue);
     /// \brief
@@ -337,7 +340,7 @@
-    FDO_API virtual FdoBoolean FeatureEndRasterProperty(FdoXmlFeatureContext*);
+    FDO_API virtual FdoBoolean FeatureEndRasterProperty(FdoXmlFeatureContext* featureContext);
     /// \brief
@@ -356,7 +359,7 @@
-    FDO_API virtual FdoBoolean FeatureStartLobProperty(FdoXmlFeatureContext*, FdoString*);
+    FDO_API virtual FdoBoolean FeatureStartLobProperty(FdoXmlFeatureContext* featureContext, FdoString* name);
     /// \brief
@@ -371,7 +374,7 @@
-    FDO_API virtual FdoBoolean FeatureEndLobProperty(FdoXmlFeatureContext*);
+    FDO_API virtual FdoBoolean FeatureEndLobProperty(FdoXmlFeatureContext* featureContext);
     /// \brief
@@ -382,9 +385,9 @@
     /// \param name
-    /// \param bytes
+    /// \param geometryByteArray
     /// Input pointer to the byte array defining the geometry value
-    /// \param count
+    /// \param byteCount
     /// Input number of bytes in the byte array
     /// \return
@@ -392,7 +395,7 @@
     /// continue. Return value is ignored if the current parse is not an incremental
-    FDO_API virtual FdoBoolean FeatureGeometricProperty(FdoXmlFeatureContext*, FdoString*, FdoByte*, FdoInt32);
+    FDO_API virtual FdoBoolean FeatureGeometricProperty(FdoXmlFeatureContext* featureContext, FdoString*name, FdoByte* geometryByteArray, FdoInt32 byteCount);
     /// \brief
@@ -410,7 +413,7 @@
     /// Returns the feature Handler for the current object property's sub-properties.
-    FDO_API virtual FdoXmlFeatureHandler* FeatureStartObjectProperty(FdoXmlFeatureContext*, FdoString*, FdoClassDefinition*);
+    FDO_API virtual FdoXmlFeatureHandler* FeatureStartObjectProperty(FdoXmlFeatureContext* featureContext, FdoString* name, FdoClassDefinition* classDefinition);
     /// \brief
@@ -425,7 +428,7 @@
-    FDO_API virtual FdoBoolean FeatureEndObjectProperty(FdoXmlFeatureContext*);
+    FDO_API virtual FdoBoolean FeatureEndObjectProperty(FdoXmlFeatureContext* featureContext);
     /// \brief
@@ -458,7 +461,7 @@
     /// Returns the feature Handler for the current association property's sub-properties.
-    FDO_API virtual FdoXmlFeatureHandler* FeatureStartAssociationProperty(FdoXmlFeatureContext*, FdoString*, FdoClassDefinition*);
+    FDO_API virtual FdoXmlFeatureHandler* FeatureStartAssociationProperty(FdoXmlFeatureContext* featureContext, FdoString* name, FdoClassDefinition* classDefinition);
     /// \brief
@@ -473,7 +476,7 @@
-    FDO_API virtual FdoBoolean FeatureEndAssociationProperty(FdoXmlFeatureContext*);
+    FDO_API virtual FdoBoolean FeatureEndAssociationProperty(FdoXmlFeatureContext* featureContext);
     /// \brief
     /// Default Feature Handle callback that is called when the FdoXmlFeaturePropertyReader
@@ -492,7 +495,7 @@
-    FDO_API virtual FdoBoolean FeatureCharacters(FdoXmlFeatureContext*, FdoString*);
+    FDO_API virtual FdoBoolean FeatureCharacters(FdoXmlFeatureContext* featureContext, FdoString* chars);
     /// \brief
     /// Default Feature callback that is called when the FdoXmlFeaturePropertyReader
@@ -515,7 +518,7 @@
-    FDO_API virtual FdoBoolean FeatureBinaryData(FdoXmlFeatureContext*, FdoByte*, FdoSize);
+    FDO_API virtual FdoBoolean FeatureBinaryData(FdoXmlFeatureContext* featureContext, FdoByte* bytes, FdoSize count);
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeaturePropertyReader.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeaturePropertyReader.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeaturePropertyReader.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -147,6 +147,7 @@
 /// \brief
 /// FdoXmlFeaturePropertyReaderP is a FdoPtr on FdoXmlFeaturePropertyReader, provided for convenience.
