[fdo-commits] r2539 -
trunk/Providers/SDF/Docs/doc_src/group_and_page_definitions
svn_fdo at osgeo.org
Thu Feb 15 15:42:50 EST 2007
Author: gregboone
Date: 2007-02-15 15:42:50 -0500 (Thu, 15 Feb 2007)
New Revision: 2539
trunk/Providers/SDF/Docs/doc_src/group_and_page_definitions/define_pages.h
FDO4: API - Update API documentation included in the FDO header files
Modified: trunk/Providers/SDF/Docs/doc_src/group_and_page_definitions/define_pages.h
--- trunk/Providers/SDF/Docs/doc_src/group_and_page_definitions/define_pages.h 2007-02-15 20:40:29 UTC (rev 2538)
+++ trunk/Providers/SDF/Docs/doc_src/group_and_page_definitions/define_pages.h 2007-02-15 20:42:50 UTC (rev 2539)
@@ -7,23 +7,34 @@
that provides access to data in a particular data store. The FDO
Provider for SDF provides FDO with access to an SDF-based data store.
-<p>The FDO Provider for SDF uses Autodesk's spatial database
-format, which is a file-based personal geodatabase that supports
-multiple features/attributes, spatial indexing,
-interoperability, file-locking, and high performance for
+<p>The Autodesk SDF file format is a standalone, file-based spatial database
+format that supports multiple features classes and properties in a single file,
+and provides spatial indexing, interoperability, and high performance for
large data sets.
</p>
<p>The SDF file format has the following characteristics:
</p>
+<ul>
+ <li>SDF files can be read on different platforms.
+ <li>One schema in a single SDF file supports multiple feature classes.
+ <li>The SDF file has its own spatial indexing.
+ <li>SDF files can store geometric and non-geometric data with minimum overhead.
+ <li>The SDF file format supports a single writer at any time, with multiple readers.
+</ul>
+<p>An SDF schema can support the following:
+</p>
<ul>
- <li> SDF files can be read on different platforms.
- <li> The SDF file format has its own spatial indexing.
- <li> SDF files can store geometric and non-geometric data with minimum
-overhead
- <li>Although it does not support concurrency control (locking),
- the SDF file format is a valid alternative to RDBMS.
+ <li>Auto ID generation
+ <li>Exclusive value range constraints
+ <li>Null value constraints
+ <li>Spatial contexts
+ <li>These geometry types: point, line string, polygon, multi-point, multi-line
+ string, multi-polygon, curve string, curve polygon, multi-curve string,
+ multi-curve polygon, linear ring, line string segment, circular arc segment, and ring.
</ul>
<p>
For more information, see <i>The Essential FDO</i> (FET_TheEssentialFDO.pdf)
and the <i>FDO Developer's Guide</i> (FDG_FDODevGuide.pdf).
More information about the fdo-commits
