[fdo-commits] r639 - branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph
svn_fdo at osgeo.org svn_fdo at osgeo.org
Fri Jan 19 13:55:21 EST 2007
Author: brentrobinson
Date: 2007-01-19 13:55:21 -0500 (Fri, 19 Jan 2007)
New Revision: 639
   branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp
Filter out check constraints on multiple columns (not supported by FDO)
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp	2007-01-19 18:51:20 UTC (rev 638)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp	2007-01-19 18:55:21 UTC (rev 639)
@@ -1029,6 +1029,9 @@
 void FdoSmPhTable::LoadCkeys( FdoSmPhReaderP ckeyRdr, bool isSkipAdd )
+    FdoStringP		         ckeyNameCurr;
+    FdoSmPhCheckConstraintP  ckeyCurr;
     // read each check constraint column.
     while (ckeyRdr && ckeyRdr->ReadNext() ) {
@@ -1047,11 +1050,27 @@
 		    if ( GetElementState() != FdoSchemaElementState_Deleted )
 		        AddCkeyColumnError( columnName );
-        if( ! isSkipAdd ) {
-		    FdoSmPhCheckConstraintP  pConstr = new FdoSmPhCheckConstraint( ckeyName, columnName, clause );
-		    mCkeysCollection->Add( pConstr );
+        if( ! isSkipAdd  ) {
+            if ( ckeyName != ckeyNameCurr ) {
+                if ( ckeyCurr )
+        		    mCkeysCollection->Add( ckeyCurr );
+                ckeyCurr = new FdoSmPhCheckConstraint( ckeyName, columnName, clause );
+            else {
+                // FDO does not support multi-column value constraints.
+                // Also, Schema Manager is not yet set up to handle them so skip them.
+                ckeyCurr = NULL;
+        ckeyNameCurr = ckeyName;
+    // Add the last constraint
+	if ( ckeyCurr && ! isSkipAdd )
More information about the fdo-commits mailing list
