[fdo-commits] r2538 - in trunk/Providers/GenericRdbms/Docs/doc_src: . group_and_page_definitions/MySQL group_and_page_definitions/ODBC headers_and_footers/MySQL headers_and_footers/ODBC
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Feb 15 15:40:29 EST 2007
Author: gregboone
Date: 2007-02-15 15:40:29 -0500 (Thu, 15 Feb 2007)
New Revision: 2538
Added:
   trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_MySQL_managed
   trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_ODBC_managed
   trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/footer_managed.html
   trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/header_managed.html
   trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/footer_managed.html
   trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/header_managed.html
   trunk/Providers/GenericRdbms/Docs/doc_src/Makefile.am
   trunk/Providers/GenericRdbms/Docs/doc_src/group_and_page_definitions/MySQL/define_pages.h
   trunk/Providers/GenericRdbms/Docs/doc_src/group_and_page_definitions/ODBC/define_pages.h
   trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/Makefile.am
   trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/Makefile.am
FDO4: API - Update API documentation included in the FDO header files
Modified: trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_MySQL
--- trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_MySQL	2007-02-15 20:35:30 UTC (rev 2537)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_MySQL	2007-02-15 20:40:29 UTC (rev 2538)
@@ -63,12 +63,12 @@
 # configuration options related to warning and progress messages
 QUIET                  = NO
-WARNINGS               = NO
-WARN_IF_UNDOCUMENTED   = NO
-WARN_IF_DOC_ERROR      = NO
-WARN_NO_PARAMDOC       = NO
+WARNINGS               = YES
+WARN_IF_UNDOCUMENTED   = YES
+WARN_IF_DOC_ERROR      = YES
+WARN_NO_PARAMDOC       = YES
 WARN_FORMAT            = "$file:$line: $text"
-WARN_LOGFILE           = warning_logfile.txt
+WARN_LOGFILE           = warning_logfile_MySQL.txt
 # configuration options related to the input files
@@ -104,7 +104,7 @@
 ALPHABETICAL_INDEX     = YES
 COLS_IN_ALPHA_INDEX    = 5
-IGNORE_PREFIX          =
+IGNORE_PREFIX          = Fdo
 # configuration options related to the HTML output
Added: trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_MySQL_managed
--- trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_MySQL_managed	                        (rev 0)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_MySQL_managed	2007-02-15 20:40:29 UTC (rev 2538)
@@ -0,0 +1,230 @@
+# Doxyfile 1.5.1-p1
+# Project related configuration options
+PROJECT_NAME           = "FDO Provider for MySQL"
+PROJECT_NUMBER         =
+OUTPUT_DIRECTORY       =
+CREATE_SUBDIRS         = NO
+OUTPUT_LANGUAGE        = English
+USE_WINDOWS_ENCODING   = NO
+BRIEF_MEMBER_DESC      = YES
+REPEAT_BRIEF           = YES
+ABBREVIATE_BRIEF       =
+ALWAYS_DETAILED_SEC    = NO
+INLINE_INHERITED_MEMB  = NO
+FULL_PATH_NAMES        = NO
+STRIP_FROM_PATH        =
+STRIP_FROM_INC_PATH    =
+SHORT_NAMES            = NO
+JAVADOC_AUTOBRIEF      = NO
+MULTILINE_CPP_IS_BRIEF = NO
+DETAILS_AT_TOP         = YES
+INHERIT_DOCS           = YES
+SEPARATE_MEMBER_PAGES  = YES
+TAB_SIZE               = 4
+ALIASES                =
+OPTIMIZE_OUTPUT_FOR_C  = NO
+OPTIMIZE_OUTPUT_JAVA   = NO
+BUILTIN_STL_SUPPORT    = NO
+DISTRIBUTE_GROUP_DOC   = NO
+SUBGROUPING            = YES
+# Build related configuration options
+EXTRACT_ALL            = YES