 typedef FdoPtr<FdoXmlFeaturePropertyReader> FdoXmlFeaturePropertyReaderP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeaturePropertyWriter.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeaturePropertyWriter.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeaturePropertyWriter.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -81,7 +81,7 @@
     /// element and the feature's actual element are written. The feature element name
     /// is derived from the feature's class and schema names.
-    /// \param stargTag
+    /// \param startTag
     /// The start tag for the feature element. If it is null, the
     /// feature's class name used.
@@ -102,7 +102,7 @@
     /// \brief
     /// Writes a feature property to XML.
-    /// \param value
+    /// \param name
     /// Input the property name
     /// \param value
     /// Input the property value as an FDO property
@@ -118,7 +118,7 @@
     /// \brief
-    /// \param value
+    /// \param name
     /// \param value
     /// Input the property value as a string
@@ -136,7 +136,7 @@
     /// \brief
     /// Writes a raster property to XML.
-    /// \param value
+    /// \param name
     /// \param value
     /// Input the raster property value
@@ -152,7 +152,7 @@
     /// \brief
     /// Writes a lob property to XML.
-    /// \param value
+    /// \param name
     /// \param value
     /// Input the lob property value
@@ -239,6 +239,7 @@
 /// \brief
 typedef FdoPtr<FdoXmlFeaturePropertyWriter> FdoXmlFeaturePropertyWriterP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureReader.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureReader.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureReader.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -102,7 +102,7 @@
     ///       Normal.
     /// </ul>
-    /// \param value
+    /// \param schemas
     /// Input the feature schemas
     /// \return
@@ -112,6 +112,7 @@
 /// \brief
 /// FdoXmlFeatureReaderP is a FdoPtr on FdoXmlFeatureReader, provided for convenience.
 typedef FdoPtr<FdoXmlFeatureReader> FdoXmlFeatureReaderP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureWriter.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureWriter.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/FeatureWriter.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -103,7 +103,7 @@
     /// \brief
     /// Sets the class definition for the current feature being written.
-    /// \param value
     /// Input the class definition
     /// \return
@@ -193,6 +193,7 @@
 /// \brief
 /// FdoXmlFeatureWriterP is a FdoPtr on FdoXmlFeatureWriter, provided for convenience.
 typedef FdoPtr<FdoXmlFeatureWriter> FdoXmlFeatureWriterP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Flags.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Flags.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/Flags.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -32,28 +32,6 @@
     /// The FdoXmlFlags::ErrorLevel determines how strict the error reporting
     /// is when a Feature Schema is read from an XML Document. For each errorLevel a
     /// certain level of round-trip fidelity is guaranteed if the read succeeds.
-    /// \param ErrorLevel_High
-    /// the read fails with an exception when the
-    /// Feature Schema cannot be read without alteration. If the Feature Schema
-    /// is read successfully from document A and then written to document B,
-    /// documents A and B are guaranteed to be identical. This errorLevel should be
-    /// used when no alterations to the Feature Schema can be tolerated
-    /// \param ErrorLevel_Normal
-    /// fails if the Feature Schema cannot be read
-    /// without changing the domain of its conforming instance documents. If the
-    /// Feature Schema is read successfully from document A and then written to
-    /// document B, any instance document that conforms to the document A schema
-    /// will also conform to the document B schema. Any instance document that does
-    /// not conform to A does not conform to B. However, documents A and B will not
-    /// necessarily be identical.
