[fdo-commits] r201 - branches/3.2.1/Providers/SHP/Src/Provider
svn_fdo at osgeo.org
Sun Feb 25 12:27:11 EST 2007
Author: badreddinekaroui
Date: 2007-02-25 12:27:11 -0500 (Sun, 25 Feb 2007)
New Revision: 201
branches/3.2.1/Providers/SHP/Src/Provider/ShpFeatIdQueryEvaluator.cpp
branches/3.2.1/Providers/SHP/Src/Provider/ShpFeatIdQueryEvaluator.h
branches/3.2.1/Providers/SHP/Src/Provider/ShpSelectCommand.cpp
See ticket #21
Modified: branches/3.2.1/Providers/SHP/Src/Provider/ShpFeatIdQueryEvaluator.cpp
--- branches/3.2.1/Providers/SHP/Src/Provider/ShpFeatIdQueryEvaluator.cpp 2007-02-24 12:54:30 UTC (rev 200)
+++ branches/3.2.1/Providers/SHP/Src/Provider/ShpFeatIdQueryEvaluator.cpp 2007-02-25 17:27:11 UTC (rev 201)
@@ -243,6 +243,51 @@
FdoCommonFilterExecutor::ProcessDistanceCondition( filter );
+void ShpFeatIdQueryEvaluator::DoSecondaryFilter(FdoIGeometry *filterGeom, FdoSpatialOperations spatialOp )
+ interval_res* results = new interval_res;
+ results->op = ShpComparisonOperation_In;
+ results->depth = m_level - 1;
+ recno_list* secFilterList = &results->queryResults;
+ FdoPtr<ShpLpClassDefinition> shpLpClassDef = ShpSchemaUtilities::GetLpClassDefinition(m_Connection, m_Class->GetName());
+ ShpFileSet* fileSet = shpLpClassDef->GetPhysicalFileSet();
+ recno_list* featidPrimarySel = &m_FeatidLists.back()->queryResults;
+ FdoPtr<FdoFgfGeometryFactory> gf = FdoFgfGeometryFactory::GetInstance();
+ for ( size_t i = 0; i < featidPrimarySel->size(); i++ )
+ ULONG offset;
+ int length;
+ Shape* shape = NULL;
+ eShapeTypes type;
+ FdoInt32 featNum = featidPrimarySel->at(i);
+ // Get info from the file.
+ fileSet->GetShapeIndexFile()->GetObjectAt( featNum, offset, length);
+ shape = fileSet->GetShapeFile()->GetObjectAt (offset, type);
+ FdoPtr<FdoByteArray> geomLeftFgf = shape->GetGeometry ();
+ FdoPtr<FdoIGeometry> geomLeft = gf->CreateGeometryFromFgf( geomLeftFgf );
+ delete shape;
+ bool ret = FdoSpatialUtility::Evaluate( geomLeft, spatialOp, filterGeom);
+ if ( ret )
+ secFilterList->push_back( featNum );
+ //delete featidPrimarySel;
+ retno_lists::iterator iter_lists = m_FeatidLists.end();
+ --iter_lists;
+ delete *iter_lists; // delete the memory this vector entry points to
+ m_FeatidLists.erase( iter_lists ); // delete this vector entry
+ m_FeatidLists.push_back( results );
void ShpFeatIdQueryEvaluator::ProcessSpatialCondition(FdoSpatialCondition& filter)
FdoPtr<FdoExpression> expr = filter.GetGeometry();
@@ -256,15 +301,31 @@
FdoPtr<FdoByteArray> geomRightFgf = geomRightVal->GetGeometry();
- BoundingBox searchArea;
- FdoSpatialUtility::GetExtents( geomRightFgf, searchArea.xMin, searchArea.yMin, searchArea.xMax, searchArea.yMax);
FdoPtr<FdoGeometricPropertyDefinition> gpd = FindGeomProp(m_Class);
FdoPtr<FdoIdentifier> idname = filter.GetPropertyName();
if (0 != wcscmp (gpd->GetName (), idname->GetName ()))
throw FdoException::Create (FdoException::NLSGetMessage(FDO_NLSID(FDO_104_READER_PROPERTY_NOT_SELECTED), idname->GetName ()));
+ if( m_level == 2 && m_LogicalOpsList.size() != 0 && m_FeatidLists.size() != 0 && m_LogicalOpsList.back() == FdoBinaryLogicalOperations_And && m_LeftRightOpsList.back() == 1 )
+ // skip primary filter and do secondary filtering on the top of the stack of m_FeatidLists
+ m_LogicalOpsList.pop_back();
+ m_LeftRightOpsList.pop_back();
+ // pop the left ops as well
+ m_level-=2;
+ FdoPtr<FdoIGeometry> filterGeom = gf->CreateGeometryFromFgf( geomRightFgf );
+ DoSecondaryFilter( filterGeom, filter.GetOperation() );
+ return;
+ BoundingBox searchArea;
+ FdoSpatialUtility::GetExtents( geomRightFgf, searchArea.xMin, searchArea.yMin, searchArea.xMax, searchArea.yMax);
if (m_RTree)
// For each bounding box build a sorted list of candidates (primary filter) and save it.
Modified: branches/3.2.1/Providers/SHP/Src/Provider/ShpFeatIdQueryEvaluator.h
--- branches/3.2.1/Providers/SHP/Src/Provider/ShpFeatIdQueryEvaluator.h 2007-02-24 12:54:30 UTC (rev 200)
+++ branches/3.2.1/Providers/SHP/Src/Provider/ShpFeatIdQueryEvaluator.h 2007-02-25 17:27:11 UTC (rev 201)
@@ -91,6 +91,7 @@
size_t EvaluateMergedListSize( int maxRecords );
void ProcessLeafExpession( interval_res* curr_filter, int curr_logical_op, int maxRecords );
void PrintFlattenParseTree();
+ void DoSecondaryFilter(FdoIGeometry *filterGeom, FdoSpatialOperations spatialOp );
FdoGeometricPropertyDefinition* FindGeomProp(FdoClassDefinition* classDef);
Modified: branches/3.2.1/Providers/SHP/Src/Provider/ShpSelectCommand.cpp
--- branches/3.2.1/Providers/SHP/Src/Provider/ShpSelectCommand.cpp 2007-02-24 12:54:30 UTC (rev 200)
+++ branches/3.2.1/Providers/SHP/Src/Provider/ShpSelectCommand.cpp 2007-02-25 17:27:11 UTC (rev 201)
@@ -96,11 +96,14 @@
class_name = id->GetText ();
FdoPtr<ShpConnection> shpConn = (ShpConnection*)GetConnection ();
- // Validate the filter. The filter may contain computed expressions involving not selected properties
+ // Validate the filter. The filter may contain computed expressions involving not selected properties.
+ // Also, try to optimize the filter
if( mFilter != NULL )
- FdoPtr<FdoClassDefinition> clas = ShpSchemaUtilities::GetLogicalClassDefinition (shpConn, class_name, NULL);
- FdoCommonFilterExecutor::ValidateFilter( clas, mFilter, mPropertiesToSelect );
+ FdoPtr<FdoClassDefinition> classDef = ShpSchemaUtilities::GetLogicalClassDefinition (shpConn, class_name, NULL);
+ FdoCommonFilterExecutor::ValidateFilter( classDef, mFilter, mPropertiesToSelect );
+ mFilter = FdoCommonFilterExecutor::OptimizeFilter( mFilter );
ret = new ShpFeatureReader (shpConn, class_name, mFilter, mPropertiesToSelect);
More information about the fdo-commits