+EXTRACT_PRIVATE        = NO
+EXTRACT_STATIC         = YES
+EXTRACT_LOCAL_CLASSES  = YES
+EXTRACT_LOCAL_METHODS  = NO
+HIDE_UNDOC_MEMBERS     = NO
+HIDE_UNDOC_CLASSES     = NO
+HIDE_FRIEND_COMPOUNDS  = NO
+HIDE_IN_BODY_DOCS      = NO
+INTERNAL_DOCS          = NO
+CASE_SENSE_NAMES       = NO
+HIDE_SCOPE_NAMES       = NO
+SHOW_INCLUDE_FILES     = YES
+INLINE_INFO            = YES
+SORT_MEMBER_DOCS       = YES
+SORT_BRIEF_DOCS        = YES
+SORT_BY_SCOPE_NAME     = NO
+GENERATE_TODOLIST      = NO
+GENERATE_TESTLIST      = NO
+GENERATE_BUGLIST       = NO
+GENERATE_DEPRECATEDLIST= NO
+ENABLED_SECTIONS       =
+MAX_INITIALIZER_LINES  = 30
+SHOW_USED_FILES        = YES
+SHOW_DIRECTORIES       = NO
+FILE_VERSION_FILTER    =
+# configuration options related to warning and progress messages
+QUIET                  = NO
+WARNINGS               = YES
+WARN_FORMAT            = "$file:$line: $text"
+WARN_LOGFILE           = warning_logfile_MySQL_managed.txt
+# configuration options related to the input files
+INPUT                  = group_and_page_definitions/MySQL \
+                         ../../Managed/Src/OSGeo/FDO/Providers/Rdbms/Override \
+                         ../../Managed/Src/OSGeo/FDO/Providers/Rdbms/Override/MySQL
+FILE_PATTERNS          = *.h
+RECURSIVE              = YES
+EXCLUDE                = ../../Managed/Src/OSGeo/FDO/Providers/Rdbms/Override/ODBC \
+                         ../../Managed/Src/Autodesk/Gis/Fdo/Providers/Rdbms/Override/Oracle \
+                         ../../Managed/Src/Autodesk/Gis/Fdo/Providers/Rdbms/Override/SQLServer
+EXCLUDE_SYMLINKS       = NO
+EXCLUDE_PATTERNS       =
+EXAMPLE_PATH           = headers_and_footers/MySQL
+EXAMPLE_PATTERNS       = *
+EXAMPLE_RECURSIVE      = YES
+IMAGE_PATH             =
+INPUT_FILTER           =
+FILTER_PATTERNS        =
+FILTER_SOURCE_FILES    = NO
+# configuration options related to source browsing
+SOURCE_BROWSER         = YES
+INLINE_SOURCES         = NO
+STRIP_CODE_COMMENTS    = NO
+REFERENCED_BY_RELATION = YES
+REFERENCES_RELATION    = YES
+REFERENCES_LINK_SOURCE = YES
+USE_HTAGS              = NO
+VERBATIM_HEADERS       = YES
+# configuration options related to the alphabetical class index
+ALPHABETICAL_INDEX     = YES
+COLS_IN_ALPHA_INDEX    = 5
+IGNORE_PREFIX          = Fdo \
+                         Mg
+# configuration options related to the HTML output
+GENERATE_HTML          = YES
+HTML_OUTPUT            = ../HTML/MySQL_managed
+HTML_FILE_EXTENSION    = .html
+HTML_HEADER            = headers_and_footers/MySQL/header_managed.html
+HTML_FOOTER            = headers_and_footers/MySQL/footer_managed.html
+HTML_STYLESHEET        = headers_and_footers/MySQL/custom.css
+HTML_ALIGN_MEMBERS     = YES
+GENERATE_HTMLHELP      = YES
+CHM_FILE               = ../../MySQL_Provider_API_managed.chm
+HHC_LOCATION           = "C:/Program Files/HTML Help Workshop/hhc.exe"
+GENERATE_CHI           = NO
+BINARY_TOC             = YES
+TOC_EXPAND             = YES
+DISABLE_INDEX          = NO
+ENUM_VALUES_PER_LINE   = 4
+GENERATE_TREEVIEW      = YES
+TREEVIEW_WIDTH         = 250
+# configuration options related to the LaTeX output
+GENERATE_LATEX         = NO
+LATEX_OUTPUT           = latex
+LATEX_CMD_NAME         = latex
+MAKEINDEX_CMD_NAME     = makeindex
+COMPACT_LATEX          = NO
+PAPER_TYPE             = a4wide
+EXTRA_PACKAGES         =
+LATEX_HEADER           =
+PDF_HYPERLINKS         = NO
+USE_PDFLATEX           = NO
+LATEX_BATCHMODE        = NO
+LATEX_HIDE_INDICES     = NO
