[fdo-commits] r2531 - in trunk/Fdo/Managed/Src/OSGeo/Common: . Xml
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Feb 15 15:09:11 EST 2007
Author: gregboone
Date: 2007-02-15 15:09:10 -0500 (Thu, 15 Feb 2007)
New Revision: 2531
   trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgIXmlSaxHandler.h
   trunk/Fdo/Managed/Src/OSGeo/Common/mgGeometryType.h
   trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReader.h
FDO4: API - Update API documentation included in the FDO header files
Modified: trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgIXmlSaxHandler.h
--- trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgIXmlSaxHandler.h	2007-02-15 20:03:41 UTC (rev 2530)
+++ trunk/Fdo/Managed/Src/OSGeo/Common/Xml/mgIXmlSaxHandler.h	2007-02-15 20:09:10 UTC (rev 2531)
@@ -22,6 +22,8 @@
 public __gc class XmlAttributeCollection;
 public __gc class XmlSaxContext;
+/// \ingroup (interfaces)
+/// \interface IXmlSaxHandler
 /// \brief
 /// IXmlSaxHandler defines the SAX Handler callback interface.
 /// It is not an interface in the strict sense, since each function has a
Modified: trunk/Fdo/Managed/Src/OSGeo/Common/mgGeometryType.h
--- trunk/Fdo/Managed/Src/OSGeo/Common/mgGeometryType.h	2007-02-15 20:03:41 UTC (rev 2530)
+++ trunk/Fdo/Managed/Src/OSGeo/Common/mgGeometryType.h	2007-02-15 20:09:10 UTC (rev 2531)
@@ -20,83 +20,67 @@
 BEGIN_NAMESPACE_OSGEO_COMMON
+/// \ingroup (enums)
 /// \brief
-///  GeometryType is an enumeration to denote the type of a Geometry.
+/// GeometryType is an enumeration to denote the type of a Geometry.
 /// \remarks
-///  This enumeration applies to types that derive from IGeometry.
-/// <param name="GeometryType_None">
-/// Indicates no specific type; used for "unknown", "don't care" or an incompletely constructed Geometry object.
-/// </param>
-/// <param name="GeometryType_Point">
-/// Point type
-/// </param>
-/// <param name="GeometryType_LineString">
-/// LineString type
-/// </param>
-/// <param name="GeometryType_Polygon">
-/// Polygon type
-/// </param>
-/// <param name="GeometryType_MultiPoint">
-/// MultiPoint type
-/// </param>
-/// <param name="GeometryType_MultiLineString">
-/// MultiLineString type
-/// </param>
-/// <param name="GeometryType_MultiPolygon">
-/// MultiPolygon type
-/// </param>
-/// <param name="GeometryType_MultiGeometry">
-/// MultiGeometry type
-/// </param>
-/// <param name="GeometryType_CurveString">
-/// CurveString type
-/// </param>
-/// <param name="GeometryType_CurvePolygon">
-/// CurvePolygon type
-/// </param>
-/// <param name="GeometryType_MultiCurveString">
-/// MultiCurveString type
-/// </param>
-/// <param name="GeometryType_MultiCurvePolygon">
-/// MultiCurvePolygon type
-/// </param>
+/// This enumeration applies to types that derive from IGeometry.
 public __value enum GeometryType
+    /// Indicates no specific type; used for "unknown", "don't care" or an incompletely constructed Geometry object.
     GeometryType_None = FdoGeometryType_None,
+    /// Point type
     GeometryType_Point = FdoGeometryType_Point,
+    /// LineString type
     GeometryType_LineString = FdoGeometryType_LineString,
+    /// Polygon type
     GeometryType_Polygon = FdoGeometryType_Polygon,
+    /// MultiPoint type
     GeometryType_MultiPoint = FdoGeometryType_MultiPoint,
+    /// MultiLineString type
     GeometryType_MultiLineString = FdoGeometryType_MultiLineString,
+    /// MultiPolygon type
     GeometryType_MultiPolygon = FdoGeometryType_MultiPolygon,
+    /// MultiGeometry type
     GeometryType_MultiGeometry = FdoGeometryType_MultiGeometry,
+    /// CurveString type
     GeometryType_CurveString = FdoGeometryType_CurveString,
+    /// CurvePolygon type
     GeometryType_CurvePolygon = FdoGeometryType_CurvePolygon,
+    /// MultiCurveString type
     GeometryType_MultiCurveString = FdoGeometryType_MultiCurveString,
+    /// MultiCurvePolygon type
     GeometryType_MultiCurvePolygon = FdoGeometryType_MultiCurvePolygon
 /// \brief
-///  Enumeration for components of Geometry.
+/// Enumeration for components of Geometry.
 /// \remarks
-///  This enumeration applies to certain helper types that are used to compose other types which derive from IGeometry.
-/// <param name="GeometryComponentType_LinearRing">
-/// LinearRing type
-/// </param>
-/// <param name="GeometryComponentType_CircularArcSegment">
-/// CircularArcSegment type
-/// </param>
-/// <param name="GeometryComponentType_LineStringSegment">
-/// LineStringSegment type
-/// </param>
-/// <param name="GeometryComponentType_Ring">
-/// Ring type
-/// </param>
+/// This enumeration applies to certain helper types that are used to compose other types which derive from IGeometry.
 public __value enum GeometryComponentType
+    /// LinearRing type
     GeometryComponentType_LinearRing = FdoGeometryComponentType_LinearRing,
+    /// CircularArcSegment type
     GeometryComponentType_CircularArcSegment = FdoGeometryComponentType_CircularArcSegment,
+    /// LineStringSegment type
     GeometryComponentType_LineStringSegment = FdoGeometryComponentType_LineStringSegment,
+    /// Ring type
     GeometryComponentType_Ring = FdoGeometryComponentType_Ring
Modified: trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReader.h
--- trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReader.h	2007-02-15 20:03:41 UTC (rev 2530)
+++ trunk/Fdo/Managed/Src/OSGeo/Common/mgIStreamReader.h	2007-02-15 20:09:10 UTC (rev 2531)
@@ -22,14 +22,20 @@
 /// \brief
 /// Enumeration for datatypes used by stream readers.
 public __value enum StreamReaderType
+    /// Byte Stream Reader type
 	StreamReaderType_Byte = FdoStreamReaderType_Byte,
+    /// Char Stream Reader type
 	StreamReaderType_Char = FdoStreamReaderType_Char,
+/// \interface IStreamReader
 /// \brief
 /// The IStreamReader class is a top level interface for stream reader classes.
 /// The API it provides allows the user to read large streams of data in blocks of items.
More information about the fdo-commits mailing list