-    /// \param ErrorLevel_Low
-    /// similar to ErrorLevel_Normal except that the
-    /// instance document domain is allowed to grow. If the Feature Schema is read
-    /// successfully from document A and then written to document B, any instance
-    /// document that conforms to the document A schema will also conform to the
-    /// document B schema. However a document that does not conform to the A schema
-    /// may or may not conform to the B schema.
     /// \param ErrorLevel_VeryLow
     /// the read succeeds even if no level of
     /// round-trip fidelity is maintained. If the Feature Schema is read successfully
@@ -65,9 +43,35 @@
     /// altered during the read.
 	enum ErrorLevel {
+    		/// The read fails with an exception when the Feature Schema cannot be read without alteration.
+		/// If the Feature Schema is read successfully from document A and then written to document B,
+    		/// documents A and B are guaranteed to be identical.
+		/// This errorLevel should be used when no alterations to the Feature Schema can be tolerated
 		ErrorLevel_High,
+    		/// Fails if the Feature Schema cannot be read
+    		/// without changing the domain of its conforming instance documents.
+		/// and then written to document B,
+    		/// any instance document that conforms to the document A schema
+    		/// will also conform to the document B schema.
+		/// Any instance document that does not conform to A does not conform to B.
+		/// However, documents A and B will not necessarily be identical.
 		ErrorLevel_Normal,
+    		/// Similar to ErrorLevel_Normal except that the
+    		/// instance document domain is allowed to grow.
+    		/// successfully from document A and then written to document B,
+		/// any instance document that conforms to the document A schema will also conform to the document B schema.
+		/// However a document that does not conform to the A schema
+    		/// may or may not conform to the B schema.
 		ErrorLevel_Low,
+    		/// The read succeeds even if no level of round-trip fidelity is maintained.
+		/// any instance document thatconforms to the document A schema
+		/// may or may not conform to the document B schema.
+    		/// A document that does not conform to the A schema may or may not conform to the B schema.
+		/// This errorLevel is useful for reading schemas from external sources into FDO
+		/// when it doesn’t matter how much the schemas are altered during the read.
 		ErrorLevel_VeryLow
@@ -113,7 +117,7 @@
     /// \brief
     /// Sets the error level, see FdoXmlFlags::Create().
-    /// \param url
+    /// \param errorLevel
     /// Input the error level.
 	FDO_API void SetErrorLevel( ErrorLevel errorLevel );
@@ -129,7 +133,7 @@
     /// \brief
     /// Sets the name adjustment flag, see FdoXmlFlags::Create().
-    /// \param url
+    /// \param nameAdjust
     /// Input the name adjustment flag.
   	FDO_API void SetNameAdjust( FdoBoolean nameAdjust );
@@ -247,6 +251,7 @@
 /// \endcond
 /// \brief
 /// FdoXmlFlagsP is a FdoPtr on FdoXmlFlags, provided for convenience.
 typedef FdoPtr<FdoXmlFlags> FdoXmlFlagsP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/NameCollectionHandler.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/NameCollectionHandler.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/NameCollectionHandler.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -58,7 +58,7 @@
     virtual void _writeXml(FdoXmlWriter* xmlWriter, const FdoXmlFlags* flags);
     virtual FdoXmlSaxHandler* XmlStartElement(
-        FdoXmlSaxContext* context,
+        FdoXmlSaxContext* saxContext,
         FdoString* uri,
         FdoString* name,
         FdoString* qname,
@@ -66,7 +66,7 @@
     virtual FdoBoolean XmlEndElement(
         FdoString* uri,
         FdoString* name,
         FdoString* qname
@@ -87,6 +87,7 @@
     FdoXmlSkipElementHandlerP   mXmlSkipper;
 /// \brief
 /// FdoXmlNameCollectionHandlerP is a FdoPtr on FdoXmlNameCollectionHandler, provided for convenience.
