[fdo-commits] r814 - in branches/3.2.1/Utilities/Common: Inc Src
svn_fdo at osgeo.org
Sun Feb 25 12:28:23 EST 2007
Author: badreddinekaroui
Date: 2007-02-25 12:28:23 -0500 (Sun, 25 Feb 2007)
New Revision: 814
branches/3.2.1/Utilities/Common/Inc/FdoCommonFilterExecutor.h
branches/3.2.1/Utilities/Common/Src/FdoCommonFilterExecutor.cpp
See ticket #21
Modified: branches/3.2.1/Utilities/Common/Inc/FdoCommonFilterExecutor.h
--- branches/3.2.1/Utilities/Common/Inc/FdoCommonFilterExecutor.h 2007-02-24 12:54:04 UTC (rev 813)
+++ branches/3.2.1/Utilities/Common/Inc/FdoCommonFilterExecutor.h 2007-02-25 17:28:23 UTC (rev 814)
@@ -79,6 +79,14 @@
static void ValidateFilter( FdoClassDefinition *cls, FdoFilter *filter, FdoIdentifierCollection *selIds = NULL );
+ /// \brief
+ /// Attempt to optimize the input filter by producing a new more efficient filter.
+ /// \return
+ /// Return a new refcounted filter that may be the same input filter with an extra addref.
+ static FdoFilter* OptimizeFilter( FdoFilter *filter );
/// \brief
/// Increase the reference count.
Modified: branches/3.2.1/Utilities/Common/Src/FdoCommonFilterExecutor.cpp
--- branches/3.2.1/Utilities/Common/Src/FdoCommonFilterExecutor.cpp 2007-02-24 12:54:04 UTC (rev 813)
+++ branches/3.2.1/Utilities/Common/Src/FdoCommonFilterExecutor.cpp 2007-02-25 17:28:23 UTC (rev 814)
@@ -3954,3 +3954,156 @@
filter->Process( &validator );
+FdoFilter* FdoCommonFilterExecutor::OptimizeFilter( FdoFilter *filter )
+ // This is mostly a place holder for potential filter optimization
+ // For now we just reduce a simple case with potentiel significant performance improvement
+ // This is the case where a filter has 2 and'ed spatial conditions that can be reduced to a
+ // single spatial condition.
+ class FdoCommonFilterOptimizer : public virtual FdoIFilterProcessor
+ private:
+ FdoPtr<FdoFilter> m_newFilter;
+ bool m_isOptimized;
+ FdoPtr<FdoIGeometry> m_geomRight;
+ FdoPtr<FdoIGeometry> m_geomLeft;
+ protected:
+ void HandleFilter( FdoFilter *filter )
+ filter->Process( this );
+ public:
+ FdoCommonFilterOptimizer( ): m_isOptimized(false),m_newFilter(NULL)
+ bool IsOptimized() { return m_isOptimized; }
+ FdoFilter* OptimizedFilter() { return FDO_SAFE_ADDREF(m_newFilter.p); }
+ virtual void Dispose() { delete this; }
+ virtual void ProcessBinaryLogicalOperator(FdoBinaryLogicalOperator& filter)
+ if( filter.GetOperation() != FdoBinaryLogicalOperations_And )
+ m_isOptimized = false;
+ return;
+ HandleFilter( FdoPtr<FdoFilter>(filter.GetLeftOperand()) );
+ HandleFilter( FdoPtr<FdoFilter>(filter.GetRightOperand()) );
+ virtual void ProcessComparisonCondition(FdoComparisonCondition& filter)
+ return;
+ virtual void ProcessDistanceCondition(FdoDistanceCondition& filter)
+ return;
+ virtual void ProcessInCondition(FdoInCondition& filter)
+ return;
+ virtual void ProcessNullCondition(FdoNullCondition& filter)
+ return;
+ virtual void ProcessSpatialCondition(FdoSpatialCondition& filter)
+ bool isleft = ( m_geomLeft == NULL );
+ FdoPtr<FdoExpression> exprRight = filter.GetGeometry ();
+ FdoGeometryValue* gv = dynamic_cast<FdoGeometryValue*>(exprRight.p);
+ if (!gv)
+ return;
+ if( filter.GetOperation() == FdoSpatialOperations_Disjoint )
+ return;
+ FdoPtr<FdoByteArray> ba = gv->GetGeometry ();
+ FdoPtr<FdoFgfGeometryFactory> gf = FdoFgfGeometryFactory::GetInstance ();
+ if( isleft )
+ m_geomLeft = gf->CreateGeometryFromFgf (ba);
+ m_newFilter = FDO_SAFE_ADDREF(&filter);
+ else
+ m_geomRight = gf->CreateGeometryFromFgf (ba);
+ bool ret = FdoSpatialUtility::Evaluate (m_geomLeft, FdoSpatialOperations_Inside, m_geomRight);
+ if( ret )
+ m_isOptimized = true;
+ return;
+ ret = FdoSpatialUtility::Evaluate (m_geomRight, FdoSpatialOperations_Inside, m_geomLeft );
+ if( ret )
+ return;
+ ret = FdoSpatialUtility::Evaluate (m_geomRight, FdoSpatialOperations_Disjoint, m_geomLeft );
+ if( ret )
+ // If the condition do not overlap, then replace it with a filter that returns 0 features.
+ double small_dbl =(double)(-9223372036854775807i64 - 1);
+ FdoPtr<FdoFgfGeometryFactory> gf = FdoFgfGeometryFactory::GetInstance();
+ double coords[] = { small_dbl, small_dbl,
+ small_dbl, small_dbl,
+ small_dbl, small_dbl };
+ FdoPtr<FdoILinearRing> outer = gf->CreateLinearRing(0, 10, coords);
+ FdoPtr<FdoIPolygon> poly = gf->CreatePolygon(outer, NULL);
+ FdoPtr<FdoByteArray> polyfgf = gf->GetFgf(poly);
+ FdoPtr<FdoGeometryValue> gv = FdoGeometryValue::Create(polyfgf);
+ m_newFilter = FdoSpatialCondition::Create(FdoPtr<FdoIdentifier>(filter.GetPropertyName())->GetName(), FdoSpatialOperations_EnvelopeIntersects, gv);
+ return;
+ // Otherwise we make sure that the condition with the FdoSpatialOperations_EnvelopeIntersects is the left condition
+ if( filter.GetOperation() == FdoSpatialOperations_EnvelopeIntersects )
+ // Let's re-arrage the filter to favor evaluating the envelope intersect first.
+ m_newFilter = FdoFilter::Combine( &filter , FdoBinaryLogicalOperations_And, m_newFilter );
+ return;
+ virtual void ProcessUnaryLogicalOperator(FdoUnaryLogicalOperator& filter)
+ return;
+ FdoCommonFilterOptimizer optimizer;
+ filter->Process( &optimizer );
+ return optimizer.IsOptimized()?optimizer.OptimizedFilter():FDO_SAFE_ADDREF(filter);
\ No newline at end of file
More information about the fdo-commits