+# configuration options related to the RTF output
+GENERATE_RTF           = NO
+RTF_OUTPUT             = rtf
+COMPACT_RTF            = NO
+RTF_HYPERLINKS         = NO
+RTF_STYLESHEET_FILE    =
+RTF_EXTENSIONS_FILE    =
+# configuration options related to the man page output
+GENERATE_MAN           = NO
+MAN_OUTPUT             = man
+MAN_EXTENSION          = .3
+MAN_LINKS              = NO
+# configuration options related to the XML output
+GENERATE_XML           = NO
+XML_OUTPUT             = xml
+XML_SCHEMA             =
+XML_DTD                =
+XML_PROGRAMLISTING     = YES
+# configuration options for the AutoGen Definitions output
+GENERATE_AUTOGEN_DEF   = NO
+# configuration options related to the Perl module output
+GENERATE_PERLMOD       = NO
+PERLMOD_LATEX          = NO
+PERLMOD_PRETTY         = YES
+PERLMOD_MAKEVAR_PREFIX =
+# Configuration options related to the preprocessor
+ENABLE_PREPROCESSING   = YES
+MACRO_EXPANSION        = YES
+EXPAND_ONLY_PREDEF     = NO
+SEARCH_INCLUDES        = YES
+INCLUDE_PATH           =
+INCLUDE_FILE_PATTERNS  =
+PREDEFINED             =
+EXPAND_AS_DEFINED      =
+SKIP_FUNCTION_MACROS   = YES
+# Configuration::additions related to external references
+TAGFILES               =
+GENERATE_TAGFILE       =
+ALLEXTERNALS           = NO
+EXTERNAL_GROUPS        = YES
+PERL_PATH              = /usr/bin/perl
+# Configuration options related to the dot tool
+CLASS_DIAGRAMS         = NO
+HIDE_UNDOC_RELATIONS   = YES
+HAVE_DOT               = YES
+CLASS_GRAPH            = YES
+COLLABORATION_GRAPH    = NO
+GROUP_GRAPHS           = NO
+UML_LOOK               = YES
+TEMPLATE_RELATIONS     = NO
+INCLUDE_GRAPH          = YES
+INCLUDED_BY_GRAPH      = YES
+CALL_GRAPH             = YES
+CALLER_GRAPH           = NO
+GRAPHICAL_HIERARCHY    = YES
+DIRECTORY_GRAPH        = YES
+DOT_IMAGE_FORMAT       = png
+DOT_PATH               =
+DOTFILE_DIRS           =
+MAX_DOT_GRAPH_WIDTH    = 1024
+MAX_DOT_GRAPH_HEIGHT   = 1024
+MAX_DOT_GRAPH_DEPTH    = 1000
+DOT_TRANSPARENT        = NO
+DOT_MULTI_TARGETS      = NO
+GENERATE_LEGEND        = YES
+DOT_CLEANUP            = YES
+# Configuration::additions related to the search engine
+SEARCHENGINE           = NO
Property changes on: trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_MySQL_managed
___________________________________________________________________
   + native
Modified: trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_ODBC
--- trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_ODBC	2007-02-15 20:35:30 UTC (rev 2537)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_ODBC	2007-02-15 20:40:29 UTC (rev 2538)
@@ -63,12 +63,12 @@
 QUIET                  = NO
-WARNINGS               = NO
+WARNINGS               = YES
+WARN_LOGFILE           = warning_logfile_ODBC.txt
@@ -79,7 +79,7 @@
 RECURSIVE              = YES
 EXCLUDE                = ../../Inc/Rdbms/Override/Oracle \
                          ../../Inc/Rdbms/Override/MySQL \
-                         ../../Inc/Rdbms/Override/SQLServer
+                         ../../Inc/Rdbms/Override/SqlServer
 EXCLUDE_PATTERNS       =
 EXAMPLE_PATH           = headers_and_footers/ODBC
@@ -104,7 +104,7 @@
-IGNORE_PREFIX          =
Added: trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_ODBC_managed
--- trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_ODBC_managed	                        (rev 0)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_ODBC_managed	2007-02-15 20:40:29 UTC (rev 2538)
@@ -0,0 +1,230 @@