 typedef FdoPtr<FdoXmlNameCollectionHandler> FdoXmlNameCollectionHandlerP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SchemaMapping.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SchemaMapping.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SchemaMapping.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -97,8 +97,8 @@
 	FDO_API FdoXmlClassMappingCollection* GetClassMappings();
 protected:
     FdoXmlSchemaMapping() {}
     FdoXmlSchemaMapping( FdoString* name );
@@ -147,6 +147,7 @@
     FdoXmlClassMappingsP mClassMappings;
 /// \brief
 /// FdoXmlSchemaMappingP is a FdoPtr on FdoXmlSchemaMapping, provided for convenience.
 typedef FdoPtr<FdoXmlSchemaMapping> FdoXmlSchemaMappingP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextFlags.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextFlags.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextFlags.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -31,25 +31,20 @@
 class FdoXmlSpatialContextFlags : public FdoXmlFlags
 public:
-    /// \brief
-    /// The FdoXmlSpatialContextFlags::ConflictOption specifies how
-    /// to handle Spatial Contexts that are already in the DataStore,
-    ///  when Deserializing:
-    /// just add new spatial contexts to the
-    /// FDO DataStore. If the Spatial Context already exists, an exception
-    /// is thrown.
-    /// Update the spatial context if it already
-    /// exists, add it if it doesn't exist.
-    /// just add new spatial contexts.
-    /// Silently skip spatial contexts already in the DataStore.
+    	/// \brief
+    	/// The FdoXmlSpatialContextFlags::ConflictOption specifies how
+    	/// to handle Spatial Contexts that are already in the DataStore,
+    	///  when Deserializing:
+    		/// Add new spatial contexts to the FDO DataStore and
+		/// if the Spatial Context already exists, throw an exception.
+    		/// is thrown.
 		ConflictOption_Add,
+    		/// Update the spatial context if it already exists and
+    		/// add it if it doesn't exist.
+    		/// Add new spatial contexts and
+    		/// silently skip spatial contexts already in the DataStore.
 		ConflictOption_Skip
@@ -139,6 +134,7 @@
 	FdoBoolean				mIncludeDefault;
 /// \brief
 /// FdoXmlSpatialContextFlagsP is a FdoPtr on FdoXmlSpatialContextFlags, provided for convenience.
 typedef FdoPtr<FdoXmlSpatialContextFlags> FdoXmlSpatialContextFlagsP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextReader.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextReader.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextReader.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -118,9 +118,6 @@
     /// Gets the extent of the spatial context currently being read as a byte
     /// array in FGF format.
-    /// \param length
-    /// Output the length of the returned byte array.
     /// \return
     /// Returns the extent as a byte array in FGF format.
@@ -171,12 +168,12 @@
     FDO_API virtual bool ReadNext();
-    FDO_API virtual FdoXmlSaxHandler* XmlStartDocument(FdoXmlSaxContext*);
+    FDO_API virtual FdoXmlSaxHandler* XmlStartDocument(FdoXmlSaxContext* saxContext);
     /// The following callbacks catch the start element and end element
     /// SAX events.
     FDO_API virtual FdoXmlSaxHandler* XmlStartElement(
         FdoString* uri,
         FdoString* name,
         FdoString* qname,
@@ -184,7 +181,7 @@
     FDO_API virtual FdoBoolean XmlEndElement(
         FdoString* uri,
         FdoString* name,
         FdoString* qname
@@ -219,6 +216,7 @@
     FdoXmlSCReadHandler*     mSCHandler;
 /// \brief
 /// FdoXmlSpatialContextReaderP is a FdoPtr on FdoXmlSpatialContextReader, provided for convenience.
 typedef FdoPtr<FdoXmlSpatialContextReader> FdoXmlSpatialContextReaderP;
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextWriter.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextWriter.h	2007-02-15 20:01:49 UTC (rev 2529)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Xml/SpatialContextWriter.h	2007-02-15 20:03:41 UTC (rev 2530)
@@ -262,6 +262,7 @@
 /// \brief
 /// FdoXmlSpatialContextWriterP is a FdoPtr on FdoXmlSpatialContextWriter, provided for convenience.
 typedef FdoPtr<FdoXmlSpatialContextWriter> FdoXmlSpatialContextWriterP;
More information about the fdo-commits mailing list