+PROJECT_NAME           = "FDO Provider for ODBC"
+PROJECT_NUMBER         =
+OUTPUT_DIRECTORY       =
+REPEAT_BRIEF           = YES
+ABBREVIATE_BRIEF       =
+STRIP_FROM_PATH        =
+SHORT_NAMES            = NO
+INHERIT_DOCS           = YES
+TAB_SIZE               = 4
+ALIASES                =
+SUBGROUPING            = YES
+EXTRACT_ALL            = YES
+INTERNAL_DOCS          = NO
+INLINE_INFO            = YES
+ENABLED_SECTIONS       =
+QUIET                  = NO
+WARNINGS               = Yes
+WARN_IF_UNDOCUMENTED   = Yes
+WARN_IF_DOC_ERROR      = Yes
+WARN_NO_PARAMDOC       = Yes
+WARN_LOGFILE           = warning_logfile_ODBC_managed.txt
+INPUT                  = group_and_page_definitions/ODBC \
+                         ../../Managed/Src/OSGeo/FDO/Providers/Rdbms/Override/ODBC
+RECURSIVE              = YES
+EXCLUDE                = ../../Managed/Src/OSGeo/FDO/Providers/Rdbms/Override/MySQL \
+EXCLUDE_PATTERNS       =
+EXAMPLE_PATH           = headers_and_footers/ODBC
+IMAGE_PATH             =
+INPUT_FILTER           =
+FILTER_PATTERNS        =
+USE_HTAGS              = NO
+                         Mg
+HTML_OUTPUT            = ../HTML/ODBC_managed
+HTML_HEADER            = headers_and_footers/ODBC/header_managed.html
+HTML_FOOTER            = headers_and_footers/ODBC/footer_managed.html
+HTML_STYLESHEET        = headers_and_footers/ODBC/custom.css
+CHM_FILE               = ../../ODBC_Provider_API_managed.chm
+GENERATE_CHI           = NO
+BINARY_TOC             = YES
+TOC_EXPAND             = YES
+DISABLE_INDEX          = NO
+COMPACT_LATEX          = NO
+EXTRA_PACKAGES         =
+LATEX_HEADER           =
+USE_PDFLATEX           = NO
+GENERATE_RTF           = NO
+RTF_OUTPUT             = rtf
+COMPACT_RTF            = NO
+GENERATE_MAN           = NO
+MAN_OUTPUT             = man
+MAN_EXTENSION          = .3
+MAN_LINKS              = NO
+GENERATE_XML           = NO
+XML_OUTPUT             = xml
+XML_SCHEMA             =
+XML_DTD                =
+PERLMOD_LATEX          = NO
+INCLUDE_PATH           =
+PREDEFINED             =
+TAGFILES               =
+GENERATE_TAGFILE       =
+ALLEXTERNALS           = NO
+HAVE_DOT               = YES
+CLASS_GRAPH            = YES
+GROUP_GRAPHS           = NO
+UML_LOOK               = YES
+CALL_GRAPH             = YES
+CALLER_GRAPH           = NO
+DOT_PATH               =
+DOTFILE_DIRS           =
+DOT_CLEANUP            = YES
+SEARCHENGINE           = NO
Property changes on: trunk/Providers/GenericRdbms/Docs/doc_src/Doxyfile_ODBC_managed
   + native
Modified: trunk/Providers/GenericRdbms/Docs/doc_src/Makefile.am
--- trunk/Providers/GenericRdbms/Docs/doc_src/Makefile.am	2007-02-15 20:35:30 UTC (rev 2537)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/Makefile.am	2007-02-15 20:40:29 UTC (rev 2538)
@@ -21,4 +21,4 @@
 DIST_SUBDIRS = group_and_page_definitions headers_and_footers
-EXTRA_DIST = Doxyfile_MySQL Doxyfile_ODBC
+EXTRA_DIST = Doxyfile_MySQL Doxyfile_ODBC Doxyfile_MySQL_managed Doxyfile_ODBC_managed
Modified: trunk/Providers/GenericRdbms/Docs/doc_src/group_and_page_definitions/MySQL/define_pages.h
--- trunk/Providers/GenericRdbms/Docs/doc_src/group_and_page_definitions/MySQL/define_pages.h	2007-02-15 20:35:30 UTC (rev 2537)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/group_and_page_definitions/MySQL/define_pages.h	2007-02-15 20:40:29 UTC (rev 2538)
@@ -7,6 +7,60 @@
 that provides access to data in a particular data store. The FDO
 Provider for MySQL provides FDO with access to a MySQL-based data store.
 </p>
+<p>MySQL 5.0.22 and later is supported. You can create, edit, and delete MySQL
+data stores and schemas, or you can access existing databases in MySQL that
+were created by other applications. The FDO Provider for MySQL supports native
+MySQL geometry, indexing, two-dimensional geometry (compatible with the OGC
+Simple Feature specificaton), and spatial query operations, but not
+transactions. Auto-generated properties are auto-incremented. MySQL uses a
+revision number for optimistic concurrency.
+</p>
+\note
+If you cannot connect to your MySQL data source and you receive the error
+message, "Specified credentials are not valid or the provider is unable to
+establish a connection," copy the libmySQL.dll file into the \FDO\bin folder
+under the Autodesk product install folder to resolve the problem.
+<p>
+A MySQL schema can support the following:
+</p>
+<ul>
+  <li>Inheritance
+  <li>Multiple schemas
+  <li>Object properties
+  <li>Association properties
+  <li>Schema overrrides
+  <li>Auto ID generation
+  <li>Null value constraints
+  <li>Unique value constraints
+  <li>Composite unique value constraints
+  <li>Spatial contexts
+  <li>These geometry types: point, line string, polygon,multi-point, multi-line
+  string, multi-polygon, curve string, curve polygon, multi-curve string,
+  multi-curve polygon, linear ring, line string segment, circular arc segment,
+  and ring.
+</ul>
+<p>When you create a MySQL schema, the following restrictions apply:
+</p>
+<ul>
+  <li>A feature class must define or inherit at least one identity property.
+  <li>You cannot specify default values for data properties.
+  <li>Inclusive value range constraints are not supported.
+  <li>Identity properties cannot be nullable.
+  <li>Read-only identity properties must be autogenerated.
+  <li>A feature class can have multiple geometric properties; main geometry is
+  not mandatory, but this attribute of the feature class indicates which
+  geometry property to use as the default for queries and rendering. HasMeasure
+  and HasElevation are supported.
+  <li>The maximum length of a string is 65,535 bytes.
+  <li>For decimal properties, precision must be between 1 and 65 inclusive and
+  scale must be between 0 and 30 inclusive.
+</ul>
 <p>The FDO Provider for MySQL API provides custom commands that are
 specifically designed to work with the FDO API. For example, using
 these commands, you can do the following:
Modified: trunk/Providers/GenericRdbms/Docs/doc_src/group_and_page_definitions/ODBC/define_pages.h
--- trunk/Providers/GenericRdbms/Docs/doc_src/group_and_page_definitions/ODBC/define_pages.h	2007-02-15 20:35:30 UTC (rev 2537)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/group_and_page_definitions/ODBC/define_pages.h	2007-02-15 20:40:29 UTC (rev 2538)
@@ -11,12 +11,13 @@
 feature objects that can run in a multi-platform
 environment, including Windows, Linux, and UNIX.
 </p>
 <p>The FDO Provider for ODBC has the following characteristics:
 </p>
 <ul>
-  <li> The FDO Provider for ODBC supports the definition of one or more feature classes in terms of
-    any relational database table that contains an X, Y, and
-    optionally, Z columns.</li>
+  <li> The FDO Provider for ODBC supports the definition of one or more
+    feature classes in terms of any relational database table that
+    contains an X, Y, and optionally, Z columns.</li>
   <li> Metadata--that maps the table name, and X, Y, and optionally, Z
     columns to a feature class--is maintained outside the
     database in a configuration file. This information, in
@@ -42,7 +43,39 @@
 Microsoft Excel (must have at least one named range; do not use DATABASE
 or other reserved words as a range name)
+<p>For more information about setting up an ODBC data store in AutoCAD Map 3D
+2008 and configuring Excel for database ranges, see the 'Managing Data' topic
+in the <i>AutoCAD Map 3D User's Guide</i> (acmap.chm).
+</p>
+<p>For ODBC, only a point geometry (X, Y, and optionally, Z columns define a
+point) is supported. The default column names are X, Y, and Z, but when you pick
+the columns to represent these, you override the defaults. In AutoCAD Map 3D
+2008, this information is stored in the map file itself, so if you go through
+the same process in another map, you will need to override the settings again
+in the same way.
+</p>
+<p>There is no spatial indexing. Object locations are stored in separate
+properties in the object definition.
 <p>
+<p>The existing schema is used, and you cannot add, change, or delete it, nor
+can you add FDO metadata to the data store.
+</p>
+<p>When you set up a Data Source Name for your ODBC data store (by adding a DSN
+in Windows), you will need to specify certain configuration options, depending
+on the type of ODBC data store you use. The connection information (Login ID
+and password) you enter here is used only for defining the DSN, and not at
+connection time with the ODBC provider.
+</p>
+\note
+For MySQL, make sure you have installed the MySQL driver from MyODBC 3.51.
+You can find it at http://dev.mysql.com/downloads/connector/odbc/3.51.html.
+<p>
 For more information, see <i>The Essential FDO</i> (FET_TheEssentialFDO.pdf)
 and the <i>FDO Developer's Guide</i> (FDG_FDODevGuide.pdf).
 </p>
Modified: trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/Makefile.am
--- trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/Makefile.am	2007-02-15 20:35:30 UTC (rev 2537)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/Makefile.am	2007-02-15 20:40:29 UTC (rev 2538)
@@ -17,4 +17,4 @@
 AUTOMAKE_OPTIONS = foreign
-EXTRA_DIST = custom.css footer.html header.html
+EXTRA_DIST = custom.css footer.html header.html footer_managed.html header_managed.html
Added: trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/footer_managed.html
--- trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/footer_managed.html	                        (rev 0)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/footer_managed.html	2007-02-15 20:40:29 UTC (rev 2538)
@@ -0,0 +1,10 @@
+<!-- footer.html -->
+		<hr>
+		<table width="100%"  border="0">
+			<tr>
+				<td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20MySQL%20.NET%20API%20documentation">Comments?</a></font></td>
+				<!-- The logo can go in another cell, when we get one -->
+			</tr>
+		</table>
+	</body>
+</html>
\ No newline at end of file
Property changes on: trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/footer_managed.html
   + native
Added: trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/header_managed.html
--- trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/header_managed.html	                        (rev 0)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/header_managed.html	2007-02-15 20:40:29 UTC (rev 2538)
@@ -0,0 +1,17 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"	"http://www.w3.org/TR/html4/loose.dtd">
+<html>
+	<head>
+		<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+		<title>OSGeo FDO Provider for MySQL .NET API Reference</title>
+		<link href="$relpath$custom.css" rel="stylesheet" type="text/css">
+		<link href="$relpath$tabs.css" rel="stylesheet" type="text/css">
+	</head>
+	<body bgcolor="#FFFFFF">
+			<tr>
+				<td><b>.NET API Reference<b></td>
+				<td align="right"><b>OSGeo FDO Provider for MySQL<b></td>
+			</tr>
+		</table>
+<!-- End of: header.html -->
Property changes on: trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/MySQL/header_managed.html
   + native
Modified: trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/Makefile.am
--- trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/Makefile.am	2007-02-15 20:35:30 UTC (rev 2537)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/Makefile.am	2007-02-15 20:40:29 UTC (rev 2538)
@@ -17,4 +17,4 @@
Added: trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/footer_managed.html
--- trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/footer_managed.html	                        (rev 0)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/footer_managed.html	2007-02-15 20:40:29 UTC (rev 2538)
@@ -0,0 +1,10 @@
+		<hr>
+			<tr>
+				<td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20ODBC%20.NET%20API%20documentation">Comments?</a></font></td>
+			</tr>
+		</table>
+	</body>
+</html>
Property changes on: trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/footer_managed.html
   + native
Added: trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/header_managed.html
--- trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/header_managed.html	                        (rev 0)
+++ trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/header_managed.html	2007-02-15 20:40:29 UTC (rev 2538)
@@ -0,0 +1,17 @@
+<html>
+	<head>
+		<title>OSGeo FDO Provider for ODBC .NET API Reference</title>
+	</head>
+			<tr>
+				<td align="right"><b>OSGeo FDO Provider for ODBC<b></td>
+			</tr>
+		</table>
Property changes on: trunk/Providers/GenericRdbms/Docs/doc_src/headers_and_footers/ODBC/header_managed.html
   + native
More information about the fdo-commits mailing list
